❯ uname -pi; lsb_release # ~
unknown unknown
LSB Version: n/a
this all seems wrong, if it’s not could someone explain why it’s not?
unknown unknown
LSB Version: n/a
Hi Xenoterracide,
Welcome to the forum! This looks exactly like the answer you are looking for.
Hi @xenoterracide,
The useful commands are the following:
uname -a
lsb_release -a
You can see them in the man pages from the terminal.
Hope it help, regards
well that explains why those 2 return nothing, but not why lsb_release
is returning n/a
. Mostly concerned (but haven’t tested yet) because yadm
relies on lsb_release
first.
Did you try with lsb_release -a
