Hi,
With the old forum it was possible to create a bug report with an automatic message / formulare on the beginning like this one
What device are you using?
What edition of Manjaro-ARM is installed? (eg minimal, server, etc.)
When did you last run updates and reboot?
What package contains the bug?
Describe the bug the best you can. What where you doing when the bug happened?
Any workarounds or known fixes?
Edit: Unfortunately I can’t delete this post…
