Bumblebee driver not working
Bus ID is there. You need to use
BusID "PCI:3:0:0"
@abel @JohnCa What I also find interesting is that in inxi shows that the Xorg server is using the nvidia gpu. I don’t know if it’s caused by bumblebee. Can you get the latest Xorg log from ~/.local/share/xorg/ or /var/log?
solved thank you very much.
Please explain what you did to solve the problem, for others.
that was about to do XD.
but here is the Xorg log
/home/camacho/.local/share/xorg/Xorg.1.log
[ 20312.188] (WW) Failed to open protocol names file lib/xorg/protocol.txt
[ 20312.188]
X.Org X Server 1.20.8
[ 20312.188] Build Operating System: Linux Manjaro Linux
[ 20312.188] Current Operating System: Linux camacho-latitudee5540 4.19.119-1-MANJARO #1 SMP Wed Apr 29 18:32:19 UTC 2020 x86_64
[ 20312.188] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.19-x86_64 root=UUID=98e372b1-5d9d-46d0-ba9f-30e83e908240 rw quiet apparmor=1 security=apparmor udev.log_priority=3
[ 20312.188] Build Date: 30 March 2020  06:33:12AM
[ 20312.188]
[ 20312.188] Current version of pixman: 0.40.0
[ 20312.188] 	Before reporting problems, check http://wiki.x.org
[ 20312.188] Markers: (--) probed, (**) from config file, (==) default setting,
[ 20312.189] (==) Log file: "/home/camacho/.local/share/xorg/Xorg.1.log", Time: Fri May  8 02:46:55 2020
[ 20312.189] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 20312.189] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 20312.189] (==) No Layout section.  Using the first Screen section.
[ 20312.189] (==) No screen section available. Using defaults.
[ 20312.189] (**) |-->Screen "Default Screen Section" (0)
[ 20312.189] (**) |   |-->Monitor "<default monitor>"
[ 20312.189] (==) No device specified for screen "Default Screen Section".
	Using the first device section listed.
[ 20312.189] (**) |   |-->Device "Device0"
[ 20312.189] (==) No monitor specified for screen "Default Screen Section".
[ 20312.189] (==) Automatically adding devices
[ 20312.189] (==) Automatically enabling devices
[ 20312.189] (==) Automatically adding GPU devices
[ 20312.189] (==) Automatically binding GPU devices
[ 20312.189] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 20312.189] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[ 20312.189] 	Entry deleted from font path.
[ 20312.189] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 20312.189] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/100dpi".
[ 20312.189] 	(Run 'mkfontdir' on "/usr/share/fonts/100dpi").
[ 20312.189] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/75dpi".
[ 20312.189] 	(Run 'mkfontdir' on "/usr/share/fonts/75dpi").
[ 20312.189] (==) FontPath set to:
	/usr/share/fonts/misc,
	/usr/share/fonts/TTF
[ 20312.189] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 20312.189] (**) Extension "Composite" is enabled
[ 20312.189] (**) Extension "RENDER" is enabled
[ 20312.189] (II) The server relies on udev to provide the list of input devices.
[ 20312.189] (II) Module ABI versions:
[ 20312.189] 	X.Org ANSI C Emulation: 0.4
[ 20312.189] 	X.Org Video Driver: 24.1
[ 20312.189] 	X.Org XInput driver : 24.1
[ 20312.189] 	X.Org Server Extension : 10.0
[ 20312.190] (++) using VT number 2
[ 20312.192] (II) systemd-logind: took control of session /org/freedesktop/login1/session/_314
[ 20312.193] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 20312.194] (II) systemd-logind: got fd for /dev/dri/card0 226:0 fd 10 paused 0
[ 20312.196] (--) PCI:*(0@0:2:0) 8086:0a16:1028:05e0 rev 11, Mem @ 0xf6400000/4194304, 0xd0000000/268435456, I/O @ 0x0000f000/64, BIOS @ 0x????????/131072
[ 20312.196] (--) PCI: (3@0:0:0) 10de:1140:1028:05e0 rev 161, Mem @ 0xf5000000/16777216, 0xe0000000/268435456, 0xf0000000/33554432, I/O @ 0x0000e000/128, BIOS @ 0x????????/524288
[ 20312.196] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 20312.196] (II) LoadModule: "glx"
[ 20312.196] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 20312.198] (II) Module glx: vendor="X.Org Foundation"
[ 20312.198] 	compiled for 1.20.8, module version = 1.0.0
[ 20312.198] 	ABI class: X.Org Server Extension, version 10.0
[ 20312.198] (II) LoadModule: "intel"
[ 20312.198] (II) Loading /usr/lib/xorg/modules/drivers/intel_drv.so
[ 20312.198] (II) Module intel: vendor="X.Org Foundation"
[ 20312.198] 	compiled for 1.20.8, module version = 2.99.917
[ 20312.198] 	Module class: X.Org Video Driver
