Ryzen 5500U Laptop Suspend Goes to Black Screen and Stops
I have a brand new install of Manjaro on a new HP 5z-ef2000 laptop with AMD Ryzen 5 5500U and Radeon Graphics. Suspend (using any method, such as close laptop lid, press power button, and systemctl) results in a completely black screen (appears black and off), but the laptop appears to still be running (e.g., fan stays on). There is no button combination that returns to a viewable screen. And the white light that indicates power remains on (whereas on other laptops I have, this light “bounces” on/off during suspend).
This problem seems to be common with Ryzen components on Linux computers. I have tried to solve it following some prior efforts (though with different distros and CPUs). Here are a few good ones: Arch; Ubuntu; Ubuntu/Arch; and general. I tried all of those on both PopOS (Ubuntu) and Manjaro (again – new computer, so no problem switching) – both run 5.15 kernel, .8 and .7 respectivey.
I also tried the suggestion on the ArchWiki Ryzen page about freezes. Well, just the one with the boot parameter processor.max_cstate=1, as my BIOS did not have an option for “Power Idle Control” or the like.
Lastly, I tried the 5.16 experimental kernel. It does change the behavior somewhat; the screen doesn’t go full dark (“black off”), but instead switches periodically between “black on” and a frozen home screen.
Here are the laptop’s specs from inxi:
  Host: hp-ryzen Kernel: 5.15.7-1-MANJARO x86_64 bits: 64 Desktop: GNOME 41.2
    Distro: Manjaro Linux
  Type: Laptop System: HP product: HP Laptop 15z-ef2xxx v: N/A
    serial: <superuser required>
  Mobo: HP model: 887A v: 59.11 serial: <superuser required> UEFI: AMI
    v: F.17 date: 10/18/2021
  ID-1: BAT0 charge: 38.1 Wh (91.4%) condition: 41.7/41.7 Wh (100.0%)
  Info: 6-core model: AMD Ryzen 5 5500U with Radeon Graphics bits: 64
    type: MT MCP cache: L2: 3 MiB
  Speed (MHz): avg: 1396 min/max: 1400/4056 cores: 1: 1397 2: 1397 3: 1397
    4: 1397 5: 1395 6: 1397 7: 1397 8: 1397 9: 1397 10: 1397 11: 1397 12: 1397
  Device-1: AMD Lucienne driver: amdgpu v: kernel
  Device-2: Quanta HP TrueVision HD Camera type: USB driver: uvcvideo
  Display: x11 server: X.org 1.21.1.2 driver: loaded: amdgpu,ati
    unloaded: modesetting,radeon resolution: <missing: xdpyinfo>
  Device-1: AMD driver: snd_hda_intel
  Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor
    driver: snd_rn_pci_acp3x
  Device-3: AMD Family 17h HD Audio driver: snd_hda_intel
  Sound Server-1: ALSA v: k5.15.7-1-MANJARO running: yes
  Sound Server-2: PulseAudio v: 15.0 running: yes
  Device-1: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
    driver: rtw_8821ce
  IF: wlo1 state: up mac: 14:13:33:7e:09:53
  Device-1: Realtek Bluetooth Radio type: USB driver: btusb
  Local Storage: total: 121.13 GiB used: 8.97 GiB (7.4%)
  ID-1: /dev/nvme0n1 vendor: SSSTC model: CL1-8D128-HP size: 119.24 GiB
  ID-2: /dev/sda type: USB vendor: Generic model: USB SD Reader
  ID-1: / size: 41.53 GiB used: 8.81 GiB (21.2%) fs: ext4 dev: /dev/nvme0n1p6
  ID-2: /boot size: 748.5 MiB used: 68.1 MiB (9.1%) fs: vfat
    dev: /dev/nvme0n1p5
  ID-3: /boot/efi size: 256 MiB used: 66.3 MiB (25.9%) fs: vfat
    dev: /dev/nvme0n1p1
  ID-1: swap-1 type: partition size: 15.37 GiB used: 0 KiB (0.0%)
    dev: /dev/nvme0n1p7
  System Temperatures: cpu: 41.0 C mobo: N/A gpu: amdgpu temp: 40.0 C
  Processes: 334 Uptime: 14h 50m Memory: 15.04 GiB used: 2.62 GiB (17.4%)
  Shell: Zsh inxi: 3.3.11
I am currently switching everything to hibernate instead of suspend, but that only works intermittently for some reason – maybe because I also needed it to lock the screen upon wake.
But it would be awesome if there were an actual solution.
Note: in case anyone wants the workaround for enabling hibernate instead of suspend, here is what I did:
### Enable Hibernate on Power Button and others ###
sudo nano /etc/mkinitcpio.conf
[add 'resume' at second to last word under active HOOKS]
sudo nano /boot/refind*conf
[add 'resume=UUID=<UUID of the swap partition without arrows>' as last entry before quotes]
sudo pacman -S dconf-editor
[open dconf-editor]
/org/gnome/settings-daemon/plugins/power/sleep-inactive-battery-type>hibernate
...sleep-inactive-ac-type>hibernate
...power-button-action>hibernate
### Edit acpi handler.sh  ###
sudo pacman -S acpid pm-utils
sudo nano /etc/acpi/handler.sh
[look for line that starts 'button/lid', and enter on line after 'logger 'LID closed'']
pm-hibernate
sudo systemctl enable acpid
sudo systemctl restart acpid
### Install i3 lock and use it on suspend --> NOTE: Per user ###
pamac install i3lock
sudo nano /etc/systemd/system/i3lock.service
[add]
[Unit]
	Description=Lock screen on sleep
	Before=hibernate.target
	[Service]
	User=<*add your user*>
	Type=forking
	Environment=DISPLAY=:0
	ExecStart=/usr/bin/i3lock -c 002b36 -e
	[Install]
	WantedBy=hibernate.target
sudo systemctl enable i3lock
This issue will be fixed in the 5.15.8 Kernel.
I’ve been running this kernel for several weeks now & I haven’t had a failure yet.
P.S. If you want the kernel now you can get it here. Unzip & install with pacman -U
I tried that kernel (5.15.8) with PopOS, and the issue was present. I will try it with Manjaro.
Are you on the same Ryzen CPU?
I’ve got the 5800U
If I understand correctly, the fix was submitted to Linus’ tree - which menas it should be distro independent. I don’t know that to tell you…
Appreciate it @frost19k. Did you have to make any tweaks after installing 5.15.8 kernel? Or did it just work with the new kernel?
Not after, no. The kernel was enough.
Although I do keep acpi_osi='Windows 2020' acpi_backlight=vendor in my GRUB_CMDLINE_LINUX_DEFAULT.
