Hello,
I’ve been trying to install fsearch and Kazam, and apparently they are not supported by pacman. For fsearch, the build instructions page says that it needs the following packages to build it:
git
build-essential (*)
automake
autopoint
autoconf
libtool
pkg-config (or pkgconfig )
intltool
autoconf-archive
libpcre3-dev (*)
libglib2.0-dev (*)
libgtk-3-dev (*)
libxml2-utils (*)
glib2-devel (*)
gtk3-devel (*)
In Manjaro, I have problems with the ones having “(*)” in front of them. I’m a beginner and it’s unclear and confusing to me where those packages are and how to install them.
Also, when trying to build Kazam, I’d get the following errors:
/usr/bin/kazam:32: PyGIWarning: Gtk was imported without specifying a version first. Use gi.require_version('Gtk', '3.0') before import to ensure that the right version gets loaded.
from gi.repository import Gtk
WARNING Kazam - Running from local directory, AppIndicator icons could be missing.
WARNING Kazam - Failed to correctly detect operating system.
File "/usr/bin/kazam", line 146, in <module>
from kazam.app import KazamApp
File "../kazam/app.py", line 35, in <module>
from kazam.backend.prefs import *
File "../kazam/backend/prefs.py", line 478, in <module>
prefs = Prefs()
File "../kazam/backend/prefs.py", line 119, in __init__
self.config = KazamConfig()
File "../kazam/backend/config.py", line 76, in __init__
ConfigParser.__init__(self, self.DEFAULTS[0]['keys'])
File "/usr/lib/python3.8/configparser.py", line 639, in __init__
self._read_defaults(defaults)
File "/usr/lib/python3.8/configparser.py", line 1219, in _read_defaults
self.read_dict({self.default_section: defaults})
File "/usr/lib/python3.8/configparser.py", line 754, in read_dict
self.set(section, key, value)
File "../kazam/backend/config.py", line 126, in set
self.add_section(section)
File "/usr/lib/python3.8/configparser.py", line 1208, in add_section
super().add_section(section)
File "/usr/lib/python3.8/configparser.py", line 656, in add_section
raise ValueError('Invalid section name: %r' % section)
ValueError: Invalid section name: 'DEFAULT'
Looks like there’s a problem with Gtk?
I’d appreciate your help.
Info about my system:
Kernel: 5.8.16-2-MANJARO x86_64 bits: 64 compiler: N/A
parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64
root=UUID=e7163391-d960-41ec-b9b2-63ffdbfd518d rw quiet
cryptdevice=UUID=d9153841-42fb-46e0-9b03-2ede24fa9ae9:luks-d9153841-42fb-46e0-9b03-2ede24fa9ae9
root=/dev/mapper/luks-d9153841-42fb-46e0-9b03-2ede24fa9ae9 apparmor=1
security=apparmor
resume=/dev/mapper/luks-14281edd-92f6-482c-b728-97bfe1826474
udev.log_priority=3
Desktop: Xfce 4.14.2 tk: Gtk 3.24.20 info: xfce4-panel wm: xfwm4
dm: LightDM 1.30.0 Distro: Manjaro Linux
Type: Laptop System: ASUSTeK product: X556UQK v: 1.0 serial: <filter>
Mobo: ASUSTeK model: X556UQK v: 1.0 serial: <filter>
UEFI: American Megatrends v: X556UQK.315 date: 01/24/2019
ID-1: BAT0 charge: 17.4 Wh condition: 17.4/38.0 Wh (46%) volts: 7.6/7.6
model: ASUSTeK ASUS Battery type: Li-ion serial: N/A status: Not charging
cycles: 439
Topology: Dual Core model: Intel Core i5-7200U bits: 64 type: MT MCP
arch: Amber Lake family: 6 model-id: 8E (142) stepping: 9 microcode: D6
L2 cache: 3072 KiB
bogomips: 21607
Speed: 500 MHz min/max: 400/3100 MHz Core speeds (MHz): 1: 500 2: 500 3: 500
4: 500
Type: l1tf
Device-1: Intel HD Graphics 620 vendor: ASUSTeK driver: i915 v: kernel
bus ID: 00:02.0 chip ID: 8086:5916
Device-2: NVIDIA GM108M [GeForce 940MX] vendor: ASUSTeK driver: nouveau
v: kernel bus ID: 01:00.0 chip ID: 10de:134d
Device-3: IMC Networks USB2.0 VGA UVC WebCam type: USB driver: uvcvideo
bus ID: 1-6:3 chip ID: 13d3:5a01 serial: <filter>
Display: x11 server: X.Org 1.20.9 driver: intel,nouveau
unloaded: modesetting alternate: fbdev,nv,vesa display ID: :0.0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 143 size: 340x190mm (13.4x7.5")
diag: 389mm (15.3")
OpenGL: renderer: Mesa Intel HD Graphics 620 (KBL GT2) v: 4.6 Mesa 20.1.8
direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus ID: 00:1f.3
chip ID: 8086:9d71
Sound Server: ALSA v: k5.8.16-2-MANJARO
vendor: ASUSTeK driver: r8169 v: kernel port: d000 bus ID: 02:00.0
chip ID: 10ec:8168
Device-2: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
vendor: AzureWave driver: ath10k_pci v: kernel port: d000 bus ID: 03:00.0
chip ID: 168c:0042
IF-ID-1: vmnet1 state: unknown speed: N/A duplex: N/A mac: <filter>
IF-ID-2: vmnet8 state: unknown speed: N/A duplex: N/A mac: <filter>
Local Storage: total: 931.51 GiB used: 62.31 GiB (6.7%)
ID-1: /dev/sda vendor: Seagate model: ST1000LM035-1RK172 size: 931.51 GiB
block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
rotation: 5400 rpm serial: <filter> rev: SDM1 scheme: GPT
ID-1: / raw size: 918.47 GiB size: 903.06 GiB (98.32%)
used: 62.31 GiB (6.9%) fs: ext4 dev: /dev/dm-0
ID-1: swap-1 type: partition size: 12.74 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/dm-1
System Temperatures: cpu: 39.0 C mobo: N/A
Fan Speeds (RPM): cpu: 2600
Processes: 215 Uptime: 1h 54m Memory: 11.58 GiB used: 2.01 GiB (17.3%)
Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: pacman: 1130 lib: 340
flatpak: 0 Shell: Bash v: 5.0.18 running in: xfce4-terminal inxi: 3.1.05
