Machine hangs in "three dots" after update
Summary:
  • After an update & installation of the new kernel (linux66-6.6.2-1), my Manjaro on startup gets stuck at the “three dots” phase. If I interrupt and restart, there is a roughly 50/50 chances of getting stuck at the same phase again or booting successfully. But if I let the machine hang at the “three dots” for a long time (e.g. 10 minutes) and then interrupt, subsequent starts will always be successful. Can there be any explanation for this? Below I’ll give more detail.
  • [Added later] I just updated one of the affected machines for the 2023-12-01 update, and the same thing repeated. I.e. just after update, a start hung on the “three dots.” After I let it hang for 10 minutes, interrupted it, and started again, I got 10 successful starts in a row. Having to do this for every update would be inconvenient, but I could live with that. My real worry would be that I am storing up trouble for later somehow, one for which a trick does not exist.
  • [ADDED LATER] My problem was the new kernel 6.6, and reverting to the use of kernel 6.1 fixed it. To confirm this, I got my “pure” copy of VM from archive (i.e., the one that is never used and to which no bad thing has ever happened) and repeated the update process sans install of kernel 6.6. The result was that there was no hanging and no other problem (what I always got after an update so far).
Environment: My Manjaro is a virtual machine running in VMware Workstation (17.0.2 and 17.5.0 for Windows, the latter being the current). Actually I am speaking of three different VMs, all of which experienced the same phenomenon as summarized.
The update dates: These dated ones were applied at once. 2023-10-04, 2023-10-09, 2023-10-13, 2023-11-06, 2023-11-13, 2023-11-21, 2023-11-28. (This list is for one of the VMs. Another VM only had the November updates applied at once.)
Phenomenon in detail:
  1. Apply updates from command line.
  2. Install kernel from command line.
  3. Start VM > see VM get stuck at the “three dots” phase.
  4. Do many “interreupt > start” sequences > see VM either get stuck or boot, chances being 50/50.
  5. Interrupt > start > see VM get stuck > let it be stuck for 10 minutes > interrupt again > start.
  6. See that, on subsequent starts, VM boots successfully ten times in a row.
Update log excerpts
[2023-11-29T11:18:38+0900] [PACMAN] Running 'pacman -Syu'
[2023-11-29T11:18:38+0900] [PACMAN] synchronizing package lists
[2023-11-29T11:18:56+0900] [ALPM] running '00-timeshift-autosnap.hook'...
[2023-11-29T11:18:56+0900] [ALPM-SCRIPTLET] ==> skipping timeshift-autosnap due skipRsyncAutosnap in /etc/timeshift-autosnap.conf set to TRUE.
[2023-11-29T11:18:56+0900] [ALPM] transaction started
[2023-11-29T11:18:56+0900] [ALPM] upgraded archlinux-keyring (20230821-2 -> 20231113-1)
[2023-11-29T11:18:56+0900] [ALPM-SCRIPTLET] ==> Appending keys from archlinux.gpg...
[2023-11-29T11:18:59+0900] [ALPM-SCRIPTLET] ==> Locally signing trusted keys in keyring...
[2023-11-29T11:18:59+0900] [ALPM-SCRIPTLET]   -> Locally signed 1 keys.
[2023-11-29T11:18:59+0900] [ALPM-SCRIPTLET] ==> Importing owner trust values...
[2023-11-29T11:18:59+0900] [ALPM-SCRIPTLET] gpg: inserting ownertrust of 4
[2023-11-29T11:18:59+0900] [ALPM-SCRIPTLET] ==> Disabling revoked keys in keyring...
[2023-11-29T11:18:59+0900] [ALPM-SCRIPTLET]   -> Disabled 5 keys.
[2023-11-29T11:18:59+0900] [ALPM-SCRIPTLET] ==> Updating trust database...
[2023-11-29T11:19:00+0900] [ALPM-SCRIPTLET] gpg: marginals needed: 3  completes needed: 1  trust model: pgp
[2023-11-29T11:19:00+0900] [ALPM-SCRIPTLET] gpg: depth: 0  valid:   1  signed:  22  trust: 0-, 0q, 0n, 0m, 0f, 1u
[2023-11-29T11:19:00+0900] [ALPM-SCRIPTLET] gpg: depth: 1  valid:  22  signed:  95  trust: 0-, 0q, 0n, 22m, 0f, 0u
[2023-11-29T11:19:00+0900] [ALPM-SCRIPTLET] gpg: depth: 2  valid:  73  signed:  27  trust: 73-, 0q, 0n, 0m, 0f, 0u
[2023-11-29T11:19:00+0900] [ALPM-SCRIPTLET] gpg: next trustdb check due at 2023-12-31
[2023-11-29T11:19:00+0900] [ALPM] transaction completed
[2023-11-29T11:19:00+0900] [ALPM] running '30-systemd-daemon-reload.hook'...
[2023-11-29T11:19:01+0900] [ALPM] running '30-systemd-update.hook'...
[2023-11-29T11:19:01+0900] [PACMAN] starting full system upgrade
[2023-11-29T11:34:53+0900] [ALPM] running '00-timeshift-autosnap.hook'...
[2023-11-29T11:34:53+0900] [ALPM-SCRIPTLET] ==> skipping timeshift-autosnap due skipRsyncAutosnap in /etc/timeshift-autosnap.conf set to TRUE.
[2023-11-29T11:34:53+0900] [ALPM] running '60-mkinitcpio-remove.hook'...
[2023-11-29T11:34:53+0900] [ALPM] running 'firefox-pre.hook'...
[2023-11-29T11:34:53+0900] [ALPM] running 'thunderbird-pre.hook'...
[2023-11-29T11:34:53+0900] [ALPM] transaction started
[2023-11-29T11:34:53+0900] [ALPM] removed kwindowsystem (5.110.0-1)
[2023-11-29T11:34:53+0900] [ALPM] removed kitemmodels (5.110.0-1)
[2023-11-29T11:34:53+0900] [ALPM] removed kauth (5.110.0-1)
[2023-11-29T11:34:53+0900] [ALPM] removed kcoreaddons (5.110.0-1)
[2023-11-29T11:34:53+0900] [ALPM] removed amtk (5.6.1-2)
[2023-11-29T11:34:53+0900] [ALPM] upgraded iana-etc (20230907-1 -> 20231117-1)
[2023-11-29T11:34:53+0900] [ALPM] upgraded filesystem (2023.09.03-1 -> 2023.09.22-1)
[2023-11-29T11:34:53+0900] [ALPM] upgraded glibc (2.38-3 -> 2.38-7)
[2023-11-29T11:34:53+0900] [ALPM-SCRIPTLET] Generating locales...
[2023-11-29T11:34:54+0900] [ALPM-SCRIPTLET]   en_US.UTF-8... done
[2023-11-29T11:34:55+0900] [ALPM-SCRIPTLET]   ko_KR.UTF-8... done
[2023-11-29T11:34:56+0900] [ALPM-SCRIPTLET]   en_US.UTF-8... done
[2023-11-29T11:34:56+0900] [ALPM-SCRIPTLET] Generation complete.
[2023-11-29T11:34:56+0900] [ALPM] upgraded abseil-cpp (20230125.3-3 -> 20230802.1-1)
[2023-11-29T11:34:56+0900] [ALPM] upgraded adwaita-cursors (44.0-1 -> 45.0-1)
[2023-11-29T11:34:56+0900] [ALPM] upgraded zlib (1:1.3-1 -> 1:1.3-2)
[2023-11-29T11:34:56+0900] [ALPM] upgraded util-linux-libs (2.39.2-1 -> 2.39.2-2)
[2023-11-29T11:34:56+0900] [ALPM] upgraded libsysprof-capture (3.48.0-4 -> 45.1-1)
[2023-11-29T11:34:56+0900] [ALPM] upgraded bashrc-manjaro (5.1.016-3 -> 5.2.015-1)
[2023-11-29T11:34:56+0900] [ALPM] upgraded bash (5.1.016-3 -> 5.2.015-1)
[2023-11-29T11:34:56+0900] [ALPM] upgraded glib2 (2.78.0-2 -> 2.78.1-1)
[2023-11-29T11:34:56+0900] [ALPM] upgraded libx11 (1.8.6-1 -> 1.8.7-1)
[2023-11-29T11:34:56+0900] [ALPM] upgraded brotli (1.0.9-12 -> 1.1.0-1)
[2023-11-29T11:34:56+0900] [ALPM] upgraded harfbuzz (8.2.0-1 -> 8.3.0-1)
[2023-11-29T11:34:56+0900] [ALPM] upgraded cairo (1.17.8-2 -> 1.18.0-1)
[2023-11-29T11:34:56+0900] [ALPM] upgraded xz (5.4.4-1 -> 5.4.5-1)
[2023-11-29T11:34:56+0900] [ALPM] upgraded libxml2 (2.11.5-1 -> 2.12.0-1.0)
[2023-11-29T11:34:56+0900] [ALPM] upgraded pango (1:1.50.14-1 -> 1:1.51.1-1)
[2023-11-29T11:34:56+0900] [ALPM] upgraded libjpeg-turbo (3.0.0-1 -> 3.0.1-1)
[2023-11-29T11:34:56+0900] [ALPM] upgraded shared-mime-info (2.2+13+ga2ffb28-1 -> 2.4-1)
[2023-11-29T11:34:56+0900] [ALPM] upgraded gtk-update-icon-cache (1:4.12.1-1 -> 1:4.12.4-1)
[2023-11-29T11:34:56+0900] [ALPM] upgraded adwaita-icon-theme (44.0-1 -> 45.0-1)
[2023-11-29T11:34:56+0900] [ALPM] upgraded protobuf (24.2-1 -> 25.1-1)
[2023-11-29T11:34:56+0900] [ALPM] upgraded openssl (3.1.2-1 -> 3.1.4-1)
[2023-11-29T11:34:56+0900] [ALPM] upgraded libldap (2.6.6-1 -> 2.6.6-2)
[2023-11-29T11:34:56+0900] [ALPM] upgraded krb5 (1.20.1-1 -> 1.20.1-2)
[2023-11-29T11:34:56+0900] [ALPM] upgraded libtirpc (1.3.3-2 -> 1.3.4-1)
[2023-11-29T11:34:56+0900] [ALPM] upgraded pambase (20221020-1 -> 20230918-1)
[2023-11-29T11:34:56+0900] [ALPM] upgraded libcap (2.69-1 -> 2.69-2)
[2023-11-29T11:34:56+0900] [ALPM] upgraded libgcrypt (1.10.2-1 -> 1.10.3-1)
[2023-11-29T11:34:56+0900] [ALPM] upgraded systemd-libs (254.3-1 -> 254.6-2)
[2023-11-29T11:34:56+0900] [ALPM] upgraded iptables (1:1.8.9-1 -> 1:1.8.10-1)
[2023-11-29T11:34:56+0900] [ALPM] upgraded kbd (2.6.2-1 -> 2.6.3-1)
[2023-11-29T11:34:56+0900] [ALPM] upgraded kmod (30-3 -> 31-1)
[2023-11-29T11:34:56+0900] [ALPM] upgraded hwdata (0.374-1 -> 0.376-1)
[2023-11-29T11:34:56+0900] [ALPM] upgraded libnghttp2 (1.56.0-1 -> 1.58.0-1)
[2023-11-29T11:34:56+0900] [ALPM] upgraded coreutils (9.3-1 -> 9.4-2)
[2023-11-29T11:34:56+0900] [ALPM] upgraded libp11-kit (0.25.0-1 -> 0.25.3-1)
[2023-11-29T11:34:56+0900] [ALPM] upgraded p11-kit (0.25.0-1 -> 0.25.3-1)
[2023-11-29T11:34:56+0900] [ALPM] upgraded ca-certificates-mozilla (3.93-1 -> 3.95-1)
[2023-11-29T11:34:56+0900] [ALPM] upgraded curl (8.3.0-1 -> 8.4.0-2)
[2023-11-29T11:34:56+0900] [ALPM] upgraded libelf (0.189-3 -> 0.190-1)
[2023-11-29T11:34:56+0900] [ALPM] upgraded shadow (4.13-3 -> 4.14.2-1)
[2023-11-29T11:34:56+0900] [ALPM] upgraded libutempter (1.2.1-3 -> 1.2.1-4)
[2023-11-29T11:34:56+0900] [ALPM] upgraded util-linux (2.39.2-1 -> 2.39.2-2)
[2023-11-29T11:34:57+0900] [ALPM] upgraded systemd (254.3-1 -> 254.6-2)
[2023-11-29T11:34:57+0900] [ALPM-SCRIPTLET] Creating group 'groups' with GID 961.
