My system is laptop, I have no printer and printer files at all
Can I remove the “foomatic” package completely?
Yes, just uninstall it, but make sure it doesn’t take any (real or false) dependencies with it.
sudo pacman -Rdd foomatic-db
Why?
Either it should be removed along with dependencies … or its required for something.
Skipping (all in the case of two d
s) dependency checks should not be so commonly suggested.
You are right
Of course, I didn’t really need it and I deleted all its dependencies foomatic*
Also, can I remove the glibc-locales
package because there are no package dependencies when I remove it?
Also a non-required package.
(ex: sudo pacman -Rns glibc-locales
I mean by deleting the 'glibc-locales` package, will there be any problems in running the other packages?
➤ sudo pacman -Rnc glibc-locales
checking dependencies...
Package (1) Old Version Net Change
glibc-locales 2.38-7 -213.33 MiB
Total Removed Size: 213.33 MiB
:: Do you want to remove these packages? [Y/n]
Understood. The answer is it is not required.
So still no unless you are using “Pregenerated locales for GNU C Library” somehow.
