I’ve only been using Manjaro for a few months, but whenever I update via Add/Remove Software or sudo pacman -Syu the download and install moves along fine until
which literally takes over an hour. I do have several drives in my PC, but I don’t understand why it’s searching those drives for bootable partitions. Is there a way to exclude those drives? Why else would it take so long?
Olli
2 September 2023 01:12
2
may you post the output of
cat /etc/default/grub | grep os- -C2
to show the setting of os-prober in grub
#GRUB_DISABLE_SUBMENU=y
GRUB_DISABLE_OS_PROBER=false
Olli
2 September 2023 01:18
4
okay, os-prober is disabled. may you post the output of
lsblk -o PATH,PTTYPE,PARTTYPE,FSTYPE,PARTTYPENAME -f
and as basic information the mandatory
PATH PTTYPE PARTTYPE FSTYPE PARTTYPENAME
/dev/sda gpt
/dev/sda1 gpt 0fc63daf-8483-4772-8e79-3d69d8477de4 ext4 Linux filesystem
/dev/sdb gpt
/dev/sdb1 gpt 0fc63daf-8483-4772-8e79-3d69d8477de4 ext4 Linux filesystem
/dev/sdc gpt
/dev/sdc1 gpt
/dev/nvme0n1 gpt
/dev/nvme0n1p1 gpt c12a7328-f81f-11d2-ba4b-00a0c93ec93b vfat EFI System
/dev/nvme0n1p2 gpt 0fc63daf-8483-4772-8e79-3d69d8477de4 ext4 Linux filesystem
/dev/nvme0n1p3 gpt 0fc63daf-8483-4772-8e79-3d69d8477de4 ext4 Linux filesystem
Kernel: 6.1.44-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=2d044f6f-8a38-45a1-9ff2-553ba20f6e75 rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 5.27.7 tk: Qt v: 5.15.10 wm: kwin_x11 vt: 2 dm: SDDM
Type: Desktop Mobo: Micro-Star model: MPG B550 GAMING CARBON WIFI (MS-7C90)
v: 1.0 serial: <superuser required> UEFI: American Megatrends LLC. v: 1.61
date: 02/26/2021
System RAM: total: 32 GiB available: 31.27 GiB used: 12.23 GiB (39.1%)
Info: model: AMD Ryzen 5 5600X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
model-id: 0x21 (33) stepping: 0 microcode: 0xA201009
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 32 MiB
desc: 1x32 MiB
Speed (MHz): avg: 2712 high: 3510 min/max: 2200/4650 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3378 2: 2200
3: 2419 4: 2200 5: 2690 6: 2448 7: 3510 8: 2668 9: 2309 10: 2868 11: 2852
12: 3005 bogomips: 88827
cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
svm svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
Type: spec_rstack_overflow mitigation: safe RET, no microcode
STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA GA104 [GeForce RTX 3070] vendor: eVga.com. driver: nvidia
v: 535.98 non-free: 535.xx+ status: current (as of 2023-08) arch: Ampere
code: GAxxx process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 1
speed: 2.5 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 2b:00.0
chip-ID: 10de:2484 class-ID: 0300
Display: x11 server: X.Org v: 21.1.8 with: Xwayland v: 23.2.0
compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia display-ID: :0
screens: 1
Screen-1: 0 s-res: 2560x1440 s-dpi: 108 s-size: 602x342mm (23.70x13.46")
s-diag: 692mm (27.26")
Monitor-1: DP-0 res: 2560x1440 hz: 60 dpi: 109
size: 598x336mm (23.54x13.23") diag: 686mm (27.01") modes: N/A
API: OpenGL v: N/A renderer: N/A direct-render: N/A
Device-1: NVIDIA GA104 High Definition Audio vendor: eVga.com.
