As soon start my virtual OS on virt-machine, with my USB device added, the virtual OS sends an endless rain of errors how it can not find the USB device.
This is supposed to show the login prompt.
The added USB device:
A hack against another issue caused this.
Vagrantfile
config.nfs.verify_installed = false
config.vm.synced_folder '.', '/vagrant', disabled: true
I had to delete this and fix the previous issue through other means.
