Can overclock Raspbian Lite but not Manjaro
Since you continue to have issues, I turned gpu overclocking back on to make sure it still works for me. And so far, I have no issues.
Current config.txt:
# See /boot/overlays/README for all available options
# kernel
kernel=kernel8.img
# cpu/gpu
arm_64bit=1
gpu_mem=64
# overclocking
over_voltage=6
arm_freq=2000
gpu_freq=700
#v3d_freq=600
#isp_freq=700
#h264_freq=700
#hdmi_enable_4kp60=1
#core_freq=600
#core_freq_min=600
# sound
dtparam=audio=on
hdmi_drive=2
# display
disable_overscan=1
max_framebuffers=2
#disable_splash=1
# vc4
dtoverlay=vc4-fkms-v3d,cma-384
#dtoverlay=vc4-kms-v3d,cma-384
# 4K@30Hz
#hdmi_group=1
#hdmi_mode=95
# 4K@60Hz
#hdmi_group=1
#hdmi_mode=97
# gpio
#enable_uart=1
#dtparam=i2c_arm=on
#dtparam=i2c1=on
dtoverlay=argonone
dtparam=fantemp0=45
dtparam=fanspeed0=33
dtparam=fantemp1=50
dtparam=fanspeed1=66
dtparam=fantemp2=55
dtparam=fanspeed2=100
dtparam=hysteresis=3
# bluetooth
dtoverlay=disable-bt
# wifi
dtoverlay=disable-wifi
Edit: I initially failed to comment out hdmi_enable_4kp60=1, which sets the gpu_freq to 550. I commented the line and rebooted, now at 700 MHz and working properly.
Edit 2: I increased the cpu _freq=2147 and gpu_freq=750, the maximum supported values, works fine.
Edit 3: Eh, my Rpi4 locks up on youttube at max, but 2000 and 700 works fine.
Is this with or without xf86-video-fbturbo-git installed?
The only change I needed to make was adding cma-384 to the dtoverlay.
Don’t know why it was needed, but it worked.
Thanks to @0n0w1c
The cma value can go as high as 512, if needed. It allocates video memory for the gpu.
Thank you
