Gnome camera software recommendation
I try to use camera sony with my latptop / archlinux manjaro, for win10 and mac i found imaging edge webcam it s very good, there is any software do the same for manjaro ?? if not can you share plz links to explain how can use camera as webcam ?
Thank you for help
:+1: Welcome to Manjaro! :+1:
  1. Please read this:
    How to provide good information
    and press the three dots … below your post and press the :pencil2: to give us more information so we can see what’s really going on.
    Now we know the symptom of the disease, but we need some more probing to know where the origin lies… :grin:
  2. An inxi --admin --verbosity=7 --filter --no-host --width would be the minimum required information for us to be able to help you. (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)
    Also, please copy-paste that output in-between 3 backticks ``` at the beginning and end of the code/text.
:+1:
@Fabby i am confusing because my question is very clear, to use sony camera on win10 / macosx must to use a software “Imaging edge mobile”, this software not compatible for linux, raison for that i ask if there is another way !
for second point:
  Kernel: 5.14.7-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
  parameters: BOOT_IMAGE=/boot/vmlinuz-5.14-x86_64
  root=UUID=868f7eb2-6ce5-4923-8365-471ec2b7ad69 rw quiet
  resume=UUID=454b0ec4-381f-430a-81a3-d0ef14fe7dd7
  Desktop: GNOME 40.4 tk: GTK 3.24.30 wm: gnome-shell dm: GDM 3.34.1
  Type: Laptop System: LENOVO product: 20HJS1C700 v: ThinkPad P51
  serial: <filter> Chassis: type: 10 serial: <filter>
  Mobo: LENOVO model: 20HJS1C700 v: SDK0J40697 WIN serial: <filter>
  UEFI: LENOVO v: N1UET78W (1.52 ) date: 06/18/2020
  RAM: total: 31.08 GiB used: 8.4 GiB (27.0%)
  Info: Quad Core model: Intel Core i7-7820HQ bits: 64 type: MT MCP
  arch: Kaby Lake family: 6 model-id: 9E (158) stepping: 9 microcode: EA
  cache: L2: 8 MiB bogomips: 46419
  Speed: 900 MHz min/max: 800/3900 MHz Core speeds (MHz): 1: 900 2: 900 3: 898
  4: 900 5: 900 6: 900 7: 900 8: 900
  Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
  avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
  hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm
  mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat
  rdrand rdseed rdtscp rep_good sdbg sep sgx smap smep smx ss ssbd sse sse2
  xsaves xtopology xtpr
  Type: l1tf
  Device-1: Intel HD Graphics 630 vendor: Lenovo driver: i915 v: kernel
  bus-ID: 00:02.0 chip-ID: 8086:591b class-ID: 0300
  Device-2: NVIDIA GM206GLM [Quadro M2200 Mobile] vendor: Lenovo
  driver: nvidia v: 470.63.01 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
  chip-ID: 10de:1436 class-ID: 0302
  Device-3: Chicony Integrated Camera type: USB driver: uvcvideo bus-ID: 1-8:4
  chip-ID: 04f2:b5ab class-ID: 0e02
  Display: x11 server: X.org 1.20.13 compositor: gnome-shell driver:
  loaded: modesetting,nvidia resolution: <missing: xdpyinfo>
  OpenGL: renderer: Quadro M2200/PCIe/SSE2 v: 4.6.0 NVIDIA 470.63.01
  direct render: Yes
  Device-1: Intel CM238 HD Audio vendor: Lenovo driver: snd_hda_intel
  v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a171 class-ID: 0403
  Device-2: NVIDIA GM206 High Definition Audio driver: snd_hda_intel v: kernel
  bus-ID: 01:00.1 chip-ID: 10de:0fba class-ID: 0403