[2023-11-29T11:34:57+0900] [ALPM] upgraded android-udev (20230614-1 -> 20231104-1)
[2023-11-29T11:34:57+0900] [ALPM] upgraded android-tools (34.0.4-1 -> 34.0.4-3)
[2023-11-29T11:34:58+0900] [ALPM] upgraded appstream (0.16.3-1 -> 1.0.0-4)
[2023-11-29T11:34:58+0900] [ALPM] upgraded archlinux-appstream-data (20230827-2 -> 20231010-1)
[2023-11-29T11:34:58+0900] [ALPM] upgraded gsettings-desktop-schemas (44.0-1 -> 45.0-1)
[2023-11-29T11:34:58+0900] [ALPM] upgraded at-spi2-core (2.48.4-1 -> 2.50.0-1)
[2023-11-29T11:34:58+0900] [ALPM] upgraded avahi (1:0.8+r127+g55d783d-1 -> 1:0.8+r139+ge5b0bad-1)
[2023-11-29T11:34:58+0900] [ALPM] upgraded blas (3.11.0-2 -> 3.11.0-3)
[2023-11-29T11:34:58+0900] [ALPM] upgraded libical (3.0.16-5 -> 3.0.17-1)
[2023-11-29T11:34:58+0900] [ALPM] upgraded bluez (5.69-1 -> 5.70-1)
[2023-11-29T11:34:58+0900] [ALPM] upgraded bluez-libs (5.69-1 -> 5.70-1)
[2023-11-29T11:34:58+0900] [ALPM] upgraded sqlite (3.43.1-1 -> 3.44.0-1)
[2023-11-29T11:34:58+0900] [ALPM] upgraded botan (3.1.1-1 -> 3.2.0-1)
[2023-11-29T11:34:58+0900] [ALPM] upgraded box2d (2.4.1-1 -> 2.4.1-2)
[2023-11-29T11:34:58+0900] [ALPM] upgraded btrfs-progs (6.5.1-1 -> 6.6.2-1)
[2023-11-29T11:34:58+0900] [ALPM] upgraded libsigc++ (2.12.0-1 -> 2.12.1-1)
[2023-11-29T11:34:58+0900] [ALPM] upgraded cairomm (1.14.4-1 -> 1.14.5-1)
[2023-11-29T11:34:58+0900] [ALPM] upgraded cpupower (6.3-5 -> 6.5-1)
[2023-11-29T11:34:58+0900] [ALPM] upgraded cronie (1.6.1-1 -> 1.7.0-4)
[2023-11-29T11:34:58+0900] [ALPM] upgraded gnutls (3.8.1-1 -> 3.8.2-1)
[2023-11-29T11:34:58+0900] [ALPM] upgraded libcups (1:2.4.6-1 -> 1:2.4.7-2)
[2023-11-29T11:34:58+0900] [ALPM] upgraded qpdf (11.6.1-1 -> 11.6.3-1)
[2023-11-29T11:34:58+0900] [ALPM] upgraded nss (3.93-1 -> 3.95-1)
[2023-11-29T11:34:58+0900] [ALPM] upgraded libsecret (0.21.0-1 -> 0.21.1-1)
[2023-11-29T11:34:58+0900] [ALPM] upgraded pinentry (1.2.1-1 -> 1.2.1-3)
[2023-11-29T11:34:58+0900] [ALPM] upgraded gpgme (1.22.0-1 -> 1.23.1-1)
[2023-11-29T11:34:58+0900] [ALPM] upgraded poppler (23.08.0-1 -> 23.10.0-1)
[2023-11-29T11:34:58+0900] [ALPM] installed libcupsfilters (2.0.0-1)
[2023-11-29T11:34:58+0900] [ALPM] installed libppd (2.0.0-1)
[2023-11-29T11:34:58+0900] [ALPM] upgraded cups-filters (1.28.17-4 -> 2.0.0-1)
[2023-11-29T11:34:58+0900] [ALPM] upgraded libpaper (2.1.1-1 -> 2.1.2-1)
[2023-11-29T11:34:59+0900] [ALPM] upgraded cups (1:2.4.6-1 -> 1:2.4.7-2)
[2023-11-29T11:34:59+0900] [ALPM] upgraded dav1d (1.2.1-1 -> 1.3.0-1)
[2023-11-29T11:34:59+0900] [ALPM] upgraded desktop-file-utils (0.26-2 -> 0.27-1)
[2023-11-29T11:34:59+0900] [ALPM] upgraded dhcpcd (10.0.2-1 -> 10.0.5-1)
[2023-11-29T11:34:59+0900] [ALPM] upgraded enchant (2.5.0-1 -> 2.6.2-1)
[2023-11-29T11:34:59+0900] [ALPM] upgraded libunwind (1.6.2-2 -> 1.7.2-1)
[2023-11-29T11:34:59+0900] [ALPM] upgraded gstreamer (1.22.5-2 -> 1.22.7-1)
[2023-11-29T11:34:59+0900] [ALPM] upgraded libdrm (2.4.116-1 -> 2.4.118-1)
[2023-11-29T11:34:59+0900] [ALPM] upgraded vulkan-icd-loader (1.3.263-1 -> 1.3.269-1)
[2023-11-29T11:34:59+0900] [ALPM] upgraded mesa (23.1.7-1 -> 1:23.1.9-1)
[2023-11-29T11:34:59+0900] [ALPM] upgraded libglvnd (1.6.0-1 -> 1.7.0-1)
[2023-11-29T11:34:59+0900] [ALPM] upgraded gst-plugins-base-libs (1.22.5-2 -> 1.22.7-1)
[2023-11-29T11:34:59+0900] [ALPM] upgraded fuse-common (3.16.1-1 -> 3.16.2-1)
[2023-11-29T11:34:59+0900] [ALPM] upgraded fuse3 (3.16.1-1 -> 3.16.2-1)
[2023-11-29T11:34:59+0900] [ALPM] upgraded glib-networking (1:2.76.1-1 -> 1:2.78.0-1)
[2023-11-29T11:34:59+0900] [ALPM] upgraded libsoup3 (3.4.2-1 -> 3.4.4-1)
[2023-11-29T11:34:59+0900] [ALPM] installed libnvme (1.6-2)
[2023-11-29T11:34:59+0900] [ALPM] upgraded libblockdev (2.28-4 -> 3.0.4-1)
[2023-11-29T11:34:59+0900] [ALPM] upgraded thin-provisioning-tools (1.0.6-1 -> 1.0.7-1)
[2023-11-29T11:34:59+0900] [ALPM] upgraded udisks2 (2.9.4-4 -> 2.10.1-2)
[2023-11-29T11:34:59+0900] [ALPM] upgraded openssh (9.4p1-4 -> 9.5p1-1)
[2023-11-29T11:34:59+0900] [ALPM] upgraded xkeyboard-config (2.39-1 -> 2.40-1)
[2023-11-29T11:34:59+0900] [ALPM] upgraded libxkbcommon (1.5.0-1 -> 1.6.0-1)
[2023-11-29T11:34:59+0900] [ALPM] upgraded libcloudproviders (0.3.4-1 -> 0.3.5-1)
[2023-11-29T11:34:59+0900] [ALPM] upgraded libxrandr (1.5.3-1 -> 1.5.4-1)
[2023-11-29T11:34:59+0900] [ALPM] upgraded json-glib (1.6.6-2 -> 1.8.0-1)
[2023-11-29T11:35:00+0900] [ALPM] upgraded tracker3 (3.5.3-2 -> 3.6.0-1)
[2023-11-29T11:35:00+0900] [ALPM] upgraded gvfs (1.50.6-1 -> 1.52.1-1)
[2023-11-29T11:35:00+0900] [ALPM] upgraded poppler-glib (23.08.0-1 -> 23.10.0-1)
[2023-11-29T11:35:00+0900] [ALPM] upgraded jbig2dec (0.19-1 -> 0.20-1)
[2023-11-29T11:35:00+0900] [ALPM] upgraded ghostscript (10.02.0-1 -> 10.02.1-1)
[2023-11-29T11:35:00+0900] [ALPM] upgraded evince (44.3-1 -> 45.0-1)
[2023-11-29T11:35:00+0900] [ALPM] upgraded exfatprogs (1.2.1-1 -> 1.2.2-1)
[2023-11-29T11:35:00+0900] [ALPM] upgraded gettext (0.22-1 -> 0.22.3-1)
[2023-11-29T11:35:00+0900] [ALPM] upgraded exiv2 (0.28.0-3 -> 0.28.1-1)
[2023-11-29T11:35:00+0900] [ALPM] upgraded fakeroot (1.32.1-1 -> 1.32.2-1)
[2023-11-29T11:35:00+0900] [ALPM] installed libunibreak (5.1-1)
[2023-11-29T11:35:00+0900] [ALPM] upgraded libass (0.17.1-1 -> 0.17.1-2)
[2023-11-29T11:35:00+0900] [ALPM] upgraded rav1e (0.6.6-1 -> 0.6.6-3)
[2023-11-29T11:35:00+0900] [ALPM] upgraded libvpx (1.13.0-1 -> 1.13.1-1)
[2023-11-29T11:35:00+0900] [ALPM] upgraded x264 (3:0.164.r3095.baee400-4 -> 3:0.164.r3108.31e19f9-1)
[2023-11-29T11:35:00+0900] [ALPM] installed onevpl (2023.3.1-1)
[2023-11-29T11:35:00+0900] [ALPM] upgraded sdl2 (2.28.3-1 -> 2.28.5-1)
[2023-11-29T11:35:00+0900] [ALPM] upgraded mpg123 (1.31.3-1 -> 1.32.3-1)
[2023-11-29T11:35:00+0900] [ALPM] upgraded libsndfile (1.2.2-1 -> 1.2.2-2)
[2023-11-29T11:35:00+0900] [ALPM] upgraded libdeflate (1.18-1 -> 1.19-1)
[2023-11-29T11:35:00+0900] [ALPM] upgraded openexr (3.2.0-2 -> 3.2.1-1)
[2023-11-29T11:35:00+0900] [ALPM] upgraded gperftools (2.12-1 -> 2.13-2)
[2023-11-29T11:35:01+0900] [ALPM] upgraded ffmpeg (2:6.0-10 -> 2:6.1-1)
[2023-11-29T11:35:01+0900] [ALPM] upgraded ffmpeg4.4 (4.4.4-1 -> 4.4.4-3)
[2023-11-29T11:35:01+0900] [ALPM] upgraded noto-fonts (1:23.9.1-1 -> 1:23.11.1-1)
[2023-11-29T11:35:02+0900] [ALPM] upgraded firefox (117.0.1-1 -> 120.0-1)
[2023-11-29T11:35:02+0900] [ALPM] upgraded libmalcontent (0.11.1-2 -> 0.11.1-3)
[2023-11-29T11:35:02+0900] [ALPM] upgraded libsodium (1.0.18-2 -> 1.0.19-2)
[2023-11-29T11:35:02+0900] [ALPM] upgraded ostree (2023.6-3 -> 2023.7-1)
[2023-11-29T11:35:02+0900] [ALPM] upgraded libnsl (2.0.0-3 -> 2.0.1-1)
[2023-11-29T11:35:03+0900] [ALPM] upgraded python (3.11.5-2 -> 3.11.6-1)
[2023-11-29T11:35:03+0900] [ALPM] upgraded libpipewire (1:0.3.80-1 -> 1:0.3.85-1)
[2023-11-29T11:35:03+0900] [ALPM] upgraded pipewire (1:0.3.80-1 -> 1:0.3.85-1)
[2023-11-29T11:35:03+0900] [ALPM] upgraded libmm-glib (1.20.6-2 -> 1.22.0-1)
[2023-11-29T11:35:03+0900] [ALPM] upgraded xdg-desktop-portal (1.16.0-3 -> 1.18.1-1)
