I updated my system yesterday where calibre was upgraded to 5.0.1, I can see it changed python version from 2.x -> 3.x. However, something seems to be very broken!
Opening calibre from the terminal gives me this error:
[~] calibre
File "/usr/bin/calibre", line 20, in <module>
sys.exit(calibre())
File "/usr/lib/calibre/calibre/gui_launch.py", line 73, in calibre
main(args)
File "/usr/lib/calibre/calibre/gui2/main.py", line 529, in main
app, opts, args = init_qt(args)
File "/usr/lib/calibre/calibre/gui2/main.py", line 114, in init_qt
app = Application(args, override_program_name=override, windows_app_uid=MAIN_APP_UID)
File "/usr/lib/calibre/calibre/gui2/__init__.py", line 885, in __init__
raise RuntimeError('Failed to load the progress_indicator C extension, with error: {}'.format(pi_err))
RuntimeError: Failed to load the progress_indicator C extension, with error: /home/daniel/.local/lib/python3.8/site-packages/PyQt5/Qt/lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/calibre/calibre/plugins/progress_indicator.so)
I then tried to search fro Qt5 but it looks like it could be a deeper problem, anyone who could help me out here?
[~] pip3 search qt5
File "/usr/bin/pip3", line 33, in <module>
sys.exit(load_entry_point('pip==20.1.1', 'console_scripts', 'pip3')())
File "/usr/lib/python3.8/site-packages/pip/_internal/cli/main.py", line 73, in main
command = create_command(cmd_name, isolated=("--isolated" in cmd_args))
File "/usr/lib/python3.8/site-packages/pip/_internal/commands/__init__.py", line 104, in create_command
module = importlib.import_module(module_path)
File "/usr/lib/python3.8/importlib/__init__.py", line 127, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 1014, in _gcd_import
File "<frozen importlib._bootstrap>", line 991, in _find_and_load
File "<frozen importlib._bootstrap>", line 975, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 671, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 783, in exec_module
File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed
File "/usr/lib/python3.8/site-packages/pip/_internal/commands/search.py", line 18, in <module>
from pip._internal.cli.req_command import SessionCommandMixin
File "/usr/lib/python3.8/site-packages/pip/_internal/cli/req_command.py", line 16, in <module>
from pip._internal.index.package_finder import PackageFinder
File "/usr/lib/python3.8/site-packages/pip/_internal/index/package_finder.py", line 21, in <module>
from pip._internal.index.collector import parse_links
File "/usr/lib/python3.8/site-packages/pip/_internal/index/collector.py", line 16, in <module>
from pip._vendor.requests.exceptions import HTTPError, RetryError, SSLError
ImportError: cannot import name 'RetryError' from 'requests.exceptions' (/home/daniel/.local/lib/python3.8/site-packages/requests/exceptions.py)