  Sound Server-1: ALSA v: k5.14.7-2-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.37 running: yes
  Device-1: Intel Ethernet I219-LM vendor: Lenovo driver: e1000e v: kernel
  port: efa0 bus-ID: 00:1f.6 chip-ID: 8086:15e3 class-ID: 0200
  IF: enp0s31f6 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-2: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel port: d000
  bus-ID: 04:00.0 chip-ID: 8086:24fd class-ID: 0280
  IF: wlp4s0 state: down mac: <filter>
  IF-ID-1: br-077e7384e26b state: down mac: <filter>
  IF-ID-2: br-33c332323d67 state: down mac: <filter>
  IF-ID-3: br-3a419f99272b state: down mac: <filter>
  IF-ID-4: br-3cc1f65f2007 state: down mac: <filter>
  IF-ID-5: br-417d6ef63f34 state: down mac: <filter>
  IF-ID-6: br-45d70ad7a930 state: down mac: <filter>
  IF-ID-7: br-4a1f0b0e13d9 state: down mac: <filter>
  IF-ID-8: br-5658a32fe595 state: down mac: <filter>
  IF-ID-9: br-58d47591e796 state: down mac: <filter>
  IF-ID-10: br-5e4fbf60d6e8 state: down mac: <filter>
  IF-ID-11: br-7c4b61109ba0 state: down mac: <filter>
  IF-ID-12: br-7c689f352ec7 state: down mac: <filter>
  IF-ID-13: br-809cdceccf16 state: down mac: <filter>
  IF-ID-14: br-861624fdafec state: down mac: <filter>
  IF-ID-15: br-9bc59fb5bc3e state: up speed: 10000 Mbps duplex: unknown
  mac: <filter>
  IP v6: <filter> scope: link
  IF-ID-16: br-9d41e7be0625 state: down mac: <filter>
  IF-ID-17: br-9fed5779af3f state: down mac: <filter>
  IF-ID-18: br-a1d0ad219b4f state: down mac: <filter>
  IF-ID-19: br-ab83eb82f8aa state: down mac: <filter>
  IF-ID-20: br-b9618715336a state: down mac: <filter>
  IF-ID-21: br-ba1d8bf8c19d state: down mac: <filter>
  IF-ID-22: br-bee9fcbf2f93 state: down mac: <filter>
  IF-ID-23: br-c46a34b440ad state: down mac: <filter>
  IF-ID-24: br-d5f1b1777d48 state: down mac: <filter>
  IF-ID-25: br-db0ff1217bdb state: down mac: <filter>
  IF-ID-26: br-de417b47ecf0 state: down mac: <filter>
  IF-ID-27: docker0 state: down mac: <filter>
  IF-ID-28: vethf3b0571 state: up speed: 10000 Mbps duplex: full mac: <filter>
  IF-ID-29: virbr0 state: down mac: <filter>
  bus-ID: 1-14:6 chip-ID: 8087:0a2b class-ID: e001
  Hardware-1: Intel SATA Controller [RAID mode] driver: ahci v: 3.0 port: e060
  bus-ID: 00:17.0 chip-ID: 8086.2822 rev: 31 class-ID: 0104
  Local Storage: total: 953.88 GiB used: 633.22 GiB (66.4%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Lenovo
  model: LENSE20512GMSP34MEAT2TA size: 476.94 GiB block-size: physical: 512 B
  rev: 2.8.8341 temp: 38.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: SK Hynix model: SC311 SATA 512GB
  size: 476.94 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
  type: SSD serial: <filter> rev: 0P10 scheme: GPT
  ID-1: / raw-size: 258.55 GiB size: 253.49 GiB (98.04%)
  used: 232.89 GiB (91.9%) fs: ext4 dev: /dev/nvme0n1p8 maj-min: 259:8
  label: N/A uuid: 868f7eb2-6ce5-4923-8365-471ec2b7ad69
  ID-2: /boot/efi raw-size: 200 MiB size: 196.9 MiB (98.45%)
  used: 271 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p6 maj-min: 259:6 label: N/A
  uuid: FAAA-F008
  ID-3: /mnt/1C12BBAC12BB8972 raw-size: 476.39 GiB size: 476.39 GiB (100.00%)
  used: 400.33 GiB (84.0%) fs: ntfs dev: /dev/sda4 maj-min: 8:4
  label: Nouveau nom uuid: 1C12BBAC12BB8972
  ID-1: swap-1 type: partition size: 1.02 GiB used: 0 KiB (0.0%) priority: -2