driver: snd_hda_intel v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 16
link-max: gen: 4 speed: 16 GT/s bus-ID: 2b:00.1 chip-ID: 10de:228b
class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: Micro-Star MSI
bus-ID: 2d:00.4 chip-ID: 1022:1487 class-ID: 0403
API: ALSA v: k6.1.44-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.78 status: off with: wireplumber status: active
tools: pw-cli,wpctl
Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 29:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlo1 state: down mac: <filter>
Device-2: Realtek RTL8125 2.5GbE vendor: Micro-Star MSI driver: r8169
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: f000 bus-ID: 2a:00.0
IF: enp42s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-9:7 chip-ID: 8087:0029
class-ID: e001
Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Local Storage: total: 7.28 TiB used: 3.51 TiB (48.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 2TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 2B2QGXA7 temp: 40.9 C
scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST3000DM001-1ER166
size: 2.73 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: HDD rpm: 7200 serial: <filter> fw-rev: CC25 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST2000DM009-2G4100
size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: HDD rpm: 7200 serial: <filter> fw-rev: DN02 scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 vendor: Western Digital model: WD10EARS-00Y5B1
size: 931.51 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
tech: N/A serial: <filter> fw-rev: 0A80 scheme: GPT
ID-1: / raw-size: 97.66 GiB size: 95.56 GiB (97.86%) used: 21.67 GiB (22.7%)
fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: 2d044f6f-8a38-45a1-9ff2-553ba20f6e75
used: 288 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 7CDB-660B
ID-3: /home raw-size: 1.72 TiB size: 1.7 TiB (98.37%)
used: 665.7 GiB (38.3%) fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:3
label: N/A uuid: 1961ade8-825d-47db-884e-8b8804c82c07
ID-4: /home/thelonghop raw-size: N/A size: 1.7 TiB used: 665.7 GiB (38.3%)
fs: ecryptfs source: ERR-102
ID-5: /run/media/thelonghop/thelonghop raw-size: 1.82 TiB size: 1.79 TiB (98.37%)
used: 1.31 TiB (73.1%) fs: ext4 dev: /dev/sdb1 maj-min: 8:17 label: thelonghop
uuid: 798bb9c3-fa89-4ccf-b736-0d6a338d4f75
ID-6: /run/media/thelonghop/thelonghop2 raw-size: 931.51 GiB
size: 915.82 GiB (98.32%) used: 263.28 GiB (28.7%) fs: ext4 dev: /dev/sdc1
maj-min: 8:33 label: N/A uuid: N/A
ID-7: /run/media/thelonghop/backup raw-size: 2.73 TiB size: 2.69 TiB (98.39%)
used: 1.27 TiB (47.5%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: backup
uuid: 6e46e430-c57f-4958-8c35-bdd5426da60f
Hub-2: 1-2:2 info: Genesys Logic Hub ports: 4 rev: 2.0
Device-1: 1-2.3:4 info: Yubicom Yubikey 4/5 OTP+U2F+CCID
type: keyboard,HID,smart card driver: hid-generic,usbhid interfaces: 3
rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 30mA
chip-ID: 1050:0407 class-ID: 0b00
Device-2: 1-5:3 info: Corsair K95 RGB PLATINUM XT Mechanical Gaming
Keyboard type: keyboard,HID,mouse driver: hid-generic,usbhid interfaces: 4
rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 500mA
chip-ID: 1b1c:1b89 class-ID: 0301 serial: <filter>
Device-3: 1-7:5 info: Micro Star MYSTIC LIGHT type: HID
lanes: 1 mode: 1.1 power: 500mA chip-ID: 1462:7c90 class-ID: 0300
serial: <filter>
Device-4: 1-8:6 info: Seiko Epson FF-680W type: <vendor specific>
driver: N/A interfaces: 2 rev: 2.1 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
mode: 2.0 power: 2mA chip-ID: 04b8:016b class-ID: 0000 serial: <filter>
Device-5: 1-9:7 info: Intel AX200 Bluetooth type: bluetooth driver: btusb
power: 100mA chip-ID: 8087:0029 class-ID: e001
Hub-3: 1-10:8 info: Genesys Logic Hub ports: 2 rev: 2.0
Hub-4: 2-0:1 info: super-speed hub ports: 4 rev: 3.1
Hub-5: 3-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 3-3:2 info: Razer USA DeathAdder Elite type: mouse,keyboard
lanes: 1 mode: 1.1 power: 500mA chip-ID: 1532:005c class-ID: 0300
Hub-6: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
System Temperatures: cpu: 53.0 C mobo: N/A gpu: nvidia temp: 41 C
Fan Speeds (rpm): N/A gpu: nvidia fan: 0%
Processes: 387 Uptime: 5d 6h 54m wakeups: 2 Init: systemd v: 253
default: graphical tool: systemctl Compilers: gcc: 13.2.1 clang: 15.0.7
Packages: 1431 pm: pacman pkgs: 1425 libs: 456 tools: pamac pm: flatpak
pkgs: 6 Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.29
Here’s all the output at step 13 that just finished after about 1.5 hours-
(13/20) Updating Grub-Bootmenu
Found linux image: /boot/vmlinuz-6.1-x86_64
Found initrd image: /boot/amd-ucode.img /boot/initramfs-6.1-x86_64.img
Found initrd fallback image: /boot/initramfs-6.1-x86_64-fallback.img
Root filesystem isn't btrfs
If you think an error has occurred, please file a bug report at "https://github.com/Antynea/grub-btrfs"
/usr/bin/grub-probe: warning: unknown device type nvme0n1.
Found memtest86+ EFI image: /boot/memtest86+/memtest.efi
done
Olli
2 September 2023 01:39
8
encrypted ? can you tell us the history of this ?
My /home partition is encrypted with ecryptfs. It auto-unencrypte on login
Olli
2 September 2023 01:48
10
got it. i can’t give you a helping hand because i’m not experienced enough about encrypted filesystems. but from what i do understand is that there is an issue with creating/updating grub-bootloader with your encryption. you should focus your search to this item. hopefully some else here can give you a helping hand at this.
Teo
2 September 2023 05:21
12
Since os prober didn’t find anything anyway and it seems you are not dualbooting, why don’t you just disable osprober? Just change the above setting to true and sudo update-grub
check journalctl and dmesg and see if there is something printed while osprober is running and finishes.
OK, done. Will update this post next time I update with results.
system
Closed
10 September 2023 13:33
15
