romu
18 January 2021 17:56
1
Good evening friends,
First of all sorry for my english ^^
I wanted some help with running my pc under KDE.
Since last update … unable to dual screen computer.
Here are the GPUs:
OpenGL renderer string: Mesa Intel® UHD Graphics 630 (CFL GT2)
OpenGL renderer string: GeForce GTX 1050/PCIe/SSE2
I have the impression that the rendering goes through the intel and not the nvdia.
How to solve the problem ?
Thanks for your help
pobrn
18 January 2021 17:57
2
Please post the output of inxi -Gazy
and xrandr --listproviders
romu
18 January 2021 18:02
3
thank you for your quick help
here is the info
Device-1: Intel UHD Graphics 630 vendor: ASUSTeK driver: i915 v: kernel
bus ID: 00:02.0 chip ID: 8086:3e9b
Device-2: NVIDIA GP107M [GeForce GTX 1050 Mobile] vendor: ASUSTeK
driver: nvidia v: 455.45.01 alternate: nouveau,nvidia_drm bus ID: 01:00.0
chip ID: 10de:1c8d
Device-3: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo
bus ID: 1-11:3 chip ID: 13d3:56a2 serial: <filter>
Display: server: X.Org 1.20.10 compositor: kwin_x11 driver: intel,nvidia
unloaded: modesetting,nouveau alternate: fbdev,nv,vesa display ID: :0
screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 128 size: 380x220mm (15.0x8.7")
diag: 439mm (17.3")
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 20.3.1
direct render: Yes
Providers: number : 2
Provider 0: id: 0x45 cap: 0xb, Source Output, Sink Output, Sink Offload crtcs: 4 outputs: 2 associated providers: 1 name:Intel
Provider 1: id: 0x220 cap: 0x2, Sink Output crtcs: 4 outputs: 1 associated providers: 1 name:NVIDIA-G0
The second display is not currently connected. But I can do it when needed
pobrn
18 January 2021 18:06
6
Please post the output of head -n999 /usr/share/xorg.conf.d/*
and mhwd -li
as well.
romu
18 January 2021 18:10
7
I don’t have xorg.conf.d folder
i don’t know if it can help
pobrn
18 January 2021 18:13
8
This issue seems to be exactly the same as this one . The simplest workaround to use the 5.9 kernel until the newer NVIDIA drivers reach the stable repositories.
Can you post the output of pacman -Qs nvidia
romu
18 January 2021 18:16
9
local/lib32-libvdpau 1.4-1
Nvidia VDPAU library
local/lib32-nvidia-utils 455.45.01-3
NVIDIA drivers utilities (32-bit)
local/libvdpau 1.4-1
local/linux510-nvidia 455.45.01-10.0 (linux510-extramodules)
NVIDIA drivers for linux.
local/linux54-nvidia 455.45.01-6 (linux54-extramodules)
local/mhwd-nvidia 455.45.01-3
MHWD module-ids for nvidia 455.45.01
local/mhwd-nvidia-340xx 340.108-1
MHWD module-ids for nvidia 340.108
local/mhwd-nvidia-390xx 390.138-1
MHWD module-ids for nvidia 390.138
local/nvidia-prime 1.0-4
NVIDIA Prime Render Offload configuration and utilities
local/nvidia-utils 455.45.01-2
local/xf86-video-nouveau 1.0.16-2 (xorg-drivers)
Open Source 3D acceleration driver for nVidia cards
The update removed me precisely 5.9.16 for incompatibility … And I retested on 5.4.85 but without success
pobrn
18 January 2021 18:19
10
Can you boot into Linux 5.4, and post the output of inxi -Gazy
from there as well?
I made a typo, the fixed command: head -n999 /usr/share/X11/xorg.conf.d/*
. Please post its output as well as the output of head -n999 /etc/X11/xorg.conf.d/*
romu
18 January 2021 18:27
11
Good news, it works fine in 5.4 :).
I just reset nvdia-prime.
I go back to 5.10, to place your order and test your order again
romu
18 January 2021 18:30
12
==> /etc/X11/xorg.conf.d/00-keyboard.conf <==
# Read and parsed by systemd-localed. It's probably wise not to edit this file
# manually too freely.
Section "InputClass"
Identifier "system-keyboard"
MatchIsKeyboard "on"
Option "XkbLayout" "fr"
Option "XkbModel" "pc105"
Option "XkbVariant" "sundeadkeys"
EndSection
==> /etc/X11/xorg.conf.d/30-touchpad.conf <==
Identifier "touchpad"
Driver "libinput"
MatchIsTouchpad "on"
Option "Tapping" "on"
EndSection
==> /etc/X11/xorg.conf.d/90-mhwd.conf <==
## Generated by mhwd - Manjaro Hardware Detection
XRaTiX
18 January 2021 18:31
13
If you want 5.10 kernel,need to wait for the next stable release with the new kernel 5.10.7 and the nvidia driver 460,both version fix the dual screen issue.
pobrn
18 January 2021 18:32
14
Well, then you need to wait until the next NVIDIA update and you can continue using Linux 5.10.
romu
18 January 2021 18:35
15
As long as the pc is functional.
No problem.
thank you
system
Closed
2 February 2021 18:35
16