Appreciate that extra info. Will add those to rEFInd’s boot parameters. I also added amdgpu to the /etc/mkinitcpio.conf settings under Modules. Removing that also - but may just try a completely clean install.
So far, 5.15.8-1 intermittently suspends, but mostly does not work or just reboots (not hibernate – it does not restore to last use). Will report back and close if I can get it working. But the different CPUs may be what is giving us different results.
Sorry to ask for more info again, but once you manually install 5.15.8, is there a way to tell pamac not to try to revert to 5.15.7? Every time I try to install/upgrade/etc, pamac says it is going to downgrade. And pacman complains warning: linux515: local (5.15.8-1) is newer than core (5.15.7-1).
pacman -Syu will not revert. pacman -Syuu will revert. You can ignore the warnings.
Did you revert all the changes you made when enabling hibernate over suspend?
I did a completely fresh install on a new partition and only installed the 5.15.8-1 kernel. Suspend does not work (ugh!!!).
I am adding files from this clean install in case it helps someone down the line.
cat /proc/cmdline
root=UUID=f6d46af1-f1d6-4ecd-b1fd-0a2f7baca1a1 rw quiet splash apparmor=1 security=apparmor udev.log_priority=3 acpi_osi='Windows 2020' acpi_backlight=vendor initrd=\initramfs-5.15-x86_64.img
inxi -f
  Host: ryzen Kernel: 5.15.8-1-MANJARO x86_64 bits: 64 Desktop: GNOME 41.2
  ID-1: BAT0 charge: 28.3 Wh (67.9%) condition: 41.7/41.7 Wh (100.0%)
    volts: 11.7 min: 11.3
  Speed (MHz): avg: 1397 min/max: 1400/4056 cores: 1: 1397 2: 1397 3: 1397
    4: 1397 5: 1397 6: 1396 7: 1398 8: 1397 9: 1397 10: 1397 11: 1397 12: 1397
  Display: wayland server: X.org 1.21.1.2 driver: loaded: amdgpu
    note: n/a (using device driver) - try sudo/root
  Sound Server-1: ALSA v: k5.15.8-1-MANJARO running: yes
    driver: rtw_8821ce
  Local Storage: total: 121.13 GiB used: 8.32 GiB (6.9%)
  ID-1: / size: 27.74 GiB used: 8.16 GiB (29.4%) fs: ext4 dev: /dev/nvme0n1p8
  ID-2: /boot size: 714.6 MiB used: 68 MiB (9.5%) fs: vfat
    dev: /dev/nvme0n1p7
  ID-3: /boot/efi size: 256 MiB used: 67.5 MiB (26.4%) fs: vfat
    dev: /dev/nvme0n1p1
  System Temperatures: cpu: 41.0 C mobo: N/A gpu: amdgpu temp: 38.0 C
  Processes: 303 Uptime: 2m Memory: 15.04 GiB used: 1.23 GiB (8.2%)
journalctl | grep amdgpu
Dec 30 10:08:01 ryzen kernel: [drm] amdgpu kernel modesetting enabled.
Dec 30 10:08:01 ryzen kernel: amdgpu: Virtual CRAT table created for CPU
Dec 30 10:08:01 ryzen kernel: amdgpu: Topology: Add CPU node
Dec 30 10:08:01 ryzen kernel: fb0: switching to amdgpu from EFI VGA
Dec 30 10:08:01 ryzen kernel: amdgpu 0000:03:00.0: vgaarb: deactivate vga console
Dec 30 10:08:01 ryzen kernel: amdgpu 0000:03:00.0: enabling device (0006 -> 0007)
Dec 30 10:08:01 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: Trusted Memory Zone (TMZ) feature enabled
Dec 30 10:08:01 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: Fetched VBIOS from VFCT
Dec 30 10:08:01 ryzen kernel: amdgpu: ATOM BIOS: 113-LUCIENNE-016
Dec 30 10:08:01 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: VRAM: 512M 0x000000F400000000 - 0x000000F41FFFFFFF (512M used)
Dec 30 10:08:01 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: GART: 1024M 0x0000000000000000 - 0x000000003FFFFFFF
Dec 30 10:08:01 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: AGP: 267419648M 0x000000F800000000 - 0x0000FFFFFFFFFFFF
Dec 30 10:08:01 ryzen kernel: [drm] amdgpu: 512M of VRAM memory ready
Dec 30 10:08:01 ryzen kernel: [drm] amdgpu: 3072M of GTT memory ready.
Dec 30 10:08:01 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: PSP runtime database doesn't exist
Dec 30 10:08:01 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: Will use PSP to load VCN firmware
Dec 30 10:08:02 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: RAS: optional ras ta ucode is not available
Dec 30 10:08:02 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: RAP: optional rap ta ucode is not available
Dec 30 10:08:02 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: SECUREDISPLAY: securedisplay ta ucode is not available
Dec 30 10:08:02 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: SMU is initialized successfully!
Dec 30 10:08:02 ryzen kernel: snd_hda_intel 0000:03:00.1: bound 0000:03:00.0 (ops amdgpu_dm_audio_component_bind_ops [amdgpu])
Dec 30 10:08:02 ryzen kernel: kfd kfd: amdgpu: Allocated 3969056 bytes on gart
Dec 30 10:08:02 ryzen kernel: amdgpu: HMM registered 512MB device memory
Dec 30 10:08:02 ryzen kernel: amdgpu: SRAT table not found
Dec 30 10:08:02 ryzen kernel: amdgpu: Virtual CRAT table created for GPU
Dec 30 10:08:02 ryzen kernel: amdgpu: Topology: Add dGPU node [0x164c:0x1002]
Dec 30 10:08:02 ryzen kernel: kfd kfd: amdgpu: added device 1002:164c
Dec 30 10:08:02 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: SE 1, SH per SE 2, CU per SH 18, active_cu_number 27
Dec 30 10:08:02 ryzen kernel: fbcon: amdgpu (fb0) is primary device
Dec 30 10:08:02 ryzen kernel: amdgpu 0000:03:00.0: [drm] fb0: amdgpu frame buffer device
Dec 30 10:08:02 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: ring gfx uses VM inv eng 0 on hub 0
Dec 30 10:08:02 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: ring comp_1.0.0 uses VM inv eng 1 on hub 0
Dec 30 10:08:02 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: ring comp_1.1.0 uses VM inv eng 4 on hub 0
Dec 30 10:08:02 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: ring comp_1.2.0 uses VM inv eng 5 on hub 0
Dec 30 10:08:02 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: ring comp_1.3.0 uses VM inv eng 6 on hub 0
Dec 30 10:08:02 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: ring comp_1.0.1 uses VM inv eng 7 on hub 0
Dec 30 10:08:02 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: ring comp_1.1.1 uses VM inv eng 8 on hub 0
Dec 30 10:08:02 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: ring comp_1.2.1 uses VM inv eng 9 on hub 0
Dec 30 10:08:02 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: ring comp_1.3.1 uses VM inv eng 10 on hub 0
Dec 30 10:08:02 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: ring kiq_2.1.0 uses VM inv eng 11 on hub 0
Dec 30 10:08:02 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: ring sdma0 uses VM inv eng 0 on hub 1
Dec 30 10:08:02 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: ring vcn_dec uses VM inv eng 1 on hub 1
Dec 30 10:08:02 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: ring vcn_enc0 uses VM inv eng 4 on hub 1
Dec 30 10:08:02 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: ring vcn_enc1 uses VM inv eng 5 on hub 1
Dec 30 10:08:02 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: ring jpeg_dec uses VM inv eng 6 on hub 1
Dec 30 10:08:02 ryzen kernel: [drm] Initialized amdgpu 3.42.0 20150101 for 0000:03:00.0 on minor 0
Dec 30 10:08:02 ryzen systemd[1]: Starting Load/Save Screen Backlight Brightness of backlight:amdgpu_bl0...