[ 20312.198] 	ABI class: X.Org Video Driver, version 24.1
[ 20312.198] (II) intel: Driver for Intel(R) Integrated Graphics Chipsets:
	i810, i810-dc100, i810e, i815, i830M, 845G, 854, 852GM/855GM, 865G,
	915G, E7221 (i915), 915GM, 945G, 945GM, 945GME, Pineview GM,
	Pineview G, 965G, G35, 965Q, 946GZ, 965GM, 965GME/GLE, G33, Q35, Q33,
	GM45, 4 Series, G45/G43, Q45/Q43, G41, B43
[ 20312.198] (II) intel: Driver for Intel(R) HD Graphics
[ 20312.198] (II) intel: Driver for Intel(R) Iris(TM) Graphics
[ 20312.198] (II) intel: Driver for Intel(R) Iris(TM) Pro Graphics
[ 20312.198] xf86EnableIOPorts: failed to set IOPL for I/O (Operation not permitted)
[ 20312.198] (II) intel(0): Using Kernel Mode Setting driver: i915, version 1.6.0 20180719
[ 20312.198] (II) intel(0): SNA compiled from 2.99.917-906-g846b53da
[ 20312.198] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
[ 20312.198] (--) intel(0): Integrated Graphics Chipset: Intel(R) HD Graphics 4400
[ 20312.198] (--) intel(0): CPU: x86-64, sse2, sse3, ssse3, sse4.1, sse4.2, avx, avx2; using a maximum of 2 threads
[ 20312.198] (II) intel(0): Creating default Display subsection in Screen section
	"Default Screen Section" for depth/fbbpp 24/32
[ 20312.198] (==) intel(0): Depth 24, (--) framebuffer bpp 32
[ 20312.198] (==) intel(0): RGB weight 888
[ 20312.198] (==) intel(0): Default visual is TrueColor
[ 20312.199] (**) intel(0): Option "AccelMethod" "sna"
[ 20312.199] (**) intel(0): Option "DRI" "true"
[ 20312.199] (II) intel(0): Output eDP1 has no monitor section
[ 20312.199] (**) intel(0): Found backlight control interface intel_backlight (type 'raw') for output eDP1
[ 20312.199] (II) intel(0): Enabled output eDP1
[ 20312.199] (II) intel(0): Output DP1 has no monitor section
[ 20312.199] (II) intel(0): Enabled output DP1
[ 20312.199] (II) intel(0): Output HDMI1 has no monitor section
[ 20312.200] (II) intel(0): Enabled output HDMI1
[ 20312.200] (II) intel(0): Output HDMI2 has no monitor section
[ 20312.200] (II) intel(0): Enabled output HDMI2
[ 20312.200] (--) intel(0): Using a maximum size of 256x256 for hardware cursors
[ 20312.200] (II) intel(0): Output VIRTUAL1 has no monitor section
[ 20312.200] (II) intel(0): Enabled output VIRTUAL1
[ 20312.200] (--) intel(0): Output eDP1 using initial mode 1366x768 on pipe 0
[ 20312.200] (==) intel(0): TearFree disabled
[ 20312.200] (==) intel(0): Using gamma correction (1.0, 1.0, 1.0)
[ 20312.200] (==) intel(0): DPI set to (96, 96)
[ 20312.200] (II) Loading sub module "dri3"
[ 20312.200] (II) LoadModule: "dri3"
[ 20312.200] (II) Module "dri3" already built-in
[ 20312.200] (II) Loading sub module "dri2"
[ 20312.200] (II) LoadModule: "dri2"
[ 20312.200] (II) Module "dri2" already built-in
[ 20312.200] (II) Loading sub module "present"
[ 20312.200] (II) LoadModule: "present"
[ 20312.200] (II) Module "present" already built-in
[ 20312.200] (II) intel(0): SNA initialized with Haswell (gen7.5, gt2) backend
[ 20312.200] (==) intel(0): Backing store enabled
[ 20312.200] (==) intel(0): Silken mouse disabled
[ 20312.200] (II) intel(0): HW Cursor enabled
[ 20312.200] (==) intel(0): DPMS enabled
[ 20312.201] (==) intel(0): Display hotplug detection enabled
[ 20312.201] (II) intel(0): [DRI2] Setup complete
[ 20312.201] (II) intel(0): [DRI2]   DRI driver: i965
[ 20312.201] (II) intel(0): [DRI2]   VDPAU driver: va_gl
[ 20312.201] (II) intel(0): direct rendering: DRI2 DRI3 enabled
[ 20312.201] (II) intel(0): hardware support for Present enabled
[ 20312.201] (II) Initializing extension Generic Event Extension
[ 20312.201] (II) Initializing extension SHAPE
[ 20312.201] (II) Initializing extension MIT-SHM
[ 20312.201] (II) Initializing extension XInputExtension
[ 20312.201] (II) Initializing extension XTEST
[ 20312.201] (II) Initializing extension BIG-REQUESTS
[ 20312.201] (II) Initializing extension SYNC
[ 20312.201] (II) Initializing extension XKEYBOARD
[ 20312.201] (II) Initializing extension XC-MISC
[ 20312.201] (II) Initializing extension SECURITY
[ 20312.201] (II) Initializing extension XFIXES
[ 20312.201] (II) Initializing extension RENDER
[ 20312.201] (II) Initializing extension RANDR
[ 20312.201] (II) Initializing extension COMPOSITE
[ 20312.201] (II) Initializing extension DAMAGE
[ 20312.201] (II) Initializing extension MIT-SCREEN-SAVER
[ 20312.201] (II) Initializing extension DOUBLE-BUFFER
[ 20312.201] (II) Initializing extension RECORD
[ 20312.201] (II) Initializing extension DPMS
