Hi, everyone.
I tried to configure KDE calendar (digital clock) widget to add ownCloud calendar via the CalDAV protocol.
Like the example:
I installed korganizer
and kdepim-addons
, but Digital Clock Setting does not show text and GUI of kdepim-addons
I tried to change default theme, the same issue again…
Logger:
file:///usr/lib/qt/qml/org/kde/kirigami.2/FormLayout.qml:313:9: QML QQuickItem* (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "preferredWidth"
file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/configuration/ConfigurationAppletPage.qml:50:5: QML Loader: Binding loop detected for property "height"
file:///usr/share/plasma/plasmoids/org.kde.plasma.battery/contents/ui/CompactRepresentation.qml:75:17: Unable to assign [undefined] to int
Error: cannot change the containment to AppletsLayout
Both point size and pixel size set. Using pixel size.
file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/configuration/ConfigurationAppletPage.qml:71: TypeError: Cannot read property 'cfg_objectNameChanged' of null
file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/configuration/ConfigurationAppletPage.qml:58: TypeError: Cannot read property 'implicitHeight' of null
file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/configuration/AppletConfiguration.qml:212: TypeError: Cannot read property 'source' of null
QQmlEngine::setContextForObject(): Object already has a QQmlContext
Last version 21.1.0 of Manjaro KDE
Branch: Stable