Dec 30 10:08:02 ryzen systemd[1]: Finished Load/Save Screen Backlight Brightness of backlight:amdgpu_bl0.
Dec 30 10:08:02 ryzen audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-backlight@backlight:amdgpu_bl0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Dec 30 10:08:03 ryzen gnome-shell[808]: Added device '/dev/dri/card0' (amdgpu) using atomic mode setting.
Dec 30 10:08:03 ryzen gnome-shell[808]: Disabling DMA buffer screen sharing for driver 'amdgpu'.
Dec 30 10:08:09 ryzen gnome-shell[1261]: Added device '/dev/dri/card0' (amdgpu) using atomic mode setting.
Dec 30 10:08:09 ryzen gnome-shell[1261]: Disabling DMA buffer screen sharing for driver 'amdgpu'.
Dec 30 10:16:34 ryzen systemd[1]: Stopping Load/Save Screen Backlight Brightness of backlight:amdgpu_bl0...
Dec 30 10:16:34 ryzen systemd[1]: systemd-backlight@backlight:amdgpu_bl0.service: Deactivated successfully.
Dec 30 10:16:34 ryzen systemd[1]: Stopped Load/Save Screen Backlight Brightness of backlight:amdgpu_bl0.
Dec 30 10:16:34 ryzen audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-backlight@backlight:amdgpu_bl0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Dec 30 10:17:19 ryzen kernel: [drm] amdgpu kernel modesetting enabled.
Dec 30 10:17:19 ryzen kernel: amdgpu: Virtual CRAT table created for CPU
Dec 30 10:17:19 ryzen kernel: amdgpu: Topology: Add CPU node
Dec 30 10:17:19 ryzen kernel: fb0: switching to amdgpu from EFI VGA
Dec 30 10:17:19 ryzen kernel: amdgpu 0000:03:00.0: vgaarb: deactivate vga console
Dec 30 10:17:19 ryzen kernel: amdgpu 0000:03:00.0: enabling device (0006 -> 0007)
Dec 30 10:17:19 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: Trusted Memory Zone (TMZ) feature enabled
Dec 30 10:17:20 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: Fetched VBIOS from VFCT
Dec 30 10:17:20 ryzen kernel: amdgpu: ATOM BIOS: 113-LUCIENNE-016
Dec 30 10:17:20 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: VRAM: 512M 0x000000F400000000 - 0x000000F41FFFFFFF (512M used)
Dec 30 10:17:20 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: GART: 1024M 0x0000000000000000 - 0x000000003FFFFFFF
Dec 30 10:17:20 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: AGP: 267419648M 0x000000F800000000 - 0x0000FFFFFFFFFFFF
Dec 30 10:17:20 ryzen kernel: [drm] amdgpu: 512M of VRAM memory ready
Dec 30 10:17:20 ryzen kernel: [drm] amdgpu: 3072M of GTT memory ready.
Dec 30 10:17:20 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: PSP runtime database doesn't exist
Dec 30 10:17:20 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: Will use PSP to load VCN firmware
Dec 30 10:17:20 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: RAS: optional ras ta ucode is not available
Dec 30 10:17:20 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: RAP: optional rap ta ucode is not available
Dec 30 10:17:20 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: SECUREDISPLAY: securedisplay ta ucode is not available
Dec 30 10:17:20 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: SMU is initialized successfully!
Dec 30 10:17:20 ryzen kernel: snd_hda_intel 0000:03:00.1: bound 0000:03:00.0 (ops amdgpu_dm_audio_component_bind_ops [amdgpu])
Dec 30 10:17:21 ryzen kernel: kfd kfd: amdgpu: Allocated 3969056 bytes on gart
Dec 30 10:17:21 ryzen kernel: amdgpu: HMM registered 512MB device memory
Dec 30 10:17:21 ryzen kernel: amdgpu: SRAT table not found
Dec 30 10:17:21 ryzen kernel: amdgpu: Virtual CRAT table created for GPU
Dec 30 10:17:21 ryzen kernel: amdgpu: Topology: Add dGPU node [0x164c:0x1002]
Dec 30 10:17:21 ryzen kernel: kfd kfd: amdgpu: added device 1002:164c
Dec 30 10:17:21 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: SE 1, SH per SE 2, CU per SH 18, active_cu_number 27
Dec 30 10:17:21 ryzen kernel: fbcon: amdgpu (fb0) is primary device
Dec 30 10:17:21 ryzen kernel: amdgpu 0000:03:00.0: [drm] fb0: amdgpu frame buffer device
Dec 30 10:17:21 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: ring gfx uses VM inv eng 0 on hub 0
Dec 30 10:17:21 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: ring comp_1.0.0 uses VM inv eng 1 on hub 0
Dec 30 10:17:21 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: ring comp_1.1.0 uses VM inv eng 4 on hub 0
Dec 30 10:17:21 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: ring comp_1.2.0 uses VM inv eng 5 on hub 0
Dec 30 10:17:21 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: ring comp_1.3.0 uses VM inv eng 6 on hub 0
Dec 30 10:17:21 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: ring comp_1.0.1 uses VM inv eng 7 on hub 0
Dec 30 10:17:21 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: ring comp_1.1.1 uses VM inv eng 8 on hub 0
Dec 30 10:17:21 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: ring comp_1.2.1 uses VM inv eng 9 on hub 0
Dec 30 10:17:21 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: ring comp_1.3.1 uses VM inv eng 10 on hub 0
Dec 30 10:17:21 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: ring kiq_2.1.0 uses VM inv eng 11 on hub 0
Dec 30 10:17:21 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: ring sdma0 uses VM inv eng 0 on hub 1
Dec 30 10:17:21 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: ring vcn_dec uses VM inv eng 1 on hub 1
Dec 30 10:17:21 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: ring vcn_enc0 uses VM inv eng 4 on hub 1
Dec 30 10:17:21 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: ring vcn_enc1 uses VM inv eng 5 on hub 1
Dec 30 10:17:21 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: ring jpeg_dec uses VM inv eng 6 on hub 1
Dec 30 10:17:21 ryzen kernel: [drm] Initialized amdgpu 3.42.0 20150101 for 0000:03:00.0 on minor 0
Dec 30 10:17:21 ryzen systemd[1]: Starting Load/Save Screen Backlight Brightness of backlight:amdgpu_bl0...
