I recently bought an Ultra WQHD monitor to use with my workstation. Sadly, every time I try to boot, (it seems) the system freeze when the DM is loaded, at least when I use the 5.10, 5.11, and 5.12rc6 kernels. Kernel 5.4 works without problems. I think this could be a bug in the amdgpu driver, What do you think?
The output of journalctl -p3
abr 08 09:09:48 manjaro-workstation kernel: igc 0000:07:00.0: no suspend buffer for PTM
abr 08 09:09:51 manjaro-workstation kernel: amdgpu 0000:0a:00.0: amdgpu: message: TransferTableSmu2Dram (18) param: 0x00000009 is timeout (no response)
abr 08 09:09:51 manjaro-workstation kernel: amdgpu 0000:0a:00.0: amdgpu: Failed to get overdrive table!
abr 08 09:09:51 manjaro-workstation kernel: amdgpu 0000:0a:00.0: amdgpu: Failed to setup default OD settings!
abr 08 09:09:51 manjaro-workstation kernel: [drm:amdgpu_device_ip_late_init [amdgpu]] *ERROR* late_init of IP block <smu> failed -62
abr 08 09:09:51 manjaro-workstation kernel: amdgpu 0000:0a:00.0: amdgpu: amdgpu_device_ip_late_init failed
abr 08 09:09:51 manjaro-workstation kernel: amdgpu 0000:0a:00.0: amdgpu: Fatal error during GPU init
abr 08 09:09:51 manjaro-workstation kernel: BUG: unable to handle page fault for address: 0000000000058a68
abr 08 09:09:51 manjaro-workstation kernel: #PF: supervisor read access in kernel mode
abr 08 09:09:51 manjaro-workstation kernel: #PF: error_code(0x0000) - not-present page
abr 08 09:09:51 manjaro-workstation kernel: Oops: 0000 [#1] PREEMPT SMP NOPTI
abr 08 09:09:51 manjaro-workstation kernel: CPU: 26 PID: 335 Comm: kworker/26:1 Tainted: G OE 5.12.0-1-MANJARO #1
abr 08 09:09:51 manjaro-workstation kernel: Hardware name: ASUS System Product Name/ROG STRIX B550-E GAMING, BIOS 2006 03/19/2021
abr 08 09:09:51 manjaro-workstation kernel: Workqueue: events splash_callback_animation
abr 08 09:09:51 manjaro-workstation kernel: RIP: 0010:amdgpu_device_rreg.part.0+0x2e/0xe0 [amdgpu]
abr 08 09:09:51 manjaro-workstation kernel: Code: 00 41 55 44 8d 2c b5 00 00 00 00 41 54 41 89 f4 55 53 48 89 fb 4c 3b af d8 0b 00 00 73 53 83 e2 02 74 1a 4c 03 ab e0 0b 00 00 <45> 8b 6d 00 0f 1f 44 00 00 5b 44 89 e8 5d 41 5c 41 5d c3 f6 87 a0
abr 08 09:09:51 manjaro-workstation kernel: RSP: 0018:ffffabf2c0b5f640 EFLAGS: 00010202
abr 08 09:09:51 manjaro-workstation kernel: RAX: ffff97718688e1e8 RBX: ffff9771a4c40000 RCX: 000000000000001a
abr 08 09:09:51 manjaro-workstation kernel: RDX: 0000000000000002 RSI: 000000000001629a RDI: ffff9771a4c40000
abr 08 09:09:51 manjaro-workstation kernel: RBP: 00000000000f4240 R08: 0000000000000000 R09: 0000000000000000
abr 08 09:09:51 manjaro-workstation kernel: R10: 00000001aa30dd9d R11: 0000000000000000 R12: 000000000001629a
abr 08 09:09:51 manjaro-workstation kernel: R13: 0000000000058a68 R14: ffff9771a4c47e70 R15: ffff9771a4c40000
abr 08 09:09:51 manjaro-workstation kernel: FS: 0000000000000000(0000) GS:ffff97902f080000(0000) knlGS:0000000000000000
abr 08 09:09:51 manjaro-workstation kernel: CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
