calamares issue (unable to load all of the configured modules)
#1
so i got this error with calamares on testing branch today i build an iso and when trying to install to test
debug log
 >>> sudo -E calamares -d
QStandardPaths: wrong ownership on runtime directory /run/user/1000, 1000 instead of 0
07:47:44 [6]: Using log file: "/home/manjaro/.cache/calamares/session.log"
07:47:44 [6]: Using Calamares QML directory "/usr/share/calamares/qml"
07:47:44 [6]: Using Calamares settings file at "/etc/calamares/settings.conf"
07:47:44 [2]: WARNING: Required settings.conf key disable-cancel is missing.
07:47:44 [6]: Using Calamares branding file at "/usr/share/calamares/branding/manjaro/branding.desc"
07:47:44 [2]: WARNING: the branding component "/usr/share/calamares/branding/manjaro" does not ship translations.
07:47:44 [6]: Loaded branding component "manjaro"
07:47:44 [6]: STARTUP: initQmlPath, initSettings, initBranding done
07:47:44 [6]: STARTUP: initModuleManager: module init started
07:47:44 [0]: Icon theme "elementary" not found.
07:47:44 [0]: Icon theme "gnome" not found.
07:47:44 [6]: STARTUP: initModuleManager: all modules init done
07:47:44 [6]: STARTUP: initJobQueue done
07:47:44 [6]: Available desktop QSize(1366, 741) minimum size QSize(1024, 520)
07:47:44 [6]:   Proposed window size: 1024 520
07:47:44 [6]: STARTUP: CalamaresWindow created; loadModules started
07:47:44 [6]: Loaded module configuration "/etc/calamares/modules/welcome.conf"
07:47:44 [6]: Matching exact locale QLocale(English, Latin, United States)
07:47:44 [6]:  .. Matched locale  "en_US"
07:47:44 [6]: Looking for translations for "en_US"
07:47:44 [6]:  .. Calamares using locale: "en_US"
07:47:44 [6]: Welcome string false "Manjaro Linux 18.0 \"Illyria\""
07:47:45 [6]: ViewModule "welcome@welcome" loading complete.
07:47:45 [6]: Loaded module configuration "/etc/calamares/modules/locale.conf"
07:47:45 [6]: ViewModule "locale@locale" loading complete.
07:47:45 [6]: Loaded module configuration "/usr/share/calamares/modules/keyboard.conf"
07:47:46 [6]: ViewModule "keyboard@keyboard" loading complete.
07:47:46 [6]: Loaded module configuration "/usr/share/calamares/modules/partition.conf"
07:47:46 [2]: WARNING: virtual void Calamares::ViewModule::loadSelf() No factory: "Cannot load library /usr/lib/calamares/modules/partition/libcalamares_viewmodule_partition.so: (libkpmcore.so.7: cannot open shared object file: No such file or directory)"
07:47:46 [1]: ERROR: Module "partition@partition" loading FAILED.
07:47:46 [6]: Loaded module configuration "/etc/calamares/modules/users.conf"
07:47:46 [6]: ViewModule "users@users" loading complete.
07:47:46 [6]: ViewModule "summary@summary" loading complete.
07:47:46 [1]: ERROR: Module "partition@partition" exists but not loaded.
07:47:46 [6]: Loaded module configuration "/usr/share/calamares/modules/mount.conf"
07:47:46 [6]: QML import paths:
     "/usr/bin"
     "qrc:/qt-project.org/imports"
     "/usr/lib/qt/qml"
07:47:46 [6]: Loaded module configuration "/etc/calamares/modules/unpackfs.conf"
07:47:46 [6]: Loaded module configuration "/etc/calamares/modules/machineid.conf"
07:47:46 [6]: Loaded module configuration "/usr/share/calamares/modules/fstab.conf"
07:47:46 [6]: Module "locale@locale" already loaded.
07:47:46 [6]: Module "keyboard@keyboard" already loaded.
07:47:46 [6]: Loaded module configuration "/usr/share/calamares/modules/luksopenswaphookcfg.conf"
07:47:46 [6]: Loaded module configuration "/etc/calamares/modules/initcpio.conf"
07:47:46 [6]: Module "users@users" already loaded.
07:47:46 [6]: Loaded module configuration "/etc/calamares/modules/displaymanager.conf"
07:47:46 [6]: Loaded module configuration "/etc/calamares/modules/mhwdcfg.conf"
07:47:46 [6]: Loaded module configuration "/etc/calamares/modules/services.conf"
07:47:46 [6]: Loaded module configuration "/usr/share/calamares/modules/grubcfg.conf"
07:47:46 [6]: Loaded module configuration "/etc/calamares/modules/bootloader.conf"
07:47:46 [6]: Loaded module configuration "/etc/calamares/modules/postcfg.conf"
07:47:46 [6]: Loaded module configuration "/usr/share/calamares/modules/umount.conf"
07:47:46 [6]: Loaded module configuration "/etc/calamares/modules/finished.conf"
07:47:46 [6]: ViewModule "finished@finished" loading complete.
07:47:46 [1]: ERROR: STARTUP: failed modules are ("partition@partition", "partition@partition")
07:47:47 [6]: xkbmap selection changed to:  "us" - ""
07:48:01 [8]: Shutting down Calamares...
07:48:01 [8]: Finished shutdown.
#2
This is a "too specialized" Calamares issue.
IMHO you should get better/faster feedback if you post at Manjaro Gitlab or Calamares Github.
#3
@philm
calamares and calamares-git needs to be rebuilt.
i rebuilt calamares using calamares-git pkg build and its working now.
i think its because of kpmcore update.
Manjaro-specific packages which need an update
#4
Please use unstable branch, were we had fixed it.
#5
Another Calamares bug, since the last update, is that most of the flags are missing in the manual partition tab including esp. The installer complains that this has not been selected on the boot/efi partition, while not realising it is not there to be ticked. If you set the flags in gparted when calamares formats the fat32 partition it is also removing the flags.
#6
just ignore that without the esp flag with only boot flag it boots
#7
Cinnamon does not like that and refuses to start.
#8
after install do not reboot
or after install in live env.
in partitionmanager/gparted set the boot flag again to fat32 partition.
it will boot.
edit: boot is not garranty even after setting boot flag on fat32 partition.
but yes its a bug it needs attention
this does not happen with erase entire disk
edit:erase entire disk also does not have esp flag.
but after install system boots.
and in partition manager also there is no esp flag so its likely an kpmcore bug.
