I am trying to build an ISO, I keep getting this error. I have tried different kernels, I have rebooted the host system a few times, i have cleaned build system. Any ideas?
sent 17 bytes received 12 bytes 58.00 bytes/sec
total size is 0 speedup is 0.00
==> ERROR: File '/var/lib/manjaro-tools/buildiso/cinnamon/x86_64/mhwdfs/opt/mhwd/pkg/*pkg.tar*' not found.
==> No packages modified, nothing to do.
==> ERROR: A failure occurred in make_image_mhwd().
Aborting...
--> overlayfs umount: [/var/lib/manjaro-tools/buildiso/cinnamon/x86_64/mhwdfs]
I did check and it was not there… I have solved the problem, I don’t know the issue but it is solved.
I backed up the ISO-Profiles directory, downloaded fresh version from GIT, copied all of my settings to new profile and everything is working, just got done uploading my new ISO.
I tried looking for a reason but just could not find one, my settings were exactly the same. But in case someone comes along and finds this same issue, at least it will give them something to try.