[ 20312.201] (II) Initializing extension Present
[ 20312.201] (II) Initializing extension DRI3
[ 20312.201] (II) Initializing extension X-Resource
[ 20312.201] (II) Initializing extension XVideo
[ 20312.201] (II) Initializing extension XVideo-MotionCompensation
[ 20312.201] (II) Initializing extension GLX
[ 20312.210] (II) AIGLX: Loaded and initialized i965
[ 20312.210] (II) GLX: Initialized DRI2 GL provider for screen 0
[ 20312.210] (II) Initializing extension XFree86-VidModeExtension
[ 20312.210] (II) Initializing extension XFree86-DGA
[ 20312.210] (II) Initializing extension XFree86-DRI
[ 20312.210] (II) Initializing extension DRI2
[ 20312.211] (II) intel(0): switch to mode 1366x768@60.0 on eDP1 using pipe 0, position (0, 0), rotation normal, reflection none
[ 20312.211] (II) intel(0): Setting screen physical size to 361 x 203
[ 20312.241] (II) config/udev: Adding input device Power Button (/dev/input/event3)
[ 20312.241] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 20312.241] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 20312.241] (**) Power Button: Applying InputClass "system-keyboard"
[ 20312.241] (**) Power Button: Applying InputClass "Keyboard Defaults"
[ 20312.241] (II) LoadModule: "libinput"
[ 20312.241] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 20312.242] (II) Module libinput: vendor="X.Org Foundation"
[ 20312.242] 	compiled for 1.20.7, module version = 0.29.0
[ 20312.242] 	Module class: X.Org XInput Driver
[ 20312.242] 	ABI class: X.Org XInput driver, version 24.1
[ 20312.242] (II) Using input driver 'libinput' for 'Power Button'
[ 20312.243] (II) systemd-logind: got fd for /dev/input/event3 13:67 fd 16 paused 0
[ 20312.243] (**) Power Button: always reports core events
[ 20312.243] (**) Option "Device" "/dev/input/event3"
[ 20312.244] (**) Option "_source" "server/udev"
[ 20312.246] (II) event3  - Power Button: is tagged by udev as: Keyboard
[ 20312.246] (II) event3  - Power Button: device is a keyboard
[ 20312.246] (II) event3  - Power Button: device removed
[ 20312.246] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input3/event3"
[ 20312.246] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[ 20312.246] (**) Option "xkb_model" "pc105"
[ 20312.246] (**) Option "xkb_layout" "es"
[ 20312.246] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 20312.262] (II) event3  - Power Button: is tagged by udev as: Keyboard
[ 20312.262] (II) event3  - Power Button: device is a keyboard
[ 20312.262] (II) config/udev: Adding input device Video Bus (/dev/input/event15)
[ 20312.262] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[ 20312.262] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[ 20312.262] (**) Video Bus: Applying InputClass "system-keyboard"
[ 20312.262] (**) Video Bus: Applying InputClass "Keyboard Defaults"
[ 20312.262] (II) Using input driver 'libinput' for 'Video Bus'
[ 20312.263] (II) systemd-logind: got fd for /dev/input/event15 13:79 fd 19 paused 0
[ 20312.263] (**) Video Bus: always reports core events
[ 20312.263] (**) Option "Device" "/dev/input/event15"
[ 20312.263] (**) Option "_source" "server/udev"
[ 20312.264] (II) event15 - Video Bus: is tagged by udev as: Keyboard
[ 20312.264] (II) event15 - Video Bus: device is a keyboard
[ 20312.264] (II) event15 - Video Bus: device removed
[ 20312.265] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:01/input/input18/event15"
[ 20312.265] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
[ 20312.265] (**) Option "xkb_model" "pc105"
[ 20312.265] (**) Option "xkb_layout" "es"
[ 20312.265] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 20312.266] (II) event15 - Video Bus: is tagged by udev as: Keyboard
[ 20312.266] (II) event15 - Video Bus: device is a keyboard
[ 20312.266] (II) config/udev: Adding input device Video Bus (/dev/input/event14)
[ 20312.266] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[ 20312.266] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[ 20312.266] (**) Video Bus: Applying InputClass "system-keyboard"
[ 20312.266] (**) Video Bus: Applying InputClass "Keyboard Defaults"
[ 20312.266] (II) Using input driver 'libinput' for 'Video Bus'
[ 20312.267] (II) systemd-logind: got fd for /dev/input/event14 13:78 fd 20 paused 0
[ 20312.267] (**) Video Bus: always reports core events
[ 20312.267] (**) Option "Device" "/dev/input/event14"
[ 20312.267] (**) Option "_source" "server/udev"
