Bumblebee Troubleshooting|20181229
Fix boot Manjaro on Laptop with Skylake CPU.
Follow this paste: https://gist.github.com/mauri870/5a54e415140875b9150ca31c491811f6 for DETAILS.
Edit /etc/default/grub and add to GRUB_CMDLINE_LINUX line:
acpi_osi=! acpi_osi="Windows 2009"
Save changes in file and run:
sudo update-grub
Reference:
Enable NVIDIA card after waking from suspend The bumblebee daemon may fail to activate the graphics card after suspending. A possible fix involves setting bbswitch as the default method for power management. Set PMMethod=bbswitch via command:
sudo sed -i "s/PMMethod=auto/PMMethod=bbswitch/" "/etc/bumblebee/bumblebee.conf"
Reboot.
Reference:
Fix OpenGL glxinfo tool Error: couldn't find RGB GLX visual or fbconfig Intel Xorg file /etc/X11/mhwd.d/intel.conf required additional code Section "OutputClass"
    Identifier "intel"
    ModulePath "/usr/lib/xorg/modules/extensions"
EndSection
Reboot.
Reference:
NVIDIA card does not launch at all Since lastest rebuild bumbebee package REQUIRED manually add user to bumblebee group via command:
sudo gpasswd -a $USER bumblebee
LOGOUT and LOGIN.
Reference:
https://forum.manjaro.org/t/60499
Also chime in here if acpi_osi=! acpi_osi="Windows 2009" is a useable default:
