Hi, I am new to Linux. I did the following
What image did you test?
Manjaro-Arm-Minimal-rpi-18.06-rc2
What device did you test on?
Raspberry PI 2
Does it boot to a CLI login prompt?
I am not sure. I used ssh to login. So it must have.
Can you login with both root and manjaro users?
I can switch between manjaro and root in ssh
Can you install/update packages?
Yes
I ran the following commands first
sudo resize-sd
sudo pacman -S manjaro-system
sudo pacman-key --populate manjaro-arm
sudo pacman-key --init
sudo pacman-key --populate archlinuxarm
As others I got the following error
==> ERROR: DC3BF5444BD19FD6AA4CFBA46875B841CC37B7EC could not be locally signed.
Updated with sudo pacman -Syu
commands everything went ok but I got the following warnings.
(11/11) checking available disk space [#########################################################] 100%
warning: could not get file information for boot/bcm2709-rpi-2-b.dtb
warning: could not get file information for boot/bcm2710-rpi-3-b-plus.dtb
warning: could not get file information for boot/bcm2710-rpi-3-b.dtb
warning: could not get file information for boot/bcm2710-rpi-cm3.dtb
warning: could not get file information for boot/bcm2836-rpi-2-b.dtb
warning: could not get file information for boot/bcm2837-rpi-3-b.dtb
warning: could not get file information for boot/cmdline.txt
warning: could not get file information for boot/config.txt
warning: could not get file information for boot/kernel7.img
warning: could not get file information for boot/overlays/
warning: could not get file information for boot/overlays/README
warning: could not get file information for boot/overlays/adau1977-adc.dtbo
warning: could not get file information for boot/overlays/adau7002-simple.dtbo
warning: could not get file information for boot/overlays/ads1015.dtbo
warning: could not get file information for boot/overlays/ads1115.dtbo
warning: could not get file information for boot/overlays/ads7846.dtbo
warning: could not get file information for boot/overlays/akkordion-iqdacplus.dtbo
warning: could not get file information for boot/overlays/allo-boss-dac-pcm512x-audio.dtbo
warning: could not get file information for boot/overlays/allo-digione.dtbo
warning: could not get file information for boot/overlays/allo-piano-dac-pcm512x-audio.dtbo
warning: could not get file information for boot/overlays/allo-piano-dac-plus-pcm512x-audio.dtbo
warning: could not get file information for boot/overlays/applepi-dac.dtbo
warning: could not get file information for boot/overlays/at86rf233.dtbo
warning: could not get file information for boot/overlays/audioinjector-addons.dtbo
warning: could not get file information for boot/overlays/audioinjector-wm8731-audio.dtbo
warning: could not get file information for boot/overlays/audremap.dtbo
warning: could not get file information for boot/overlays/bmp085_i2c-sensor.dtbo
warning: could not get file information for boot/overlays/dht11.dtbo
warning: could not get file information for boot/overlays/dionaudio-loco-v2.dtbo
warning: could not get file information for boot/overlays/dionaudio-loco.dtbo
warning: could not get file information for boot/overlays/dpi18.dtbo
warning: could not get file information for boot/overlays/dpi24.dtbo
warning: could not get file information for boot/overlays/dwc-otg.dtbo
warning: could not get file information for boot/overlays/dwc2.dtbo
warning: could not get file information for boot/overlays/enc28j60-spi2.dtbo
warning: could not get file information for boot/overlays/enc28j60.dtbo
warning: could not get file information for boot/overlays/exc3000.dtbo
warning: could not get file information for boot/overlays/fe-pi-audio.dtbo
warning: could not get file information for boot/overlays/goodix.dtbo
warning: could not get file information for boot/overlays/googlevoicehat-soundcard.dtbo
warning: could not get file information for boot/overlays/gpio-ir-tx.dtbo
warning: could not get file information for boot/overlays/gpio-ir.dtbo
warning: could not get file information for boot/overlays/gpio-key.dtbo
warning: could not get file information for boot/overlays/gpio-poweroff.dtbo
warning: could not get file information for boot/overlays/gpio-shutdown.dtbo
warning: could not get file information for boot/overlays/hifiberry-amp.dtbo
warning: could not get file information for boot/overlays/hifiberry-dac.dtbo
warning: could not get file information for boot/overlays/hifiberry-dacplus.dtbo
warning: could not get file information for boot/overlays/hifiberry-digi-pro.dtbo
warning: could not get file information for boot/overlays/hifiberry-digi.dtbo
