Iβm trying to create a /etc/skel folder in desktop-overlay, but it gives me an error which says this file is already exists in file system. I can do it by editing build images but I donβt want to repeat it everytime I build an iso. Is there a way to force buildiso tool to overwrite the current filesystem? Thanks
desktop-overlay is meant to be used exactly for that purpose. Maybe post the errors during your build so we may help. Also link to your code or at least share a tree list of the file structure you want to add. You can use the tool tree for that to list the current folder: tree .
If I try to overwrite calamares configs, I get this;
calamares: /var/lib/manjaro-tools/buildiso/kde/x86_64/livefs/usr/share/calamares/branding/manjaro/branding.desc exists in filesystem
calamares: /var/lib/manjaro-tools/buildiso/kde/x86_64/livefs/usr/share/calamares/branding/manjaro/languages.png exists in filesystem
calamares: /var/lib/manjaro-tools/buildiso/kde/x86_64/livefs/usr/share/calamares/branding/manjaro/logo.png exists in filesystem
calamares: /var/lib/manjaro-tools/buildiso/kde/x86_64/livefs/usr/share/calamares/branding/manjaro/show.qml exists in filesystem
calamares: /var/lib/manjaro-tools/buildiso/kde/x86_64/livefs/usr/share/calamares/branding/manjaro/slide1.png exists in filesystem
calamares: /var/lib/manjaro-tools/buildiso/kde/x86_64/livefs/usr/share/calamares/branding/manjaro/slide2.png exists in filesystem
calamares: /var/lib/manjaro-tools/buildiso/kde/x86_64/livefs/usr/share/calamares/branding/manjaro/slide3.png exists in filesystem
calamares: /var/lib/manjaro-tools/buildiso/kde/x86_64/livefs/usr/share/calamares/branding/manjaro/slide4.png exists in filesystem
calamares: /var/lib/manjaro-tools/buildiso/kde/x86_64/livefs/usr/share/calamares/branding/manjaro/slide5.png exists in filesystem
calamares: /var/lib/manjaro-tools/buildiso/kde/x86_64/livefs/usr/share/calamares/branding/manjaro/squid.png exists in filesystem
calamares: /var/lib/manjaro-tools/buildiso/kde/x86_64/livefs/usr/share/calamares/modules/chrootcfg.conf exists in filesystem
calamares: /var/lib/manjaro-tools/buildiso/kde/x86_64/livefs/usr/share/calamares/modules/contextualprocess.conf exists in filesystem
calamares: /var/lib/manjaro-tools/buildiso/kde/x86_64/livefs/usr/share/calamares/modules/finished.conf exists in filesystem
calamares: /var/lib/manjaro-tools/buildiso/kde/x86_64/livefs/usr/share/calamares/modules/finishedq.conf exists in filesystem
calamares: /var/lib/manjaro-tools/buildiso/kde/x86_64/livefs/usr/share/calamares/modules/fsresizer.conf exists in filesystem
calamares: /var/lib/manjaro-tools/buildiso/kde/x86_64/livefs/usr/share/calamares/modules/fstab.conf exists in filesystem
calamares: /var/lib/manjaro-tools/buildiso/kde/x86_64/livefs/usr/share/calamares/modules/grubcfg.conf exists in filesystem
calamares: /var/lib/manjaro-tools/buildiso/kde/x86_64/livefs/usr/share/calamares/modules/interactiveterminal.conf exists in filesystem
calamares: /var/lib/manjaro-tools/buildiso/kde/x86_64/livefs/usr/share/calamares/modules/keyboard.conf exists in filesystem
calamares: /var/lib/manjaro-tools/buildiso/kde/x86_64/livefs/usr/share/calamares/modules/keyboardq.conf exists in filesystem
calamares: /var/lib/manjaro-tools/buildiso/kde/x86_64/livefs/usr/share/calamares/modules/license.conf exists in filesystem
calamares: /var/lib/manjaro-tools/buildiso/kde/x86_64/livefs/usr/share/calamares/modules/locale.conf exists in filesystem
calamares: /var/lib/manjaro-tools/buildiso/kde/x86_64/livefs/usr/share/calamares/modules/localeq.conf exists in filesystem
calamares: /var/lib/manjaro-tools/buildiso/kde/x86_64/livefs/usr/share/calamares/modules/luksopenswaphookcfg.conf exists in filesystem
