Hello forum,
I signed up to report a weird behaviour I experienced with my new PC and installation.
HP EliteDesk 800 G4
i5-8500 with integrated GPU UHD 630
16 GB RAM
M2 SSD
4k screen at DisplayPort 1.2
Manjaro Gnome stable edition
updated daily
initially run with kernel 5.16, since 1+ week kernel 5.17RC
The computer hangs up repeatedly for up to a minute. btop shows very low CPU load during the freezes, followed by a spike when btop catches up. RAM is 60 % free, disk usage very low.
The freezes seemed to not depend on the open website, with the exception of Reddit. Here freezes occured roughly twice per minute instead of roughly every 10 minutes. Sluggishness was so bad that even typing was impossible.
Just switched to kernel 5.15 and the freezing is gone. The PC is responsive as expected.
When I set up this desktop with Manjaro Gnome 2 weeks ago, I also updated my old notebook to the same distribution. Lenovo Thinkpad X200s (2009) with Centrino Core 2 Duo L9400 and 2 GB RAM. This does not show any freezes under kernel 5.17.
Welcome to the forum!
Please post your system info as outlined here:
Welcome to Manjaro!
To allow all of us helpful people on this forum TO HELP YOU, we need some basic information about your system. This probably means you described the symptoms of your problem, but now we need some more information to know where the origin of your issue is exactly.
Someone else probably linked you to this tutorial, so if you’re reading this in response to a question, please click the link above this text to bring you to the full and unabridged text of the tutorial…
Please also see:
How verbose do you need it?
I just tried to post the result of inxi --admin --verbosity=7 --filter --width, but the forum software didn’t let mw. I’m not allowed o post links - but can’t see a link in the inxi report.
Paste the inxi
ouput between three backticks ` like this:
type or paste code here
See also:
Difficulty: ★☆☆☆☆
Formatting differences
Discourse – this forum’s engine – uses Markdown to format its posts, and removes “unnecessary” whitespace.
Terminal commands often produce output formatted so that they are better readable by the user, taking advantage of the monospaced font used.
Programming code often rely on indentation to make it more readable.
Using preformatting in Markdown
Markdown includes a pattern to provide preformatting when necessary.
You only need to put the part to f…
Kernel 5.15 is what I am running since yesterday, that solved the issue.
Before I ran kernels 5.16 and 5.17 RC from the Manjaro stable branch, installed with the Manjaro Settings tool.
Kernel: 5.15.21-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-5.15-x86_64
root=UUID=8d899a99-5ac8-4cbc-9151-9e8241d86bde rw rootflags=subvol=@ quiet
cryptdevice=UUID=9fac55b9-a634-46d1-a8bd-7c04ee2d7c64:luks-9fac55b9-a634-46d1-a8bd-7c04ee2d7c64
root=/dev/mapper/luks-9fac55b9-a634-46d1-a8bd-7c04ee2d7c64 splash
apparmor=1 security=apparmor
resume=/dev/mapper/luks-852715b4-5428-442e-a3f6-e05ffbb3d203
udev.log_priority=3
Desktop: GNOME 41.3 tk: GTK 3.24.31 wm: gnome-shell dm: GDM 41.3
Type: Desktop System: HP product: HP EliteDesk 800 G4 SFF v: N/A
serial: <superuser required> Chassis: type: 3 serial: <superuser required>
Mobo: HP model: 83E1 v: KBC Version 07.D1.00 serial: <superuser required>
UEFI: HP v: Q01 Ver. 02.18.00 date: 12/27/2021
RAM: total: 15.41 GiB used: 10.4 GiB (67.5%)
RAM Report:
Info: model: Intel Core i5-8500 bits: 64 type: MCP arch: Coffee Lake
family: 6 model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xEC
Topology: cpus: 1x cores: 6 smt: <unsupported> cache: L1: 384 KiB
desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB L3: 9 MiB
desc: 1x9 MiB
Speed (MHz): avg: 3900 min/max: 800/4100 scaling: driver: intel_pstate
governor: powersave cores: 1: 3900 2: 3900 3: 3900 4: 3900 5: 3900 6: 3900
bogomips: 36012
arch_capabilities arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt
cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts
epb ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr
ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr
nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln
pni popcnt pse pse36 pti pts rdrand rdseed rdtscp rep_good sdbg sep smap
smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
Type: l1tf
Device-1: Intel CoffeeLake-S GT2 [UHD Graphics 630] vendor: Hewlett-Packard
driver: i915 v: kernel ports: active: DP-6,DP-7
empty: DP-1, DP-2, DP-3, HDMI-A-1, HDMI-A-2, HDMI-A-3 bus-ID: 00:02.0
chip-ID: 8086:3e92 class-ID: 0300
Device-2: Logitech HD Pro Webcam C920 type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 1-9:3 chip-ID: 046d:082d