[2023-11-29T11:35:03+0900] [ALPM] upgraded flatpak (1:1.15.4-1 -> 1:1.15.6-1)
[2023-11-29T11:35:03+0900] [ALPM] upgraded fluidsynth (2.3.3-1 -> 2.3.4-1)
[2023-11-29T11:35:04+0900] [ALPM] upgraded foomatic-db-gutenprint-ppds (5.3.4-2 -> 5.3.4-3)
[2023-11-29T11:35:04+0900] [ALPM] upgraded python-cairo (1.24.0-1 -> 1.25.1-1)
[2023-11-29T11:35:04+0900] [ALPM] upgraded python-packaging (23.1-1 -> 23.2-1)
[2023-11-29T11:35:04+0900] [ALPM] upgraded libgirepository (1.78.0-1 -> 1.78.1-1)
[2023-11-29T11:35:04+0900] [ALPM] upgraded gobject-introspection-runtime (1.78.0-1 -> 1.78.1-1)
[2023-11-29T11:35:04+0900] [ALPM] upgraded python-nbxmpp (4.3.3-1 -> 4.5.2-1)
[2023-11-29T11:35:04+0900] [ALPM] upgraded python-cffi (1.15.1-4 -> 1.16.0-1)
[2023-11-29T11:35:04+0900] [ALPM] upgraded python-cryptography (41.0.3-1 -> 41.0.5-1)
[2023-11-29T11:35:04+0900] [ALPM] upgraded libimagequant (4.2.1-1 -> 4.2.2-2)
[2023-11-29T11:35:04+0900] [ALPM] upgraded python-pillow (10.0.0-2 -> 10.1.0-2)
[2023-11-29T11:35:04+0900] [ALPM] upgraded python-protobuf (24.2-1 -> 25.1-1)
[2023-11-29T11:35:04+0900] [ALPM] upgraded python-omemo-dr (1.0.0-1 -> 1.0.1-1)
[2023-11-29T11:35:04+0900] [ALPM] upgraded python-zipp (3.16.2-1 -> 3.17.0-1)
[2023-11-29T11:35:04+0900] [ALPM] upgraded python-typing_extensions (4.7.1-1 -> 4.8.0-1)
[2023-11-29T11:35:04+0900] [ALPM] upgraded python-pypng (0.0.21-4 -> 0.20231004.0-1)
[2023-11-29T11:35:04+0900] [ALPM] upgraded gajim (1.8.1-1 -> 1.8.3-1)
[2023-11-29T11:35:04+0900] [ALPM] upgraded gawk (5.2.2-1 -> 5.3.0-1)
[2023-11-29T11:35:04+0900] [ALPM] installed libgedit-amtk (5.8.0-1)
[2023-11-29T11:35:04+0900] [ALPM] upgraded libpeas (1.36.0-2 -> 1.36.0-4)
[2023-11-29T11:35:04+0900] [ALPM] installed libgedit-gtksourceview (299.0.4-2)
[2023-11-29T11:35:04+0900] [ALPM] upgraded tepl (1:6.4.0-4 -> 1:6.8.0-1)
[2023-11-29T11:35:04+0900] [ALPM] upgraded gedit (44.2-2 -> 46.1-1)
[2023-11-29T11:35:04+0900] [ALPM] upgraded libde265 (1.0.12-1 -> 1.0.14-1)
[2023-11-29T11:35:04+0900] [ALPM] upgraded libheif (1.16.2-1 -> 1.17.3-1)
[2023-11-29T11:35:04+0900] [ALPM] upgraded libxpm (3.5.16-1 -> 3.5.17-1)
[2023-11-29T11:35:04+0900] [ALPM] upgraded luajit (2.1.1694285958-1 -> 2.1.1700008891-1)
[2023-11-29T11:35:04+0900] [ALPM] upgraded lapack (3.11.0-2 -> 3.11.0-3)
[2023-11-29T11:35:05+0900] [ALPM] upgraded suitesparse (7.1.0-2 -> 7.3.1-1)
[2023-11-29T11:35:06+0900] [ALPM] upgraded gimp (2.10.34-3 -> 2.10.36-1)
[2023-11-29T11:35:06+0900] [ALPM] upgraded git (2.42.0-1 -> 2.43.0-1)
[2023-11-29T11:35:06+0900] [ALPM] upgraded glslang (12.3.1-2 -> 13.0.0-1)
[2023-11-29T11:35:06+0900] [ALPM] installed grub-update (2.12rc1.r49.ge58b870ff-2)
[2023-11-29T11:35:06+0900] [ALPM-SCRIPTLET] :: Install your bootloader and generate configuration:
[2023-11-29T11:35:06+0900] [ALPM-SCRIPTLET]      UEFI: https://wiki.archlinux.org/title/GRUB#Installation
[2023-11-29T11:35:06+0900] [ALPM-SCRIPTLET]      BIOS: https://wiki.archlinux.org/title/GRUB#Installation_2
[2023-11-29T11:35:06+0900] [ALPM] upgraded grub (2.06.r499.ge67a551a4-4 -> 2.12rc1.r49.ge58b870ff-2)
[2023-11-29T11:35:06+0900] [ALPM] upgraded gssdp (1.6.2-1 -> 1.6.3-1)
[2023-11-29T11:35:06+0900] [ALPM] upgraded gssproxy (0.9.1-2 -> 0.9.2-1)
[2023-11-29T11:35:06+0900] [ALPM] upgraded gst-libav (1.22.5-2 -> 1.22.7-1)
[2023-11-29T11:35:06+0900] [ALPM] upgraded libxkbcommon-x11 (1.5.0-1 -> 1.6.0-1)
[2023-11-29T11:35:06+0900] [ALPM] upgraded gupnp (1:1.6.5-1 -> 1:1.6.6-1)
[2023-11-29T11:35:06+0900] [ALPM] upgraded gst-plugins-bad-libs (1.22.5-2 -> 1.22.7-1)
[2023-11-29T11:35:06+0900] [ALPM] upgraded gst-plugin-gtk (1.22.5-2 -> 1.22.7-1)
[2023-11-29T11:35:06+0900] [ALPM] upgraded libxslt (1.1.38-1 -> 1.1.39-1)
[2023-11-29T11:35:06+0900] [ALPM] upgraded serd (0.30.16-1 -> 0.32.0-1)
[2023-11-29T11:35:06+0900] [ALPM] upgraded tar (1.35-1 -> 1.35-2)
[2023-11-29T11:35:06+0900] [ALPM] upgraded imagemagick (7.1.1.15-4 -> 7.1.1.21-1)
[2023-11-29T11:35:06+0900] [ALPM] upgraded gst-plugins-bad (1.22.5-2 -> 1.22.7-1)
[2023-11-29T11:35:06+0900] [ALPM] upgraded gst-plugins-base (1.22.5-2 -> 1.22.7-1)
[2023-11-29T11:35:06+0900] [ALPM] upgraded procps-ng (4.0.4-1.2 -> 4.0.4-2)
[2023-11-29T11:35:06+0900] [ALPM] upgraded imlib2 (1.12.0-1 -> 1.12.1-1)
[2023-11-29T11:35:06+0900] [ALPM] upgraded gst-plugins-good (1.22.5-2 -> 1.22.7-1)
[2023-11-29T11:35:06+0900] [ALPM] upgraded gst-plugins-ugly (1.22.5-2 -> 1.22.7-1)
[2023-11-29T11:35:06+0900] [ALPM] upgraded harfbuzz-icu (8.2.0-1 -> 8.3.0-1)
[2023-11-29T11:35:06+0900] [ALPM] upgraded libyuv (r2322+3aebf69d-1 -> r2426+464c51a0-1)
[2023-11-29T11:35:06+0900] [ALPM] upgraded libavif (1.0.1-1 -> 1.0.2-1)
[2023-11-29T11:35:07+0900] [ALPM] upgraded webkit2gtk (2.40.5-2 -> 2.42.2-1)
[2023-11-29T11:35:07+0900] [ALPM] upgraded gthumb (3.12.3-1 -> 3.12.4-1)
[2023-11-29T11:35:07+0900] [ALPM] upgraded gtk4 (1:4.12.1-1 -> 1:4.12.4-1)
[2023-11-29T11:35:07+0900] [ALPM] upgraded gufw (22.04-2 -> 24.04-1)
[2023-11-29T11:35:07+0900] [ALPM] upgraded gutenprint (5.3.4-2 -> 5.3.4-3)
[2023-11-29T11:35:07+0900] [ALPM-SCRIPTLET] >>please run /usr/bin/cups-genppdupdate
[2023-11-29T11:35:07+0900] [ALPM-SCRIPTLET] >>and restart cups daemon
[2023-11-29T11:35:07+0900] [ALPM] upgraded gvfs-afc (1.50.6-1 -> 1.52.1-1)
[2023-11-29T11:35:07+0900] [ALPM] upgraded gvfs-gphoto2 (1.50.6-1 -> 1.52.1-1)
[2023-11-29T11:35:07+0900] [ALPM] upgraded gvfs-mtp (1.50.6-1 -> 1.52.1-1)
[2023-11-29T11:35:07+0900] [ALPM] upgraded gvfs-nfs (1.50.6-1 -> 1.52.1-1)
[2023-11-29T11:35:07+0900] [ALPM] upgraded libwbclient (4.19.0-1 -> 4.19.2-1)
[2023-11-29T11:35:07+0900] [ALPM] upgraded smbclient (4.19.0-1 -> 4.19.2-1)
[2023-11-29T11:35:07+0900] [ALPM] upgraded gvfs-smb (1.50.6-1 -> 1.52.1-1)
[2023-11-29T11:35:07+0900] [ALPM] upgraded inetutils (2.4-1 -> 2.4-2)
[2023-11-29T11:35:07+0900] [ALPM] upgraded intel-ucode (20230808-1 -> 20231114-1)
[2023-11-29T11:35:07+0900] [ALPM] upgraded inxi (3.3.29.1-1 -> 3.3.31.2-1)
[2023-11-29T11:35:07+0900] [ALPM] upgraded iproute2 (6.5.0-1 -> 6.6.0-2)
[2023-11-29T11:35:07+0900] [ALPM] upgraded qt5-translations (5.15.10-1 -> 5.15.11-1)
[2023-11-29T11:35:07+0900] [ALPM] upgraded qt5-base (5.15.10+kde+r155-1 -> 5.15.11+kde+r146-1)
[2023-11-29T11:35:07+0900] [ALPM] installed kcoreaddons5 (5.112.0-1)
[2023-11-29T11:35:07+0900] [ALPM] upgraded polkit-qt5 (0.114.0-1 -> 0.175.0-1)
[2023-11-29T11:35:07+0900] [ALPM] installed kauth5 (5.112.0-1)
[2023-11-29T11:35:07+0900] [ALPM] installed kitemmodels5 (5.112.0-1)
[2023-11-29T11:35:07+0900] [ALPM] upgraded qt5-x11extras (5.15.10-1 -> 5.15.11-1)
[2023-11-29T11:35:07+0900] [ALPM] installed kwindowsystem5 (5.112.0-1)
[2023-11-29T11:35:07+0900] [ALPM] upgraded qt5-svg (5.15.10+kde+r8-1 -> 5.15.11+kde+r6-1)
[2023-11-29T11:35:07+0900] [ALPM] upgraded kvantum (1.0.10-1 -> 1.0.10-2)
[2023-11-29T11:35:07+0900] [ALPM] upgraded kvantum-theme-matcha (20190810-1 -> 20190810-3)
[2023-11-29T11:35:07+0900] [ALPM] upgraded lib32-glibc (2.38-3 -> 2.38-7)
