Built-in audio not working after switching to Nvidia proprietary driver
Hi, I recently installed Manjaro 18.1.2 with Gnome on my new (optimus...) laptop.
It's an optimus (yay...) laptop with a RTX 2060, so I installed the video-nvidia-440xx driver to only use the dGPU (following this guide).
The problem is that after a reboot, my built-in does not work anymore (and the HDMI one is still not working), it appear as headset in the settings menu:
I've read different posts with the different audio problem, but none provided a valid solution.
Here the output of various commands:
inxi -Fx
16:29:18 ~ $ inxi -Fx
System:    Host: manjaro-qcoumes Kernel: 5.3.8-3-MANJARO x86_64 bits: 64 compiler: gcc v: 9.2.0 Desktop: Gnome 3.34.1
           Distro: Manjaro Linux
Machine:   Type: Laptop System: Notebook product: NH5x_7xEDx,RCx,RDx v: N/A serial: <root required>
           Mobo: Notebook model: NH5x_7xEDx,RCx,RDx serial: <root required> UEFI: INSYDE v: 1.07.03 date: 11/16/2018
Battery:   ID-1: BAT0 charge: 46.3 Wh condition: 46.3/47.2 Wh (98%) model: Notebook BAT status: Full
CPU:       Topology: 6-Core model: Intel Core i7-9750H bits: 64 type: MT MCP arch: Kaby Lake rev: A L2 cache: 12.0 MiB
           flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 62431
           Speed: 4375 MHz min/max: 800/4500 MHz Core speeds (MHz): 1: 4295 2: 4384 3: 4247 4: 4368 5: 4405 6: 4305 7: 4379
           8: 4293 9: 4397 10: 4495 11: 4338 12: 4304
Graphics:  Device-1: Intel UHD Graphics 630 vendor: CLEVO/KAPOK driver: i915 v: kernel bus ID: 00:02.0
           Device-2: NVIDIA TU106M [GeForce RTX 2060 Mobile] vendor: CLEVO/KAPOK driver: nvidia v: 440.26 bus ID: 01:00.0
           Display: x11 server: X.org 1.20.5 driver: nvidia resolution: <xdpyinfo missing>
           OpenGL: renderer: GeForce RTX 2060/PCIe/SSE2 v: 4.6.0 NVIDIA 440.26 direct render: Yes
Audio:     Device-1: Intel Cannon Lake PCH cAVS vendor: CLEVO/KAPOK driver: snd_hda_intel v: kernel bus ID: 00:1f.3
           Device-2: NVIDIA TU106 High Definition Audio vendor: CLEVO/KAPOK driver: snd_hda_intel v: kernel bus ID: 01:00.1
           Sound Server: ALSA v: k5.3.8-3-MANJARO
Network:   Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel port: 4000 bus ID: 08:00.0
           IF: wlp8s0 state: up mac: 50:e0:85:f3:27:c1
           Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: CLEVO/KAPOK driver: r8168 v: 8.047.04-NAPI
           port: 3000 bus ID: 09:00.1
           IF: enp9s0f1 state: down mac: 80:fa:5b:69:bf:80
           IF-ID-1: docker0 state: down mac: 22:6c:18:78:04:6f
Drives:    Local Storage: total: 698.65 GiB used: 32.63 GiB (4.7%)
           ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 970 EVO Plus 250GB size: 232.89 GiB
           ID-2: /dev/nvme1n1 vendor: Samsung model: SSD 970 EVO Plus 250GB size: 232.89 GiB
           ID-3: /dev/sda vendor: Samsung model: SSD 860 EVO 500GB size: 465.76 GiB
Partition: ID-1: / size: 211.99 GiB used: 21.88 GiB (10.3%) fs: ext4 dev: /dev/nvme0n1p3
           ID-2: swap-1 size: 16.00 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/nvme0n1p2
Sensors:   System Temperatures: cpu: 69.0 C mobo: N/A gpu: nvidia temp: 55 C
Info:      Processes: 292 Uptime: 14m Memory: 15.36 GiB used: 1.73 GiB (11.3%) Init: systemd Compilers: gcc: 9.2.0 Shell: bash
           v: 5.0.11 inxi: 3.0.36
pacman -Qi pulseaudio
16:42:03 ~ $ pacman -Qi pulseaudio
Version         : 13.0-2
Description     : A featureful, general-purpose sound server
Architecture    : x86_64
URL             : https://www.freedesktop.org/wiki/Software/PulseAudio/
Licenses        : GPL
Groups          : None
Provides        : None
Depends On      : libpulse=13.0-2  rtkit  libltdl  speexdsp  tdb  orc  libsoxr  webrtc-audio-processing
Optional Deps   : pulseaudio-alsa: ALSA configuration (recommended) [installed]
Required By     : gnome-settings-daemon  manjaro-pulse  pulseaudio-alsa  pulseaudio-bluetooth  pulseaudio-ctl  pulseaudio-zeroconf
Optional For    : firefox  pavucontrol
Conflicts With  : None
Replaces        : pulseaudio-xen<=9.0  pulseaudio-gconf<=11.1
Installed Size  : 6.25 MiB
Packager        : Jan Alexander Steffens (heftig) <jan.steffens@gmail.com>
Build Date      : Sun 15 Sep 2019 14:01:38 CEST
Install Date    : Thu 07 Nov 2019 22:35:41 CET
Install Reason  : Installed as a dependency for another package
Install Script  : Yes
Validated By    : Signature
systemctl --user status pulseaudio
16:16:45 ~ $ systemctl --user status pulseaudio
● pulseaudio.service - Sound Service
   Loaded: loaded (/usr/lib/systemd/user/pulseaudio.service; disabled; vendor preset: enabled)
   Active: deactivating (stop-sigterm) (Result: timeout)
 Main PID: 1539 (pulseaudio)
   CGroup: /user.slice/user-1000.slice/user@1000.service/pulseaudio.service
           └─1539 /usr/bin/pulseaudio --daemonize=no
sudo dmesg | egrep -i "alsa|snd"
16:35:42 ~ $ sudo dmesg | egrep -i "alsa|snd"
[sudo] password for qcoumes:
[    5.011051] snd_hda_intel 0000:01:00.1: Disabling MSI
[    5.011056] snd_hda_intel 0000:01:00.1: Handle vga_switcheroo audio client
[    5.446759] snd_hda_intel 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[    5.520404] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC293: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:speaker
[    5.520406] snd_hda_codec_realtek hdaudioC0D0:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[    5.520408] snd_hda_codec_realtek hdaudioC0D0:    hp_outs=1 (0x15/0x0/0x0/0x0/0x0)
[    5.520409] snd_hda_codec_realtek hdaudioC0D0:    mono: mono_out=0x0
[    5.520409] snd_hda_codec_realtek hdaudioC0D0:    inputs:
[    5.520411] snd_hda_codec_realtek hdaudioC0D0:      Front Mic=0x18
[    5.520412] snd_hda_codec_realtek hdaudioC0D0:      Headset Mic=0x1a
[    5.520413] snd_hda_codec_realtek hdaudioC0D0:      Internal Mic=0x12
[    9.000408] snd_hda_intel 0000:00:1f.3: spurious response 0x0:0x2, last cmd=0x201f0500
[   13.811212] snd_hda_intel 0000:00:1f.3: No response from codec, disabling MSI: last cmd=0x20170503
[   14.817897] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20170503
[   15.821225] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20270503
[   16.827907] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20370503
[   17.834609] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20470503