Dec 30 10:17:21 ryzen systemd[1]: Finished Load/Save Screen Backlight Brightness of backlight:amdgpu_bl0.
Dec 30 10:17:21 ryzen audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-backlight@backlight:amdgpu_bl0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Dec 30 10:17:21 ryzen gnome-shell[798]: Added device '/dev/dri/card0' (amdgpu) using atomic mode setting.
Dec 30 10:17:22 ryzen gnome-shell[798]: Disabling DMA buffer screen sharing for driver 'amdgpu'.
Dec 30 10:17:26 ryzen gnome-shell[1236]: Added device '/dev/dri/card0' (amdgpu) using atomic mode setting.
Dec 30 10:17:27 ryzen gnome-shell[1236]: Disabling DMA buffer screen sharing for driver 'amdgpu'.
Dec 30 10:21:26 ryzen kernel: [drm] amdgpu kernel modesetting enabled.
Dec 30 10:21:26 ryzen kernel: amdgpu: Virtual CRAT table created for CPU
Dec 30 10:21:26 ryzen kernel: amdgpu: Topology: Add CPU node
Dec 30 10:21:26 ryzen kernel: fb0: switching to amdgpu from EFI VGA
Dec 30 10:21:26 ryzen kernel: amdgpu 0000:03:00.0: vgaarb: deactivate vga console
Dec 30 10:21:26 ryzen kernel: amdgpu 0000:03:00.0: enabling device (0006 -> 0007)
Dec 30 10:21:26 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: Trusted Memory Zone (TMZ) feature enabled
Dec 30 10:21:27 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: Fetched VBIOS from VFCT
Dec 30 10:21:27 ryzen kernel: amdgpu: ATOM BIOS: 113-LUCIENNE-016
Dec 30 10:21:27 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: VRAM: 512M 0x000000F400000000 - 0x000000F41FFFFFFF (512M used)
Dec 30 10:21:27 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: GART: 1024M 0x0000000000000000 - 0x000000003FFFFFFF
Dec 30 10:21:27 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: AGP: 267419648M 0x000000F800000000 - 0x0000FFFFFFFFFFFF
Dec 30 10:21:27 ryzen kernel: [drm] amdgpu: 512M of VRAM memory ready
Dec 30 10:21:27 ryzen kernel: [drm] amdgpu: 3072M of GTT memory ready.
Dec 30 10:21:27 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: PSP runtime database doesn't exist
Dec 30 10:21:27 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: Will use PSP to load VCN firmware
Dec 30 10:21:27 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: RAS: optional ras ta ucode is not available
Dec 30 10:21:27 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: RAP: optional rap ta ucode is not available
Dec 30 10:21:27 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: SECUREDISPLAY: securedisplay ta ucode is not available
Dec 30 10:21:27 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: SMU is initialized successfully!
Dec 30 10:21:27 ryzen kernel: snd_hda_intel 0000:03:00.1: bound 0000:03:00.0 (ops amdgpu_dm_audio_component_bind_ops [amdgpu])
Dec 30 10:21:28 ryzen kernel: kfd kfd: amdgpu: Allocated 3969056 bytes on gart
Dec 30 10:21:28 ryzen kernel: amdgpu: HMM registered 512MB device memory
Dec 30 10:21:28 ryzen kernel: amdgpu: SRAT table not found
Dec 30 10:21:28 ryzen kernel: amdgpu: Virtual CRAT table created for GPU
Dec 30 10:21:28 ryzen kernel: amdgpu: Topology: Add dGPU node [0x164c:0x1002]
Dec 30 10:21:28 ryzen kernel: kfd kfd: amdgpu: added device 1002:164c
Dec 30 10:21:28 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: SE 1, SH per SE 2, CU per SH 18, active_cu_number 27
Dec 30 10:21:28 ryzen kernel: fbcon: amdgpu (fb0) is primary device
Dec 30 10:21:28 ryzen kernel: amdgpu 0000:03:00.0: [drm] fb0: amdgpu frame buffer device
Dec 30 10:21:28 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: ring gfx uses VM inv eng 0 on hub 0
Dec 30 10:21:28 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: ring comp_1.0.0 uses VM inv eng 1 on hub 0
Dec 30 10:21:28 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: ring comp_1.1.0 uses VM inv eng 4 on hub 0
Dec 30 10:21:28 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: ring comp_1.2.0 uses VM inv eng 5 on hub 0
Dec 30 10:21:28 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: ring comp_1.3.0 uses VM inv eng 6 on hub 0
Dec 30 10:21:28 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: ring comp_1.0.1 uses VM inv eng 7 on hub 0
Dec 30 10:21:28 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: ring comp_1.1.1 uses VM inv eng 8 on hub 0
Dec 30 10:21:28 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: ring comp_1.2.1 uses VM inv eng 9 on hub 0
Dec 30 10:21:28 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: ring comp_1.3.1 uses VM inv eng 10 on hub 0
Dec 30 10:21:28 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: ring kiq_2.1.0 uses VM inv eng 11 on hub 0
Dec 30 10:21:28 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: ring sdma0 uses VM inv eng 0 on hub 1
Dec 30 10:21:28 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: ring vcn_dec uses VM inv eng 1 on hub 1
Dec 30 10:21:28 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: ring vcn_enc0 uses VM inv eng 4 on hub 1
Dec 30 10:21:28 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: ring vcn_enc1 uses VM inv eng 5 on hub 1
Dec 30 10:21:28 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: ring jpeg_dec uses VM inv eng 6 on hub 1
Dec 30 10:21:28 ryzen kernel: [drm] Initialized amdgpu 3.42.0 20150101 for 0000:03:00.0 on minor 0
Dec 30 10:21:28 ryzen systemd[1]: Starting Load/Save Screen Backlight Brightness of backlight:amdgpu_bl0...
Dec 30 10:21:28 ryzen systemd[1]: Finished Load/Save Screen Backlight Brightness of backlight:amdgpu_bl0.