[2023-11-29T11:35:07+0900] [ALPM] upgraded lib32-brotli (1.0.9-12 -> 1.1.0-1)
[2023-11-29T11:35:07+0900] [ALPM] upgraded lib32-glib2 (2.78.0-2 -> 2.78.1-1)
[2023-11-29T11:35:07+0900] [ALPM] upgraded lib32-libx11 (1.8.6-1 -> 1.8.7-1)
[2023-11-29T11:35:07+0900] [ALPM] upgraded lib32-harfbuzz (8.2.0-1 -> 8.3.0-1)
[2023-11-29T11:35:07+0900] [ALPM] upgraded lib32-cairo (1.17.8-2 -> 1.18.0-1)
[2023-11-29T11:35:07+0900] [ALPM] upgraded lib32-openssl (1:3.1.2-1 -> 1:3.1.4-1)
[2023-11-29T11:35:07+0900] [ALPM] upgraded lib32-curl (8.3.0-1 -> 8.4.0-2)
[2023-11-29T11:35:07+0900] [ALPM] upgraded libdecor (0.1.1-2 -> 0.2.0-1)
[2023-11-29T11:35:07+0900] [ALPM] upgraded lib32-pango (1:1.50.14-1 -> 1:1.51.1-1)
[2023-11-29T11:35:07+0900] [ALPM] upgraded lib32-xz (5.4.4-1 -> 5.4.5-1)
[2023-11-29T11:35:07+0900] [ALPM] upgraded lib32-libxml2 (2.11.5-1 -> 2.12.0-1.0)
[2023-11-29T11:35:07+0900] [ALPM] installed lib32-libxtst (1.2.4-1)
[2023-11-29T11:35:07+0900] [ALPM] upgraded lib32-libgcrypt (1.10.2-1 -> 1.10.3-1)
[2023-11-29T11:35:07+0900] [ALPM] upgraded lib32-libtirpc (1.3.3-2 -> 1.3.4-1)
[2023-11-29T11:35:07+0900] [ALPM] upgraded lib32-systemd (254.3-1 -> 254.6-1)
[2023-11-29T11:35:07+0900] [ALPM] installed lib32-at-spi2-core (2.50.0-1)
[2023-11-29T11:35:07+0900] [ALPM] installed lib32-libjpeg-turbo (3.0.1-1)
[2023-11-29T11:35:07+0900] [ALPM] installed lib32-libtiff (4.6.0-1)
[2023-11-29T11:35:07+0900] [ALPM] installed lib32-lcms2 (2.15-1)
[2023-11-29T11:35:07+0900] [ALPM] installed lib32-colord (1.4.6-1)
[2023-11-29T11:35:07+0900] [ALPM] installed lib32-gdk-pixbuf2 (2.42.10-2)
[2023-11-29T11:35:07+0900] [ALPM] installed lib32-libogg (1.3.5-1)
[2023-11-29T11:35:07+0900] [ALPM] installed lib32-libvorbis (1.3.7-1)
[2023-11-29T11:35:07+0900] [ALPM] installed lib32-libltdl (2.4.7-3)
[2023-11-29T11:35:07+0900] [ALPM] installed lib32-alsa-lib (1.2.10-2)
[2023-11-29T11:35:07+0900] [ALPM] installed lib32-libasyncns (1:0.8+r3+g68cd5af-2)
[2023-11-29T11:35:07+0900] [ALPM] installed lib32-opus (1.4-1)
[2023-11-29T11:35:07+0900] [ALPM] installed lib32-flac (1.4.3-1)
[2023-11-29T11:35:07+0900] [ALPM] installed lib32-libsndfile (1.2.2-1)
[2023-11-29T11:35:07+0900] [ALPM] installed lib32-libpulse (16.1-6)
[2023-11-29T11:35:07+0900] [ALPM] installed lib32-tdb (1.4.9-1)
[2023-11-29T11:35:07+0900] [ALPM] installed lib32-libcanberra (1:0.30+r2+gc0620e4-2)
[2023-11-29T11:35:07+0900] [ALPM] installed lib32-gmp (6.3.0-1)
[2023-11-29T11:35:07+0900] [ALPM] installed lib32-nettle (3.9.1-1)
[2023-11-29T11:35:07+0900] [ALPM] installed lib32-libtasn1 (4.19.0-1)
[2023-11-29T11:35:07+0900] [ALPM] installed lib32-p11-kit (0.25.3-1)
[2023-11-29T11:35:07+0900] [ALPM] installed lib32-gnutls (3.8.2-1)
[2023-11-29T11:35:07+0900] [ALPM] installed lib32-libcups (2.4.7-1)
[2023-11-29T11:35:07+0900] [ALPM] installed lib32-libepoxy (1.5.10-1)
[2023-11-29T11:35:07+0900] [ALPM] installed lib32-librsvg (2:2.57.0-1)
[2023-11-29T11:35:08+0900] [ALPM] installed lib32-libxcomposite (0.4.6-1)
[2023-11-29T11:35:08+0900] [ALPM] installed lib32-libxcursor (1.2.1-2)
[2023-11-29T11:35:08+0900] [ALPM] installed lib32-libxinerama (1.1.5-1)
[2023-11-29T11:35:08+0900] [ALPM] upgraded lib32-libxkbcommon (1.5.0-1 -> 1.6.0-1)
[2023-11-29T11:35:08+0900] [ALPM] upgraded lib32-libxrandr (1.5.3-1 -> 1.5.4-1)
[2023-11-29T11:35:08+0900] [ALPM] upgraded lib32-libdrm (2.4.116-1 -> 2.4.117-1)
[2023-11-29T11:35:08+0900] [ALPM] upgraded lib32-libelf (0.189-1 -> 0.190-1)
[2023-11-29T11:35:08+0900] [ALPM] upgraded lib32-libglvnd (1.6.0-1 -> 1.7.0-1)
[2023-11-29T11:35:08+0900] [ALPM] upgraded lib32-libunwind (1.6.2-2 -> 1.7.2-1)
[2023-11-29T11:35:08+0900] [ALPM] upgraded lib32-vulkan-icd-loader (1.3.263-1 -> 1.3.269-1)
[2023-11-29T11:35:08+0900] [ALPM] upgraded lib32-mesa (23.1.7-1 -> 1:23.1.9-1)
[2023-11-29T11:35:08+0900] [ALPM] installed lib32-gtk3 (1:3.24.38-1)
[2023-11-29T11:35:08+0900] [ALPM] upgraded lib32-libdecor (0.1.1-1 -> 0.2.0-1)
[2023-11-29T11:35:08+0900] [ALPM] upgraded lib32-libva (2.19.0-2 -> 2.20.0-1)
[2023-11-29T11:35:08+0900] [ALPM] upgraded lib32-libva-mesa-driver (23.1.7-1 -> 1:23.1.9-1)
[2023-11-29T11:35:08+0900] [ALPM] upgraded lib32-libxkbcommon-x11 (1.5.0-1 -> 1.6.0-1)
[2023-11-29T11:35:08+0900] [ALPM] upgraded libadwaita (1:1.3.5-1 -> 1:1.4.0-2)
[2023-11-29T11:35:08+0900] [ALPM] upgraded libdbusmenu-glib (16.04.0.r498-1 -> 16.04.0.r498-2)
[2023-11-29T11:35:08+0900] [ALPM] upgraded libdbusmenu-gtk3 (16.04.0.r498-1 -> 16.04.0.r498-2)
[2023-11-29T11:35:08+0900] [ALPM] upgraded libappindicator-gtk3 (12.10.0.r298-2 -> 12.10.0.r298-3)
[2023-11-29T11:35:08+0900] [ALPM] upgraded libcue (2.2.1-3 -> 2.3.0-1)
[2023-11-29T11:35:08+0900] [ALPM] upgraded libdnet (1.16.4-1 -> 1.17.0-1)
[2023-11-29T11:35:08+0900] [ALPM] upgraded libgsf (1.14.50-1 -> 1.14.51-1)
[2023-11-29T11:35:08+0900] [ALPM] upgraded libgtop (2.41.1-1 -> 2.41.2-1)
[2023-11-29T11:35:08+0900] [ALPM] upgraded libgusb (0.4.6-1 -> 0.4.8-1)
[2023-11-29T11:35:08+0900] [ALPM] upgraded libixion (0.18.1-3 -> 0.19.0-1)
[2023-11-29T11:35:08+0900] [ALPM] upgraded libmbim (1.28.4-1 -> 1.30.0-1)
[2023-11-29T11:35:08+0900] [ALPM] upgraded libnm (1.44.0-1 -> 1.44.2-3)
[2023-11-29T11:35:08+0900] [ALPM] upgraded libnotify (0.8.2-1 -> 0.8.3-1)
[2023-11-29T11:35:08+0900] [ALPM] upgraded liborcus (0.18.1-3 -> 0.19.2-1)
[2023-11-29T11:35:08+0900] [ALPM] installed python-charset-normalizer (3.3.2-1)
[2023-11-29T11:35:08+0900] [ALPM] upgraded python-urllib3 (1.26.15-1 -> 1.26.18-1)
[2023-11-29T11:35:08+0900] [ALPM] upgraded python-requests (2.28.2-4 -> 2.31.0-1)
[2023-11-29T11:35:08+0900] [ALPM] upgraded pacman-mirrors (4.23.2+3+g4148c3d-1 -> 4.24.1-1)
[2023-11-29T11:35:08+0900] [ALPM] upgraded pacman (6.0.2-13 -> 6.0.2-14)
[2023-11-29T11:35:08+0900] [ALPM] upgraded libpamac (11.6.2+6+ge74fe0e-1 -> 11.6.2+6+ge74fe0e-4)
[2023-11-29T11:35:08+0900] [ALPM] upgraded libpamac-flatpak-plugin (11.6.2+6+ge74fe0e-1 -> 11.6.2+6+ge74fe0e-4)
[2023-11-29T11:35:10+0900] [ALPM] upgraded snapd (2.60.3-1 -> 2.61-1)
[2023-11-29T11:35:10+0900] [ALPM] upgraded qt5-declarative (5.15.10+kde+r31-1 -> 5.15.11+kde+r32-1)
[2023-11-29T11:35:10+0900] [ALPM] upgraded libpamac-snap-plugin (11.6.2+6+ge74fe0e-1 -> 11.6.2+6+ge74fe0e-4)
[2023-11-29T11:35:10+0900] [ALPM] upgraded shaderc (2023.4-1 -> 2023.5-1)
[2023-11-29T11:35:10+0900] [ALPM] installed libdovi (3.2.0-2)
[2023-11-29T11:35:10+0900] [ALPM] upgraded libplacebo (5.264.1-2 -> 5.264.1-4)
[2023-11-29T11:35:10+0900] [ALPM] upgraded libqmi (1.32.4-1 -> 1.34.0-1)
[2023-11-29T11:35:11+0900] [ALPM] upgraded libreoffice-still (7.5.6-1 -> 7.5.8-1)
[2023-11-29T11:35:11+0900] [ALPM] upgraded libva-mesa-driver (23.1.7-1 -> 1:23.1.9-1)
[2023-11-29T11:35:11+0900] [ALPM] upgraded licenses (20230903-1 -> 20231011-1)
[2023-11-29T11:35:11+0900] [ALPM] upgraded linux-firmware-whence (20230810.7be2766d-1 -> 20231030.2b304bfe-1)
[2023-11-29T11:35:12+0900] [ALPM] upgraded linux-firmware (20230810.7be2766d-1 -> 20231030.2b304bfe-1)