[   18.841242] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20570503
[   19.844562] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20670503
[   20.847855] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20770503
[   21.854586] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x201f0500
[   22.887891] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20170503
[   23.897888] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20270503
[   24.907867] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20370503
[   25.911215] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20470503
[   26.921210] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20570503
[   27.931219] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20670503
[   28.941236] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20770503
[   29.951220] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x201f0500
[   30.984583] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20170503
[   31.994555] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20270503
[   33.001223] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20370503
[   34.004540] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20470503
[   35.011206] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20570503
[   36.021206] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20670503
[   37.024541] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20770503
[   38.031209] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x201f0500
[   39.061217] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20170503
[   40.064557] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20270503
[   41.067923] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20370503
[   42.071215] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20470503
[   43.077882] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20570503
[   44.081224] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20670503
[   45.087895] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20770503
[   46.091216] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x201f0500
[   47.124547] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20170503
[   48.131219] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20270503
[   49.134556] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20370503
[   50.147883] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20470503
[   51.151218] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20570503
[   52.154517] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20670503
[   53.164511] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20770503
[   54.171206] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x201f0500
[   55.208080] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20170503
[   56.217873] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20270503
[   57.224542] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20370503
[   58.228002] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20470503
[   59.234539] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20570503
[   60.244504] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20670503
[   61.247885] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20770503
[   62.251204] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x201f0500
[   63.281225] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20170503
[   64.294537] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20270503
[   65.304525] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20370503
[   66.311260] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20470503
[   67.317872] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20570503
[   68.321203] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20670503
[   69.324710] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20770503
[   70.334535] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x201f0500
[   71.371202] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20170503
[   72.374574] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20270503
[   73.377869] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20370503
[   74.381220] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20470503
[   75.391201] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20570503
[   76.401217] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20670503
[   77.404529] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20770503
[   78.407871] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x201f0500
[   79.438006] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20170503
[   80.444530] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20270503
[   81.451225] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20370503
[   82.454560] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20470503
[   83.464553] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20570503
[   84.474557] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20670503
[   85.484524] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20770503
[   86.491256] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x201f0500
[   87.521218] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20170503
[   88.524536] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20270503
[   89.531209] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20370503
[   90.534556] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20470503
[   91.537871] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20570503
[   92.544537] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20670503
[   93.551211] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20770503
[   94.557873] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x201f0500
[   95.594501] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x208f8100
[   96.597861] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x208f8100
[   97.607864] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20170500
[   98.614507] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20270500
[   99.624539] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20370500
[  100.631202] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20470500