[ 20312.268] (II) event14 - Video Bus: is tagged by udev as: Keyboard
[ 20312.268] (II) event14 - Video Bus: device is a keyboard
[ 20312.269] (II) event14 - Video Bus: device removed
[ 20312.269] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:08/LNXVIDEO:00/input/input17/event14"
[ 20312.269] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 8)
[ 20312.269] (**) Option "xkb_model" "pc105"
[ 20312.269] (**) Option "xkb_layout" "es"
[ 20312.269] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 20312.270] (II) event14 - Video Bus: is tagged by udev as: Keyboard
[ 20312.270] (II) event14 - Video Bus: device is a keyboard
[ 20312.270] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[ 20312.271] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 20312.271] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 20312.271] (**) Power Button: Applying InputClass "system-keyboard"
[ 20312.271] (**) Power Button: Applying InputClass "Keyboard Defaults"
[ 20312.271] (II) Using input driver 'libinput' for 'Power Button'
[ 20312.271] (II) systemd-logind: got fd for /dev/input/event1 13:65 fd 21 paused 0
[ 20312.271] (**) Power Button: always reports core events
[ 20312.271] (**) Option "Device" "/dev/input/event1"
[ 20312.271] (**) Option "_source" "server/udev"
[ 20312.272] (II) event1  - Power Button: is tagged by udev as: Keyboard
[ 20312.273] (II) event1  - Power Button: device is a keyboard
[ 20312.273] (II) event1  - Power Button: device removed
[ 20312.273] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1/event1"
[ 20312.273] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 9)
[ 20312.273] (**) Option "xkb_model" "pc105"
[ 20312.273] (**) Option "xkb_layout" "es"
[ 20312.273] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 20312.274] (II) event1  - Power Button: is tagged by udev as: Keyboard
[ 20312.274] (II) event1  - Power Button: device is a keyboard
[ 20312.275] (II) config/udev: Adding input device Lid Switch (/dev/input/event0)
[ 20312.275] (II) No input driver specified, ignoring this device.
[ 20312.275] (II) This device may have been added with another device file.
[ 20312.275] (II) config/udev: Adding input device Sleep Button (/dev/input/event2)
[ 20312.275] (**) Sleep Button: Applying InputClass "evdev keyboard catchall"
[ 20312.275] (**) Sleep Button: Applying InputClass "libinput keyboard catchall"
[ 20312.275] (**) Sleep Button: Applying InputClass "system-keyboard"
[ 20312.275] (**) Sleep Button: Applying InputClass "Keyboard Defaults"
[ 20312.275] (II) Using input driver 'libinput' for 'Sleep Button'
[ 20312.276] (II) systemd-logind: got fd for /dev/input/event2 13:66 fd 22 paused 0
[ 20312.276] (**) Sleep Button: always reports core events
[ 20312.276] (**) Option "Device" "/dev/input/event2"
[ 20312.276] (**) Option "_source" "server/udev"
[ 20312.277] (II) event2  - Sleep Button: is tagged by udev as: Keyboard
[ 20312.277] (II) event2  - Sleep Button: device is a keyboard
[ 20312.278] (II) event2  - Sleep Button: device removed
[ 20312.278] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input2/event2"
[ 20312.278] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 10)
[ 20312.278] (**) Option "xkb_model" "pc105"
[ 20312.278] (**) Option "xkb_layout" "es"
[ 20312.278] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 20312.279] (II) event2  - Sleep Button: is tagged by udev as: Keyboard
[ 20312.279] (II) event2  - Sleep Button: device is a keyboard
[ 20312.279] (II) config/udev: Adding input device HDA Intel HDMI HDMI/DP,pcm=3 (/dev/input/event16)
[ 20312.279] (II) No input driver specified, ignoring this device.
[ 20312.279] (II) This device may have been added with another device file.
[ 20312.280] (II) config/udev: Adding input device HDA Intel HDMI HDMI/DP,pcm=7 (/dev/input/event17)
[ 20312.280] (II) No input driver specified, ignoring this device.
[ 20312.280] (II) This device may have been added with another device file.
[ 20312.280] (II) config/udev: Adding input device HDA Intel HDMI HDMI/DP,pcm=8 (/dev/input/event18)
[ 20312.280] (II) config/udev: Adding input device HDA Intel HDMI HDMI/DP,pcm=9 (/dev/input/event19)
[ 20312.281] (II) config/udev: Adding input device HDA Intel HDMI HDMI/DP,pcm=10 (/dev/input/event20)
[ 20312.281] (II) No input driver specified, ignoring this device.
[ 20312.281] (II) This device may have been added with another device file.