abr 08 09:09:51 manjaro-workstation kernel: CR2: 0000000000058a68 CR3: 00000014fee10000 CR4: 0000000000350ee0
abr 08 09:09:51 manjaro-workstation kernel: Call Trace:
abr 08 09:09:51 manjaro-workstation kernel: smu_cmn_wait_for_response.isra.0+0x4b/0x60 [amdgpu]
abr 08 09:09:51 manjaro-workstation kernel: smu_cmn_send_msg_without_waiting+0x1d/0x90 [amdgpu]
abr 08 09:09:51 manjaro-workstation kernel: smu_cmn_send_smc_msg_with_param+0x95/0x110 [amdgpu]
abr 08 09:09:51 manjaro-workstation kernel: smu_set_display_count+0x5c/0x80 [amdgpu]
abr 08 09:09:51 manjaro-workstation kernel: pp_nv_set_display_count+0x23/0x40 [amdgpu]
abr 08 09:09:51 manjaro-workstation kernel: dcn2_update_clocks+0x50f/0x550 [amdgpu]
abr 08 09:09:51 manjaro-workstation kernel: dcn20_prepare_bandwidth+0x32/0x70 [amdgpu]
abr 08 09:09:51 manjaro-workstation kernel: dc_commit_updates_for_stream+0x108e/0x1d20 [amdgpu]
abr 08 09:09:51 manjaro-workstation kernel: amdgpu_dm_atomic_commit_tail+0x1634/0x2660 [amdgpu]
abr 08 09:09:51 manjaro-workstation kernel: commit_tail+0x94/0x130 [drm_kms_helper]
abr 08 09:09:51 manjaro-workstation kernel: drm_atomic_helper_commit+0x113/0x140 [drm_kms_helper]
abr 08 09:09:51 manjaro-workstation kernel: drm_client_modeset_commit_atomic+0x1fc/0x240 [drm]
abr 08 09:09:51 manjaro-workstation kernel: drm_client_modeset_commit_locked+0x56/0x150 [drm]
abr 08 09:09:51 manjaro-workstation kernel: drm_fb_helper_pan_display+0xdc/0x210 [drm_kms_helper]
abr 08 09:09:51 manjaro-workstation kernel: fb_pan_display+0x83/0x100
abr 08 09:09:51 manjaro-workstation kernel: dummy_update_start+0x1a/0x40
abr 08 09:09:51 manjaro-workstation kernel: fbcon_switch+0x3dc/0x5a0
abr 08 09:09:51 manjaro-workstation kernel: redraw_screen+0xe5/0x230
abr 08 09:09:51 manjaro-workstation kernel: ? _raw_spin_lock_irqsave+0x26/0x50
abr 08 09:09:51 manjaro-workstation kernel: splash_callback_animation+0x58/0x60
abr 08 09:09:51 manjaro-workstation kernel: process_one_work+0x214/0x3e0
abr 08 09:09:51 manjaro-workstation kernel: worker_thread+0x4d/0x3d0
abr 08 09:09:51 manjaro-workstation kernel: ? process_one_work+0x3e0/0x3e0
abr 08 09:09:51 manjaro-workstation kernel: kthread+0x142/0x160
abr 08 09:09:51 manjaro-workstation kernel: ? __kthread_bind_mask+0x60/0x60
abr 08 09:09:51 manjaro-workstation kernel: ret_from_fork+0x22/0x30
abr 08 09:09:51 manjaro-workstation kernel: Modules linked in: pcc_cpufreq(-) amd64_edac(-) bnep btusb btrtl btbcm btintel bluetooth ecdh_generic ecc crc16 snd_usb_audio snd_usbmidi_lib snd_rawmidi snd_seq_device mc usbhid iwlmvm mac80211 snd_hda_codec_realtek nct6775 hwmon_vid libarc4 intel_rapl_msr snd_hda_codec_generic intel_rapl_com>
abr 08 09:09:51 manjaro-workstation kernel: xfs libcrc32c crc32c_generic crc32c_intel xhci_pci
abr 08 09:09:52 manjaro-workstation kernel: RIP: 0010:amdgpu_device_rreg.part.0+0x2e/0xe0 [amdgpu]
abr 08 09:09:52 manjaro-workstation kernel: Code: 00 41 55 44 8d 2c b5 00 00 00 00 41 54 41 89 f4 55 53 48 89 fb 4c 3b af d8 0b 00 00 73 53 83 e2 02 74 1a 4c 03 ab e0 0b 00 00 <45> 8b 6d 00 0f 1f 44 00 00 5b 44 89 e8 5d 41 5c 41 5d c3 f6 87 a0