[  101.634547] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20570500
[  102.637865] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20670500
[  103.644495] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20770500
[  104.651193] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x201f0500
[  105.687882] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x208f8100
[  106.697849] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x208f8100
[  107.704531] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20170500
[  108.711195] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20270500
[  109.717832] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20370500
[  110.721194] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20470500
[  111.731211] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20570500
[  112.737879] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20670500
[  113.744592] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20770500
[  114.754543] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x201f0500
[  115.791210] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x208f8100
[  116.797868] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x208f8100
[  117.801210] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20170500
[  118.811201] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20270500
[  119.814528] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20370500
[  120.824535] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20470500
[  121.831189] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20570500
[  122.841393] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20670500
[  123.847849] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20770500
[  124.854541] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x201f0500
[  125.891201] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x208f8100
[  126.901186] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x208f8100
[  127.907871] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20170500
[  128.911211] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20270500
[  129.917870] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20370500
[  130.924497] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20470500
[  131.934552] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20570500
[  132.937817] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20670500
[  133.941209] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20770500
[  134.944583] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x201f0500
[  135.974530] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x208f8100
[  136.984523] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x208f8100
[  137.991199] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20170500
[  138.997863] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20270500
[  140.007878] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20370500
[  141.017869] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20470500
[  142.024521] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20570500
[  143.034493] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20670500
[  144.041184] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20770500
[  145.044530] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x201f0500
[  146.081186] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x208f8100
[  147.091172] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x208f8100
[  148.094557] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20170500
[  149.097866] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20270500
[  150.104516] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20370500
[  151.107850] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20470500
[  152.117854] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20570500
[  153.127836] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20670500
[  154.131188] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20770500
[  155.141206] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x201f0500
[  156.177875] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x208f8100
[  157.181196] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x208f8100
[  158.184513] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20170500
[  159.191167] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20270500
[  160.197852] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20370500
[  161.204478] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20470500
[  162.207860] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20570500
[  163.214516] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20670500
[  164.221228] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20770500
[  165.231191] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x201f0500
[  166.261189] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x208f8100
[  167.271198] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x208f8100
[  168.277877] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20170500
[  169.281145] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20270500
[  170.287847] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20370500
[  171.291205] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20470500
[  172.304511] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20570500
[  173.307851] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20670500
[  174.314527] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20770500
[  175.321223] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x201f0500
[  176.351140] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x208f8100
[  177.357855] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x208f8100
[  178.367857] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20170500
[  179.374509] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20270500
[  180.384514] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20370500
[  181.391151] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20470500
[  182.401164] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20570500
[  183.404523] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20670500
[  184.411195] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20770500