[ 20312.281] (II) config/udev: Adding input device Logitech USB Receiver (/dev/input/event5)
[ 20312.281] (**) Logitech USB Receiver: Applying InputClass "evdev pointer catchall"
[ 20312.281] (**) Logitech USB Receiver: Applying InputClass "libinput pointer catchall"
[ 20312.281] (II) Using input driver 'libinput' for 'Logitech USB Receiver'
[ 20312.348] (II) systemd-logind: got fd for /dev/input/event5 13:69 fd 23 paused 0
[ 20312.348] (**) Logitech USB Receiver: always reports core events
[ 20312.348] (**) Option "Device" "/dev/input/event5"
[ 20312.348] (**) Option "_source" "server/udev"
[ 20312.353] (II) event5  - Logitech USB Receiver: is tagged by udev as: Mouse
[ 20312.353] (II) event5  - Logitech USB Receiver: device set to 1000 DPI
[ 20312.353] (II) event5  - Logitech USB Receiver: device is a pointer
[ 20312.354] (II) event5  - Logitech USB Receiver: device removed
[ 20312.354] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-1/2-1:1.0/0003:046D:C52F.0001/input/input6/event5"
[ 20312.354] (II) XINPUT: Adding extended input device "Logitech USB Receiver" (type: MOUSE, id 11)
[ 20312.354] (**) Option "AccelerationScheme" "none"
[ 20312.354] (**) Logitech USB Receiver: (accel) selected scheme none/0
[ 20312.354] (**) Logitech USB Receiver: (accel) acceleration factor: 2.000
[ 20312.354] (**) Logitech USB Receiver: (accel) acceleration threshold: 4
[ 20312.355] (II) event5  - Logitech USB Receiver: is tagged by udev as: Mouse
[ 20312.355] (II) event5  - Logitech USB Receiver: device set to 1000 DPI
[ 20312.355] (II) event5  - Logitech USB Receiver: device is a pointer
[ 20312.356] (II) config/udev: Adding input device Logitech USB Receiver (/dev/input/mouse0)
[ 20312.356] (II) No input driver specified, ignoring this device.
[ 20312.356] (II) This device may have been added with another device file.
[ 20312.357] (II) config/udev: Adding input device Logitech USB Receiver Consumer Control (/dev/input/event6)
[ 20312.357] (**) Logitech USB Receiver Consumer Control: Applying InputClass "evdev keyboard catchall"
[ 20312.357] (**) Logitech USB Receiver Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 20312.357] (**) Logitech USB Receiver Consumer Control: Applying InputClass "system-keyboard"
[ 20312.357] (**) Logitech USB Receiver Consumer Control: Applying InputClass "Keyboard Defaults"
[ 20312.357] (II) Using input driver 'libinput' for 'Logitech USB Receiver Consumer Control'
[ 20312.358] (II) systemd-logind: got fd for /dev/input/event6 13:70 fd 24 paused 0
[ 20312.358] (**) Logitech USB Receiver Consumer Control: always reports core events
[ 20312.358] (**) Option "Device" "/dev/input/event6"
[ 20312.358] (**) Option "_source" "server/udev"
[ 20312.359] (II) event6  - Logitech USB Receiver Consumer Control: is tagged by udev as: Keyboard
[ 20312.359] (II) event6  - Logitech USB Receiver Consumer Control: device is a keyboard
[ 20312.359] (II) event6  - Logitech USB Receiver Consumer Control: device removed
[ 20312.359] (II) libinput: Logitech USB Receiver Consumer Control: needs a virtual subdevice
[ 20312.359] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-1/2-1:1.1/0003:046D:C52F.0002/input/input7/event6"
[ 20312.360] (II) XINPUT: Adding extended input device "Logitech USB Receiver Consumer Control" (type: MOUSE, id 12)
[ 20312.360] (**) Option "AccelerationScheme" "none"
[ 20312.360] (**) Logitech USB Receiver Consumer Control: (accel) selected scheme none/0
[ 20312.360] (**) Logitech USB Receiver Consumer Control: (accel) acceleration factor: 2.000
[ 20312.360] (**) Logitech USB Receiver Consumer Control: (accel) acceleration threshold: 4
[ 20312.361] (II) event6  - Logitech USB Receiver Consumer Control: is tagged by udev as: Keyboard
[ 20312.361] (II) event6  - Logitech USB Receiver Consumer Control: device is a keyboard
[ 20312.361] (II) config/udev: Adding input device HDA Digital PCBeep (/dev/input/event9)
[ 20312.361] (II) No input driver specified, ignoring this device.
[ 20312.361] (II) This device may have been added with another device file.
[ 20312.362] (II) config/udev: Adding input device HDA Intel PCH Dock Mic (/dev/input/event10)
[ 20312.362] (II) No input driver specified, ignoring this device.
[ 20312.362] (II) This device may have been added with another device file.
