Hello, as the title says, I have been trying to build an image with a custom default timezone, among other things**, before installation.
What I’ve tried so far:
. copied localtime symlink into /live-overlay/etc/ > failure*
. copied timeszone file that symlink points to into /live-overlay/etc/ and renamed it to localtime > failure*
. copied localtime symlink from live image after changing timezone into /live-overlay/etc/ > failure*
The desktop I am using for my custom iso is kde plasma, if that matters, I’m not sure if it does.
I am out of ideas. Any help is appreciated.
*by failure, I mean the timezone being set to UTC(the default) when booting into the newly created images.
**I was able to successfully add wallpapers and change packages thanks to the wiki.