[  185.421168] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x201f0500
[  186.454503] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x208f8100
[  187.464513] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x208f8100
[  188.467836] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20170500
[  189.471180] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20270500
[  190.474658] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20370500
[  191.477838] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20470500
[  192.481211] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20570500
[  193.491243] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20670500
[  194.494513] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20770500
[  195.497846] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x201f0500
[  196.527857] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x205f0015
[  197.531171] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x205f0015
[  198.534501] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x2053b000
[  199.541176] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20570740
[  200.547839] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x205f0015
[  201.554509] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x205f0015
[  202.561183] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x2053b000
[  203.564496] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20570740
[  204.567842] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x205f0015
[  205.577835] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x205f0015
[  206.584496] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x2053b000
[  207.587844] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20570740
[  208.591176] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x206f0015
[  209.594494] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x206f0015
[  210.597826] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x2063b000
[  211.601184] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20670740
[  212.604501] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x206f0015
[  213.607840] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x206f0015
[  214.611166] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x2063b000
[  215.617843] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20670740
[  216.621169] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x206f0015
[  217.627831] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x206f0015
[  218.634504] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x2063b000
[  219.637832] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20670740
[  220.641154] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x207f0015
[  221.644506] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x207f0015
[  222.647831] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x2073b000
[  223.651170] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20770740
[  224.661163] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x207f0015
[  225.664506] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x207f0015
[  226.667823] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x2073b000
[  227.671162] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20770740
[  228.677832] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x207f0015
[  229.681158] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x207f0015
[  230.684497] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x2073b000
[  231.687831] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20770740
[  232.694496] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20270d01
[  232.694498] snd_hda_codec_hdmi hdaudioC0D2: Unable to sync register 0x2f0d00. -11
[  234.744491] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20170503
[  235.754498] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20270503
[  236.757824] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20370503
[  237.764500] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20470503
[  238.767828] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20570503
[  239.774498] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20670503
[  240.784496] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20770503
[  241.787822] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x201f0500
[  242.817852] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20170503
[  243.821161] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20270503
[  244.831158] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20370503
[  245.834497] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20470503
[  246.838044] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20570503
[  247.847843] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20670503
[  248.851166] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20770503
[  249.854499] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x201f0500
[  250.891186] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20170503
[  251.894488] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20270503
[  252.904490] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20370503
[  253.907834] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20470503
[  254.911158] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20570503
[  255.914516] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20670503
[  256.924494] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20770503
[  257.931607] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x201f0500
[  258.967821] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20170503
[  259.977822] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20270503
[  260.981150] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20370503
[  261.987815] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20470503
[  262.994484] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20570503
[  264.004502] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20670503
[  265.014903] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20770503
[  266.027807] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x201f0500
[  267.057993] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20170503
