After system locks, or sleeps and when it wakes up, it cannot connect to Ethernet, Wifi or any network.
So I have to reboot the system everytime it is suspended to connect to internet. Please help. Thank You.
Output of inxi --admin --verbosity=7 --filter --width
Kernel: 5.15.60-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.1
root=UUID=e2975f62-eb9e-4f59-b6b3-afb063da810a rw quiet apparmor=1
Desktop: Xfce v: 4.16.0 tk: Gtk v: 3.24.29 info: xfce4-panel wm: xfwm
v: 4.16.1 vt: 7 dm: LightDM v: 1.32.0 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: HP product: HP Laptop 15-da0xxx v: Type1ProductConfigId
Mobo: HP model: 84A7 v: 80.50 serial: <superuser required> UEFI: Insyde
v: F.36 date: 02/03/2021
ID-1: BAT1 charge: 25.7 Wh (100.0%) condition: 25.7/41.0 Wh (62.6%)
volts: 12.9 min: 11.4 model: Hewlett-Packard PABAS0241231 type: Li-ion
serial: <filter> status: full
RAM: total: 7.67 GiB used: 4.74 GiB (61.8%)
RAM Report: permissions: Unable to run dmidecode. Root privileges
required.
Info: model: Intel Core i5-8250U bits: 64 type: MT MCP arch: Coffee Lake
gen: core 8 level: v3 built: 2017 process: Intel 14nm family: 6
model-id: 0x8E (142) stepping: 0xA (10) microcode: 0xF0
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 800 min/max: 400/3400 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
8: 800 bogomips: 28808
intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp
rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
vulnerable
prctl and seccomp
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, RSB filling,
PBRSB-eIBRS: Not affected
Device-1: Intel UHD Graphics 620 vendor: Hewlett-Packard driver: i915
v: kernel arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports:
active: eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:5917
class-ID: 0300
Device-2: NVIDIA GM108M [GeForce MX110] vendor: Hewlett-Packard
driver: nvidia v: 515.65.01 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-08) arch: Maxwell code: GMxxx
process: TSMC 28nm built: 2014-19 pcie: gen: 1 speed: 2.5 GT/s lanes: 4
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:174e
class-ID: 0302
Device-3: IMC Networks HP TrueVision HD Camera type: USB driver: uvcvideo
bus-ID: 1-5:2 chip-ID: 13d3:56c9 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.4 compositor: xfwm v: 4.16.1 driver: X:
loaded: modesetting,nvidia unloaded: nouveau alternate: fbdev,nv,vesa
gpu: i915 display-ID: :0.0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 model: BOE Display 0x0687 built: 2015 res: 1920x1080
hz: 60 dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: 1920x1080
Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: Intel Sunrise Point-LP HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus-ID: 00:1f.3
chip-ID: 8086:9d71 class-ID: 0403
Sound Server-1: ALSA v: k5.15.60-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.56 running: yes
vendor: Hewlett-Packard driver: r8168 v: 8.050.03-NAPI modules: r8169 pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 port: 4000 bus-ID: 02:00.0
IP v4: <filter> type: secondary dynamic noprefixroute scope: global
IP v6: <filter> scope: link
Device-2: Realtek RTL8723DE 802.11b/g/n PCIe Adapter
vendor: Hewlett-Packard driver: rtw_8723de v: N/A modules: rtw88_8723de,wl
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 03:00.0
chip-ID: 10ec:d723 class-ID: 0280
Message: Output throttled. IPs: 3; Limit: 10; Override: --limit [1-x;-1
all]
Device-1: Realtek Bluetooth 4.2 Adapter type: USB driver: btusb v: 0.8
bus-ID: 1-6:3 chip-ID: 0bda:b009 class-ID: e001 serial: <filter>
Report: rfkill ID: hci0 rfk-id: 2 state: down bt-service: enabled,running
Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
v: 3.0 port: 6060 bus-ID: 00:17.0 chip-ID: 8086:282a rev: N/A class-ID: 0104
Local Storage: total: 1.36 TiB used: 781.27 GiB (55.9%)
model: WDS500G2B0C-00PXH0 size: 465.76 GiB block-size: physical: 512 B
rev: 211210WD temp: 35.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM035-1RK172
type: HDD rpm: 5400 serial: <filter> rev: RSM7 scheme: MBR
Optical-1: /dev/sr0 vendor: hp model: DVDRW DA8AESH rev: XH6M
dev-links: cdrom
rw: cd-r,cd-rw,dvd-r state: running
ID-1: / raw-size: 80.39 GiB size: 78.57 GiB (97.74%) used: 48.8 GiB (62.1%)
fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:4 label: N/A
uuid: e2975f62-eb9e-4f59-b6b3-afb063da810a
ID-2: /boot/efi raw-size: 100 MiB size: 96 MiB (96.00%) used: 38.1 MiB
(39.6%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 62E4-B991
ID-3: /mnt/BasicDataPartition raw-size: 309.76 GiB size: 309.76 GiB
(100.00%) used: 149.1 GiB (48.1%) fs: ntfs dev: /dev/nvme0n1p3
maj-min: 259:3 label: N/A uuid: A8A8E764A8E7300C
ID-4: /mnt/DriveD raw-size: 488.28 GiB size: 488.28 GiB (100.00%)
used: 377.45 GiB (77.3%) fs: ntfs dev: /dev/sda1 maj-min: 8:1 label: DriveD
uuid: BE1A67121A66C6CD
ID-5: /mnt/DriveF raw-size: 443.23 GiB size: 443.23 GiB (100.00%)
used: 205.88 GiB (46.4%) fs: ntfs dev: /dev/sda2 maj-min: 8:2 label: DriveF
uuid: 8EBA892DBA89133F
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/nvme0n1p8 maj-min: 259:5 size: 75 GiB fs: ext4 label: N/A
uuid: e6dca9ce-64d2-491d-ac9e-ce47987b1be5
ID-3: /dev/nvme0n1p9 maj-min: 259:6 size: 509 MiB fs: ntfs label: N/A
uuid: 92E4ECC2E4ECAA25
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-5:2 info: IMC Networks HP TrueVision HD Camera type: Video
Device-2: 1-6:3 info: Realtek Bluetooth 4.2 Adapter type: Bluetooth
driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 500mA
Hub-2: 2-0:1 info: Super-speed hub ports: 6 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 52.0 C pch: 48.5 C mobo: N/A
Processes: 301 Uptime: 1h 37m wakeups: 3 Init: systemd v: 251
default: graphical tool: systemctl Compilers: gcc: 12.1.1 clang: 14.0.6
Packages: pm: pacman pkgs: 1339 libs: 368 tools: pamac,yay pm: flatpak
pkgs: 0 Shell: fish v: 3.5.1 running-in: xfce4-terminal inxi: 3.3.21