class-ID: 0102 serial: <filter>
Display: wayland server: X.org v: 1.21.1.3 with: Xwayland v: 21.1.4
compositor: gnome-shell driver: gpu: i915 display-ID: 0
Monitor-1: DP-6 model: Dell UP3214Q serial: <filter> built: 2013
res: 1920x2160 dpi: 70 gamma: 1.2 size: 698x392mm (27.5x15.4")
diag: 801mm (31.5") ratio: 16:9 modes: 1920x2160
Monitor-2: DP-7 model: Dell UP3214Q serial: <filter> built: 2013
diag: 801mm (31.5") ratio: 16:9 modes: max: 1920x2160 min: 720x400
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 21.3.5
direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci_intel_cnl
bus-ID: 00:1f.3 chip-ID: 8086:a348 class-ID: 0403
Sound Server-1: ALSA v: k5.15.21-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.45 running: yes
Device-1: Intel Ethernet I219-LM vendor: Hewlett-Packard driver: e1000e
v: kernel port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15bb class-ID: 0200
IF-ID-1: docker0 state: down mac: <filter>
IF-ID-2: tun0 state: unknown speed: 10 Mbps duplex: full mac: N/A
IP v4: <filter> scope: global
IP v6: <filter> virtual: stable-privacy scope: link
Device-1: luks-9fac55b9-a634-46d1-a8bd-7c04ee2d7c64 maj-min: 254:0
type: LUKS dm: dm-0 size: 221.22 GiB
Components:
p-1: nvme0n1p2 maj-min: 259:8 size: 221.22 GiB
Device-2: luks-852715b4-5428-442e-a3f6-e05ffbb3d203 maj-min: 254:1
type: LUKS dm: dm-1 size: 16.95 GiB
Components:
p-1: nvme0n1p3 maj-min: 259:9 size: 16.95 GiB
Local Storage: total: 7.74 TiB used: 3.52 TiB (45.5%)
ID-1: /dev/nvme0n1 maj-min: 259:6 vendor: Innovation IT model: N/A
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: T0918A0L temp: 30.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Toshiba model: N/A
lanes: 4 type: SSD serial: <filter> rev: AGHA4101 temp: 27.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 type: USB vendor: Seagate
model: Backup+ Hub BK size: 7.28 TiB block-size: physical: 4096 B
logical: 512 B type: N/A serial: <filter> rev: D785 scheme: GPT
ID-1: / raw-size: 221.22 GiB size: 221.22 GiB (100.00%)
used: 63.44 GiB (28.7%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-9fac55b9-a634-46d1-a8bd-7c04ee2d7c64 label: N/A
uuid: 8d899a99-5ac8-4cbc-9151-9e8241d86bde
used: 712 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:7
label: NO_LABEL uuid: 8ED5-8B1C
ID-3: /home raw-size: 221.22 GiB size: 221.22 GiB (100.00%)
ID-4: /run/media/axl/Video-C raw-size: 7.28 TiB size: 7.28 TiB (100.00%)
used: 3.46 TiB (47.6%) fs: btrfs dev: /dev/sda1 maj-min: 8:1 label: Video-C
uuid: 685b52af-eff8-48b4-bcbb-ad352e61a7cc
ID-5: /var/cache raw-size: 221.22 GiB size: 221.22 GiB (100.00%)
ID-6: /var/log raw-size: 221.22 GiB size: 221.22 GiB (100.00%)
ID-1: swap-1 type: partition size: 16.95 GiB used: 1.5 GiB (8.8%)
priority: -2 dev: /dev/dm-1 maj-min: 254:1
mapped: luks-852715b4-5428-442e-a3f6-e05ffbb3d203 label: swap
uuid: ef308308-33af-41a1-8093-6ee705f39ef1
ID-1: /dev/nvme1n1p1 maj-min: 259:1 size: 529 MiB fs: ntfs
label: Wiederherstellung uuid: 644081904081699E
ID-2: /dev/nvme1n1p2 maj-min: 259:2 size: 99 MiB fs: vfat label: N/A
uuid: E281-A4C3
ID-3: /dev/nvme1n1p3 maj-min: 259:3 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-4: /dev/nvme1n1p4 maj-min: 259:4 size: 237.18 GiB fs: ntfs label: N/A
uuid: C6EE8231EE821A37
ID-5: /dev/nvme1n1p5 maj-min: 259:5 size: 675 MiB fs: ntfs label: N/A
uuid: 08CCE29BCCE281F4
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
Device-1: 1-4:2 info: Logitech M-U0007 [Corded Mouse M500] type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s
power: 98mA chip-ID: 046d:c069 class-ID: 0301
Hub-2: 1-5:5 info: Seagate RSS LLC Backup Plus Hub ports: 3 rev: 2.1
speed: 480 Mb/s power: 100mA chip-ID: 0bc2:ab44 class-ID: 0900
Device-1: 1-9:3 info: Logitech HD Pro Webcam C920 type: Video,Audio
power: 500mA chip-ID: 046d:082d class-ID: 0102 serial: <filter>
Device-2: 1-13:4 info: Cherry GmbH G83 (RS 6000) Keyboard type: Keyboard
power: 100mA chip-ID: 046a:0011 class-ID: 0301
Hub-3: 2-0:1 info: Super-speed hub ports: 10 rev: 3.1 speed: 10 Gb/s
Hub-4: 2-6:2 info: Seagate RSS LLC Backup+ Hub ports: 3 rev: 3.0
speed: 5 Gb/s chip-ID: 0bc2:ab45 class-ID: 0900
Device-1: 2-6.1:3 info: Seagate RSS LLC Backup Plus Hub (Mass Storage)
type: Mass Storage driver: uas interfaces: 1 rev: 3.1 speed: 5 Gb/s
chip-ID: 0bc2:ab38 class-ID: 0806 serial: <filter>
System Temperatures: cpu: 63.0 C pch: 52.0 C mobo: N/A
Processes: 367 Uptime: 9h 3m wakeups: 19 Init: systemd v: 250
tool: systemctl Compilers: gcc: 11.1.0 clang: 13.0.1 Packages: pacman: 1828
lib: 392 flatpak: 0 Shell: Zsh v: 5.8 running-in: gnome-terminal
inxi: 3.3.13