[  268.067826] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20270503
[  269.071153] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20370503
[  270.074485] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20470503
[  271.084490] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20570503
[  272.091152] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20670503
[  273.101148] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20770503
[  274.104482] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x201f0500
[  275.137819] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20170503
[  276.144486] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20270503
[  277.151186] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20370503
[  278.157803] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20470503
[  279.164493] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20570503
[  280.171156] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20670503
[  281.181143] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20770503
[  282.191680] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x201f0500
[  283.221152] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20170503
[  284.227822] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20270503
[  285.237844] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20370503
[  286.244489] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20470503
[  287.251149] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20570503
[  288.257808] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20670503
[  289.264484] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20770503
[  290.267848] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x201f0500
[  291.304474] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20170503
[  292.311152] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20270503
[  293.321243] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20370503
[  294.331146] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20470503
[  295.337807] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20570503
[  296.347807] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20670503
[  297.358403] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20770503
[  298.367809] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x201f0500
[  299.401123] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20170503
[  300.407813] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20270503
[  301.411156] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20370503
[  302.421146] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20470503
[  303.424483] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20570503
[  304.431138] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20670503
[  305.437810] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20770503
[  306.444477] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x201f0500
[  307.474479] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20170503
[  308.484468] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20270503
[  309.491135] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20370503
[  310.494470] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20470503
[  311.504469] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20570503
[  312.514439] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20670503
[  313.524481] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20770503
[  314.531133] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x201f0500
[  315.567799] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x208f8100
[  316.571143] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x208f8100
[  317.581135] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20170500
[  318.584462] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20270500
[  319.587793] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20370500
[  320.594480] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20470500
[  321.604499] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20570500
[  322.614471] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20670500
[  323.617771] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20770500
[  324.627876] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x201f0500
[  325.661138] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x208f8100
[  326.671144] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x208f8100
[  327.681148] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20170500
[  328.687823] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20270500
[  329.694478] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20370500
[  330.697809] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20470500
[  331.704548] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20570500
[  332.714505] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20670500
[  333.717804] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20770500
[  334.727801] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x201f0500
[  335.757818] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x208f8100
[  336.767808] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x208f8100
[  337.771131] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20170500
[  338.781138] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20270500
[  339.787799] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20370500
[  340.797801] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20470500
[  341.807799] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20570500
[  342.811132] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20670500
[  343.817795] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20770500
[  344.824481] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x201f0500
[  345.861139] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x208f8100
[  346.864428] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x208f8100
[  347.867794] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20170500
[  348.871179] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20270500
[  349.881119] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20370500
[  350.891126] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20470500
