Calamares (Installer) waiting for 1 module and crashes
Hi everyone, I wrote this topic because I have a problem with Calamares (Manjaro Installer)
When I launch Calamares, it says “waiting for 1 module” and after 7 seconds, it crashes.
Thanks for your help
Here is Calamares log :
Generated on 2024-06-23 15:04:1719155099
cat /var/log/Calamares. log
Welcome to the forum! Be sure to keep all information in your main post. Please see how to ask for support on the forum.
You need to run in a terminal:
cat /var/log/Calamares.log
And then write down the output in your post.
Also run:
inxi -Fazy
And show us the output.
We need this kind of information to help you out. We really can’t do much based on the information you’ve currently posted.
When I run “cat /var/…”
It says me “No file or folder of that name”
(I have already launched Calamares)
And here is the result for the 2nd command :
Pastebin Link
I will try again with a new iso
Firstly, make sure you post all information here in preformatted text.
Secondly,
Nothing stood out to me from what you provided in the Pastebin except this.
So,
Try with a new iso and let us know.
it is:
not
and it’ll probably only even be there once the installer has started
if it crashes … there might not be anything
I tried with a new iso (flashed, i used ventoy in my previous try)
And calamares crashed…
Try with a different USB and insert it into a separate USB slot if you have one.
