Hello @ropox
Seems to be a bug with conversion of the Russian language at script level. Try to install it in English and convert the local installation into Russian.
hello, could you help me with this problem
Installation Failed
External command finished with errors.
Command systemd-machine-id-setup finished with exit code 126.
Output:
/usr/bin/chroot: failed to run command ‘systemd-machine-id-setup’: Exec format error
Please do not create duplicate threads. Posts merged and duplicate post removed.
Скажите нам, если вы не понимаете:
Плохо говорю по русски и мало понимаю…
