When I install Manjaro and the Calamares “Welcome” shows up, I select Swedish.
Next is the location. Since I already have choosen Swedish, then it should understand
that the location, most likely, is Sweden. It is very annoying to see that it suggest USA.
Another annoying thing is that I have selected a WiFi network, and the installation is done.
After reboot it doesn’t remember the WiFi network, so I have to re-connect to it again.
All following reboots it remembers the WiFi connection.
It should remember the WiFi connection at the first reboot, aswell.
/ Hans Gatu
