Camera / video not working / not available
In many respects, a NOOB, particularly as far as terminal & CLI goes and hence, help would be appreciated.
I have been running Manjaro Gnome for some time. Did a silly thing recently when attempting to downgrade the kernel. Hence, a new installation of Gnome 2114 with subsequent updates to today, 20211031.
Prior to Gnome 2114, the camera / video worked 100%. Now no longer. Using mhwd I’ve tried to understand the problem and resolve. Without success / luck, it seems.
Gnome Settings tells me the camera is on but no applications have requested permission. Apps like Telegram / Signal tell me there’s no camera.
Here’s what I’ve learned (?) from mhwd using a live 2114 usb:
print from mhwd
sudo mhwd -lh -d --pci
Warning: config '/var/lib/mhwd/db/pci/graphic_drivers/catalyst/MHWDCONFIG' is invalid!
Warning: config '/var/lib/mhwd/db/pci/graphic_drivers/hybrid-intel-nvidia-340xx-bumblebee/MHWDCONFIG' is invalid!
Warning: config '/var/lib/mhwd/db/pci/graphic_drivers/hybrid-intel-nvidia-418xx-bumblebee/MHWDCONFIG' is invalid!
Warning: config '/var/lib/mhwd/db/pci/graphic_drivers/hybrid-intel-nvidia-430xx-bumblebee/MHWDCONFIG' is invalid!
Warning: config '/var/lib/mhwd/db/pci/graphic_drivers/hybrid-intel-nvidia-435xx-prime/MHWDCONFIG' is invalid!
Warning: config '/var/lib/mhwd/db/pci/graphic_drivers/hybrid-intel-nvidia-440xx-prime/MHWDCONFIG' is invalid!
Warning: config '/var/lib/mhwd/db/pci/graphic_drivers/nvidia-340xx/MHWDCONFIG' is invalid!
Warning: config '/var/lib/mhwd/db/pci/graphic_drivers/nvidia-418xx/MHWDCONFIG' is invalid!
Warning: config '/var/lib/mhwd/db/pci/graphic_drivers/nvidia-430xx/MHWDCONFIG' is invalid!
Warning: config '/var/lib/mhwd/db/pci/graphic_drivers/nvidia-435xx/MHWDCONFIG' is invalid!
Warning: config '/var/lib/mhwd/db/pci/graphic_drivers/nvidia-440xx/MHWDCONFIG' is invalid!
Warning: config '/var/lib/mhwd/db/pci/graphic_drivers/virtualbox/MHWDCONFIG' is invalid!
Warning: config '/var/lib/mhwd/db/pci/network_drivers/r8168/MHWDCONFIG' is invalid!
Warning: config '/var/lib/mhwd/db/pci/network_drivers/rt3562sta/MHWDCONFIG' is invalid!
Output " 0300=
22: PCI 02.0: 0300 VGA compatible controller (VGA)
  SysFS ID: /devices/pci0000:00/0000:00:02.0
  SysFS BusID: 0000:00:02.0
  Hardware Class: graphics card
  Model: "Intel Crystal Well Integrated Graphics Controller"
  Vendor: pci 0x8086 "Intel Corporation"
  Device: pci 0x0d26 "Crystal Well Integrated Graphics Controller"
  SubVendor: pci 0x1558 "CLEVO/KAPOK Computer"
  SubDevice: pci 0x7410
  Revision: 0x08
  Driver: "i915"
  Driver Modules: "i915"
  Memory Range: 0xf7800000-0xf7bfffff (rw,non-prefetchable)
  Memory Range: 0xe0000000-0xefffffff (ro,non-prefetchable)
  I/O Ports: 0xf000-0xf03f (rw)
  Memory Range: 0x000c0000-0x000dffff (rw,non-prefetchable,disabled)
  IRQ: 33 (90451 events)
  I/O Ports: 0x3c0-0x3df (rw)
  Module Alias: "pci:v00008086d00000D26sv00001558sd00007410bc03sc00i00"
  Driver Info #0:
    Driver Status: i915 is active
    Driver Activation Cmd: "modprobe i915"
And
sudo mhwd -a pci nonfree 0300
Warning: config 'Warning: config '/var/lib/mhwd/db/pci/graphic_drivers/hybrid-intel-nvidia-340xx-bumblebee/MHWDCONFIG' is invalid!
> All PCI configs:
video-hybrid-amd-nvidia-prime            2021.07.28               false            PCI
video-hybrid-intel-nvidia-390xx-bumblebee            2020.11.30               false            PCI
video-hybrid-intel-nvidia-prime            2021.07.28               false            PCI
          video-nvidia            2020.11.30               false            PCI
    video-nvidia-390xx            2020.11.30               false            PCI
           video-linux            2018.05.04                true            PCI
  video-virtualmachine            2021.07.26                true            PCI
      video-openchrome            2020.01.18                true            PCI
       video-rendition            2020.01.18                true            PCI
              video-s3            2020.01.18                true            PCI
          video-sisusb            2020.01.18                true            PCI
          video-voodoo            2017.03.12                true            PCI
   network-broadcom-wl            2018.10.07                true            PCI
       network-slmodem            2013.12.07                true            PCI
And
sudo mhwd -li                                                  1 ✘
[sudo] password for
> Installed PCI configs:
And finally, hardware:
> PCI devices:
                          TYPE            BUS   CLASS  VENDOR  DEVICE   CONFIGS
            Network controller   0000:03:00.0    0200    10ec    b723         0
       Mass storage controller   0000:00:1f.2    0106    8086    8c03         0
                        Bridge   0000:00:1c.0    0604    8086    8c10         0
                        Bridge   0000:00:1f.0    0601    8086    8c4b         0
           Unclassified device   0000:02:00.0    ff00    10ec    5229         0
      Communication controller   0000:00:16.0    0780    8086    8c3a         0
         Multimedia controller   0000:00:1b.0    0403    8086    8c20         0
                        Bridge   0000:00:1c.3    0604    8086    8c16         0
            Network controller   0000:00:19.0    0200    8086    153b         0
         Serial bus controller   0000:00:1f.3    0c05    8086    8c22         0
                        Bridge   0000:00:00.0    0600    8086    0d04         0
                        Bridge   0000:00:1c.1    0604    8086    8c12         0
         Multimedia controller   0000:00:03.0    0403    8086    0d0c         0
         Serial bus controller   0000:00:1a.0    0c03    8086    8c2d         0
         Serial bus controller   0000:00:1d.0    0c03    8086    8c26         0
            Display controller   0000:00:02.0    0300    8086    0d26         3
         Serial bus controller   0000:00:14.0    0c03    8086    8c31         0
> USB devices:
           Mass Storage Device        6:0:0:0   10600    0951    1666         0
                           Hub        2-1:1.0   10a00    8087    8000         0
                           Hub        3-0:1.0   10a00    1d6b    0002         0
              Bluetooth Device        3-4:1.0   11500    0bda    b002         0
                           Hub        4-0:1.0   10a00    1d6b    0003         0
                           Hub        1-0:1.0   10a00    1d6b    0002         0
                           Hub        1-1:1.0   10a00    8087    8008         0
                           Hub        2-0:1.0   10a00    1d6b    0002         0
Apps like Cheese etc also tell me there’s no camera
Any help to get my camera back would be appreciated. Thanks