[ 20312.362] (II) config/udev: Adding input device HDA Intel PCH Dock Line Out (/dev/input/event11)
[ 20312.362] (II) config/udev: Adding input device HDA Intel PCH Front Headphone (/dev/input/event12)
[ 20312.363] (II) config/udev: Adding input device Laptop_Integrated_Webcam_HD: In (/dev/input/event21)
[ 20312.363] (**) Laptop_Integrated_Webcam_HD: In: Applying InputClass "evdev keyboard catchall"
[ 20312.363] (**) Laptop_Integrated_Webcam_HD: In: Applying InputClass "libinput keyboard catchall"
[ 20312.363] (**) Laptop_Integrated_Webcam_HD: In: Applying InputClass "system-keyboard"
[ 20312.363] (**) Laptop_Integrated_Webcam_HD: In: Applying InputClass "Keyboard Defaults"
[ 20312.363] (II) Using input driver 'libinput' for 'Laptop_Integrated_Webcam_HD: In'
[ 20312.364] (II) systemd-logind: got fd for /dev/input/event21 13:85 fd 25 paused 0
[ 20312.364] (**) Laptop_Integrated_Webcam_HD: In: always reports core events
[ 20312.364] (**) Option "Device" "/dev/input/event21"
[ 20312.364] (**) Option "_source" "server/udev"
[ 20312.366] (II) event21 - Laptop_Integrated_Webcam_HD: In: is tagged by udev as: Keyboard
[ 20312.366] (II) event21 - Laptop_Integrated_Webcam_HD: In: device is a keyboard
[ 20312.366] (II) event21 - Laptop_Integrated_Webcam_HD: In: device removed
[ 20312.366] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.0/usb1/1-1/1-1.6/1-1.6:1.0/input/input24/event21"
[ 20312.366] (II) XINPUT: Adding extended input device "Laptop_Integrated_Webcam_HD: In" (type: KEYBOARD, id 13)
[ 20312.366] (**) Option "xkb_model" "pc105"
[ 20312.366] (**) Option "xkb_layout" "es"
[ 20312.366] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 20312.368] (II) event21 - Laptop_Integrated_Webcam_HD: In: is tagged by udev as: Keyboard
[ 20312.368] (II) event21 - Laptop_Integrated_Webcam_HD: In: device is a keyboard
[ 20312.368] (II) config/udev: Adding input device Dell WMI hotkeys (/dev/input/event8)
[ 20312.368] (**) Dell WMI hotkeys: Applying InputClass "evdev keyboard catchall"
[ 20312.368] (**) Dell WMI hotkeys: Applying InputClass "libinput keyboard catchall"
[ 20312.368] (**) Dell WMI hotkeys: Applying InputClass "system-keyboard"
[ 20312.368] (**) Dell WMI hotkeys: Applying InputClass "Keyboard Defaults"
[ 20312.368] (II) Using input driver 'libinput' for 'Dell WMI hotkeys'
[ 20312.369] (II) systemd-logind: got fd for /dev/input/event8 13:72 fd 26 paused 0
[ 20312.369] (**) Dell WMI hotkeys: always reports core events
[ 20312.369] (**) Option "Device" "/dev/input/event8"
[ 20312.369] (**) Option "_source" "server/udev"
[ 20312.371] (II) event8  - Dell WMI hotkeys: is tagged by udev as: Keyboard
[ 20312.371] (II) event8  - Dell WMI hotkeys: device is a keyboard
[ 20312.371] (II) event8  - Dell WMI hotkeys: device removed
[ 20312.371] (**) Option "config_info" "udev:/sys/devices/platform/PNP0C14:01/wmi_bus/wmi_bus-PNP0C14:01/9DBB5994-A997-11DA-B012-B622A1EF5492/input/input12/event8"
[ 20312.371] (II) XINPUT: Adding extended input device "Dell WMI hotkeys" (type: KEYBOARD, id 14)
[ 20312.371] (**) Option "xkb_model" "pc105"
[ 20312.371] (**) Option "xkb_layout" "es"
[ 20312.371] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 20312.372] (II) event8  - Dell WMI hotkeys: is tagged by udev as: Keyboard
[ 20312.372] (II) event8  - Dell WMI hotkeys: device is a keyboard
[ 20312.373] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event4)
[ 20312.373] (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
[ 20312.373] (**) AT Translated Set 2 keyboard: Applying InputClass "libinput keyboard catchall"
[ 20312.373] (**) AT Translated Set 2 keyboard: Applying InputClass "system-keyboard"
[ 20312.373] (**) AT Translated Set 2 keyboard: Applying InputClass "Keyboard Defaults"
[ 20312.373] (II) Using input driver 'libinput' for 'AT Translated Set 2 keyboard'
[ 20312.374] (II) systemd-logind: got fd for /dev/input/event4 13:68 fd 27 paused 0
[ 20312.374] (**) AT Translated Set 2 keyboard: always reports core events
[ 20312.374] (**) Option "Device" "/dev/input/event4"
[ 20312.374] (**) Option "_source" "server/udev"
[ 20312.375] (II) event4  - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 20312.375] (II) event4  - AT Translated Set 2 keyboard: device is a keyboard