Dec 30 10:21:28 ryzen audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-backlight@backlight:amdgpu_bl0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Dec 30 10:21:28 ryzen gnome-shell[833]: Added device '/dev/dri/card0' (amdgpu) using atomic mode setting.
Dec 30 10:21:29 ryzen gnome-shell[833]: Disabling DMA buffer screen sharing for driver 'amdgpu'.
Dec 30 10:21:33 ryzen gnome-shell[1284]: Added device '/dev/dri/card0' (amdgpu) using atomic mode setting.
Dec 30 10:21:33 ryzen gnome-shell[1284]: Disabling DMA buffer screen sharing for driver 'amdgpu'.
Dec 30 10:27:37 ryzen systemd[1]: Stopping Load/Save Screen Backlight Brightness of backlight:amdgpu_bl0...
Dec 30 10:27:37 ryzen systemd[1]: systemd-backlight@backlight:amdgpu_bl0.service: Deactivated successfully.
Dec 30 10:27:37 ryzen systemd[1]: Stopped Load/Save Screen Backlight Brightness of backlight:amdgpu_bl0.
Dec 30 10:27:37 ryzen audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-backlight@backlight:amdgpu_bl0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Dec 30 10:27:51 ryzen kernel: [drm] amdgpu kernel modesetting enabled.
Dec 30 10:27:51 ryzen kernel: amdgpu: Virtual CRAT table created for CPU
Dec 30 10:27:51 ryzen kernel: amdgpu: Topology: Add CPU node
Dec 30 10:27:51 ryzen kernel: fb0: switching to amdgpu from EFI VGA
Dec 30 10:27:51 ryzen kernel: amdgpu 0000:03:00.0: vgaarb: deactivate vga console
Dec 30 10:27:51 ryzen kernel: amdgpu 0000:03:00.0: enabling device (0006 -> 0007)
Dec 30 10:27:51 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: Trusted Memory Zone (TMZ) feature enabled
Dec 30 10:27:52 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: Fetched VBIOS from VFCT
Dec 30 10:27:52 ryzen kernel: amdgpu: ATOM BIOS: 113-LUCIENNE-016
Dec 30 10:27:52 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: VRAM: 512M 0x000000F400000000 - 0x000000F41FFFFFFF (512M used)
Dec 30 10:27:52 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: GART: 1024M 0x0000000000000000 - 0x000000003FFFFFFF
Dec 30 10:27:52 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: AGP: 267419648M 0x000000F800000000 - 0x0000FFFFFFFFFFFF
Dec 30 10:27:52 ryzen kernel: [drm] amdgpu: 512M of VRAM memory ready
Dec 30 10:27:52 ryzen kernel: [drm] amdgpu: 3072M of GTT memory ready.
Dec 30 10:27:52 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: PSP runtime database doesn't exist
Dec 30 10:27:52 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: Will use PSP to load VCN firmware
Dec 30 10:27:52 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: RAS: optional ras ta ucode is not available
Dec 30 10:27:52 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: RAP: optional rap ta ucode is not available
Dec 30 10:27:52 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: SECUREDISPLAY: securedisplay ta ucode is not available
Dec 30 10:27:52 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: SMU is initialized successfully!
Dec 30 10:27:52 ryzen kernel: snd_hda_intel 0000:03:00.1: bound 0000:03:00.0 (ops amdgpu_dm_audio_component_bind_ops [amdgpu])
Dec 30 10:27:53 ryzen kernel: kfd kfd: amdgpu: Allocated 3969056 bytes on gart
Dec 30 10:27:53 ryzen kernel: amdgpu: HMM registered 512MB device memory
Dec 30 10:27:53 ryzen kernel: amdgpu: SRAT table not found
Dec 30 10:27:53 ryzen kernel: amdgpu: Virtual CRAT table created for GPU
Dec 30 10:27:53 ryzen kernel: amdgpu: Topology: Add dGPU node [0x164c:0x1002]
Dec 30 10:27:53 ryzen kernel: kfd kfd: amdgpu: added device 1002:164c
Dec 30 10:27:53 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: SE 1, SH per SE 2, CU per SH 18, active_cu_number 27
Dec 30 10:27:53 ryzen kernel: fbcon: amdgpu (fb0) is primary device
Dec 30 10:27:53 ryzen kernel: amdgpu 0000:03:00.0: [drm] fb0: amdgpu frame buffer device
Dec 30 10:27:53 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: ring gfx uses VM inv eng 0 on hub 0
Dec 30 10:27:53 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: ring comp_1.0.0 uses VM inv eng 1 on hub 0
Dec 30 10:27:53 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: ring comp_1.1.0 uses VM inv eng 4 on hub 0
Dec 30 10:27:53 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: ring comp_1.2.0 uses VM inv eng 5 on hub 0
Dec 30 10:27:53 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: ring comp_1.3.0 uses VM inv eng 6 on hub 0
Dec 30 10:27:53 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: ring comp_1.0.1 uses VM inv eng 7 on hub 0
Dec 30 10:27:53 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: ring comp_1.1.1 uses VM inv eng 8 on hub 0
Dec 30 10:27:53 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: ring comp_1.2.1 uses VM inv eng 9 on hub 0
Dec 30 10:27:53 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: ring comp_1.3.1 uses VM inv eng 10 on hub 0
Dec 30 10:27:53 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: ring kiq_2.1.0 uses VM inv eng 11 on hub 0
Dec 30 10:27:53 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: ring sdma0 uses VM inv eng 0 on hub 1
Dec 30 10:27:53 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: ring vcn_dec uses VM inv eng 1 on hub 1
Dec 30 10:27:53 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: ring vcn_enc0 uses VM inv eng 4 on hub 1
Dec 30 10:27:53 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: ring vcn_enc1 uses VM inv eng 5 on hub 1
Dec 30 10:27:53 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: ring jpeg_dec uses VM inv eng 6 on hub 1
Dec 30 10:27:53 ryzen kernel: [drm] Initialized amdgpu 3.42.0 20150101 for 0000:03:00.0 on minor 0
Dec 30 10:27:53 ryzen systemd[1]: Starting Load/Save Screen Backlight Brightness of backlight:amdgpu_bl0...
Dec 30 10:27:53 ryzen systemd[1]: Finished Load/Save Screen Backlight Brightness of backlight:amdgpu_bl0.
Dec 30 10:27:53 ryzen audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-backlight@backlight:amdgpu_bl0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Dec 30 10:27:53 ryzen gnome-shell[803]: Added device '/dev/dri/card0' (amdgpu) using atomic mode setting.
Dec 30 10:27:54 ryzen gnome-shell[803]: Disabling DMA buffer screen sharing for driver 'amdgpu'.
Dec 30 10:27:59 ryzen gnome-shell[1257]: Added device '/dev/dri/card0' (amdgpu) using atomic mode setting.
