In windows you just need to go to graphics settings, locate the game exe, and select high performance. But how do i do that in Linux Manjaro?
Hi @Allistair343,
While I don’t have something like that (I have a desktop with only 1 GPU), I have read about it here.
And at least tell you that it’s not hard,but you need to know whether it’s an AMD or a nvidia GPU. You also need to have the hybrid drivers installed, either the video-hybrid-intel-nvidia-***
or the video-hybrid-intel-amd-***
ones. (Take note: The driver names might be incorredc, seeing as don’t have/use it.)
Then you need to edit the command of the application you’re runing, and tell Manjaro to execute the command with prime-run
for nvidia or an environment variable, DRI_PRIME=1
for AMD GPUs.
I doubt it will, but I hope it helps!
