During build of cinnamon iso I get this error:
-> Call manjaro-live-setup ...
chroot: failed to run command '/usr/bin/manjaro-live-setup': No such file or directory
==> ERROR: A failure occurred in make_image_live().
Aborting...
--> overlayfs umount: [/var/lib/manjaro-tools/buildiso/cinnamon/x86_64/livefs]
--> umount overlayfs: [/var/lib/manjaro-tools/buildiso/cinnamon/x86_64/livefs]
Adding to the Packages-Live of cinnamon did not help
Hi,
Build Manjaro ISO
Prerequisites
lots of diskspace (skip this if your root is sufficiently large)
installing the tools
tools configuration
building
Diskspace
You need a lot diskspace - 15-20G per iso you intend to build
The tools
Install the manjaro-tools needed for building an ISO
sudo pacman -Syu git manjaro-tools-iso-git
Configure tools
With the tools installed copy the default tools configuration to your home
cp -R /etc/manjaro-tools ~/.config
Modify the tools configuration to poin…
Did you follow this tutorial ?
Yes, still the same error
Hmm - I just tested buildiso - no errors.
I am thinking your build mirror may be outdated - check it
cat ~/.config/manjaro-tools/manjaro-tools.conf | grep build_mirror
If you don’t have that file - check the default file
cat /etc/manjaro-tools/manjaro-tools.conf | grep build_mirror
Copy the folder /etc/manjaro-tools to your home ~/.config and edit the build_mirror to use an up-to-date mirror.
Are you running the latest ISO-PROFILES, can’t tell you how many times that has bit me in the a**!
Thanks @linux-aarhus it is working again after setup another more up to date mirror in the config file.
linux-aarhus:
Where is a list of build mirrors??? I can’t even find a reference to this on the main Wiki page.
There is no list - only a single mirror
# custom build mirror server
# build_mirror=https://manjaro.moson.eu/
Due to the nature of voluntary mirror providers, there is no guarantees…
Not everything is in the wiki - only the toe-dipping stuff - the configuration file is self documenting.
EDIT: 2026-09-07T06:14:00Z
As for a list of up-to-date mirrors - please see https://repo.manjaro.org
Ahhh, I thought that build mirrors were different than regular mirrors. Now, if the Gitlab site could stay up for a few minutes, I could actually try this again…
Phil is in the process of migrating our GitLab to a new Forgejo instance, so might not want to bother right now.
The Manjaro Development category is not for support issues.
Moved to Support with buildiso tag
