Hi all,
I’m facing a similar issue to other posted on the forum, but I’ve tried various resolutions and they don’t seem to be working for me, so I’m wondering if I’m missing something obvious
I’ve got a Lenovo X1 Carbon (no Nvidia, just integrated Intel GPU) on which I’ve run Manjaro just fine for about 2 years now.
However I ran a big set of updates about a week back, and since then I’ve been booting into a black screen. I can see the initial BIOS screen (I’m using UEFI, but I don’t know what else to call that first screen!), but after that everything just goes blank. I’ve tried waiting for a while, and tried switching over to other TTYs (Ctrl + Alt + F2/3/4 etc) but I don’t see anything happening. If I hit the Cap Lock key though I can see the light go on and off on it.
I then booted into a Live USB and a chroot and tried this troubleshooting guide, but it doesn’t work even after that.
Here’s some relevant info I found people asking for in other related threads:
[manjaro /]# mhwd -li
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
[manjaro /]# mhwd-kernel -li
Currently running: 6.1.30-1-MANJARO (linux61)
* linux61
* linux66
[manjaro /]# journalctl --boot=-1 --priority=4
Feb 19 08:24:32 manjaro-x1 kernel: MMIO Stale Data CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/processor_mmio_stale_data.html for more details.
Feb 19 08:24:32 manjaro-x1 kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
Feb 19 08:24:32 manjaro-x1 kernel: pnp 00:09: disabling [mem 0x000c0000-0x000c3fff] because it overlaps 0000:00:02.0 BAR 6 [mem 0x000c0000-0x000dffff]
Feb 19 08:24:32 manjaro-x1 kernel: pnp 00:09: disabling [mem 0x000c8000-0x000cbfff] because it overlaps 0000:00:02.0 BAR 6 [mem 0x000c0000-0x000dffff]
Feb 19 08:24:32 manjaro-x1 kernel: pnp 00:09: disabling [mem 0x000d0000-0x000d3fff] because it overlaps 0000:00:02.0 BAR 6 [mem 0x000c0000-0x000dffff]
Feb 19 08:24:32 manjaro-x1 kernel: pnp 00:09: disabling [mem 0x000d8000-0x000dbfff] because it overlaps 0000:00:02.0 BAR 6 [mem 0x000c0000-0x000dffff]
Feb 19 08:24:32 manjaro-x1 kernel: hpet_acpi_add: no address or irqs in _CRS
Feb 19 08:24:32 manjaro-x1 kernel: blacklist: Duplicate blacklisted hash bin:47ff1b63b140b6fc04ed79131331e651da5b2e2f170f5daef4153dc2fbc532b1
Feb 19 08:24:32 manjaro-x1 kernel: blacklist: Duplicate blacklisted hash bin:992d359aa7a5f789d268b94c11b9485a6b1ce64362b0edb4441ccc187c39647b
Feb 19 08:24:32 manjaro-x1 kernel: blacklist: Duplicate blacklisted hash bin:c452ab846073df5ace25cca64d6b7a09d906308a1a65eb5240e3c4ebcaa9cc0c
Feb 19 08:24:32 manjaro-x1 kernel: blacklist: Duplicate blacklisted hash bin:e051b788ecbaeda53046c70e6af6058f95222c046157b8c4c1b9c2cfc65f46e5
Feb 19 08:24:32 manjaro-x1 kernel: i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
Feb 19 08:24:32 manjaro-x1 kernel: usb: port power management may be unreliable
Feb 19 08:24:31 manjaro-x1 systemd-vconsole-setup[239]: KD_FONT_OP_GET failed while trying to get the font metadata: Invalid argument
Feb 19 08:24:31 manjaro-x1 systemd-vconsole-setup[239]: Fonts will not be copied to remaining consoles
Feb 19 08:24:32 manjaro-x1 systemd-journald[256]: File /var/log/journal/656c1c29990e41babd99eef65ae92ace/system.journal corrupted or uncleanly shut down, renaming and replacing.
