I got an Argon One case for my raspberry pi and I was wondering if there is an install script for Arch. I can’t find any results or scripts on google.
They got it going in this thread:
https://archived.forum.manjaro.org/t/how-to-install-argonone/113990
Hi
I have followed the instructions from hectorkvs in his post of 12 April 2020 to the letter as best I can:
git clone (Elrondo46 script from github)
cd argonone
sudo pacman -S base-devel (to install some missing packages)
makepkg -si
yay -S raspberrypi-userland-aarch64-git
sudo systemctl enable argononed.service
sudo rebootMake sure you put :
dtparam=i2c_arm=on
dtparam=i2c-1=on
enable_uart=1
in config.txt before rebooting.also I forgot to mention that the ’ enable_uart=1 ’ in /boot/config.txt in conjunction with having ’ kgdboc=ttyAMA0,115200 ’ mentioned in /boot/cmdline does crash the kernel (kernel panic) so please check for this if you are planning on automatically add the uart-option to /boot/config.txt.
I did fix this by removing ’ kgdboc=ttyAMA0,115200 ’ from my /boot/cmdline.If you have a problem with shuting down when the power isn’t cut as it should (power led still working, after pi shutdown) you need to change in ’ /usr/lib/systemd/system-shutdown/argononed-poweroff.py ’ the following:Line 20
bus.write_byte_data(0x1a,0,0)
to looks like this…hope this help
However, when I try to configure the fan (test by setting to always on) it still doesn’t work.
When I check sudo sytstemctl status argononed.service I get:
argononed.service - Argon One Fan and Button Service
Loaded: loaded (/usr/lib/systemd/system/argononed.service; enabled; vendor preset: disabled)
Active: failed (Result: exit-code) since Fri 2021-01-15 19:53:52 AEST; 1min 14s ago
Process: 1881 ExecStart=/opt/argonone/bin/python3 /opt/argonone/bin/argononed.py (code=exited, status=1/FAILURE)
Main PID: 1881 (code=exited, status=1/FAILURE)Jan 15 19:53:52 ARMManjaroKDE systemd[1]: argononed.service: Main process exited, code=exited, status=1/FAILURE
Jan 15 19:53:52 ARMManjaroKDE systemd[1]: argononed.service: Failed with result ‘exit-code’.
Jan 15 19:53:52 ARMManjaroKDE systemd[1]: argononed.service: Scheduled restart job, restart counter is at 5.
Jan 15 19:53:52 ARMManjaroKDE systemd[1]: Stopped Argon One Fan and Button Service.
Jan 15 19:53:52 ARMManjaroKDE systemd[1]: argononed.service: Start request repeated too quickly.
Jan 15 19:53:52 ARMManjaroKDE systemd[1]: Failed to start Argon One Fan and Button Service.
Here’s the output of Neofetch for my system:
[stevemanjkde@ARMManjaroKDE /]$ neofetch
OS: Manjaro ARM Linux aarch64
Host: Raspberry Pi 4 Model B Rev 1.4
Kernel: 5.4.83-1-MANJARO-ARM
Uptime: 1 hour, 37 mins
Packages: 1005 (pacman)
Shell: bash 5.1.0
Resolution: 1920x1080
DE: Plasma 5.20.4
WM: KWin
Theme: Breath2Dark [Plasma], Breeze [GTK2], Breath-Dark [GTK3]
Icons: breath2-dark [Plasma], breath2-dark [GTK2/3]
Terminal: konsole
CPU: BCM2835 (4) @ 1.500GHz
Memory: 2122MiB / 7379MiB
Going crazy. Please help.
Steve
Not a coder, just a user with a few years experience.
What happens if you just execute:
Any errors in the output?
I may be thinking about something else but was installing RPi.GPIO mentioned in the guide.
Also I would git rid of raspberrypi-userland-aarch64-git and use raspberrypi-userland-aarch64 in the repo. The AUR package has not been updtaed in almost a year.
Thanks for your reply.
This is the output of running the commands you suggested.
File “/opt/argonone/bin/argononed.py”, line 9, in
import smbus
ModuleNotFoundError: No module named ‘smbus’
Does this suggest a hardware error? The original argonone script works fine on a Ubuntu Mate for ARM that I have installed on a separate SSD.
Steve
Sounds like a missing dependency.
Try installing smbus2 with:
sudo pip install smbus2
I decided to give this a try and the fan speed setting does work. It seems to check the cpu temp at some interval, as the fan does not (de)activate immediately upon hitting the configured temperature, not according to my conky script anyway.
Edit: After running this a couple of days with the fan set to run at 40° C, it does make a definite difference. Especially noticeable by the temperature of the case. I had my doubts as to how much of a difference the fan would make.
So this evening I become aware that the fan is not spinning up. I check the status of the service and it is failed. I run the python app from the command line and see the error, file not found for /dev/i2c-1
I check and sure enough, not there. Why? dunno. Why did it exist previously? dunno.
How did I fix it? By adding the following to config.txt
dtparam=i2c1=on
I believe there is more than one way to activate this device, so no doubt my messing around with settings caused its (dis)appeance.