Dec 30 10:27:59 ryzen gnome-shell[1257]: Disabling DMA buffer screen sharing for driver 'amdgpu'.
Dec 30 10:30:14 ryzen systemd[1]: Stopping Load/Save Screen Backlight Brightness of backlight:amdgpu_bl0...
Dec 30 10:30:14 ryzen systemd[1]: systemd-backlight@backlight:amdgpu_bl0.service: Deactivated successfully.
Dec 30 10:30:14 ryzen systemd[1]: Stopped Load/Save Screen Backlight Brightness of backlight:amdgpu_bl0.
Dec 30 10:30:14 ryzen audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-backlight@backlight:amdgpu_bl0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Dec 30 10:30:37 ryzen kernel: [drm] amdgpu kernel modesetting enabled.
Dec 30 10:30:37 ryzen kernel: amdgpu: Virtual CRAT table created for CPU
Dec 30 10:30:37 ryzen kernel: amdgpu: Topology: Add CPU node
Dec 30 10:30:37 ryzen kernel: fb0: switching to amdgpu from EFI VGA
Dec 30 10:30:37 ryzen kernel: amdgpu 0000:03:00.0: vgaarb: deactivate vga console
Dec 30 10:30:37 ryzen kernel: amdgpu 0000:03:00.0: enabling device (0006 -> 0007)
Dec 30 10:30:37 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: Trusted Memory Zone (TMZ) feature enabled
Dec 30 10:30:37 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: Fetched VBIOS from VFCT
Dec 30 10:30:37 ryzen kernel: amdgpu: ATOM BIOS: 113-LUCIENNE-016
Dec 30 10:30:37 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: VRAM: 512M 0x000000F400000000 - 0x000000F41FFFFFFF (512M used)
Dec 30 10:30:37 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: GART: 1024M 0x0000000000000000 - 0x000000003FFFFFFF
Dec 30 10:30:37 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: AGP: 267419648M 0x000000F800000000 - 0x0000FFFFFFFFFFFF
Dec 30 10:30:37 ryzen kernel: [drm] amdgpu: 512M of VRAM memory ready
Dec 30 10:30:37 ryzen kernel: [drm] amdgpu: 3072M of GTT memory ready.
Dec 30 10:30:37 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: PSP runtime database doesn't exist
Dec 30 10:30:37 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: Will use PSP to load VCN firmware
Dec 30 10:30:38 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: RAS: optional ras ta ucode is not available
Dec 30 10:30:38 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: RAP: optional rap ta ucode is not available
Dec 30 10:30:38 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: SECUREDISPLAY: securedisplay ta ucode is not available
Dec 30 10:30:38 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: SMU is initialized successfully!
Dec 30 10:30:38 ryzen kernel: snd_hda_intel 0000:03:00.1: bound 0000:03:00.0 (ops amdgpu_dm_audio_component_bind_ops [amdgpu])
Dec 30 10:30:38 ryzen kernel: kfd kfd: amdgpu: Allocated 3969056 bytes on gart
Dec 30 10:30:38 ryzen kernel: amdgpu: HMM registered 512MB device memory
Dec 30 10:30:38 ryzen kernel: amdgpu: SRAT table not found
Dec 30 10:30:38 ryzen kernel: amdgpu: Virtual CRAT table created for GPU
Dec 30 10:30:38 ryzen kernel: amdgpu: Topology: Add dGPU node [0x164c:0x1002]
Dec 30 10:30:38 ryzen kernel: kfd kfd: amdgpu: added device 1002:164c
Dec 30 10:30:38 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: SE 1, SH per SE 2, CU per SH 18, active_cu_number 27
Dec 30 10:30:38 ryzen kernel: fbcon: amdgpu (fb0) is primary device
Dec 30 10:30:38 ryzen kernel: amdgpu 0000:03:00.0: [drm] fb0: amdgpu frame buffer device
Dec 30 10:30:38 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: ring gfx uses VM inv eng 0 on hub 0
Dec 30 10:30:38 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: ring comp_1.0.0 uses VM inv eng 1 on hub 0
Dec 30 10:30:38 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: ring comp_1.1.0 uses VM inv eng 4 on hub 0
Dec 30 10:30:38 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: ring comp_1.2.0 uses VM inv eng 5 on hub 0
Dec 30 10:30:38 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: ring comp_1.3.0 uses VM inv eng 6 on hub 0
Dec 30 10:30:38 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: ring comp_1.0.1 uses VM inv eng 7 on hub 0
Dec 30 10:30:38 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: ring comp_1.1.1 uses VM inv eng 8 on hub 0
Dec 30 10:30:38 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: ring comp_1.2.1 uses VM inv eng 9 on hub 0
Dec 30 10:30:38 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: ring comp_1.3.1 uses VM inv eng 10 on hub 0
Dec 30 10:30:38 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: ring kiq_2.1.0 uses VM inv eng 11 on hub 0
Dec 30 10:30:38 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: ring sdma0 uses VM inv eng 0 on hub 1
Dec 30 10:30:38 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: ring vcn_dec uses VM inv eng 1 on hub 1
Dec 30 10:30:38 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: ring vcn_enc0 uses VM inv eng 4 on hub 1
Dec 30 10:30:38 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: ring vcn_enc1 uses VM inv eng 5 on hub 1
Dec 30 10:30:38 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: ring jpeg_dec uses VM inv eng 6 on hub 1
Dec 30 10:30:38 ryzen kernel: [drm] Initialized amdgpu 3.42.0 20150101 for 0000:03:00.0 on minor 0
Dec 30 10:30:38 ryzen systemd[1]: Starting Load/Save Screen Backlight Brightness of backlight:amdgpu_bl0...
Dec 30 10:30:38 ryzen systemd[1]: Finished Load/Save Screen Backlight Brightness of backlight:amdgpu_bl0.
Dec 30 10:30:38 ryzen audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-backlight@backlight:amdgpu_bl0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Dec 30 10:30:39 ryzen gnome-shell[783]: Added device '/dev/dri/card0' (amdgpu) using atomic mode setting.
Dec 30 10:30:39 ryzen gnome-shell[783]: Disabling DMA buffer screen sharing for driver 'amdgpu'.
Dec 30 10:30:44 ryzen gnome-shell[1223]: Added device '/dev/dri/card0' (amdgpu) using atomic mode setting.
Dec 30 10:30:45 ryzen gnome-shell[1223]: Disabling DMA buffer screen sharing for driver 'amdgpu'.
Dec 30 10:32:11 ryzen kernel: [drm] amdgpu kernel modesetting enabled.
