Can someone help with these errors gdm GJS. how to fix?
systemctl status gdm
● gdm.service - GNOME Display Manager
     Loaded: loaded (/usr/lib/systemd/system/gdm.service; enabled; vendor prese>
     Active: active (running) since Thu 2021-05-27 20:02:39 EEST; 4 days ago
    Process: 597 ExecStartPre=/usr/lib/gdm-wait-for-drm (code=exited, status=0/>
   Main PID: 599 (gdm)
      Tasks: 3 (limit: 19050)
     Memory: 4.3M
     CGroup: /system.slice/gdm.service
             └─599 /usr/bin/gdm
gdm-password][73759]: pam_systemd_home(gdm-password:account>
gdm-password][77613]: gkr-pam: unable to locate daemon cont>
gdm-password][77613]: gkr-pam: stashed password to try late>
gdm-password][77613]: pam_systemd_home(gdm-password:account>
gdm-password][82366]: gkr-pam: unable to locate daemon cont>
gdm-password][82366]: gkr-pam: stashed password to try late>
gdm-password][82366]: pam_systemd_home(gdm-password:account>
gdm-password][132602]: gkr-pam: unable to locate daemon con>
gdm-password][132602]: gkr-pam: stashed password to try lat>
gdm-password][132602]: pam_systemd_home(gdm-password:accoun>
journalctl --boot --priority=err
-- Journal begins at Sun 2020-08-23 14:54:34 EEST, ends at Tue 2021-06-01 16:45:35 EEST. --
May 27 20:02:38  kernel:
May 27 21:54:51  resolve[18726]: dynamic_cast error 1: Both of the following type_info's should have public visibility.  At least one of them is hidden. NSt6lo>
May 27 21:54:51 eli resolve[18726]: dynamic_cast error 1: Both of the following type_info's should have public visibility.  At least one of them is hidden. NSt6lo>
lines 1-23...skipping...
May 27 20:02:38 eli kernel:
May 27 21:54:51 eli resolve[18726]: dynamic_cast error 1: Both of the following type_info's should have public visibility.  At least one of them is hidden. NSt6locale5facetE, St5ctypeIcE.
May 27 21:54:51 eli resolve[18726]: dynamic_cast error 1: Both of the following type_info's should have public visibility.  At least one of them is hidden. NSt6locale5facetE, St7num_putIcSt19ostreambuf_iteratorIcSt11>
May 27 21:54:51 eli resolve[18726]: dynamic_cast error 1: Both of the following type_info's should have public visibility.  At least one of them is hidden. NSt6locale5facetE, St7num_getIcSt19istreambuf_iteratorIcSt11>
May 27 21:54:51 *** resolve[18726]: dynamic_cast error 1: Both of the following type_info's should have public visibility.  At least one of them is hidden. NSt6locale5facetE, St7num_getIcSt19istreambuf_iteratorIcSt11>
May 27 21:54:51 *** resolve[18726]: dynamic_cast error 1: Both of the following type_info's should have public visibility.  At least one of them is hidden. NSt6locale5facetE, St5ctypeIcE.
May 27 21:54:51 *** resolve[18726]: dynamic_cast error 1: Both of the following type_info's should have public visibility.  At least one of them is hidden. NSt6locale5facetE, St7num_putIcSt19ostreambuf_iteratorIcSt11>
May 27 21:54:51 *** resolve[18726]: dynamic_cast error 1: Both of the following type_info's should have public visibility.  At least one of them is hidden. NSt6locale5facetE, St5ctypeIwE.
May 27 21:54:51 *** resolve[18726]: dynamic_cast error 1: Both of the following type_info's should have public visibility.  At least one of them is hidden. NSt6locale5facetE, St7num_putIwSt19ostreambuf_iteratorIwSt11>
May 27 21:54:51 *** resolve[18726]: dynamic_cast error 1: Both of the following type_info's should have public visibility.  At least one of them is hidden. NSt6locale5facetE, St7num_getIwSt19istreambuf_iteratorIwSt11>
May 28 05:05:17 *** systemd-coredump[72918]: Process 1568 (gjs) of user 1000 dumped core.
                                             Stack trace of thread 1568:
                                             #0  0x00007f432a9fcba8 g_log_structured_array (libglib-2.0.so.0 + 0x5aba8)
                                             #1  0x00007f432a9fce76 g_log_default_handler (libglib-2.0.so.0 + 0x5ae76)
                                             #2  0x00007f432a9fe2b9 g_logv (libglib-2.0.so.0 + 0x5c2b9)
                                             #3  0x00007f432a9fe560 g_log (libglib-2.0.so.0 + 0x5c560)
                                             #4  0x00007f432ab2a946 n/a (libgjs.so.0 + 0x53946)
                                             #5  0x00007f4328da8e9b n/a (libmozjs-78.so + 0x737e9b)
                                             #6  0x00007f4328da2356 n/a (libmozjs-78.so + 0x731356)
                                             #7  0x00007f4329222f18 n/a (libmozjs-78.so + 0xbb1f18)
                                             #8  0x00007f43295af0b5 n/a (libmozjs-78.so + 0xf3e0b5)
                                             #9  0x00007f43295af46c n/a (libmozjs-78.so + 0xf3e46c)
                                             #10 0x00007f43295aeeed n/a (libmozjs-78.so + 0xf3deed)
                                             #11 0x00007f43295af46c n/a (libmozjs-78.so + 0xf3e46c)
                                             #12 0x00007f4329227d55 n/a (libmozjs-78.so + 0xbb6d55)
                                             #13 0x00007f4328a7fe51 n/a (libmozjs-78.so + 0x40ee51)
                                             #14 0x00007f4328a7cc06 n/a (libmozjs-78.so + 0x40bc06)
                                             #15 0x00007f4328f58f04 n/a (libmozjs-78.so + 0x8e7f04)
                                             #16 0x00007f432ab3719c n/a (libgjs.so.0 + 0x6019c)
                                             #17 0x00007f432a967785 g_object_unref (libgobject-2.0.so.0 + 0x1f785)
                                             #18 0x000055be8ed08a42 n/a (gjs-console + 0x2a42)
                                             #19 0x00007f432a3ecb25 __libc_start_main (libc.so.6 + 0x27b25)
When pasting terminal output, highlight it and use the Preformatted text </> button.
Alternatively, add three backticks ` above and below the text:
text
I’ve fixed it for you this time. :wink:
Did you just happen to notice the errors, or is there a problem that’s happening as well?
I have the same gdm errors since install. They are nothing to worry about : [SOLVED] Gdm-password error : gkr-pam daemon control file not found / Applications & Desktop Environments / Arch Linux Forums
The errors in the journal do not seem to be a problem to me, have you searched for reasons/solutions?
i was found something but not exatly this problem. i will dig deeper :))
