[Bug] Marco with compositor doesn't work after reboot on Raspberry pi4
Please supply this information when submitting a bug report.
  • What device are you using?
    Raspberry pi v4 b 2GB
  • What edition of Manjaro-ARM is installed? (eg minimal, server, etc.)
    Mate via manjaro-arm-installer
  • When did you last run updates and reboot?
    Latest updates
  • What package contains the bug?
    Marco? Mate tweak
  • Describe the bug the best you can. What where you doing when the bug happened?
    After enabling Marco with compositor in Mate tweak gui it works, windows move faster on screen and have shadows. But after reboot it is lost and compositor gone
  • Any workarounds or known fixes?
Sounds like the config is not getting written. Can you post the content of it's config file?
I don't know Marco, so I have no idea how or why it does what it does. :slight_smile:
After reboot in Mate tweak it's selected Marco with composition, the correct one but it doesn't load/activated at startup. I'm not close to rpi now but if you tell me what files should I paste here next time I can do that
Oh yeah, I forgot. MATE is also proabbly using dconf, so no config files to view.
Maybe you can spot something in dconf-editor.
Yes, I have changed settings with dconf-editor and it is persistent after reboot. So it's a Mate tweak bug.
