When I run calibre, it gives me an error and quits. Here is the error message:
File "/usr/bin/calibre", line 21, in <module>
sys.exit(calibre())
File "/usr/lib/calibre/calibre/gui_launch.py", line 72, in calibre
from calibre.gui2.main import main
File "/usr/lib/calibre/calibre/gui2/main.py", line 12, in <module>
import apsw
ImportError: libicui18n.so.67: não é possível abrir arquivo compartilhado: Arquivo ou diretório inexistente
So I tried creating symlinks for the libraries that it searched, but I ended up with a different error:
sys.exit(calibre())
import apsw
ImportError: /home/user/.local/lib/python3.9/site-packages/apsw.cpython-39-x86_64-linux-gnu.so: undefined symbol: u_strToLower_67
I already deleted the symlinks and the error returned to the initial. I don’t know how to fix it, so I hope someone can help.
I executed this command and looks like that I’m fully up to date already. I read in the dependencies file at GitHub and it looks like that Calibre still depends on ICU 67.
That file is only used for building installers, that’s not used in our package. Calibre has been built with ICU 69.1 since 5.14.0-2 in April. I have no issues with 5.21.0-1 in the unstable branch.
The error you’re receiving shouldn’t be happening and the following shouldn’t be necessary, but since we’re here, why not? You can try rebuilding Calibre:
Well, it seems like I don’t have trusted the PGP signature of the downloaded file. I don’t know if it’s very important for the security, so… Can I skip the PGP check?
This also looks weird. Seems more a problem with your local python install. Why do you have modules installed in your home that are going to be sourced with system packages.
I did try that, but it returned an error. I don’t have much experience with pip and Python in general.
Found existing installation: apsw 3.35.4.post1
ERROR: Cannot uninstall 'apsw'. It is a distutils installed project and thus we cannot accurately determine which files belong to it which would lead to only a partial uninstall.
I have python-apsw installed. And I don’t know exactly how did I set up my python environment, I’d only use it for installing a Discord bot and ProtonVPN (and the Discord bot (Red) did use a virtual environment).
I realized that it did have 2 apsw packages installed, one that was the system package (apsw), and another that was installed by the bot (apsw-wheels). I uninstalled the latter and opened Calibre, so… it worked. Thank you all for helping me in this issue.
