After updating my system (around the 23rd) I can no longer connect a bluetooth device to my system in order to hear audio playback from it.
The devices appear in PA volume control as Audio gateway (A2DP Source & HSP/HFP AG)
but do not appear in the output of pactl list sources
Using pipewire for audio, here is the output of inxi:
Kernel: 5.17.9-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.17-x86_64
root=UUID=2bd04f27-f67d-4eaa-9bf1-37ab3aec675f rw quiet
udev.log_priority=3
Desktop: KDE Plasma v: 5.24.5 tk: Qt v: 5.15.4 wm: kwin_x11 vt: 1 dm: SDDM
Type: Convertible System: ASUSTeK product: ZenBook Q326FA_Q326FA v: 1.0
serial: <superuser required>
Mobo: ASUSTeK model: Q326FA v: 1.0 serial: <superuser required>
UEFI: American Megatrends v: Q326FA.305 date: 10/14/2019
ID-1: BAT0 charge: 40.4 Wh (99.3%) condition: 40.7/50.0 Wh (81.4%)
volts: 11.9 min: 11.9 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
status: not charging cycles: 95
Device-1: hid-0018:04F3:284E.0001-battery model: ELAN9008:00 04F3:284E
serial: N/A charge: N/A status: N/A
Info: model: Intel Core i7-8565U bits: 64 type: MT MCP arch: Whiskey Lake
family: 6 model-id: 0x8E (142) stepping: 0xB (11) microcode: 0xF0
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 800 min/max: 400/4600 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
8: 800 bogomips: 32012
Device-1: Intel WhiskeyLake-U GT2 [UHD Graphics 620] vendor: ASUSTeK
driver: i915 v: kernel ports: active: DP-1,DP-2,eDP-1 empty: HDMI-A-1
bus-ID: 00:02.0 chip-ID: 8086:3ea0 class-ID: 0300
Device-2: IMC Networks USB2.0 HD IR UVC WebCam type: USB driver: uvcvideo
bus-ID: 1-5:5 chip-ID: 13d3:56cb class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.3 compositor: kwin_x11 driver: X:
loaded: intel gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 5760x1080 s-dpi: 96 s-size: 1520x285mm (59.84x11.22")
s-diag: 1546mm (60.89")
Monitor-1: DP-1 mapped: DP1 pos: right model: Asus VE248 serial: <filter>
built: 2015 res: 1920x1080 hz: 60 dpi: 92 gamma: 1.2
size: 530x300mm (20.87x11.81") diag: 609mm (24") ratio: 16:9 modes:
max: 1920x1080 min: 720x400
Monitor-2: DP-2 mapped: DP2 pos: center model: Samsung S24F350
serial: <filter> built: 2018 res: 1920x1080 hz: 60 dpi: 94 gamma: 1.2
size: 520x290mm (20.47x11.42") diag: 598mm (23.5") ratio: 16:9 modes:
Monitor-3: eDP-1 mapped: eDP1 pos: primary,left model: AU Optronics 0x5c2d
built: 2018 res: 1920x1080 hz: 60 dpi: 168 gamma: 1.2
size: 290x170mm (11.42x6.69") diag: 336mm (13.2") ratio: 16:9
modes: 1920x1080
OpenGL: renderer: Mesa Intel UHD Graphics 620 (WHL GT2) v: 4.6 Mesa 22.0.4
direct render: Yes
Device-1: Intel Cannon Point-LP High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci_intel_cnl
bus-ID: 00:1f.3 chip-ID: 8086:9dc8 class-ID: 0403
Device-2: Corsair VOID Surround USB Sound Adapter type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-1.3:14 chip-ID: 1b1c:0a30
class-ID: 0300 serial: <filter>
Sound Server-1: ALSA v: k5.17.9-1-MANJARO running: yes
Sound Server-3: PulseAudio v: 15.0 running: no
Sound Server-4: PipeWire v: 0.3.51 running: yes
Device-1: Intel Cannon Point-LP CNVi [Wireless-AC] driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:9df0 class-ID: 0280
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
driver: btusb v: 0.8 bus-ID: 1-10:8 chip-ID: 8087:0aaa class-ID: e001
Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Local Storage: total: 931.51 GiB used: 228.83 GiB (24.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT1000P5SSD8
lanes: 4 type: SSD serial: <filter> rev: P4CR311 temp: 42.9 C scheme: GPT
ID-1: / raw-size: 830.08 GiB size: 815.98 GiB (98.30%)
used: 228.8 GiB (28.0%) fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5
used: 25.2 MiB (26.3%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
System Temperatures: cpu: 58.0 C pch: 56.0 C mobo: N/A
Fan Speeds (RPM): cpu: 0
Processes: 276 Uptime: 12h 23m wakeups: 4 Memory: 15.41 GiB
used: 3.88 GiB (25.2%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 12.1.0 clang: 13.0.1 Packages: pacman: 1493 lib: 471 Shell: Zsh v: 5.9
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.16