Feb 19 08:24:32 manjaro-x1 kernel: ACPI Error: Needed [Integer/String/Buffer], found [Package] 0000000025f9f831 (20230628/exresop-469)
Feb 19 08:24:32 manjaro-x1 kernel: ACPI Error: AE_AML_OPERAND_TYPE, While resolving operands for [ToHexString] (20230628/dswexec-433)
Feb 19 08:24:32 manjaro-x1 kernel: ACPI Error: Aborting method \ADBG due to previous error (AE_AML_OPERAND_TYPE) (20230628/psparse-529)
Feb 19 08:24:32 manjaro-x1 kernel: ACPI Error: Aborting method \_SB.HIDD._DSM due to previous error (AE_AML_OPERAND_TYPE) (20230628/psparse-529)
Feb 19 08:24:32 manjaro-x1 kernel: ACPI: \_SB_.HIDD: failed to evaluate _DSM b356ecee-4244-8f40-a792-4edd4d758054 (0x3003)
Feb 19 08:24:33 manjaro-x1 kernel: resource: resource sanity check: requesting [mem 0x00000000fed10000-0x00000000fed15fff], which spans more than pnp 00:06 [mem 0xfed10000-0xfed13fff]
Feb 19 08:24:33 manjaro-x1 kernel: caller snb_uncore_imc_init_box+0x84/0xe0 [intel_uncore] mapping multiple BARs
Feb 19 08:24:33 manjaro-x1 systemd-vconsole-setup[356]: KD_FONT_OP_GET failed while trying to get the font metadata: Invalid argument
Feb 19 08:24:33 manjaro-x1 systemd-vconsole-setup[356]: Fonts will not be copied to remaining consoles
Feb 19 08:24:33 manjaro-x1 kernel: i801_smbus 0000:00:1f.4: Transaction timeout
Feb 19 08:24:33 manjaro-x1 kernel: i801_smbus 0000:00:1f.4: Failed terminating the transaction
Feb 19 08:24:33 manjaro-x1 kernel: i801_smbus 0000:00:1f.4: SMBus is busy, can't use it!
Feb 19 08:24:33 manjaro-x1 kernel: iwlwifi 0000:00:14.3: api flags index 2 larger than supported by driver
Feb 19 08:24:33 manjaro-x1 kernel: thermal thermal_zone6: failed to read out thermal zone (-61)
Feb 19 08:24:34 manjaro-x1 bluetoothd[438]: src/plugin.c:plugin_init() System does not support csip plugin
Feb 19 08:24:34 manjaro-x1 bluetoothd[438]: profiles/audio/micp.c:micp_init() D-Bus experimental not enabled
Feb 19 08:24:34 manjaro-x1 bluetoothd[438]: src/plugin.c:plugin_init() System does not support micp plugin
Feb 19 08:24:34 manjaro-x1 bluetoothd[438]: src/plugin.c:plugin_init() System does not support vcp plugin
Feb 19 08:24:34 manjaro-x1 bluetoothd[438]: src/plugin.c:plugin_init() System does not support mcp plugin
Feb 19 08:24:34 manjaro-x1 bluetoothd[438]: src/plugin.c:plugin_init() System does not support bass plugin
Feb 19 08:24:34 manjaro-x1 bluetoothd[438]: src/plugin.c:plugin_init() System does not support bap plugin
Feb 19 08:24:35 manjaro-x1 kernel: Bluetooth: hci0: Malformed MSFT vendor event: 0x02
Feb 19 08:24:35 manjaro-x1 kernel: Bluetooth: hci0: HCI LE Coded PHY feature bit is set, but its usage is not supported.
Feb 19 08:24:35 manjaro-x1 kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: Parent card not yet available, widget card binding deferred
[manjaro /]#
Please is anyone able to help?? I foolishly installed everything on a single partition so would prefer to not have to reinstall from scratch if possible, and hadn’t heard of Timeshift before this so hadn’t set it up