[2023-11-29T11:35:12+0900] [ALPM] upgraded mkinitcpio (36-6 -> 37-1)
[2023-11-29T11:35:13+0900] [ALPM] upgraded linux61 (6.1.53-1 -> 6.1.63-1)
[2023-11-29T11:35:13+0900] [ALPM] upgraded lua (5.4.6-1 -> 5.4.6-2)
[2023-11-29T11:35:13+0900] [ALPM] upgraded lua52 (5.2.4-5 -> 5.2.4-6)
[2023-11-29T11:35:13+0900] [ALPM] upgraded man-db (2.11.2-1 -> 2.12.0-1)
[2023-11-29T11:35:13+0900] [ALPM] upgraded man-pages (6.05.01-1 -> 6.05.01-2)
[2023-11-29T11:35:13+0900] [ALPM] upgraded manjaro-browser-settings (20220522-1 -> 20231111-1)
[2023-11-29T11:35:13+0900] [ALPM] upgraded manjaro-release (23.0.2-1 -> 23.1.0-1)
[2023-11-29T11:35:13+0900] [ALPM] upgraded perl-uri (5.20-1 -> 5.21-1)
[2023-11-29T11:35:13+0900] [ALPM] installed perl-http-cookiejar (0.014-1)
[2023-11-29T11:35:13+0900] [ALPM] upgraded perl-http-message (6.44-2 -> 6.45-1)
[2023-11-29T11:35:13+0900] [ALPM] upgraded perl-libwww (6.67-2 -> 6.72-1)
[2023-11-29T11:35:13+0900] [ALPM] upgraded manjaro-settings-manager (0.5.7-16 -> 0.5.7-18)
[2023-11-29T11:35:13+0900] [ALPM] upgraded manjaro-settings-manager-notifier (0.5.7-16 -> 0.5.7-18)
[2023-11-29T11:35:13+0900] [ALPM] upgraded matcha-gtk-theme (20230403-2 -> 20231030-2)
[2023-11-29T11:35:13+0900] [ALPM-SCRIPTLET]
[2023-11-29T11:35:13+0900] [ALPM-SCRIPTLET] To force Libadwaita appliations to use the gtk-4.0 theme,
[2023-11-29T11:35:13+0900] [ALPM-SCRIPTLET] symlink the gtk-4.0 theme to config folder
[2023-11-29T11:35:13+0900] [ALPM-SCRIPTLET] (replace Matcha-dark-sea with chosen theme variant):
[2023-11-29T11:35:13+0900] [ALPM-SCRIPTLET] mkdir -p ~/.config/gtk-4.0/
[2023-11-29T11:35:13+0900] [ALPM-SCRIPTLET] ln -sf /usr/share/themes/Matcha-dark-sea/gtk-4.0/{assets,gtk.css,gtk-dark.css} ~/.config/gtk-4.0/
[2023-11-29T11:35:13+0900] [ALPM] upgraded qt5ct (1.7-1 -> 1.8-1)
[2023-11-29T11:35:17+0900] [ALPM] upgraded papirus-icon-theme (20230901-1 -> 20231101-1)
[2023-11-29T11:35:17+0900] [ALPM] upgraded manjaro-xfce-settings (20220616-2 -> 20231011-1)
[2023-11-29T11:35:17+0900] [ALPM] upgraded mesa-demos (9.0.0-2 -> 9.0.0-3)
[2023-11-29T11:35:17+0900] [ALPM] upgraded mhwd-nvidia (535.104.05-1 -> 535.129.03-2)
[2023-11-29T11:35:17+0900] [ALPM] upgraded mhwd-nvidia-390xx (390.157-8 -> 390.157-9)
[2023-11-29T11:35:17+0900] [ALPM] upgraded mhwd-nvidia-470xx (470.199.02-3 -> 470.223.02-1)
[2023-11-29T11:35:17+0900] [ALPM] upgraded mhwd-db (0.6.5-27 -> 0.6.5-28)
[2023-11-29T11:35:17+0900] [ALPM] upgraded mhwd (0.6.5-27 -> 0.6.5-28)
[2023-11-29T11:35:17+0900] [ALPM] upgraded modemmanager (1.20.6-2 -> 1.22.0-1)
[2023-11-29T11:35:17+0900] [ALPM] upgraded zeromq (4.3.4-4 -> 4.3.5-2)
[2023-11-29T11:35:17+0900] [ALPM] upgraded networkmanager (1.44.0-1 -> 1.44.2-3)
[2023-11-29T11:35:17+0900] [ALPM] upgraded nm-connection-editor (1.32.0-3 -> 1.34.0-1)
[2023-11-29T11:35:17+0900] [ALPM] upgraded network-manager-applet (1.32.0-3 -> 1.34.0-1)
[2023-11-29T11:35:17+0900] [ALPM] upgraded nfsidmap (2.6.3-1 -> 2.6.4-1)
[2023-11-29T11:35:17+0900] [ALPM] upgraded nfs-utils (2.6.3-1 -> 2.6.4-1)
[2023-11-29T11:35:17+0900] [ALPM] upgraded nftables (1:1.0.8-2 -> 1:1.0.9-1)
[2023-11-29T11:35:17+0900] [ALPM] upgraded open-vm-tools (6:12.3.0-1 -> 6:12.3.5-1)
[2023-11-29T11:35:17+0900] [ALPM] upgraded openvpn (2.6.6-1 -> 2.6.8-1)
[2023-11-29T11:35:17+0900] [ALPM] upgraded p7zip (1:17.05-1 -> 1:17.05-2)
[2023-11-29T11:35:17+0900] [ALPM] upgraded pamac-gtk (11.6.0-1 -> 11.6.0+2+g5ac9b28-1)
[2023-11-29T11:35:17+0900] [ALPM] installed python-wrapt (1.14.1-2)
[2023-11-29T11:35:17+0900] [ALPM] installed python-deprecated (1.2.14-1)
[2023-11-29T11:35:17+0900] [ALPM] installed cblas (3.11.0-3)
[2023-11-29T11:35:17+0900] [ALPM] installed python-numpy (1.26.1-1)
[2023-11-29T11:35:17+0900] [ALPM] upgraded python-pikepdf (8.4.1-1 -> 8.7.1-1)
[2023-11-29T11:35:17+0900] [ALPM] upgraded pdfarranger (1.10.0-1 -> 1.10.1-1)
[2023-11-29T11:35:17+0900] [ALPM] upgraded protobuf-c (1.4.1-3 -> 1.4.1-5)
[2023-11-29T11:35:17+0900] [ALPM] upgraded vulkan-headers (1:1.3.264-2 -> 1:1.3.269-1)
[2023-11-29T11:35:17+0900] [ALPM] upgraded xcb-util-cursor (0.1.4-1 -> 0.1.5-1)
[2023-11-29T11:35:17+0900] [ALPM] upgraded qt6-translations (6.5.2-1 -> 6.6.0-1)
[2023-11-29T11:35:17+0900] [ALPM] upgraded qt6-base (6.5.2-1 -> 6.6.0-3)
[2023-11-29T11:35:17+0900] [ALPM] upgraded qt6-declarative (6.5.2-2 -> 6.6.0-1)
[2023-11-29T11:35:17+0900] [ALPM] upgraded shiboken6 (6.5.2-2 -> 6.6.0-3)
[2023-11-29T11:35:18+0900] [ALPM] upgraded pyside6 (6.5.2-2 -> 6.6.0-3)
[2023-11-29T11:35:18+0900] [ALPM] upgraded python-certifi (2023.07.22-1 -> 2023.11.17-1)
[2023-11-29T11:35:18+0900] [ALPM] upgraded python-fastjsonschema (2.18.0-1 -> 2.19.0-1)
[2023-11-29T11:35:18+0900] [ALPM] installed python-annotated-types (0.6.0-1)
[2023-11-29T11:35:18+0900] [ALPM] installed python-pydantic-core (1:2.10.1-1)
[2023-11-29T11:35:18+0900] [ALPM] upgraded python-pydantic (1.10.9-1 -> 2.4.2-1)
[2023-11-29T11:35:18+0900] [ALPM] upgraded python-inflect (7.0.0-1 -> 7.0.0-2)
[2023-11-29T11:35:18+0900] [ALPM] upgraded python-manjaro-sdk (0.9-2 -> 1:0.1.1-1)
[2023-11-29T11:35:18+0900] [ALPM] upgraded python-platformdirs (3.10.0-1 -> 4.0.0-1)
[2023-11-29T11:35:18+0900] [ALPM] upgraded python-psutil (5.9.5-1 -> 5.9.6-1)
[2023-11-29T11:35:18+0900] [ALPM] upgraded python-trove-classifiers (2023.8.7-1 -> 2023.11.14-1)
[2023-11-29T11:35:18+0900] [ALPM] upgraded qt6-svg (6.5.2-1 -> 6.6.0-2)
[2023-11-29T11:35:18+0900] [ALPM] upgraded qbittorrent (4.5.5-1 -> 4.6.1-1)
[2023-11-29T11:35:18+0900] [ALPM] upgraded qemu-guest-agent (8.1.0-2 -> 8.1.2-1)
[2023-11-29T11:35:18+0900] [ALPM] upgraded qt5-imageformats (5.15.10+kde+r9-1 -> 5.15.11+kde+r12-1)
[2023-11-29T11:35:18+0900] [ALPM] upgraded rsync (3.2.7-4 -> 3.2.7-6)
[2023-11-29T11:35:18+0900] [ALPM] upgraded samba (4.19.0-1 -> 4.19.2-1)
[2023-11-29T11:35:18+0900] [ALPM] upgraded sof-firmware (2.2.6-1 -> 2023.09.2-1)
[2023-11-29T11:35:18+0900] [ALPM] upgraded sudo (1.9.14.p3-1 -> 1.9.15.p2-1)
[2023-11-29T11:35:18+0900] [ALPM] upgraded systemd-sysvcompat (254.3-1 -> 254.6-2)
[2023-11-29T11:35:18+0900] [ALPM] upgraded texinfo (7.0.3-1 -> 7.1-2)
[2023-11-29T11:35:18+0900] [ALPM] upgraded xfconf (4.18.1-2 -> 4.18.3-1)
[2023-11-29T11:35:18+0900] [ALPM] upgraded thunar (4.18.7-1 -> 4.18.8-1)
[2023-11-29T11:35:18+0900] [ALPM] upgraded thunar-archive-plugin (0.5.1-1 -> 0.5.2-1)
[2023-11-29T11:35:18+0900] [ALPM] upgraded thunderbird (115.2.2-1 -> 115.5.0-1)
[2023-11-29T11:35:18+0900] [ALPM] upgraded usbutils (015-3 -> 017-1)
[2023-11-29T11:35:18+0900] [ALPM] upgraded tlp (1.6.0-1 -> 1.6.1-1)
[2023-11-29T11:35:20+0900] [ALPM] upgraded ttf-noto-nerd (3.0.2-1 -> 3.1.0-1)
[2023-11-29T11:35:20+0900] [ALPM] upgraded udiskie (2.4.2-2 -> 2.5.0-1)
[2023-11-29T11:35:20+0900] [ALPM] upgraded unrar (1:6.2.10-1 -> 1:6.2.12-1)
[2023-11-29T11:35:20+0900] [ALPM] upgraded unzip (6.0-19 -> 6.0-20)
[2023-11-29T11:35:20+0900] [ALPM] upgraded virtualbox-guest-utils (7.0.10-2 -> 7.0.12-1)