calamares: /var/lib/manjaro-tools/buildiso/kde/x86_64/livefs/usr/share/calamares/modules/machineid.conf exists in filesystem
calamares: /var/lib/manjaro-tools/buildiso/kde/x86_64/livefs/usr/share/calamares/modules/mhwdcfg.conf exists in filesystem
calamares: /var/lib/manjaro-tools/buildiso/kde/x86_64/livefs/usr/share/calamares/modules/mount.conf exists in filesystem
calamares: /var/lib/manjaro-tools/buildiso/kde/x86_64/livefs/usr/share/calamares/modules/netinstall.conf exists in filesystem
calamares: /var/lib/manjaro-tools/buildiso/kde/x86_64/livefs/usr/share/calamares/modules/notesqml.conf exists in filesystem
calamares: /var/lib/manjaro-tools/buildiso/kde/x86_64/livefs/usr/share/calamares/modules/oemid.conf exists in filesystem
calamares: /var/lib/manjaro-tools/buildiso/kde/x86_64/livefs/usr/share/calamares/modules/openrcdmcryptcfg.conf exists in filesystem
calamares: /var/lib/manjaro-tools/buildiso/kde/x86_64/livefs/usr/share/calamares/modules/owncloud.conf exists in filesystem
calamares: /var/lib/manjaro-tools/buildiso/kde/x86_64/livefs/usr/share/calamares/modules/packagechooser.conf exists in filesystem
calamares: /var/lib/manjaro-tools/buildiso/kde/x86_64/livefs/usr/share/calamares/modules/packagechooserq.conf exists in filesystem
calamares: /var/lib/manjaro-tools/buildiso/kde/x86_64/livefs/usr/share/calamares/modules/packages.conf exists in filesystem
calamares: /var/lib/manjaro-tools/buildiso/kde/x86_64/livefs/usr/share/calamares/modules/partition.conf exists in filesystem
calamares: /var/lib/manjaro-tools/buildiso/kde/x86_64/livefs/usr/share/calamares/modules/plasmalnf.conf exists in filesystem
calamares: /var/lib/manjaro-tools/buildiso/kde/x86_64/livefs/usr/share/calamares/modules/plymouthcfg.conf exists in filesystem
calamares: /var/lib/manjaro-tools/buildiso/kde/x86_64/livefs/usr/share/calamares/modules/postcfg.conf exists in filesystem
calamares: /var/lib/manjaro-tools/buildiso/kde/x86_64/livefs/usr/share/calamares/modules/preservefiles.conf exists in filesystem
calamares: /var/lib/manjaro-tools/buildiso/kde/x86_64/livefs/usr/share/calamares/modules/rawfs.conf exists in filesystem
calamares: /var/lib/manjaro-tools/buildiso/kde/x86_64/livefs/usr/share/calamares/modules/removeuser.conf exists in filesystem
calamares: /var/lib/manjaro-tools/buildiso/kde/x86_64/livefs/usr/share/calamares/modules/services.conf exists in filesystem
calamares: /var/lib/manjaro-tools/buildiso/kde/x86_64/livefs/usr/share/calamares/modules/servicescfg.conf exists in filesystem
calamares: /var/lib/manjaro-tools/buildiso/kde/x86_64/livefs/usr/share/calamares/modules/shellprocess.conf exists in filesystem
calamares: /var/lib/manjaro-tools/buildiso/kde/x86_64/livefs/usr/share/calamares/modules/tracking.conf exists in filesystem
calamares: /var/lib/manjaro-tools/buildiso/kde/x86_64/livefs/usr/share/calamares/modules/umount.conf exists in filesystem
calamares: /var/lib/manjaro-tools/buildiso/kde/x86_64/livefs/usr/share/calamares/modules/users.conf exists in filesystem
calamares: /var/lib/manjaro-tools/buildiso/kde/x86_64/livefs/usr/share/calamares/modules/usersq.conf exists in filesystem
calamares: /var/lib/manjaro-tools/buildiso/kde/x86_64/livefs/usr/share/calamares/modules/webview.conf exists in filesystem
calamares: /var/lib/manjaro-tools/buildiso/kde/x86_64/livefs/usr/share/calamares/modules/welcome.conf exists in filesystem
calamares: /var/lib/manjaro-tools/buildiso/kde/x86_64/livefs/usr/share/calamares/modules/welcomeq.conf exists in filesystem
calamares: /var/lib/manjaro-tools/buildiso/kde/x86_64/livefs/usr/share/calamares/modules/zfs.conf exists in filesystem
calamares: /var/lib/manjaro-tools/buildiso/kde/x86_64/livefs/usr/share/calamares/qml/calamares/slideshow/BackButton.qml exists in filesystem
