pietet
1
Hi,
I ran the recent upgrade, which upgraded postgresql to 17.
trying to install the plpython3u
extension I am getting,
ERROR: could not load library "/usr/lib/postgresql/plpython3.so": libpython3.13.so.1.0: cannot open shared object file: No such file or directory
I presume I need python 3.13
on the system but alas I can not find it. pacman only shows python 3.12
The announcement says it upgraded python to 3.13 but how to install it?
Are you sure your system is up-to-date? Python 3.13 is in all branches:
mbn info python -q | grep -e 'Branch' -e 'Version' -e 'Build Date'
Branch : archlinux
Version : 3.13.1-1
Build Date : Thu 05 Dec 2024 05:05:56
Branch : unstable
Version : 3.13.1-1
Branch : testing
Version : 3.13.1-1
Branch : stable
Version : 3.13.1-1
sudo pacman -Syu python
pietet
3
Yes,
warning: python-3.12.7-1 is up to date -- reinstalling
I ran the upgrade from pamac.
Maybe your mirrors are not up-to-date yet - the Stable update was released a couple of hours ago.
Try the following instead to generate a new mirror list & do the system update:
sudo pacman-mirrors --continent && sudo pacman -Syu
Or just wait a bit, if you can. As of 2025-02-04 07:24 UTC, about half of the stable mirrors are out-of-date.
pietet
7
Ok thanks, I’ll wait a bit.
Ok, all is back to normal, seems I was just a bit too eager.
Thanks
Well, that was a shorter wait than I expected
, but I am glad that it worked out for you.
system
Closed
9