[2023-11-29T11:35:20+0900] [ALPM] upgraded vlc (3.0.18-15 -> 3.0.20-2)
[2023-11-29T11:35:20+0900] [ALPM] upgraded vte-common (0.72.2-2 -> 0.74.1-1)
[2023-11-29T11:35:20+0900] [ALPM] upgraded vte3 (0.72.2-2 -> 0.74.1-1)
[2023-11-29T11:35:20+0900] [ALPM] upgraded webkit2gtk-4.1 (2.40.5-2 -> 2.42.2-1)
[2023-11-29T11:35:20+0900] [ALPM] upgraded xapp (2.6.1-2 -> 2.8.0-1)
[2023-11-29T11:35:20+0900] [ALPM] upgraded xdg-desktop-portal-gtk (1.14.1-1 -> 1.15.1-1)
[2023-11-29T11:35:20+0900] [ALPM] upgraded xfce4-panel (4.18.4-1 -> 4.18.5-1)
[2023-11-29T11:35:20+0900] [ALPM] upgraded xfce4-clipman-plugin (1.6.4-1 -> 1.6.5-1)
[2023-11-29T11:35:20+0900] [ALPM] upgraded xfce4-dict (0.8.5-1 -> 0.8.6-1)
[2023-11-29T11:35:20+0900] [ALPM] upgraded xfce4-notifyd (0.8.2-1 -> 0.9.3-1)
[2023-11-29T11:35:20+0900] [ALPM] upgraded xfce4-pulseaudio-plugin (0.4.7-1 -> 0.4.8-1)
[2023-11-29T11:35:20+0900] [ALPM] upgraded xfce4-taskmanager (1.5.5-1 -> 1.5.6-2)
[2023-11-29T11:35:20+0900] [ALPM] upgraded xfce4-terminal (1.1.0-1 -> 1.1.1-2)
[2023-11-29T11:35:20+0900] [ALPM] upgraded xfce4-whiskermenu-plugin (2.8.0-1 -> 2.8.1-1)
[2023-11-29T11:35:20+0900] [ALPM] upgraded xfsprogs (6.4.0-1 -> 6.5.0-1)
[2023-11-29T11:35:20+0900] [ALPM] upgraded xfwm4 (4.18.0-1 -> 4.18.0-2)
[2023-11-29T11:35:20+0900] [ALPM] upgraded xorg-server-common (21.1.8-2 -> 21.1.9-1)
[2023-11-29T11:35:20+0900] [ALPM] upgraded xorg-server (21.1.8-2 -> 21.1.9-1)
[2023-11-29T11:35:20+0900] [ALPM] upgraded yt-dlp (2023.07.06-2 -> 2023.11.16-1)
[2023-11-29T11:35:20+0900] [ALPM] upgraded zip (3.0-10 -> 3.0-11)
[2023-11-29T11:35:21+0900] [ALPM] transaction completed
[2023-11-29T11:35:24+0900] [ALPM] running '20-systemd-sysusers.hook'...
[2023-11-29T11:35:24+0900] [ALPM-SCRIPTLET] Creating group '_talkd' with GID 960.
[2023-11-29T11:35:24+0900] [ALPM-SCRIPTLET] Creating user '_talkd' (User for legacy talkd server) with UID 960 and GID 960.
[2023-11-29T11:35:24+0900] [ALPM] running '30-systemd-catalog.hook'...
[2023-11-29T11:35:24+0900] [ALPM] running '30-systemd-daemon-reload.hook'...
[2023-11-29T11:35:24+0900] [ALPM] running '30-systemd-hwdb.hook'...
[2023-11-29T11:35:24+0900] [ALPM] running '30-systemd-sysctl.hook'...
[2023-11-29T11:35:24+0900] [ALPM] running '30-systemd-tmpfiles.hook'...
[2023-11-29T11:35:24+0900] [ALPM] running '30-systemd-udev-reload.hook'...
[2023-11-29T11:35:25+0900] [ALPM] running '30-systemd-update.hook'...
[2023-11-29T11:35:25+0900] [ALPM] running '30-update-mime-database.hook'...
[2023-11-29T11:35:25+0900] [ALPM] running '40-update-ca-trust.hook'...
[2023-11-29T11:35:26+0900] [ALPM] running '60-depmod.hook'...
[2023-11-29T11:35:27+0900] [ALPM] running '80-cronie.hook'...
[2023-11-29T11:35:27+0900] [ALPM] running '90-mkinitcpio-install.hook'...
[2023-11-29T11:35:27+0900] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux61.preset: 'default'
[2023-11-29T11:35:27+0900] [ALPM-SCRIPTLET] ==> Using default configuration file: '/etc/mkinitcpio.conf'
[2023-11-29T11:35:27+0900] [ALPM-SCRIPTLET]   -> -k /boot/vmlinuz-6.1-x86_64 -g /boot/initramfs-6.1-x86_64.img --microcode /boot/intel-ucode.img
[2023-11-29T11:35:27+0900] [ALPM-SCRIPTLET] ==> Starting build: '6.1.63-1-MANJARO'
[2023-11-29T11:35:27+0900] [ALPM-SCRIPTLET]   -> Running build hook: [base]
[2023-11-29T11:35:27+0900] [ALPM-SCRIPTLET]   -> Running build hook: [udev]
[2023-11-29T11:35:27+0900] [ALPM-SCRIPTLET]   -> Running build hook: [autodetect]
[2023-11-29T11:35:28+0900] [ALPM-SCRIPTLET]   -> Running build hook: [modconf]
[2023-11-29T11:35:28+0900] [ALPM-SCRIPTLET]   -> Running build hook: [block]
[2023-11-29T11:35:28+0900] [ALPM-SCRIPTLET]   -> Running build hook: [keyboard]
[2023-11-29T11:35:28+0900] [ALPM-SCRIPTLET]   -> Running build hook: [keymap]
[2023-11-29T11:35:28+0900] [ALPM-SCRIPTLET] loadkeys: Unable to open file: ko: No such file or directory
[2023-11-29T11:35:28+0900] [ALPM-SCRIPTLET]   -> Running build hook: [consolefont]
[2023-11-29T11:35:28+0900] [ALPM-SCRIPTLET] ==> WARNING: consolefont: no font found in configuration
[2023-11-29T11:35:28+0900] [ALPM-SCRIPTLET]   -> Running build hook: [plymouth]
[2023-11-29T11:35:28+0900] [ALPM-SCRIPTLET]   -> Running build hook: [filesystems]
[2023-11-29T11:35:28+0900] [ALPM-SCRIPTLET]   -> Running build hook: [fsck]
[2023-11-29T11:35:28+0900] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2023-11-29T11:35:28+0900] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: '/boot/initramfs-6.1-x86_64.img'
[2023-11-29T11:35:30+0900] [ALPM-SCRIPTLET] ==> Image generation successful
[2023-11-29T11:35:30+0900] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux61.preset: 'fallback'
[2023-11-29T11:35:30+0900] [ALPM-SCRIPTLET] ==> Using default configuration file: '/etc/mkinitcpio.conf'
[2023-11-29T11:35:30+0900] [ALPM-SCRIPTLET]   -> -k /boot/vmlinuz-6.1-x86_64 -g /boot/initramfs-6.1-x86_64-fallback.img -S autodetect --microcode /boot/intel-ucode.img
[2023-11-29T11:35:30+0900] [ALPM-SCRIPTLET] ==> Starting build: '6.1.63-1-MANJARO'
[2023-11-29T11:35:30+0900] [ALPM-SCRIPTLET]   -> Running build hook: [base]
[2023-11-29T11:35:30+0900] [ALPM-SCRIPTLET]   -> Running build hook: [udev]
[2023-11-29T11:35:30+0900] [ALPM-SCRIPTLET]   -> Running build hook: [modconf]
[2023-11-29T11:35:30+0900] [ALPM-SCRIPTLET]   -> Running build hook: [block]
[2023-11-29T11:35:30+0900] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'qla1280'
[2023-11-29T11:35:30+0900] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'qla2xxx'
[2023-11-29T11:35:30+0900] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'qed'
[2023-11-29T11:35:30+0900] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'wd719x'
[2023-11-29T11:35:30+0900] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'aic94xx'
[2023-11-29T11:35:30+0900] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'bfa'
[2023-11-29T11:35:31+0900] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'xhci_pci'
[2023-11-29T11:35:31+0900] [ALPM-SCRIPTLET]   -> Running build hook: [keyboard]
[2023-11-29T11:35:32+0900] [ALPM-SCRIPTLET]   -> Running build hook: [keymap]
[2023-11-29T11:35:32+0900] [ALPM-SCRIPTLET] loadkeys: Unable to open file: ko: No such file or directory
[2023-11-29T11:35:32+0900] [ALPM-SCRIPTLET]   -> Running build hook: [consolefont]
[2023-11-29T11:35:32+0900] [ALPM-SCRIPTLET] ==> WARNING: consolefont: no font found in configuration
[2023-11-29T11:35:32+0900] [ALPM-SCRIPTLET]   -> Running build hook: [plymouth]
[2023-11-29T11:35:32+0900] [ALPM-SCRIPTLET]   -> Running build hook: [filesystems]
[2023-11-29T11:35:33+0900] [ALPM-SCRIPTLET]   -> Running build hook: [fsck]
[2023-11-29T11:35:34+0900] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2023-11-29T11:35:34+0900] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: '/boot/initramfs-6.1-x86_64-fallback.img'
[2023-11-29T11:35:39+0900] [ALPM-SCRIPTLET] ==> Image generation successful
[2023-11-29T11:35:39+0900] [ALPM] running '90-update-appstream-cache.hook'...
