Can’t move or delete elements on panel
When I’m in edit mode on the panel, if I hover the mouse over an item I want to delete or move and click the right mouse button, the edit menu flashes up for a split second and disappears straight away, but of course I don’t have time to select anything. After that, the panel exits edit mode. Restarting doesn’t help.
KDE Plasma Version: 6.5.6
KDE Frameworks Version: 6.24.0
Qt Version: 6.10.2
Kernel Version: 6.18.18-1-MANJARO (64-bit)
Graphics Platform: Wayland
Processors: 12 × AMD Ryzen 5 5600H with Radeon Graphics
Memory: 16 GiB of RAM (15.0 GiB usable)
Graphics Processor: AMD Radeon Graphics
Manufacturer: ASUSTeK COMPUTER INC.
Product Name: VivoBook_ASUSLaptop M1603QA_M1603QA
System Version: 1.0
It wouldn’t have been a problem for me at all, as I’d already got everything set up, but today I saw on Reddit how to make the clock bigger and I tried it… I added a spacer and it took up half the panel… Of course, I could stick with the standard one for a few days, but it just doesn’t feel right)
Did you try editing the config file?
No, I prefer GUI, so I`ll wait, but thanks for the hint!
If you’re on current stable version, The move is not available, That’ll return with future update…
Although the remove applet option is moved from hovering over applet icon (In edit mode) to right click on applet icon (while in edit mode)
If you’re only right clicking on icon while on desktop - It’ll only give you configuration options and such depending on what applet you’re interacting with.
I see this a better change as hovering made the remove option go nuts for multi-panel setup…
But yea the change should’ve been more obvious that the remove option is in secondary right click menu inside of edit mode.
If the right-click menu worked, I wouldn’t be writing this…
…click the right mouse button, the edit menu flashes up for a split second and disappears straight away, but of course I don’t have time to select anything.
In any case, I’ve already removed my panel and replaced it with the standard one. I’ll be waiting for an update…
No, nothing actually worked except editing the text file - but now Testing updated, so I’m out of the loop with regard Phil’s latest pushes.
The menu would barely flicker on, and I spent a good ten minutes trying to play whack-a-mole before deciding it was pretty much a waste of time anyway - editing that file just worked.
Yes, This rearrangement issue I experienced on Stable until March 31, The hover menu was not present.
But as I said earlier - there was an option for me to remove the applet by right click on panel > configure panel > right click on desired applet (while in configuration/edit mode) > Remove ‘applet name’ option is last in the list.
As of now, I’ve switched to unstable since April 1, and the rearrange option - the move cursor on hover is back in 6.6.3 This Issue wasn’t the reason of switching to unstable nor do I recommend doing that for this.
