Budgie glitch
When the panel is on the top or on the left and I click on the menu it leaves an outline of the menu after the menu closes, as shown in the image. When on the bottom it does not.
System info?
inxi -Fxxxz
and updated?
sudo pacman-mirrors -f && sudo pacman -Syyuu
This is my system, it's older, but I don't have problems with any other desktop.
Update ... I was wrong the menu outline does happen when the panel is on the bottom too.
 Host: mcfit-pc Kernel: 5.0.5-rt3-MANJARO x86_64 bits: 64 compiler: gcc
  v: 8.2.1 Desktop: Budgie 10.5 info: budgie-panel wm: budgie-wm
  dm: LightDM 1.28.0 Distro: Manjaro Linux
  Type: Desktop System: HP-Pavilion product: BK238AA-ABL HPE-142c v: N/A
  serial: <filter> Chassis: Hewlett-Packard type: 3 serial: <filter>
  Mobo: MSI model: IONA v: 1.0 serial: <filter> BIOS: American Megatrends
  v: 5.15 date: 06/25/2010
  Topology: Dual Core model: Intel Core i5 650 bits: 64 type: MT MCP
  arch: Nehalem rev: 2 L2 cache: 4096 KiB
  flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 25539
  Speed: 1236 MHz min/max: 1200/3201 MHz boost: enabled Core speeds (MHz):
  1: 1239 2: 1367 3: 1253 4: 1375
  Device-1: AMD RV710 [Radeon HD 4350/4550] vendor: Micro-Star MSI
  driver: radeon v: kernel bus ID: 01:00.0 chip ID: 1002:954f
  Display: x11 server: X.org 1.20.4 driver: ati,radeon unloaded: modesetting
  alternate: fbdev,vesa compositor: budgie-wm resolution: <xdpyinfo missing>
  OpenGL: renderer: AMD RV710 (DRM 2.50.0 / 5.0.5-rt3-MANJARO LLVM 8.0.0)
  v: 3.3 Mesa 19.0.1 compat-v: 3.0 direct render: Yes
  Device-1: Intel 5 Series/3400 Series High Definition Audio
  vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus ID: 00:1b.0
  chip ID: 8086:3b56
  Device-2: AMD RV710/730 HDMI Audio [Radeon HD 4000 series]
  vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus ID: 01:00.1
  chip ID: 1002:aa38
  Sound Server: ALSA v: k5.0.5-rt3-MANJARO
  vendor: Hewlett-Packard driver: r8168 v: 8.045.08-NAPI port: d800
  bus ID: 02:00.0 chip ID: 10ec:8168
  IF: enp2s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-2: Qualcomm Atheros AR928X Wireless Network Adapter driver: ath9k
  v: kernel port: e800 bus ID: 04:00.0 chip ID: 168c:002a
  IF: wlp4s0 state: down mac: <filter>
  Local Storage: total: 931.51 GiB used: 17.62 GiB (1.9%)
  ID-1: /dev/sda vendor: Hitachi model: HDT721010SLA360 size: 931.51 GiB
  speed: 3.0 Gb/s rotation: 7200 rpm serial: <filter> rev: A39D scheme: MBR
  Hardware-1: Intel SATA Controller [RAID mode] driver: ahci v: 3.0
  port: b400 bus ID: 00:1f.2 chip ID: 8086.2822 rev: 06
  ID-1: / size: 907.23 GiB used: 17.62 GiB (1.9%) fs: ext4 dev: /dev/sda1
  ID-2: swap-1 size: 8.80 GiB used: 1.8 MiB (0.0%) fs: swap dev: /dev/sda2
  System Temperatures: cpu: 26.0 C mobo: N/A gpu: radeon temp: 62 C
  Processes: 224 Uptime: 1d 58m Memory: 7.72 GiB used: 1.94 GiB (25.2%)
  Init: systemd v: 241 Compilers: gcc: 8.2.1 Shell: bash v: 5.0.2
  running in: gnome-terminal inxi: 3.0.32
I installed Budgie on my Mac using Virtualbox and the same problem happens.
Cheers
I've seen the same thing - the bottom edge (sometimes also the right edge) of the menu persists after it hides. This was on two entirely different laptops, one high end with an NVidia 1080 and one portable which must be just integrated graphics. This is a brand new install (it did the same thing when I booted in from USB to do the install, and I hoped maybe an update would resolve - it didn't).
I had to choose nonfree drivers when installing (assume that's what it'd select for the actual install?), because it didn't seem to want to get past a black screen using the other drivers. I'm used to Linux Mint so I might be a little slow on the troubleshooting but I'm willing to entertain suggested resolutions.
manjaro-budgie-18.0.4-stable-x86_64
Sorry for the 2nd reply as I can't seem to do an edit - but I want to add:
I've also installed Budgie onto my primary PC (not a laptop) which runs Linux Mint, and I haven't seen this. I'll try some of the suggestions in the post above later when I get a chance.
This might be referred to here.
"For our Budgie users, we are now using Budgie git builds with GNOME 3.32 support. This support was graciously provided by the Ubuntu Budgie developers and we’re grateful for their contribution to the Budgie Desktop. We have performed a few changes on top of this new support to ensure we continue to use Budgie WM schemas (to make any transitions between stack upgrades and newer Budgie releases occur more smoothly), as well as fixed instances where we would not be performing a redraw on closing the Budgie Menu, resulting in artifacts."