[2023-11-29T11:35:39+0900] [ALPM-SCRIPTLET] ✔ Metadata cache was updated successfully.
[2023-11-29T11:35:39+0900] [ALPM] running '99-grub.hook'...
[2023-11-29T11:35:39+0900] [ALPM-SCRIPTLET] Generating grub configuration file ...
[2023-11-29T11:35:39+0900] [ALPM-SCRIPTLET] Found theme: /usr/share/grub/themes/manjaro/theme.txt
[2023-11-29T11:35:40+0900] [ALPM-SCRIPTLET] Found linux image: /boot/vmlinuz-6.1-x86_64
[2023-11-29T11:35:40+0900] [ALPM-SCRIPTLET] Found initrd image: /boot/intel-ucode.img /boot/initramfs-6.1-x86_64.img
[2023-11-29T11:35:40+0900] [ALPM-SCRIPTLET] Found initrd fallback image: /boot/initramfs-6.1-x86_64-fallback.img
[2023-11-29T11:35:40+0900] [ALPM-SCRIPTLET] Warning: os-prober will be executed to detect other bootable partitions.
[2023-11-29T11:35:40+0900] [ALPM-SCRIPTLET] Its output will be used to detect bootable binaries on them and create new boot entries.
[2023-11-29T11:35:40+0900] [ALPM-SCRIPTLET] Adding boot menu entry for UEFI Firmware Settings ...
[2023-11-29T11:35:40+0900] [ALPM-SCRIPTLET] Root filesystem isn't btrfs
[2023-11-29T11:35:40+0900] [ALPM-SCRIPTLET] If you think an error has occurred, please file a bug report at "https://github.com/Antynea/grub-btrfs"
[2023-11-29T11:35:40+0900] [ALPM-SCRIPTLET] Found memtest86+ image: /boot/memtest86+/memtest.bin
[2023-11-29T11:35:40+0900] [ALPM-SCRIPTLET] Found memtest86+ EFI image: /boot/memtest86+/memtest.efi
[2023-11-29T11:35:40+0900] [ALPM-SCRIPTLET] done
[2023-11-29T11:35:40+0900] [ALPM] running 'dbus-reload.hook'...
[2023-11-29T11:35:40+0900] [ALPM] running 'detect-old-perl-modules.hook'...
[2023-11-29T11:35:40+0900] [ALPM] running 'firefox-post.hook'...
[2023-11-29T11:35:40+0900] [ALPM] running 'fontconfig.hook'...
[2023-11-29T11:35:40+0900] [ALPM] running 'fontconfig-32.hook'...
[2023-11-29T11:35:41+0900] [ALPM] running 'gdk-pixbuf-query-loaders.hook'...
[2023-11-29T11:35:41+0900] [ALPM] running 'gdk-pixbuf-query-loaders-32.hook'...
[2023-11-29T11:35:41+0900] [ALPM] running 'gio-querymodules.hook'...
[2023-11-29T11:35:41+0900] [ALPM] running 'glib-compile-schemas.hook'...
[2023-11-29T11:35:41+0900] [ALPM] running 'gtk-query-immodules-3.0-32.hook'...
[2023-11-29T11:35:41+0900] [ALPM] running 'gtk-update-icon-cache.hook'...
[2023-11-29T11:35:44+0900] [ALPM] running 'gtk4-querymodules.hook'...
[2023-11-29T11:35:44+0900] [ALPM] running 'gvfsd.hook'...
[2023-11-29T11:35:44+0900] [ALPM] running 'manjaro-printer.hook'...
[2023-11-29T11:35:44+0900] [ALPM] running 'networkmanager-connectivity.hook'...
[2023-11-29T11:35:44+0900] [ALPM] running 'pacman-mirrors-upgrade.hook'...
[2023-11-29T11:35:49+0900] [ALPM-SCRIPTLET] ::e[1;37mINFOe[1;m Downloading mirrors from Manjaro
[2023-11-29T11:35:49+0900] [ALPM-SCRIPTLET] ::e[1;37mINFOe[1;m => Mirror pool: https://repo.manjaro.org/mirrors.json
[2023-11-29T11:35:49+0900] [ALPM-SCRIPTLET] ::e[1;37mINFOe[1;m => Mirror status: https://repo.manjaro.org/status.json
[2023-11-29T11:35:49+0900] [ALPM-SCRIPTLET] hint: use `pacman-mirrors` to generate and update your pacman mirrorlist.
[2023-11-29T11:35:49+0900] [ALPM] running 'texinfo-install.hook'...
[2023-11-29T11:35:50+0900] [ALPM] running 'thunderbird-post.hook'...
[2023-11-29T11:35:50+0900] [ALPM] running 'update-desktop-database.hook'...
[2023-11-29T11:35:50+0900] [ALPM] running 'update-vlc-plugin-cache.hook'...
[2023-11-29T11:35:50+0900] [ALPM] running 'xorg-mkfontscale.hook'...
[2023-11-29T12:53:56+0900] [PACMAN] Running 'pacman -Sy'
[2023-11-29T12:53:56+0900] [PACMAN] synchronizing package lists
[2023-11-29T12:53:59+0900] [PACMAN] Running 'pacman -S linux66'
[2023-11-29T12:54:47+0900] [ALPM] transaction started
[2023-11-29T12:54:48+0900] [ALPM] installed linux66 (6.6.2-1)
[2023-11-29T12:54:48+0900] [ALPM] transaction completed
[2023-11-29T12:54:48+0900] [ALPM] running '30-systemd-update.hook'...
[2023-11-29T12:54:48+0900] [ALPM] running '60-depmod.hook'...
[2023-11-29T12:54:49+0900] [ALPM] running '90-mkinitcpio-install.hook'...
[2023-11-29T12:54:49+0900] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux66.preset: 'default'
[2023-11-29T12:54:49+0900] [ALPM-SCRIPTLET] ==> Using default configuration file: '/etc/mkinitcpio.conf'
[2023-11-29T12:54:49+0900] [ALPM-SCRIPTLET]   -> -k /boot/vmlinuz-6.6-x86_64 -g /boot/initramfs-6.6-x86_64.img --microcode /boot/intel-ucode.img
[2023-11-29T12:54:49+0900] [ALPM-SCRIPTLET] ==> Starting build: '6.6.2-1-MANJARO'
[2023-11-29T12:54:49+0900] [ALPM-SCRIPTLET]   -> Running build hook: [base]
[2023-11-29T12:54:50+0900] [ALPM-SCRIPTLET]   -> Running build hook: [udev]
[2023-11-29T12:54:50+0900] [ALPM-SCRIPTLET]   -> Running build hook: [autodetect]
[2023-11-29T12:54:50+0900] [ALPM-SCRIPTLET]   -> Running build hook: [modconf]
[2023-11-29T12:54:50+0900] [ALPM-SCRIPTLET]   -> Running build hook: [block]
[2023-11-29T12:54:50+0900] [ALPM-SCRIPTLET]   -> Running build hook: [keyboard]
[2023-11-29T12:54:50+0900] [ALPM-SCRIPTLET]   -> Running build hook: [keymap]
[2023-11-29T12:54:50+0900] [ALPM-SCRIPTLET] loadkeys: Unable to open file: ko: No such file or directory
[2023-11-29T12:54:50+0900] [ALPM-SCRIPTLET]   -> Running build hook: [consolefont]
[2023-11-29T12:54:50+0900] [ALPM-SCRIPTLET] ==> WARNING: consolefont: no font found in configuration
[2023-11-29T12:54:50+0900] [ALPM-SCRIPTLET]   -> Running build hook: [plymouth]
[2023-11-29T12:54:50+0900] [ALPM-SCRIPTLET]   -> Running build hook: [filesystems]
[2023-11-29T12:54:50+0900] [ALPM-SCRIPTLET]   -> Running build hook: [fsck]
[2023-11-29T12:54:51+0900] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2023-11-29T12:54:51+0900] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: '/boot/initramfs-6.6-x86_64.img'
[2023-11-29T12:54:52+0900] [ALPM-SCRIPTLET] ==> Image generation successful
[2023-11-29T12:54:52+0900] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux66.preset: 'fallback'
[2023-11-29T12:54:52+0900] [ALPM-SCRIPTLET] ==> Using default configuration file: '/etc/mkinitcpio.conf'
[2023-11-29T12:54:52+0900] [ALPM-SCRIPTLET]   -> -k /boot/vmlinuz-6.6-x86_64 -g /boot/initramfs-6.6-x86_64-fallback.img -S autodetect --microcode /boot/intel-ucode.img
[2023-11-29T12:54:52+0900] [ALPM-SCRIPTLET] ==> Starting build: '6.6.2-1-MANJARO'
[2023-11-29T12:54:52+0900] [ALPM-SCRIPTLET]   -> Running build hook: [base]
[2023-11-29T12:54:52+0900] [ALPM-SCRIPTLET]   -> Running build hook: [udev]
[2023-11-29T12:54:52+0900] [ALPM-SCRIPTLET]   -> Running build hook: [modconf]
[2023-11-29T12:54:52+0900] [ALPM-SCRIPTLET]   -> Running build hook: [block]
[2023-11-29T12:54:52+0900] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'qla1280'
[2023-11-29T12:54:53+0900] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'qla2xxx'
[2023-11-29T12:54:53+0900] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'qed'
[2023-11-29T12:54:53+0900] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'wd719x'
[2023-11-29T12:54:53+0900] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'aic94xx'
[2023-11-29T12:54:53+0900] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'bfa'
[2023-11-29T12:54:53+0900] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'xhci_pci'
[2023-11-29T12:54:54+0900] [ALPM-SCRIPTLET]   -> Running build hook: [keyboard]
[2023-11-29T12:54:54+0900] [ALPM-SCRIPTLET]   -> Running build hook: [keymap]
[2023-11-29T12:54:54+0900] [ALPM-SCRIPTLET] loadkeys: Unable to open file: ko: No such file or directory
[2023-11-29T12:54:54+0900] [ALPM-SCRIPTLET]   -> Running build hook: [consolefont]
[2023-11-29T12:54:54+0900] [ALPM-SCRIPTLET] ==> WARNING: consolefont: no font found in configuration
[2023-11-29T12:54:54+0900] [ALPM-SCRIPTLET]   -> Running build hook: [plymouth]
[2023-11-29T12:54:54+0900] [ALPM-SCRIPTLET]   -> Running build hook: [filesystems]
[2023-11-29T12:54:55+0900] [ALPM-SCRIPTLET]   -> Running build hook: [fsck]
[2023-11-29T12:54:56+0900] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2023-11-29T12:54:56+0900] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: '/boot/initramfs-6.6-x86_64-fallback.img'
[2023-11-29T12:55:02+0900] [ALPM-SCRIPTLET] ==> Image generation successful
[2023-11-29T12:55:02+0900] [ALPM] running '99-grub.hook'...
