Bug, manjaro legacy
when i right click on app in the dock i get the pop up at up left corner and i can’t press it
i am using manjaro legacy
OS Name: Manjaro Linux; Build ID: rolling
Gnome Version: 40.3.0
Hello,
From Extensions enable User-Theme, then go to Tweaks and set the shell theme to Default, then open Layouts Switcher again and set to Manjaro then back to Manjaro Legacy.
still same problem didn’t fix it
Since i can’t reproduce the issue, i’ll ping @Chrysostomus as he definitely knows most of Layouts Switcher, and quite possible i’m missing something …
Getting the same bug in non-legacy version. Changing to DashToPanel instead of dock fixes it for me.
I have the same bugs when i try to change layout to Manjaro Legacy
The issue has already been fixed. First make sure you’re fully up to date. You might also try uninstalling / reinstalling gnome-shell-extension-dash-to-dock. Be sure and restart GNOME Shell or log out / login after.
Also make sure Dash to Dock is only installed once listed under Built-In and not Manually Installed in the Extensions application.