warning: could not get file information for boot/overlays/hy28a.dtbo
warning: could not get file information for boot/overlays/hy28b.dtbo
warning: could not get file information for boot/overlays/i2c-bcm2708.dtbo
warning: could not get file information for boot/overlays/i2c-gpio.dtbo
warning: could not get file information for boot/overlays/i2c-mux.dtbo
warning: could not get file information for boot/overlays/i2c-pwm-pca9685a.dtbo
warning: could not get file information for boot/overlays/i2c-rtc-gpio.dtbo
warning: could not get file information for boot/overlays/i2c-rtc.dtbo
warning: could not get file information for boot/overlays/i2c-sensor.dtbo
warning: could not get file information for boot/overlays/i2c0-bcm2708.dtbo
warning: could not get file information for boot/overlays/i2c1-bcm2708.dtbo
warning: could not get file information for boot/overlays/i2s-gpio28-31.dtbo
warning: could not get file information for boot/overlays/iqaudio-dac.dtbo
warning: could not get file information for boot/overlays/iqaudio-dacplus.dtbo
warning: could not get file information for boot/overlays/iqaudio-digi-wm8804-audio.dtbo
warning: could not get file information for boot/overlays/justboom-dac.dtbo
warning: could not get file information for boot/overlays/justboom-digi.dtbo
warning: could not get file information for boot/overlays/lirc-rpi.dtbo
warning: could not get file information for boot/overlays/mbed-dac.dtbo
warning: could not get file information for boot/overlays/mcp23017.dtbo
warning: could not get file information for boot/overlays/mcp23s17.dtbo
warning: could not get file information for boot/overlays/mcp2515-can0.dtbo
warning: could not get file information for boot/overlays/mcp2515-can1.dtbo
warning: could not get file information for boot/overlays/mcp3008.dtbo
warning: could not get file information for boot/overlays/mcp3202.dtbo
warning: could not get file information for boot/overlays/media-center.dtbo
warning: could not get file information for boot/overlays/midi-uart0.dtbo
warning: could not get file information for boot/overlays/midi-uart1.dtbo
warning: could not get file information for boot/overlays/mmc.dtbo
warning: could not get file information for boot/overlays/mpu6050.dtbo
warning: could not get file information for boot/overlays/mz61581.dtbo
warning: could not get file information for boot/overlays/papirus.dtbo
warning: could not get file information for boot/overlays/pi3-act-led.dtbo
warning: could not get file information for boot/overlays/pi3-disable-bt.dtbo
warning: could not get file information for boot/overlays/pi3-disable-wifi.dtbo
warning: could not get file information for boot/overlays/pi3-miniuart-bt.dtbo
warning: could not get file information for boot/overlays/pibell.dtbo
warning: could not get file information for boot/overlays/piscreen.dtbo
warning: could not get file information for boot/overlays/piscreen2r.dtbo
warning: could not get file information for boot/overlays/pisound.dtbo
warning: could not get file information for boot/overlays/pitft22.dtbo
warning: could not get file information for boot/overlays/pitft28-capacitive.dtbo
warning: could not get file information for boot/overlays/pitft28-resistive.dtbo
warning: could not get file information for boot/overlays/pitft35-resistive.dtbo
warning: could not get file information for boot/overlays/pps-gpio.dtbo
warning: could not get file information for boot/overlays/pwm-2chan.dtbo
warning: could not get file information for boot/overlays/pwm-ir-tx.dtbo
warning: could not get file information for boot/overlays/pwm.dtbo
warning: could not get file information for boot/overlays/qca7000.dtbo
warning: could not get file information for boot/overlays/rotary-encoder.dtbo
warning: could not get file information for boot/overlays/rpi-backlight.dtbo
warning: could not get file information for boot/overlays/rpi-cirrus-wm5102.dtbo
warning: could not get file information for boot/overlays/rpi-dac.dtbo
warning: could not get file information for boot/overlays/rpi-display.dtbo
warning: could not get file information for boot/overlays/rpi-ft5406.dtbo
warning: could not get file information for boot/overlays/rpi-proto.dtbo
warning: could not get file information for boot/overlays/rpi-sense.dtbo
warning: could not get file information for boot/overlays/rpi-tv.dtbo
warning: could not get file information for boot/overlays/rra-digidac1-wm8741-audio.dtbo
warning: could not get file information for boot/overlays/sc16is750-i2c.dtbo
warning: could not get file information for boot/overlays/sc16is752-i2c.dtbo