[ 20312.376] (II) event4  - AT Translated Set 2 keyboard: device removed
[ 20312.376] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input4/event4"
[ 20312.376] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 15)
[ 20312.376] (**) Option "xkb_model" "pc105"
[ 20312.376] (**) Option "xkb_layout" "es"
[ 20312.376] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 20312.378] (II) event4  - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 20312.378] (II) event4  - AT Translated Set 2 keyboard: device is a keyboard
[ 20312.379] (II) config/udev: Adding input device AlpsPS/2 ALPS GlidePoint (/dev/input/event13)
[ 20312.379] (**) AlpsPS/2 ALPS GlidePoint: Applying InputClass "evdev touchpad catchall"
[ 20312.379] (**) AlpsPS/2 ALPS GlidePoint: Applying InputClass "libinput touchpad catchall"
[ 20312.379] (II) Using input driver 'libinput' for 'AlpsPS/2 ALPS GlidePoint'
[ 20312.380] (II) systemd-logind: got fd for /dev/input/event13 13:77 fd 28 paused 0
[ 20312.380] (**) AlpsPS/2 ALPS GlidePoint: always reports core events
[ 20312.380] (**) Option "Device" "/dev/input/event13"
[ 20312.380] (**) Option "_source" "server/udev"
[ 20312.383] (II) event13 - AlpsPS/2 ALPS GlidePoint: is tagged by udev as: Touchpad
[ 20312.383] (II) event13 - AlpsPS/2 ALPS GlidePoint: device is a touchpad
[ 20312.383] (II) event13 - AlpsPS/2 ALPS GlidePoint: device removed
[ 20312.384] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio1/input/input11/event13"
[ 20312.384] (II) XINPUT: Adding extended input device "AlpsPS/2 ALPS GlidePoint" (type: TOUCHPAD, id 16)
[ 20312.384] (**) Option "AccelerationScheme" "none"
[ 20312.384] (**) AlpsPS/2 ALPS GlidePoint: (accel) selected scheme none/0
[ 20312.384] (**) AlpsPS/2 ALPS GlidePoint: (accel) acceleration factor: 2.000
[ 20312.384] (**) AlpsPS/2 ALPS GlidePoint: (accel) acceleration threshold: 4
[ 20312.385] (II) event13 - AlpsPS/2 ALPS GlidePoint: is tagged by udev as: Touchpad
[ 20312.385] (II) event13 - AlpsPS/2 ALPS GlidePoint: device is a touchpad
[ 20312.386] (II) config/udev: Adding input device AlpsPS/2 ALPS GlidePoint (/dev/input/mouse1)
[ 20312.386] (II) No input driver specified, ignoring this device.
[ 20312.386] (II) This device may have been added with another device file.
[ 20312.386] (II) config/udev: Adding input device PC Speaker (/dev/input/event7)
[ 20312.395] (**) Logitech USB Receiver Consumer Control: Applying InputClass "evdev keyboard catchall"
[ 20312.395] (**) Logitech USB Receiver Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 20312.395] (**) Logitech USB Receiver Consumer Control: Applying InputClass "system-keyboard"
[ 20312.395] (**) Logitech USB Receiver Consumer Control: Applying InputClass "Keyboard Defaults"
[ 20312.395] (II) Using input driver 'libinput' for 'Logitech USB Receiver Consumer Control'
[ 20312.395] (II) systemd-logind: returning pre-existing fd for /dev/input/event6 13:70
[ 20312.395] (**) Logitech USB Receiver Consumer Control: always reports core events
[ 20312.395] (**) Option "Device" "/dev/input/event6"
[ 20312.395] (**) Option "_source" "_driver/libinput"
[ 20312.395] (II) libinput: Logitech USB Receiver Consumer Control: is a virtual subdevice
[ 20312.395] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-1/2-1:1.1/0003:046D:C52F.0002/input/input7/event6"
[ 20312.395] (II) XINPUT: Adding extended input device "Logitech USB Receiver Consumer Control" (type: KEYBOARD, id 17)
[ 20312.395] (**) Option "xkb_model" "pc105"
[ 20312.395] (**) Option "xkb_layout" "es"
[ 20312.395] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 20313.531] (II) intel(0): EDID vendor "AUO", prod id 18156
[ 20313.531] (II) intel(0): Printing DDC gathered Modelines:
[ 20313.531] (II) intel(0): Modeline "1366x768"x0.0   70.28  1366 1374 1384 1480  768 771 772 790 +hsync -vsync (47.5 kHz eP)
[ 20313.531] (II) intel(0): Modeline "1366x768"x0.0   70.28  1366 1374 1384 1812  768 771 772 968 +hsync -vsync (38.8 kHz e)
[ 20313.567] (**) Option "fd" "28"
[ 20313.567] (II) event13 - AlpsPS/2 ALPS GlidePoint: device removed
[ 20353.321] (**) Option "fd" "16"
[ 20353.321] (II) event3  - Power Button: device removed
[ 20353.321] (**) Option "fd" "19"