Dec 30 10:32:11 ryzen kernel: amdgpu: Virtual CRAT table created for CPU
Dec 30 10:32:11 ryzen kernel: amdgpu: Topology: Add CPU node
Dec 30 10:32:11 ryzen kernel: fb0: switching to amdgpu from EFI VGA
Dec 30 10:32:11 ryzen kernel: amdgpu 0000:03:00.0: vgaarb: deactivate vga console
Dec 30 10:32:11 ryzen kernel: amdgpu 0000:03:00.0: enabling device (0006 -> 0007)
Dec 30 10:32:11 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: Trusted Memory Zone (TMZ) feature enabled
Dec 30 10:32:11 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: Fetched VBIOS from VFCT
Dec 30 10:32:11 ryzen kernel: amdgpu: ATOM BIOS: 113-LUCIENNE-016
Dec 30 10:32:11 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: VRAM: 512M 0x000000F400000000 - 0x000000F41FFFFFFF (512M used)
Dec 30 10:32:11 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: GART: 1024M 0x0000000000000000 - 0x000000003FFFFFFF
Dec 30 10:32:11 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: AGP: 267419648M 0x000000F800000000 - 0x0000FFFFFFFFFFFF
Dec 30 10:32:11 ryzen kernel: [drm] amdgpu: 512M of VRAM memory ready
Dec 30 10:32:11 ryzen kernel: [drm] amdgpu: 3072M of GTT memory ready.
Dec 30 10:32:11 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: PSP runtime database doesn't exist
Dec 30 10:32:11 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: Will use PSP to load VCN firmware
Dec 30 10:32:12 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: RAS: optional ras ta ucode is not available
Dec 30 10:32:12 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: RAP: optional rap ta ucode is not available
Dec 30 10:32:12 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: SECUREDISPLAY: securedisplay ta ucode is not available
Dec 30 10:32:12 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: SMU is initialized successfully!
Dec 30 10:32:12 ryzen kernel: snd_hda_intel 0000:03:00.1: bound 0000:03:00.0 (ops amdgpu_dm_audio_component_bind_ops [amdgpu])
Dec 30 10:32:12 ryzen kernel: kfd kfd: amdgpu: Allocated 3969056 bytes on gart
Dec 30 10:32:12 ryzen kernel: amdgpu: HMM registered 512MB device memory
Dec 30 10:32:12 ryzen kernel: amdgpu: SRAT table not found
Dec 30 10:32:12 ryzen kernel: amdgpu: Virtual CRAT table created for GPU
Dec 30 10:32:12 ryzen kernel: amdgpu: Topology: Add dGPU node [0x164c:0x1002]
Dec 30 10:32:12 ryzen kernel: kfd kfd: amdgpu: added device 1002:164c
Dec 30 10:32:12 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: SE 1, SH per SE 2, CU per SH 18, active_cu_number 27
Dec 30 10:32:12 ryzen kernel: fbcon: amdgpu (fb0) is primary device
Dec 30 10:32:12 ryzen kernel: amdgpu 0000:03:00.0: [drm] fb0: amdgpu frame buffer device
Dec 30 10:32:12 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: ring gfx uses VM inv eng 0 on hub 0
Dec 30 10:32:12 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: ring comp_1.0.0 uses VM inv eng 1 on hub 0
Dec 30 10:32:12 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: ring comp_1.1.0 uses VM inv eng 4 on hub 0
Dec 30 10:32:12 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: ring comp_1.2.0 uses VM inv eng 5 on hub 0
Dec 30 10:32:12 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: ring comp_1.3.0 uses VM inv eng 6 on hub 0
Dec 30 10:32:12 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: ring comp_1.0.1 uses VM inv eng 7 on hub 0
Dec 30 10:32:12 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: ring comp_1.1.1 uses VM inv eng 8 on hub 0
Dec 30 10:32:12 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: ring comp_1.2.1 uses VM inv eng 9 on hub 0
Dec 30 10:32:12 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: ring comp_1.3.1 uses VM inv eng 10 on hub 0
Dec 30 10:32:12 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: ring kiq_2.1.0 uses VM inv eng 11 on hub 0
Dec 30 10:32:12 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: ring sdma0 uses VM inv eng 0 on hub 1
Dec 30 10:32:12 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: ring vcn_dec uses VM inv eng 1 on hub 1
Dec 30 10:32:12 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: ring vcn_enc0 uses VM inv eng 4 on hub 1
Dec 30 10:32:12 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: ring vcn_enc1 uses VM inv eng 5 on hub 1
Dec 30 10:32:12 ryzen kernel: amdgpu 0000:03:00.0: amdgpu: ring jpeg_dec uses VM inv eng 6 on hub 1
Dec 30 10:32:12 ryzen kernel: [drm] Initialized amdgpu 3.42.0 20150101 for 0000:03:00.0 on minor 0
Dec 30 10:32:12 ryzen systemd[1]: Starting Load/Save Screen Backlight Brightness of backlight:amdgpu_bl0...
Dec 30 10:32:12 ryzen systemd[1]: Finished Load/Save Screen Backlight Brightness of backlight:amdgpu_bl0.
Dec 30 10:32:12 ryzen audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-backlight@backlight:amdgpu_bl0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Dec 30 10:32:13 ryzen gnome-shell[912]: Added device '/dev/dri/card0' (amdgpu) using atomic mode setting.
Dec 30 10:32:13 ryzen gnome-shell[912]: Disabling DMA buffer screen sharing for driver 'amdgpu'.
Dec 30 10:32:21 ryzen gnome-shell[1362]: Added device '/dev/dri/card0' (amdgpu) using atomic mode setting.
Dec 30 10:32:21 ryzen gnome-shell[1362]: Disabling DMA buffer screen sharing for driver 'amdgpu'.
FWIW, I upgraded the BIOS to the latest version (released 12.07.2021). And tried to add iommu=soft to the boot parameters. No joy.
Just one last thing - and them I’m outta ideas.
Can you uncomment these two lines in your /etc/systemd/logind.conf - restart & try again.
#HandleLidSwitch=suspend
#HandleLidSwitchExternalPower=suspend
A problem in suspend can also be caused by display issue not able to turn off properly.
Check your installed graphics driver by mhwd -li. If you use proprietary driver, then running ls /sys/class/backlight should display your GPU name, not like a generic acpi naming.
But try @frost19k last advice first before troubleshooting your display.
Thanks @frost19k. Unfortunately, uncommenting those lines has no effect on the issue; it still crashes at supsend. I paste below portions of journalctl that show the laptop hitting suspend s2idle, then … nothing until hard reboot.
Also, here is a link to an issue that I started with the amd kernel folks.
Dec 31 09:51:07 ryzen systemd-logind[458]: Lid closed.
Dec 31 09:51:07 ryzen systemd-logind[458]: Suspending...
