Hi,
The links on the bottom point in no way.
https://wiki.manjaro.org/index.php?title=Build_Manjaro_ISOs_with_buildiso
I hope to build x86 ISO like arm ISO.
Hi,
Hi,
Two of those links had to point to archived.forum … Now is all corrected.
It works, I wrote this message with the iso image I built.
Question, why is this kernel install ?
Kernel: x86_64 Linux 5.4.150-1-MANJARO
why not the last one 5.14 ?
post scriptum : sound and video are working well
Om guessing it installs a lts kernel by default to make sure an EOL kernel doesn’t get installed
Provide the kernel argument when building the iso
buildiso -p xfce -k linux514
To have a more permanent setting
cp -R /etc/manjaro-tools ~/.config/manjaro-tools
Then edit the manjaro-tools.conf and set which kernel you will use - you can always override using commandline argument.
OK, I’ll try as soon as possible.
If I set with 510 the image will be created with the 5.10.70 LTS ? Right ?
I refereed to the Manjaro settings manager kernel manager
I did, it works
buildiso -f -p kde -b stable -k linux514