abr 08 09:09:52 manjaro-workstation kernel: RSP: 0018:ffffabf2c0b5f640 EFLAGS: 00010202
abr 08 09:09:52 manjaro-workstation kernel: RAX: ffff97718688e1e8 RBX: ffff9771a4c40000 RCX: 000000000000001a
abr 08 09:09:52 manjaro-workstation kernel: RDX: 0000000000000002 RSI: 000000000001629a RDI: ffff9771a4c40000
abr 08 09:09:52 manjaro-workstation kernel: RBP: 00000000000f4240 R08: 0000000000000000 R09: 0000000000000000
abr 08 09:09:52 manjaro-workstation kernel: R10: 00000001aa30dd9d R11: 0000000000000000 R12: 000000000001629a
abr 08 09:09:52 manjaro-workstation kernel: R13: 0000000000058a68 R14: ffff9771a4c47e70 R15: ffff9771a4c40000
abr 08 09:09:52 manjaro-workstation kernel: FS: 0000000000000000(0000) GS:ffff97902f080000(0000) knlGS:0000000000000000
abr 08 09:09:52 manjaro-workstation kernel: CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
abr 08 09:09:52 manjaro-workstation kernel: CR2: 0000000000058a68 CR3: 0000000118758000 CR4: 0000000000350ee0
Relevant inxi output:
Kernel: 5.4.110-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
root=UUID=7244fb8a-244a-4903-96b9-f9989c584cd2 rw quiet
bootsplash.bootfile=bootsplash-themes/manjaro/bootsplash udev.log_priority=3
loglevel=3
Desktop: KDE Plasma 5.21.4 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1
Type: Desktop System: ASUS product: N/A v: N/A serial: <filter>
Mobo: ASUSTeK model: ROG STRIX B550-E GAMING v: Rev X.0x serial: <filter>
UEFI: American Megatrends v: 2006 date: 03/19/2021
RAM: total: 125.79 GiB used: 8.28 GiB (6.6%)
Info: 16-Core (2-Die) model: AMD Ryzen 9 3950X bits: 64 type: MT MCP MCM
arch: Zen 2 family: 17 (23) model-id: 71 (113) stepping: N/A
microcode: 8701021 cache: L2: 8 MiB bogomips: 224096
Speed: 2197 MHz min/max: 2200/3500 MHz boost: enabled Core speeds (MHz):
1: 2197 2: 2200 3: 2057 4: 2054 5: 4356 6: 2187 7: 2188 8: 2186 9: 2186
10: 2196 11: 2193 12: 2191 13: 2196 14: 2197 15: 2199 16: 2193 17: 2194
18: 2056 19: 3592 20: 2058 21: 2054 22: 4356 23: 2181 24: 2200 25: 2184
26: 2181 27: 2203 28: 2203 29: 2201 30: 2197 31: 2056 32: 3599
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs irperf lahf_lm lbrv lm
mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc
nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse
pse36 rdpid rdrand rdseed rdt_a rdtscp rep_good sep sev sha_ni skinit smap
smca sme smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm
svm_lock syscall tce topoext tsc tsc_scale umip v_vmsave_vmload vgif
vmcb_clean vme vmmcall wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt
xsaves
conditional, RSB filling
Device-1: AMD Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT]
vendor: ASUSTeK driver: amdgpu v: kernel bus-ID: 0a:00.0 chip-ID: 1002:731f
class-ID: 0300
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver:
loaded: amdgpu,ati unloaded: modesetting,radeon alternate: fbdev,vesa
display-ID: :0 screens: 1
Screen-1: 0 s-res: 3440x1440 s-dpi: 96 s-size: 910x381mm (35.8x15.0")
s-diag: 987mm (38.8")
OpenGL: renderer: AMD Radeon RX 5700 XT (NAVI10 DRM 3.35.0 5.4.110-1-MANJARO
LLVM 11.1.0)
v: 4.6 Mesa 21.0.1 direct render: Yes