[2023-11-29T12:55:02+0900] [ALPM-SCRIPTLET] Generating grub configuration file ...
[2023-11-29T12:55:02+0900] [ALPM-SCRIPTLET] Found theme: /usr/share/grub/themes/manjaro/theme.txt
[2023-11-29T12:55:02+0900] [ALPM-SCRIPTLET] Found linux image: /boot/vmlinuz-6.6-x86_64
[2023-11-29T12:55:02+0900] [ALPM-SCRIPTLET] Found initrd image: /boot/intel-ucode.img /boot/initramfs-6.6-x86_64.img
[2023-11-29T12:55:02+0900] [ALPM-SCRIPTLET] Found initrd fallback image: /boot/initramfs-6.6-x86_64-fallback.img
[2023-11-29T12:55:02+0900] [ALPM-SCRIPTLET] Found linux image: /boot/vmlinuz-6.1-x86_64
[2023-11-29T12:55:02+0900] [ALPM-SCRIPTLET] Found initrd image: /boot/intel-ucode.img /boot/initramfs-6.1-x86_64.img
[2023-11-29T12:55:02+0900] [ALPM-SCRIPTLET] Found initrd fallback image: /boot/initramfs-6.1-x86_64-fallback.img
[2023-11-29T12:55:02+0900] [ALPM-SCRIPTLET] Warning: os-prober will be executed to detect other bootable partitions.
[2023-11-29T12:55:02+0900] [ALPM-SCRIPTLET] Its output will be used to detect bootable binaries on them and create new boot entries.
[2023-11-29T12:55:03+0900] [ALPM-SCRIPTLET] Adding boot menu entry for UEFI Firmware Settings ...
[2023-11-29T12:55:03+0900] [ALPM-SCRIPTLET] Root filesystem isn't btrfs
[2023-11-29T12:55:03+0900] [ALPM-SCRIPTLET] If you think an error has occurred, please file a bug report at "https://github.com/Antynea/grub-btrfs"
[2023-11-29T12:55:03+0900] [ALPM-SCRIPTLET] Found memtest86+ image: /boot/memtest86+/memtest.bin
[2023-11-29T12:55:03+0900] [ALPM-SCRIPTLET] Found memtest86+ EFI image: /boot/memtest86+/memtest.efi
[2023-11-29T12:55:03+0900] [ALPM-SCRIPTLET] done
ADDED LATER:
Summary: Upgrading VMware Workstation Pro from 17.0.2 to 17.5.0 solved no problem and only created an new one.
More detailed: In the replies below, you will see the idea that a later version of VMware may support kernel 6.6. Because I was using an outdated version of VMware, i.e. 17.0.2, when I first encountering the problem (boot hanging at “three dots”), I tried updating it to the current version, i.e. 17.5.0. That solved no problem. It only caused an additional one: my Manjaro VM froze (or at least lost mouse input) after a while (happened two or three times). Maybe installing the new version VMware tools (which came with 17.5.0) could have fixed this new problem. But that would mean installing it into every single VM, and I am not that crazy about using the latest VMware software. I had to uninstall 17.5.0 and reinstall 17.0.2. Just in case anybody is similarly positioned and similarly tempted.
VMware as a platform for running Manjaro is unsupported.
There has been a couple of issues where kernel is not supported by VMware.
Also plymouth may interfere - again a kernel gpu driver issue.
Reboot and choose 6.1 kernel - 6.6 is likely not yet supported by VMware.
Thank you. Does that mean Manjaro does not support VMware? (E.g., the Manjaro team does not check for compatibility with VMware.)
To choose kernel, do I press Esc during boot?
What I’ll do is make 6.1 default > update a VM > see whether “hanging at three dots” happens. That should confirm the “unsupported kernel” hypothesis. Will report back.
It is VMware which makes it unsupported.
VMware is a commercial product - which only supports a short list of operating systems.
https://kb.vmware.com/s/article/80807
https://www.vmware.com/resources/compatibility/search.php?deviceCategory=software
Hello everyone,
I have the same problem with the boot screen hang in new kernel (linux66-6.6.3-1 LTS). The problem is that for me it is after a fresh installation of Manjaro XFCE on my laptop (Dell Latitude E6540). If I manage to press the “Esc” button then the screen with the three dots disappears and Manjaro loads normally. It’s very annoying!!!
A few updates have passed already, but the problem remains…
After reading the advice here about downgrading the kernel everything went fine for now!!!
Please fix this problem!!! However, we want to use newer kernel versions…
Best regards
Don’t be - you hurt your health - you are the only one to suffer from it.
And please remove those useless screenshots …
Hey @jamjar,
I had the same issue with my VM’s, but I use Oracle VirtualBox.
I tried multiple times to update to no avail. At the end I gave up and reverted to previous snapshot - saved all the data, exported it out of the VM’s and went for a clean installation.
I used manjaro-gnome-23.0.4-231015-linux65.iso as the current one, manjaro-gnome-23.1-231201-linux66.iso I had different kind of issues.
The update from 23.0.4 to 23.1 went OK and my VM’s works as expected now.
I changed the default kernel from 6.6.2-1 to 6.1.63-1, and the problem went away. I.e., after I applied the latest update (2023-12-01), the first boot went normally and so did all subsequent boots so far.
For anybody trying to do the same, this is what I did (the “linux-aarhus” method).
  1. Confirm that /etc/default/grub has these two lines (separated by other lines)
GRUB_DEFAULT=saved
GRUB_SAVEDEFAULT=true
This is per How to make a Kernel default? - #3 by linux-aarhus
  1. While the machine is booting, press Esc
  2. See this menu (with Green letters)
Manjaro
  Manjaro Linux
  Advanced Options for Manjaro Linux
  Memory Tester (memtest86+)
Note at this point that some clicking of Esc gave me quite a different menu (which was in gray scale and included “Hard drive”). If you get to this wrong screen, press Esc to get out of it. The screen will turn black again (to continue booting). Press Esc again, and you will probably get to the right menu (in Green letters).
  1. Choose “Advanced Options for Manjaro Linux”
  2. See this menu (yours may look different)
Manjaro Linux (Kernel: 6.6.2-1-MANJARO)
Manjaro Linux (Kernel: 6.1.63-1-MANJAR)
See that there is doubling of each kernel. Also I believe the far right ends may have been cut off.
  1. Choose the 2nd item from the bottom, i.e. the top one of the two 6.1.63-1 items.
  2. See machine boot > see that it has loaded 6.1.63-1
  3. Restart machine > see that it has loaded 6.1.63-1, i.e. that the last chosen kernel has become the new default.
There is an alternative method to linux-aarhus, this from aragorn, found here:
With that I had trouble. After I edit the grub file, ran sudo update-grub, and restarted, the machine went into memory test. (This may not happen immediately, but at some point down the line). Once that happens, every reboot took me into memory test. I never chose memory test from the menu. Because I am working with a virtual machine, I can easily restore myself to an earlier state and repeat the experiment. This obligatory memory test began happening after several restorations. (After one restoration, I believe I never went into the “Esc during boot” menu. All I did was to edit the grub file, and I began getting memory test.)
Conclusion: For the time being, I can avoid this “hanging after an update” issue by using an older kernel per the linux-aarhus method.
Questions:
  1. What is the downside of using an older kernel? For example, will updated packages start not working with an older kernel at some point so that I get stuck with older versions of packages?
  2. As stated in the original post, I can use the new kernel if I apply the “let hang for 10 minutes” trick. Anybody has insight as to how that could make the problem go away (i.e. cause subsequent boots go normal)?
ADDED LATER:
Now that I have made kernel 6.1.63-1 default and done the 2023-12-01 update to several VMs, I noticed that, when I go in that order (i.e. set default kernel and then update), the default kernel after the update may be one of:
  • 6.1.64-1
  • 6.6.3-1
That is, the updating may change default kernel from 6.1 back to 6.6. If that happens, you’d just have to do the “making 6.1 default” sequence again.
None - if you are LTS
Thank you. Is there a list of LTS kernels and their expiration dates (the date support ends)?
In GUI “Manjaro Settings Manager” > Kernel, I can see which kernels are LTS but not their expiration. Internet search didn’t turn up a ready list.
https://kernel.org
I think the LTS window recently changed to a fixed window.
But 6.1 will be maintained by third party for 10 years.
It will likely disappear when VMware supports the 6.6 kernel - which is LTS - so at some point they will.
It may be plymouth - so removing plymouth could possibly remedy the situation.
Is this what you are after?
Version Maintainer Released Projected EOL
6.6 Greg Kroah-Hartman & Sasha Levin 2023-10-29 Dec, 2026
6.1 Greg Kroah-Hartman & Sasha Levin 2022-12-11 Dec, 2026
5.15 Greg Kroah-Hartman & Sasha Levin 2021-10-31 Dec, 2026
5.10 Greg Kroah-Hartman & Sasha Levin 2020-12-13 Dec, 2026
5.4 Greg Kroah-Hartman & Sasha Levin 2019-11-24 Dec, 2025
4.19 Greg Kroah-Hartman & Sasha Levin 2018-10-22 Dec, 2024
4.14 Greg Kroah-Hartman & Sasha Levin 2017-11-12 Jan, 2024
https://www.kernel.org/category/releases.html
Yes. Thank you. So I’m good for some time with 6.1.
Thanks. Does that mean using the “removal” section of this post:
With respect the updates; each of those mentioned may have had at least one issue in need of manual intervention; as would have been indicated in the respective Update Announcements.
It’s arguably not surprising there might be issues with your scenario, whether it be a virtual machine, or hardware; as this often stems from ongoing neglect. I understand, however, that keeping virtual machines regularly updated may not always be high on the priority list (I can attest to that, myself).
Regular use of VMware’s snapshot feature can often help in these situations. Do you use them?
Do you mean that I could have avoided the problem by diligently applying each update when it came out?
Or maybe such diligence would not have sufficed, but I should have tracked down and fixed those issues requiring manual intervention? To find out which issues I had as require intervention, do I have to go through all the update posts, understand each item, and determine whether it applies to me? (I don’t know I have the technical wherewithal.)
Yes. When I know I messed up I go back to an earlier dated snapshot. But I don’t see how a snapshot could help with “neglect” in the above sense. Thanks.
And applying any necessary attention to aforementioned issues, as they may be indicated in the Update Announcements, yes, that’s often the case.
Yes. However, there is usually sufficient information to make that determination, and cleary outlined.
A good practice.
By extrapolation, one could return to a previous snapshot, decide to approach the update differently by reading the Update Notifications and noting potential issues that might cause problems if left unattended.
Then you have an opportunity; a second chance; to ask in the forum for clarification about issues mentioned that you’re unsure about. The whole process then becomes preventative, for the next attempt, rather than being an immediate cure.
My comments were intended as helpful considerations. In this instance, using an LTS kernel saved the day; it was an easy fix this time, but it might not have been. This is why most users will recommend reading the Announcements.
Cheers.
The real fix for the hang was to disable plymouth, per this post: How to remove plymouth? - #14 by jamjar
Reverting to kernel 6.1 was a stopgap and also brought this other problem: Manjaro VMware guest: Copying in Thunar to cifs-mounted Windows locations fails
Yes, Plymouth can sometimes be the culprit, along with many other possibilities.
The correct procedure to remove Plymouth is described in Plymouth (Manjaro Wiki) under the heading of REMOVAL. Cheers.
