[BUG] Fresh install, sddm-greeter dumped core
Hey all
I've found today that if you download the current image ( Manjaro-ARM-lxqt-rpi3-19.04) for Manjaro LXQT for RPi3 (I'm using a B+) and do a pacman -Syu, the current package versions result in sddm-greeter failing to start and causing a hang.
You can, however, login via ctrl+alt+f2 (I never learned the real name for this), start startx and run startlxqt to get into the DE.
Here is the message from journalctl:
Process 585 (sddm-greeter) of user 1000 dumped core.
Stack trace of thread 585:
#0 0x0000ffff950d2494 raise (libc.so.6)
#1 0x0000ffff950bfe68 abort (libc.so.6)
#2 0x0000ffff9547bfdc _ZNK14QMessageLogger5fatalEPKcz (libQt5Core.so.5)
#3 0x0000ffff95a9e090 _ZN22QGuiApplicationPrivate25createPlatformIntegrationEv (libQt5Gui.so.5)
#4 0x0000ffff95a9e5a8 _ZN22QGuiApplicationPrivate21createEventDispatcherEv (libQt5Gui.so.5)
#5 0x0000ffff956a3524 _ZN23QCoreApplicationPrivate4initEv (libQt5Core.so.5)
#6 0x0000ffff95aa0598 _ZN22QGuiApplicationPrivate4initEv (libQt5Gui.so.5)
#7 0x0000ffff95aa133c _ZN15QGuiApplicationC1ERiPPci (libQt5Gui.so.5)
#8 0x0000aaaae552be38 main (sddm-greeter)
#9 0x0000ffff950c02a4 __libc_start_main (libc.so.6)
#10 0x0000aaaae552c6b0 _start (sddm-greeter)
#11 0x0000aaaae552c6b0 _start (sddm-greeter)
We have had multiple reports of this from 3B+ users.
But I have had no issues like this on my regular 3B.
The Core dump trace does not tell me much. :frowning:
The SDDM package used is from Arch Linux ARM.
Can you try installing Arch Linux ARM, update and reboot? Just to see if it's a problem there aswell.
Sure, i'll report back soon :slight_smile:
I was hoping to find info around for autologin and booting straight to lxqt (This pi is just a stats display monitor essentially) but since it's already dead in the water I'll see if I can reproduce with arch linux arm.
Thanks.
If the same issue happens on ALARM, you can try installing sddm-n2 on Manjaro ARM instead.
It's just the 0.15 version of SDDM instead of 0.18.1.
I am using the current Manjaro image on my RPi 3B+ and I did have similar issues at first. I even upgraded everything again today and rebooted all still seems good.
I have no issues at present ( after fixing the sound issue) except no VC4 hardware decoding with the GPU using the mainline kernel so I compiled and installed the Pi Foundation 64 bit kernel and it's overlays to have it. I spend most of my time viewing videos with mpv so GPU hardware decoding is a must. I still use the rest of the manjaro image though and really like it.
Here is what I did and and really do not know what the culprit was at this point:
First off I did not go through the setting up the user account properly for some reason and had to re-burn the image.
It would not bring up the sddm login until I:
Updated the the system with sudo pacman -Syu
Re-installed sddm
I can not remember but seems like I also did what was recommended in the release statement.
I couldn't reproduce this the other day with arch on ALARM sadly, playing with it again today...
Okay rolling back to sddm-n2 worked perfectly, with the new config. Just had to rename config to replace, now all is well. weird.
This topic was automatically closed after 90 days. New replies are no longer allowed.
