Hey
I tried to use my laptop with an external monitor that has a max resolution of 2560x1080 (21:9), but I can’t choose anything higher than 1080p (16:9).
Tried setting a custom resolution using xrandr
but no luck. I can choose that, it looks like its changing but afterall it looks the same on my display (same as 1920x1080).
Dell Inspiron 3593, iris plus graphics g7 and geforce mx230
KDE Plasma 5.23.5
Kernel: 5.15.16
xrandr output:
Screen 0: minimum 320 x 200, current 1920 x 1080, maximum 16384 x 16384
eDP-1 connected (normal left inverted right x axis y axis)
1920x1080 60.05 + 60.01 59.97 59.96 59.93 48.04
1680x1050 59.95 59.88
1400x1050 59.98
1600x900 59.99 59.94 59.95 59.82
1280x1024 60.02
1400x900 59.96 59.88
1280x960 60.00
1440x810 60.00 59.97
1368x768 59.88 59.85
1280x800 59.99 59.97 59.81 59.91
1280x720 60.00 59.99 59.86 59.74
1024x768 60.04 60.00
960x720 60.00
928x696 60.05
896x672 60.01
1024x576 59.95 59.96 59.90 59.82
960x600 59.93 60.00
960x540 59.96 59.99 59.63 59.82
800x600 60.00 60.32 56.25
840x525 60.01 59.88
864x486 59.92 59.57
700x525 59.98
800x450 59.95 59.82
640x512 60.02
700x450 59.96 59.88
640x480 60.00 59.94
720x405 59.51 58.99
684x384 59.88 59.85
640x400 59.88 59.98
640x360 59.86 59.83 59.84 59.32
512x384 60.00
512x288 60.00 59.92
480x270 59.63 59.82
400x300 60.32 56.34
432x243 59.92 59.57
320x240 60.05
360x202 59.51 59.13
320x180 59.84 59.32
HDMI-1 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 798mm x 334mm
1920x1080 60.00* 50.00 59.94
1680x1050 59.88
1600x900 60.00
1280x1024 75.02 60.02
1280x800 59.91
1152x864 75.00
1280x720 60.00 50.00 59.94
1024x768 75.03 60.00
832x624 74.55
800x600 75.00 60.32
720x576 50.00
720x480 60.00 59.94
640x480 75.00 60.00 59.94
inxi output:
Device-1: Intel Iris Plus Graphics G7 vendor: Dell driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:8a52 class-ID: 0300
Device-2: NVIDIA GP108M [GeForce MX230] vendor: Dell driver: nvidia
v: 495.46 alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:1d11
class-ID: 0302
Device-3: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 1-6:3 chip-ID: 0c45:671e class-ID: 0e02
Display: x11 server: X.Org 1.21.1.3 compositor: kwin_x11 driver:
loaded: modesetting display-ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: HDMI-1 res: 1920x1080 hz: 60 dpi: 61
size: 798x334mm (31.4x13.1") diag: 865mm (34.1")
OpenGL: renderer: Mesa Intel Iris Plus Graphics (ICL GT2)
v: 4.6 Mesa 21.3.4 direct render: Yes