[  351.894425] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20570500
[  352.907838] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20670500
[  353.911153] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20770500
[  354.914480] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x201f0500
[  355.947806] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x208f8100
[  356.951133] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x208f8100
[  357.954456] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20170500
[  358.961129] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20270500
[  359.967788] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20370500
[  360.971168] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20470500
[  361.977774] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20570500
[  362.981141] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20670500
[  363.991150] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20770500
[  364.994592] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x201f0500
[  366.031137] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x208f8100
[  367.034454] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x208f8100
[  368.044461] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20170500
[  369.047796] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20270500
[  370.054457] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20370500
[  371.057788] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20470500
[  372.064462] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20570500
[  373.071117] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20670500
[  374.074454] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20770500
[  375.084500] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x201f0500
[  376.114457] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x208f8100
[  377.117790] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x208f8100
[  378.127786] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20170500
[  379.137787] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20270500
[  380.141111] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20370500
[  381.144458] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20470500
[  382.154451] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20570500
[  383.157808] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20670500
[  384.161119] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20770500
[  385.171083] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x201f0500
[  386.204459] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x208f8100
[  387.214449] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x208f8100
[  388.224454] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20170500
[  389.227787] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20270500
[  390.231116] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20370500
[  391.241108] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20470500
[  392.251117] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20570500
[  393.254456] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20670500
[  394.257783] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20770500
[  395.261124] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x201f0500
[  396.291116] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x208f8100
[  397.294452] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x208f8100
[  398.301153] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20170500
[  399.304457] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20270500
[  400.314453] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20370500
[  401.317778] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20470500
[  402.321116] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20570500
[  403.327761] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20670500
[  404.331111] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20770500
[  405.334501] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x201f0500
[  406.367796] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x208f8100
[  407.374459] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x208f8100
[  408.381122] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20170500
[  409.384437] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20270500
[  410.387782] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20370500
[  411.394451] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20470500
[  412.397778] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20570500
[  413.401110] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20670500
[  414.404445] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20770500
[  415.407777] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x201f0500
[  416.441084] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x205f0015
[  417.444422] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x205f0015
[  418.454447] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x2053b000
[  419.457776] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20570740
[  420.467741] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x205f0015
[  421.474435] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x205f0015
[  422.477782] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x2053b000
[  423.487797] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20570740
[  424.494458] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x205f0015
[  425.501109] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x205f0015
[  426.504449] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x2053b000
[  427.511109] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20570740
[  428.514442] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x206f0015
[  429.517775] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x206f0015
[  430.527742] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x2063b000
[  431.534450] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20670740
[  432.544446] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x206f0015
[  433.551102] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x206f0015