  dev: /dev/nvme0n1p7 maj-min: 259:7 label: N/A
  uuid: 454b0ec4-381f-430a-81a3-d0ef14fe7dd7
  ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 499 MiB fs: ntfs
  label: R\xc3\xa9cup\xc3\xa9ration uuid: DEC8B8A8C8B87FF7
  ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 100 MiB fs: vfat label: N/A
  uuid: DEB9-8A37
  ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 16 MiB fs: <superuser required>
  label: N/A uuid: N/A
  ID-4: /dev/nvme0n1p4 maj-min: 259:4 size: 216 GiB fs: ntfs label: N/A
  uuid: 60F4D9A0F4D9792C
  ID-5: /dev/nvme0n1p5 maj-min: 259:5 size: 585 MiB fs: ntfs label: N/A
  uuid: 6CFA3F7FFA3F449C
  ID-6: /dev/sda1 maj-min: 8:1 size: 450 MiB fs: ntfs
  label: R\xc3\xa9cup\xc3\xa9ration uuid: FA3C8AB73C8A6E87
  ID-7: /dev/sda2 maj-min: 8:2 size: 100 MiB fs: vfat label: N/A
  uuid: D88B-4C24
  ID-8: /dev/sda3 maj-min: 8:3 size: 16 MiB fs: <superuser required>
  Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0
  Device-1: 1-1:2 info: Novatek Micro GamingKeyboard type: Keyboard
  driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s
  power: 500mA chip-ID: 0603:0098 class-ID: 0301
  Device-2: 1-2:3 info: Cooler Master CM310 type: Mouse,Keyboard
  power: 480mA chip-ID: 2516:0099 class-ID: 0301
  Device-3: 1-5:7 info: Sony USB Bus-powered Device type: HID
  driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s
  power: 500mA chip-ID: 054c:0830 class-ID: 0300 serial: <filter>
  Device-4: 1-8:4 info: Chicony Integrated Camera type: Video driver: uvcvideo
  interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 04f2:b5ab
  class-ID: 0e02
  Device-5: 1-9:5 info: Validity Sensors type: <vendor specific> driver: N/A
  interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 138a:0097
  class-ID: ff00 serial: <filter>
  Device-6: 1-14:6 info: Intel Bluetooth wireless interface type: Bluetooth
  Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 10 rev: 3.0 speed: 5 Gb/s
  System Temperatures: cpu: 51.0 C mobo: N/A gpu: nvidia temp: 46 C
  Fan Speeds (RPM): fan-1: 3059 fan-2: 3061
  Processes: 380 Uptime: 39m wakeups: 1 Init: systemd v: 249 tool: systemctl
  Compilers: gcc: 11.1.0 Packages: pacman: 1687 lib: 458 flatpak: 0 Shell: Zsh
  v: 5.8 running-in: tilix inxi: 3.3.06
No it’s not:
It doesn’t work under Linux, so we don’t know what it does so we cannot recommend any software… What are your requirements for camera software?
The camera is recognized is all we can tell you:
And now at least we can see you’re running Gnome:
so I’ve reclassified your question to the Gnome support (as I’m on KDE and cannot help you any further, except that “Cheese” is the standard Gnome camera software IIRC).
:bowing_man:
@Fabby it s ok if not understand the question, i found a solution with diffirent way and now camera Sony work correctly as webcam with manjaro, thank you for your time.
And the soliution is? Or you intend to keep it for yourself?
could you do me a favour and:
  • post your solution into a reply to your own question
  • click the 3 dots below your own answer to mark a solution like this:
    Solution
    so that the next person that has the exact same problem you just had will benefit from your post as your question will now be in the “solved” status.
:crossed_fingers:
i enable option on camera setting so it s not related to archlinux