Dec 31 09:51:07 ryzen ModemManager[515]: <info>  [sleep-monitor] system is about to suspend
Dec 31 09:51:07 ryzen NetworkManager[455]: <info>  [1640969467.6084] manager: sleep: sleep requested (sleeping: no  enabled: yes)
Dec 31 09:51:07 ryzen NetworkManager[455]: <info>  [1640969467.6085] manager: NetworkManager state is now ASLEEP
Dec 31 09:51:07 ryzen NetworkManager[455]: <info>  [1640969467.6087] device (wlo1): state change: activated -> deactivating (reason 'sleeping', sys-iface-state: 'managed')
Dec 31 09:51:07 ryzen dbus-daemon[454]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.3' (uid=0 pid=455 comm="/usr/bin/NetworkManager --no-daemon ")
Dec 31 09:51:07 ryzen systemd[1]: Starting Network Manager Script Dispatcher Service...
Dec 31 09:51:07 ryzen dbus-daemon[454]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Dec 31 09:51:07 ryzen systemd[1]: Started Network Manager Script Dispatcher Service.
Dec 31 09:51:07 ryzen audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Dec 31 09:51:07 ryzen kernel: audit: type=1130 audit(1640969467.616:102): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Dec 31 09:51:07 ryzen kernel: wlo1: deauthenticating from 94:83:c4:0d:56:c5 by local choice (Reason: 3=DEAUTH_LEAVING)
Dec 31 09:51:07 ryzen kernel: rtw_8821ce 0000:01:00.0: sta 94:83:c4:0d:56:c5 with macid 0 left
Dec 31 09:51:07 ryzen wpa_supplicant[732]: wlo1: CTRL-EVENT-DISCONNECTED bssid=94:83:c4:0d:56:c5 reason=3 locally_generated=1
Dec 31 09:51:07 ryzen wpa_supplicant[732]: wlo1: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
Dec 31 09:51:07 ryzen NetworkManager[455]: <info>  [1640969467.7944] device (wlo1): state change: deactivating -> disconnected (reason 'sleeping', sys-iface-state: 'managed')
Dec 31 09:51:07 ryzen NetworkManager[455]: <info>  [1640969467.8131] dhcp4 (wlo1): canceled DHCP transaction
Dec 31 09:51:07 ryzen NetworkManager[455]: <info>  [1640969467.8131] dhcp4 (wlo1): state changed bound -> terminated
Dec 31 09:51:07 ryzen NetworkManager[455]: <info>  [1640969467.8144] device (wlo1): set-hw-addr: set MAC address to B6:3B:C1:B2:6A:EC (scanning)
Dec 31 09:51:07 ryzen kernel: rtw_8821ce 0000:01:00.0: stop vif 14:13:33:7e:09:53 on port 0
Dec 31 09:51:07 ryzen gnome-shell[1237]: An active wireless connection, in infrastructure mode, involves no access point?
Dec 31 09:51:08 ryzen kernel: rtw_8821ce 0000:01:00.0: start vif b6:3b:c1:b2:6a:ec on port 0
Dec 31 09:51:08 ryzen NetworkManager[455]: <info>  [1640969468.3033] device (wlo1): supplicant interface state: completed -> disconnected
Dec 31 09:51:08 ryzen NetworkManager[455]: <info>  [1640969468.3041] device (wlo1): supplicant interface state: disconnected -> interface_disabled
Dec 31 09:51:08 ryzen NetworkManager[455]: <info>  [1640969468.3042] device (wlo1): state change: disconnected -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
Dec 31 09:51:08 ryzen NetworkManager[455]: <info>  [1640969468.3052] device (wlo1): set-hw-addr: reset MAC address to 14:13:33:7E:09:53 (unmanage)
Dec 31 09:51:08 ryzen kernel: rtw_8821ce 0000:01:00.0: stop vif b6:3b:c1:b2:6a:ec on port 0
Dec 31 09:51:08 ryzen kernel: rtw_8821ce 0000:01:00.0: start vif 14:13:33:7e:09:53 on port 0
Dec 31 09:51:08 ryzen systemd[1]: Reached target Sleep.
Dec 31 09:51:08 ryzen systemd[1]: Starting System Suspend...
Dec 31 09:51:08 ryzen wpa_supplicant[732]: nl80211: deinit ifname=wlo1 disabled_11b_rates=0
Dec 31 09:51:08 ryzen systemd-sleep[1803]: Entering sleep state 'suspend'...
Dec 31 09:51:08 ryzen kernel: PM: suspend entry (s2idle)
-- Boot ecc797f87d56404f88f0f60708908952 --
Dec 31 09:52:11 ryzen kernel: Linux version 5.15.8-1-MANJARO (builduser@fv-az121-204) (gcc (GCC) 11.1.0, GNU ld (GNU Binutils) 2.36.1) #1 SMP PREEMPT Tue Dec 14 17:08:08 UTC 2021
Dec 31 09:52:11 ryzen kernel: Command line: root=UUID=f6d46af1-f1d6-4ecd-b1fd-0a2f7baca1a1 rw quiet splash apparmor=1 security=apparmor udev.log_priority=3 acpi_osi='Windows 2020' acpi_backlight=vendor iommu=soft initrd=\initramfs-5.15-x86_64.img
Thanks @JiaZhang. It does not appear to be a monitor issue, but here are the outputs from your suggested commands.
mhwd -li
Installed PCI configs:
           video-linux            2018.05.04                true            PCI
amdgpu_bl0
I’m sorry I couldn’t be more helpful - i did my best.
I’ll be honest, I’ve never opened an issue on freedesktop.org. Those people are hardcore & scare me. Half the time they’ll tell you to patch & recompile the kernel - I don’t know how to do that!!!
At any rate, you’re in the hands of someone with an @amd.com email address. Doesn’t get more expert than that :stuck_out_tongue_winking_eye:
P.S. Thanks for the link. I’ve enabled notifications, I’m sure there’s tons I’ll learn.
similar issue :point_down:
So to check one of the things they asked for (CONFIG_AMD_PMC):
cat /proc/config.gz | gunzip > running.config
grep AMD_PMC running.config || echo "Nada :("
But according to gitlab, it does exist as a module:
@frost19k: Me too! That’s exactly how I feel. Hopefully, they will be gentle.
Thanks @cscs. Maybe together we can get them the information they need.
I have – long time ago – built a kernel to get wifi working on a laptop. But I forgot everything that involved. And I don’t even remember how to enable a kernel configuration option (as requested in the other thread). If anyone here has that knowledge, please post back?
For example, where is the kernel config file in Manjaro? It is not in /boot for me – neither on the new laptop or two other machines running Manjaro (it is present on a Pi running Manjaro though).