[ 20353.321] (II) event15 - Video Bus: device removed
[ 20353.321] (**) Option "fd" "20"
[ 20353.321] (II) event14 - Video Bus: device removed
[ 20353.321] (**) Option "fd" "21"
[ 20353.321] (II) event1  - Power Button: device removed
[ 20353.321] (**) Option "fd" "22"
[ 20353.321] (II) event2  - Sleep Button: device removed
[ 20353.321] (**) Option "fd" "23"
[ 20353.321] (II) event5  - Logitech USB Receiver: device removed
[ 20353.321] (**) Option "fd" "24"
[ 20353.322] (**) Option "fd" "25"
[ 20353.322] (II) event21 - Laptop_Integrated_Webcam_HD: In: device removed
[ 20353.322] (**) Option "fd" "26"
[ 20353.322] (II) event8  - Dell WMI hotkeys: device removed
[ 20353.322] (**) Option "fd" "27"
[ 20353.322] (II) event4  - AT Translated Set 2 keyboard: device removed
[ 20353.322] (**) Option "fd" "24"
[ 20353.322] (II) event6  - Logitech USB Receiver Consumer Control: device removed
[ 20353.322] (II) UnloadModule: "libinput"
[ 20353.322] (II) systemd-logind: not releasing fd for 13:70, still in use
[ 20353.322] (II) systemd-logind: releasing fd for 13:68
[ 20353.377] (II) UnloadModule: "libinput"
[ 20353.377] (II) systemd-logind: releasing fd for 13:72
[ 20353.507] (II) UnloadModule: "libinput"
[ 20353.507] (II) systemd-logind: releasing fd for 13:85
[ 20353.607] (II) UnloadModule: "libinput"
[ 20353.607] (II) systemd-logind: releasing fd for 13:70
[ 20353.647] (II) UnloadModule: "libinput"
[ 20353.647] (II) systemd-logind: releasing fd for 13:69
[ 20353.727] (II) UnloadModule: "libinput"
[ 20353.727] (II) systemd-logind: releasing fd for 13:66
[ 20353.767] (II) UnloadModule: "libinput"
[ 20353.767] (II) systemd-logind: releasing fd for 13:65
[ 20353.817] (II) UnloadModule: "libinput"
[ 20353.817] (II) systemd-logind: releasing fd for 13:78
[ 20353.927] (II) UnloadModule: "libinput"
[ 20353.927] (II) systemd-logind: releasing fd for 13:79
[ 20354.027] (II) UnloadModule: "libinput"
[ 20354.027] (II) systemd-logind: releasing fd for 13:67
[ 20354.067] (II) UnloadModule: "libinput"
[ 20354.067] (II) systemd-logind: releasing fd for 13:77
[ 20354.223] (II) Server terminated successfully (0). Closing log file.
now if I proceed with the explanation
how :flushed:???
I’ll just order the steps …
we execute one of these commands in terminal.
lspci
or
inxi -Fazy
should return something like this:
03:00.0 3D controller: NVIDIA Corporation GF117M [GeForce 610M/710M/810M/820M / GT 620M/625M/630M/720M] (rev ff)
or this
  Device-1: Intel Haswell-ULT Integrated Graphics vendor: Dell driver: i915
  v: kernel bus ID: 00:02.0 chip ID: 8086:0a16
  Device-2: NVIDIA GF117M [GeForce 610M/710M/810M/820M / GT
  vendor: Dell driver: nvidia v: 390.132 bus ID: 03:00.0 chip ID: 10de:1140
These will help us to identify the bus that corresponds to our graphic card.
once we have it identified we go to the directory:
/etc/bumblebee/
we should be able to look at the xorg.conf.nvidia file
edit the file as root
In the “Device” section we enter for example the line:
BusID "PCI:3:0:0"
the identification number bus ID may vary depending on your equipment.
so I stay with me and it works:
## Generated by mhwd - Manjaro Hardware Detection
Section "ServerLayout"
    Identifier "Layout0"
    Option "AutoAddDevices" "false"
EndSection
Section "Device"
    Identifier  "Device1"
    Driver      "nvidia"
    VendorName "NVIDIA Corporation"
    Option "NoLogo" "true"
    Option "UseEDID" "false"
    Option "ConnectedMonitor" "DFP"
    BusID "PCI:3:0:0"
EndSection
finally run:
optirun glxgears -info
to check that everything works.
not working for me :frowning_face:
send me a copy…
okay with the edited answer now everything is working :grinning:
Thanks !!!
I am very happy.
keep enjoying Manjaro :slight_smile:
One thing worth mentioning (copy paste from the link posted above):
" Observe that the format of lspci output is in HEX, while in xorg it is in decimals. So if the output of lspci is, for example, 0a:00.0 the BusID should be PCI:10:0:0 ."
This bite me, so heads up for the others!
thanks bro. Just one line and it fixed all my misery.
happy to be able to help more people, and that our community is full of people willing to solve a problem.
enjoy manjaro, greetings.