calamares: /var/lib/manjaro-tools/buildiso/kde/x86_64/livefs/usr/share/calamares/qml/calamares/slideshow/ForwardButton.qml exists in filesystem
calamares: /var/lib/manjaro-tools/buildiso/kde/x86_64/livefs/usr/share/calamares/qml/calamares/slideshow/NavButton.qml exists in filesystem
calamares: /var/lib/manjaro-tools/buildiso/kde/x86_64/livefs/usr/share/calamares/qml/calamares/slideshow/Presentation.qml exists in filesystem
calamares: /var/lib/manjaro-tools/buildiso/kde/x86_64/livefs/usr/share/calamares/qml/calamares/slideshow/Slide.qml exists in filesystem
calamares: /var/lib/manjaro-tools/buildiso/kde/x86_64/livefs/usr/share/calamares/qml/calamares/slideshow/SlideCounter.qml exists in filesystem
calamares: /var/lib/manjaro-tools/buildiso/kde/x86_64/livefs/usr/share/calamares/qml/calamares/slideshow/qmldir exists in filesystem
calamares: /var/lib/manjaro-tools/buildiso/kde/x86_64/livefs/usr/share/calamares/qml/calamares/slideshow/qmldir.license exists in filesystem
calamares: /var/lib/manjaro-tools/buildiso/kde/x86_64/livefs/usr/share/calamares/settings.conf exists in filesystem
manjaro-live-skel: /var/lib/manjaro-tools/buildiso/kde/x86_64/livefs/etc/skel/.config/autostart/disable-dpms.desktop exists in filesystem
manjaro-live-skel: /var/lib/manjaro-tools/buildiso/kde/x86_64/livefs/etc/skel/.config/autostart/live-session.desktop exists in filesystem
manjaro-live-skel: /var/lib/manjaro-tools/buildiso/kde/x86_64/livefs/etc/skel/.config/autostart/pulseaudio-ctl.desktop exists in filesystem
screen: /var/lib/manjaro-tools/buildiso/kde/x86_64/livefs/etc/skel/.screenrc exists in filesystem
==> ERROR: Failed to install packages to new root
==> ERROR: Failed to install all packages
==> ERROR: A failure occurred in make_image_live().
Aborting...
--> overlayfs umount: [/var/lib/manjaro-tools/buildiso/kde/x86_64/livefs]
--> umount overlayfs: [/var/lib/manjaro-tools/buildiso/kde/x86_64/livefs]
tree;
βββ etc
β βββ locale.conf
β βββ locale.gen
β βββ localtime
β βββ lsb-release
β βββ pam.d
β β βββ sddm
β βββ sddm.conf
β βββ skel
β βββ X11
β βββ xorg.conf.d
β βββ 30-touchpad.conf
βββ usr
βββ share
βββ calamares
β βββ branding
β β βββ manjaro
β β βββ branding.desc
β β βββ show.qml
β βββ modules
β β βββ bootloader.conf
β β βββ chrootcfg.conf
β β βββ contextualprocess.conf
β β βββ displaymanager.conf
β β βββ finished.conf
β β βββ finishedq.conf
β β βββ fsresizer.conf
β β βββ fstab.conf
β β βββ grubcfg.conf
β β βββ initcpio.conf
β β βββ interactiveterminal.conf
β β βββ keyboard.conf
β β βββ keyboardq.conf
β β βββ license.conf
β β βββ locale.conf
β β βββ localeq.conf
β β βββ luksopenswaphookcfg.conf
β β βββ machineid.conf
β β βββ mhwdcfg.conf
β β βββ mount.conf
β β βββ netinstall.conf
β β βββ notesqml.conf
β β βββ oemid.conf
β β βββ openrcdmcryptcfg.conf
β β βββ owncloud.conf
β β βββ packagechooser.conf
β β βββ packagechooserq.conf
β β βββ packages.conf
β β βββ partition.conf
β β βββ plasmalnf.conf
β β βββ plymouthcfg.conf
β β βββ postcfg.conf
β β βββ preservefiles.conf
β β βββ rawfs.conf
β β βββ removeuser.conf
β β βββ servicescfg.conf
β β βββ services.conf
β β βββ shellprocess.conf
β β βββ tracking.conf
β β βββ umount.conf
β β βββ unpackfs.conf
β β βββ users.conf
β β βββ usersq.conf
β β βββ webview.conf
β β βββ welcome.conf
β β βββ welcomeq.conf
β β βββ zfs.conf
β βββ qml
β β βββ calamares
β β βββ slideshow
β β βββ BackButton.qml
β β βββ ForwardButton.qml
β β βββ NavButton.qml
β β βββ Presentation.qml
β β βββ qmldir
β β βββ qmldir.license
β β βββ SlideCounter.qml
β β βββ Slide.qml
β βββ settings.conf
βββ icons
β βββ default
β βββ index.theme
βββ mergen-logo.svg
βββ wallpapers
17 directories, 76 files```