warning: could not get file information for boot/overlays/sc16is752-spi1.dtbo
warning: could not get file information for boot/overlays/sdhost.dtbo
warning: could not get file information for boot/overlays/sdio-1bit.dtbo
warning: could not get file information for boot/overlays/sdio.dtbo
warning: could not get file information for boot/overlays/sdtweak.dtbo
warning: could not get file information for boot/overlays/smi-dev.dtbo
warning: could not get file information for boot/overlays/smi-nand.dtbo
warning: could not get file information for boot/overlays/smi.dtbo
warning: could not get file information for boot/overlays/spi-gpio35-39.dtbo
warning: could not get file information for boot/overlays/spi-rtc.dtbo
warning: could not get file information for boot/overlays/spi0-cs.dtbo
warning: could not get file information for boot/overlays/spi0-hw-cs.dtbo
warning: could not get file information for boot/overlays/spi1-1cs.dtbo
warning: could not get file information for boot/overlays/spi1-2cs.dtbo
warning: could not get file information for boot/overlays/spi1-3cs.dtbo
warning: could not get file information for boot/overlays/spi2-1cs.dtbo
warning: could not get file information for boot/overlays/spi2-2cs.dtbo
warning: could not get file information for boot/overlays/spi2-3cs.dtbo
warning: could not get file information for boot/overlays/superaudioboard.dtbo
warning: could not get file information for boot/overlays/sx150x.dtbo
warning: could not get file information for boot/overlays/tinylcd35.dtbo
warning: could not get file information for boot/overlays/uart0.dtbo
warning: could not get file information for boot/overlays/uart1.dtbo
warning: could not get file information for boot/overlays/upstream-aux-interrupt.dtbo
warning: could not get file information for boot/overlays/upstream.dtbo
warning: could not get file information for boot/overlays/vc4-fkms-v3d.dtbo
warning: could not get file information for boot/overlays/vc4-kms-v3d.dtbo
warning: could not get file information for boot/overlays/vga666.dtbo
warning: could not get file information for boot/overlays/w1-gpio-pullup.dtbo
warning: could not get file information for boot/overlays/w1-gpio.dtbo
warning: could not get file information for boot/overlays/wittypi.dtbo
warning: could not get file information for boot/bootcode.bin
warning: could not get file information for boot/fixup.dat
warning: could not get file information for boot/fixup_cd.dat
warning: could not get file information for boot/fixup_db.dat
warning: could not get file information for boot/start.elf
warning: could not get file information for boot/start_cd.elf
warning: could not get file information for boot/start_db.elf
And the following mirrorlist errors
( 9/11) upgrading pacman-mirrorlist [#########################################################] 100%
:: Querying servers, this may take some time...
Denmark
-> 0.462 http://mirror.strits.dk/manjaro-arm/stable/$arch/$repo
-> ..... https://www.uex.dk/public/manjaro-arm/stable/$arch/$repo
Error: Failed to reach the server: [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed (_ssl.c:833)
Switzerland
-> ..... https://mirror.scachemaille.ch/manjaro-arm/stable/$arch/$repo
United_States
-> 0.830 http://ftp-osl.osuosl.org/pub/manjaro-arm/repo/stable/$arch/$repo
:: Generated and saved '/etc/pacman.d/mirrorlist' mirrorlist.
Raspberry pi 2 has no built in wifi. I have wifi dongle connected to it even though I am networking it through ethernet. When I type typed sudo wifi-menu
it asked me to install dialog, and when I did so, its asking me the following. It asked me again when I installed vim. I pressed ānā each time.
[manjaro@manjaro-arm ~]$ sudo pacman -Syu vim
[sudo] password for manjaro:
core is up to date
extra is up to date
community is up to date
:: Replace compositeproto with extra/xorgproto? [Y/n] n
:: Replace dmxproto with extra/xorgproto? [Y/n] n
:: Replace fixesproto with extra/xorgproto? [Y/n] n
:: Replace inputproto with extra/xorgproto? [Y/n] n
:: Replace kbproto with extra/xorgproto? [Y/n] n
:: Replace recordproto with extra/xorgproto? [Y/n] n
:: Replace renderproto with extra/xorgproto? [Y/n] n
:: Replace xextproto with extra/xorgproto? [Y/n] n
:: Replace xf86dgaproto with extra/xorgproto? [Y/n] n
:: Replace xf86vidmodeproto with extra/xorgproto? [Y/n] n
:: Replace xineramaproto with extra/xorgproto? [Y/n] n
:: Replace xproto with extra/xorgproto? [Y/n] n
Btw, I added the image to sd card through etcher. Also Nextcloud is very slow and the links are not resumable. I lost the connection once and had to re download the entire file again.
