After installing Manjaro on my laptop, I have been unable to access the Internet through either wired ethernet cable or through a wifi connection. Below is my system info; the formatting is bad because I am typing this on a phone. I hope it will be of relevance to the issue.
Kernal: 5.9.11-3-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
root=UUID=6ac59f7e-71fa-4695-b9a5-1c4e81272d2b rw quiet apparmor=1
Desktop: Xfce 4.14.3 tk: Gtk 3.24.23 info: xfce4-panel wm: xfwm4
dm: LightDM 1.30.0 Distro: Manjaro Linux
Type: Laptop System: HP product: HP Laptop 15-da0xxx v: Type1ProductConfigId
serial: <filter> Chassis: type: 10 serial <filter>
Mobo: HP model: 84A6 v: 80.31 serial <filter> UEFI: Insyde v: F.07
date: 11/21/2018
ID-1: BAT1 charge: 34.4 Wh condition: 34.4/41.0 Wh (84%) volts: 12.9/11.4
model: Hewlett-Packard PABAS0241231 type: Li-ion serial <filter>
status: Full
RAM: total: 11.62 GiB used: 525.9 MiB (4.4%)
RAM Report: permissions: Unable to run dmide ode. Root privileges required.
Info: Dual Core model: Intel Core i3-8130U bits: 64 type: MT MCP
arch: Kaby Lake family: 6 model-id: 8E (142) stepping: A (10) microcode: E0
L2 cache: 4096 KiB bogomips: 17605
Speed: 800 MHz min/max: 400/3400 MHz Core speeds (MHz): 1: 800 2: 800 3: 800 4: 801
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb erms est f16c flush_l1d fma fpu fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp red_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tsc tsc_adjust tsc_deadline_timer vme x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Vulnerabilities: Type: itlb_multihit status: KVM: VMX unsupported
mitigation: usercopy/swapgs barriers and __user pointer and sanitization
Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: conditional, RSB filling
Device-1: Intel UHD Graphics 620 vendor: Hewlett-Packard driver: i915 v: kernal bus ID: 00:02.0 chip ID: 8086:5917
Device-2: Lite-On HP TrueVision HD Camera type: USB driver: uvcvideo
bus ID: 1-5:3 chip ID: 04ca:7092
Display: x11 server: X.Org 1.20.10 driver: intel unloaded: modesetting alternate: fbdev,vesa display ID: :0.0 screens: 1
Screen-1: 0 s-res: 1366x768 hz: 60 dpi: 102 size: 340x190mm (13.4x7.5”)
diag: 389mm (15.3”)
OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2) v: 4.6 Mesa 20.2.3
direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernal alternate: snd_soc_skl bus ID: 00:1f.3
chip ID: 8086:9d71
Sound Server: ALSA v: k5.9.11-2-MANJARO
vendor: Hewlett-Packard driver: r8169 v: kernal port: 4000 bus ID: 01:00.0
chip ID: 10ec:8168
Device-2: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
vendor: Hewlett-Packard driver: N/A modules: rtw88_8821ce port: 3000
bus ID: 02:00.0 chip ID: 10ec:c821
WAN IP: No WAN IP found. Connected to web? SSL issues? Try enabling dig
Local Storage: total: 931.51 GiB used: 175.99 GiB (18.9%)
SMART Message: Required tool smartctl not installed. Check —recommends
ID-1: /dev/sda vendor: Toshiba model: MQ04ABF100 size: 931.51 GiB
block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
rotation: 5409 rom serial: <filter> rev: 1C scheme: GBT
Optical-1: /dev/sr0 vendor: hp model: DVDRW GUE1N rev: UE00 dev-links: cdrom
re: cd-r,cd-rw,dvd-r,dvd-ram state: running
Hardware-1: Intel 82801 Mobile SATA Controller [RAID Mode] driver: ahci
v: 3.0 port: 5060 bus ID: 00:17.0 chip ID: 8086.282a rev: 21
ID-1: / raw size: 931.22 GiB size: 915.60 GiB (98.32%)
used: 175.99 GiB (19.2%) fs: ext4 dev: /dev/sda2 label: N/A
uuid: 6ac59f7e-71fa-4695-b9a5-1c4e81272d2b
ID-2: /boot/efi raw size: 300.0 MiB size: 299.4 MiB (99.80%)
used: 312 KiB (0.1%) fs: vfat dev: /dev/sda1 label: N/A uuid: 678D-B734
Hub: 1-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0 speed: 480 Mb/s
chip ID: 1d6b:0002
Device-1: 1-3:2 info: Pixart Imaging Optical Mouse type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s
chip ID: 093a:2510
Device-2: 1-5:3 info: Lite-On HP TrueVision HD Camera type: Video
driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s chip ID: 04ca:7092
Device-3: 1-6:4 info: Realtek Realtek Bluetooth 4.2 Adapter type: Bluetooth
driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s chip ID: 0bda:b00a
serial: <filter>
Device-4: 1-7.5 info: Elan Micro Touchscreen type: HID
driver: hid-multitouch,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s
chip ID: 04f3:22c3
Hub:2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.0 speed: 5 Gb/s
chip ID: 1d6b:0003
System Temperatures: cpu: 34.5 C mobo: 29.8 C
Processes: 165 Uptime: 10m Init: systems v: 246 Compilers: gcc: N/A
Packages: pacman: 1111 lib: 349 flatpak: 0 Shell: Bash v: 5.0.18
running in: xfce4-terminal inxi: 3.1.08
