Bug libreoffice-still 7.0.5-3
Dear All,
I have a bug with m installation of Libreoffice
pacman -Q libreoffice
libreoffice
Fatal exception: Signal 11
Stack:
/usr/lib/libreoffice/program/libuno_sal.so.3(+0x3ed64)[0x7f60ac809d64]
/usr/lib/libreoffice/program/libuno_sal.so.3(+0x3eeec)[0x7f60ac809eec]
/usr/lib/libc.so.6(+0x3cf80)[0x7f60ac4f1f80]
/usr/lib/libreoffice/program/libuno_cppu.so.3(+0x1486d)[0x7f60abbef86d]
/usr/lib/libreoffice/program/libuno_cppu.so.3(+0x14b54)[0x7f60abbefb54]
/usr/lib/libreoffice/program/libutllo.so(+0x6338b)[0x7f60a979f38b]
/usr/lib/libreoffice/program/libutllo.so(+0x63f26)[0x7f60a979ff26]
/usr/lib/libreoffice/program/libutllo.so(_ZN3utl10ConfigItemC2ERKN3rtl8OUStringE14ConfigItemMode+0x81)[0x7f60a9796da1]
/usr/lib/libreoffice/program/libutllo.so(+0xaeb84)[0x7f60a97eab84]
/usr/lib/libreoffice/program/libutllo.so(_ZN19SvtSysLocaleOptionsC1Ev+0x12e)[0x7f60a97ec09e]
/usr/lib/libreoffice/program/libvcllo.so(_Z7InitVCLv+0x1bd)[0x7f60a937c63d]
/usr/lib/libreoffice/program/libvcllo.so(_Z10ImplSVMainv+0x106)[0x7f60a937dfa6]
/usr/lib/libreoffice/program/libsofficeapp.so(soffice_main+0xa8)[0x7f60ac73e8d8]
/usr/lib/libreoffice/program/soffice.bin(+0x102e)[0x55c1ef0a002e]
/usr/lib/libc.so.6(__libc_start_main+0xd5)[0x7f60ac4dcb25]
/usr/lib/libreoffice/program/soffice.bin(+0x106e)[0x55c1ef0a006e]
inxi -F
System:    Host: i7 Kernel: 5.10.34-1-MANJARO x86_64 bits: 64 Desktop: Xfce 4.16.0 Distro: Manjaro Linux
Machine:   Type: Desktop Mobo: ASUSTeK model: P9X79-WS-SYS v: Rev 1.xx serial: <superuser required>
           UEFI: ASUSTeK (Licensed from AMI) v: 4304 date: 12/05/2013
CPU:       Info: Quad Core model: Intel Core i7-4820K bits: 64 type: MT MCP cache: L2: 10 MiB
           Speed: 1352 MHz min/max: 1200/3900 MHz Core speeds (MHz): 1: 1352 2: 2035 3: 1243 4: 2023 5: 1455 6: 1584 7: 1488
           8: 1266
Graphics:  Device-1: NVIDIA GF119 [GeForce GT 610] driver: nvidia v: 390.143
           Device-2: Microdia Webcam Vitade AF type: USB driver: uvcvideo
           Display: x11 server: X.Org 1.20.11 driver: loaded: nvidia resolution: 1: 1920x1080~60Hz 2: 1920x1080~60Hz
           OpenGL: renderer: GeForce GT 610/PCIe/SSE2 v: 4.6.0 NVIDIA 390.143
Audio:     Device-1: Intel C600/X79 series High Definition Audio driver: snd_hda_intel
           Device-2: NVIDIA GF119 HDMI Audio driver: snd_hda_intel
           Device-3: Logitech G430 Surround Sound Gaming Headset type: USB driver: hid-generic,snd-usb-audio,usbhid
           Device-4: Compal (LCS) USB Audio Device type: USB driver: snd-usb-audio
           Sound Server-1: ALSA v: k5.10.34-1-MANJARO running: yes
           Sound Server-2: PulseAudio v: 14.2 running: yes
           Sound Server-3: PipeWire v: 0.3.26 running: yes
Network:   Device-1: Intel 82579V Gigabit Network driver: e1000e
           IF: eno1 state: down mac: ac:22:0b:89:8f:d2
           Device-2: Intel 82574L Gigabit Network driver: e1000e
           IF: enp11s0 state: up speed: 1000 Mbps duplex: full mac: ac:22:0b:89:d6:a4
Bluetooth: Device-1: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) type: USB driver: btusb
           Report: bt-adapter ID: hci0 state: up address: 00:1A:7D:DA:71:13
Drives:    Local Storage: total: 2.84 TiB used: 2.26 TiB (79.5%)
           ID-1: /dev/sda vendor: Samsung model: SSD 850 EVO 120GB size: 111.79 GiB
           ID-2: /dev/sdb vendor: Toshiba model: DT01ACA200 size: 1.82 TiB
           ID-3: /dev/sdc type: USB vendor: Seagate model: ST1000LM025 HN-M101ABB size: 931.51 GiB
Partition: ID-1: / size: 108.62 GiB used: 93.41 GiB (86.0%) fs: ext4 dev: /dev/sda2
           ID-2: /boot/efi size: 951.1 MiB used: 144 KiB (0.0%) fs: vfat dev: /dev/sda1
Swap:      Alert: No swap data was found.
Sensors:   System Temperatures: cpu: 41.0 C mobo: N/A gpu: nvidia temp: 53 C
Info:      Processes: 457 Uptime: 15h 25m Memory: 31.31 GiB used: 11.34 GiB (36.2%) Shell: Bash inxi: 3.3.04
Thank you
Is your system fully synced?
sudo pacman -Syu
If yes - then :man_shrugging: - you could simply install libreoffice-fresh - personal experience is, it generally works better.
bugs within upstream packages are reported upstream https://bugs.documentfoundation.org/
Yes, it is.
core is up to date
extra is up to date
community is up to date
multilib is up to date
:: Starting full system upgrade…
there is nothing to do
Resolved. I deleted the user configuration of libreoffice.
where is that located? probably not /etc/libreoffice ?
It’s in .config/libreoffice
so would you remove the entire ~/.config/libreoffice/ folder, or just parts of it?
You can remove it entirely, it will be regenerate after install of libreoffice (maybe on startup of program without uninstall, I don’t remember).
Thx 4 your response I did no see the question