[  434.561072] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x2063b000
[  435.567793] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20670740
[  436.574435] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x206f0015
[  437.577781] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x206f0015
[  438.584471] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x2063b000
[  439.587742] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20670740
[  440.591110] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x207f0015
[  441.594399] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x207f0015
[  442.607784] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x2073b000
[  443.614462] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20770740
[  444.621102] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x207f0015
[  445.627757] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x207f0015
[  446.631109] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x2073b000
[  447.634427] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20770740
[  448.637779] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x207f0015
[  449.644463] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x207f0015
[  450.651114] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x2073b000
[  451.657761] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20770740
[  452.661103] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x20270d01
[  452.661106] snd_hda_codec_hdmi hdaudioC0D2: Unable to sync register 0x2f0d00. -11
[  454.717771] snd_hda_intel 0000:00:1f.3: No response from codec, resetting bus: last cmd=0x202f0600
[  455.911098] snd_hda_intel 0000:00:1f.3: azx_get_response timeout, switching to single_cmd mode: last cmd=0x20170503
[  455.911133] WARNING: CPU: 5 PID: 2835 at sound/pci/hda/hda_controller.c:878 azx_rirb_get_response+0x1a8/0x220 [snd_hda_codec]
[  455.911133] Modules linked in: xt_conntrack xt_MASQUERADE nf_conntrack_netlink nfnetlink xfrm_user xfrm_algo xt_addrtype iptable_filter iptable_nat nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 libcrc32c br_netfilter bridge stp llc overlay aufs msr ccm rfcomm cmac algif_hash algif_skcipher snd_hda_codec_realtek af_alg snd_hda_codec_generic bnep ledtrig_audio intel_rapl_msr uinput intel_rapl_common snd_soc_skl snd_soc_skl_ipc snd_soc_sst_ipc snd_soc_sst_dsp snd_hda_ext_core snd_hda_codec_hdmi snd_soc_acpi_intel_match snd_soc_acpi snd_soc_core x86_pkg_temp_thermal intel_powerclamp coretemp joydev mousedev snd_compress kvm_intel iwlmvm hid_multitouch uvcvideo hid_generic ac97_bus snd_pcm_dmaengine videobuf2_vmalloc mac80211 kvm snd_hda_intel videobuf2_memops snd_hda_codec irqbypass libarc4 btusb nls_iso8859_1 snd_hda_core videobuf2_v4l2 btrtl nls_cp437 btbcm vfat crct10dif_pclmul iwlwifi snd_hwdep btintel crc32_pclmul videobuf2_common mei_hdcp fat fuse ghash_clmulni_intel i915 snd_pcm
[  455.911161]  bluetooth ucsi_ccg aesni_intel typec_ucsi snd_timer typec cfg80211 videodev i2c_algo_bit mei_me snd aes_x86_64 crypto_simd ecdh_generic wmi_bmof intel_wmi_thunderbolt mxm_wmi idma64 iTCO_wdt mc iTCO_vendor_support r8168(OE) ecc i2c_i801 i2c_hid cryptd pcspkr rfkill soundcore mei i2c_nvidia_gpu intel_gtt intel_lpss_pci intel_pch_thermal hid intel_lpss tpm_crb glue_helper intel_cstate rtsx_pci_ms intel_uncore memstick psmouse input_leds intel_rapl_perf tpm_tis tpm_tis_core tpm wmi battery rng_core intel_hid sparse_keymap evdev ac mac_hid nvidia_drm(POE) nvidia_modeset(POE) drm_kms_helper drm agpgart syscopyarea sysfillrect sysimgblt fb_sys_fops nvidia(POE) ipmi_devintf ipmi_msghandler crypto_user ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 sd_mod ahci libahci libata serio_raw rtsx_pci_sdmmc atkbd xhci_pci libps2 mmc_core scsi_mod crc32c_intel xhci_hcd rtsx_pci i8042 serio
[  455.911184] RIP: 0010:azx_rirb_get_response+0x1a8/0x220 [snd_hda_codec]
[  455.911194]  snd_hdac_bus_exec_verb_unlocked+0xa4/0x1c0 [snd_hda_core]
[  455.911198]  codec_exec_verb+0x72/0x110 [snd_hda_codec]
[  455.911200]  codec_read+0x49/0x80 [snd_hda_core]
[  455.911202]  haswell_set_power_state+0x2d/0x50 [snd_hda_codec_hdmi]
[  455.911205]  hda_set_power_state+0x49/0x100 [snd_hda_codec]
[  455.911208]  hda_call_codec_suspend+0x6f/0xa0 [snd_hda_codec]
[  455.911210]  snd_hda_bus_reset_codecs+0x25/0x70 [snd_hda_codec]
[  455.911213]  snd_hda_bus_reset+0x3c/0x50 [snd_hda_codec]
[  455.911215]  codec_exec_verb+0xb7/0x110 [snd_hda_codec]
[  455.911217]  codec_read+0x49/0x80 [snd_hda_core]
[  455.911220]  snd_hda_codec_setup_stream.part.0+0xaf/0x260 [snd_hda_codec]
[  455.911222]  generic_hdmi_playback_pcm_prepare+0x236/0x240 [snd_hda_codec_hdmi]
[  455.911224]  snd_hda_codec_prepare+0x51/0x120 [snd_hda_codec]
[  455.911227]  azx_pcm_prepare+0x11b/0x1c0 [snd_hda_codec]
[  455.911231]  snd_pcm_do_prepare+0x19/0x30 [snd_pcm]
[  455.911233]  snd_pcm_action_single+0x37/0x80 [snd_pcm]
[  455.911235]  snd_pcm_action_nonatomic+0x65/0x70 [snd_pcm]
[  455.911237]  snd_pcm_common_ioctl+0x39f/0xb20 [snd_pcm]
[  455.911240]  snd_pcm_ioctl+0x23/0x30 [snd_pcm]
[  456.452323] snd_hda_codec_hdmi hdaudioC0D2: Unable to sync register 0x2f0d00. -5
[  457.013162] snd_hda_codec_realtek hdaudioC0D0: Unable to sync register 0x1f0e00. -5
[  457.014695] snd_hda_codec_realtek hdaudioC0D0: Unable to sync register 0x1f0e00. -5
I have pavucontrol installed but its stuck on Establishing connection to PulseAudio. Please wait....
Thanks for the help.
how are you using your prime/optimus system. bumblebeed or optimus ?
i ran in trouble with bumblebbed because the service was still active while i have to use optimus.
can you post the messages of 'systemctl status optimus-manager' and 'systemctl status bumblebeed' ?
Neither of them, I always use the dGPU and cannot switch to the iGPU. I follow this guide:
17:38:11 ~ $ systemctl status bumblebeed
Unit bumblebeed.service could not be found.
17:38:11 ~ $ systemctl status optimus-manager
Unit optimus-manager.service could not be found.
install the optimus-manager and try it.
after installation check if optimus-manager is working.
use
'sudo systemctl enable optimus-manager'
'sudo systemctl start optimus-manager'
'sudo optimus-manager --set-startup nvidia'
reboot
I don't know how I did it, but after last reboot, everything works.
@olli Thanks for your time.
