This is after compositor is enabled again (I will restart and give the log without compositor):
Aug 06 23:43:55 ManjaroTower systemsettings[1370]: file:///usr/lib/qt/qml/org/kde/kirigami.2/PlaceholderMessage.qml:235:5: QML Heading: Binding loop detected for property "verticalAlignment"
Aug 06 23:43:55 ManjaroTower systemsettings[1370]: QQmlEngine::setContextForObject(): Object already has a QQmlContext
Aug 06 23:43:55 ManjaroTower kwin_x11[604]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 3482, resource id: 73400329, major code: 18 (ChangeProperty), minor code: 0
Aug 06 23:43:55 ManjaroTower plasmashell[649]: qml: PlasmaExtras.ScrollArea is deprecated. Use PlasmaComponents3.ScrollView instead.
Aug 06 23:43:55 ManjaroTower plasmashell[649]: qt.svg: Cannot open file '/usr/share/icons/Humanity/devices/48/printer.svg', because: No such file or directory
Aug 06 23:43:56 ManjaroTower plasmashell[649]: qml: PlasmaExtras.ScrollArea is deprecated. Use PlasmaComponents3.ScrollView instead.
Aug 06 23:43:56 ManjaroTower kernel: usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
Aug 06 23:44:03 ManjaroTower kernel: kauditd_printk_skb: 2 callbacks suppressed
Aug 06 23:44:07 ManjaroTower kernel: usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
Aug 06 23:44:08 ManjaroTower kded5[601]: kf.bluezqt: PendingCall Error: "Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken."
Aug 06 23:44:08 ManjaroTower pulseaudio[668]: GetManagedObjects() failed: org.freedesktop.DBus.Error.TimedOut: Failed to activate service 'org.bluez': timed out (service_start_timeout=25000ms)
Aug 06 23:44:14 ManjaroTower kernel: usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
Aug 06 23:44:19 ManjaroTower kernel: usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
Aug 06 23:44:25 ManjaroTower kernel: usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
Aug 06 23:44:29 ManjaroTower kernel: usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
Aug 06 23:44:34 ManjaroTower kernel: usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
Aug 06 23:44:38 ManjaroTower kernel: usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
Aug 06 23:44:42 ManjaroTower kernel: usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
Aug 06 23:44:47 ManjaroTower kernel: usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
Aug 06 23:44:54 ManjaroTower kernel: usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
Aug 06 23:44:59 ManjaroTower kernel: usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
Aug 06 23:45:06 ManjaroTower kernel: usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
Aug 06 23:45:12 ManjaroTower kernel: usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
Aug 06 23:45:19 ManjaroTower kernel: usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
Aug 06 23:45:24 ManjaroTower kernel: usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
Aug 06 23:45:28 ManjaroTower kernel: usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
Aug 06 23:45:32 ManjaroTower kernel: usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
Aug 06 23:45:37 ManjaroTower kernel: usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
Aug 06 23:45:43 ManjaroTower kernel: usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
Aug 06 23:45:51 ManjaroTower kernel: usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
Aug 06 23:45:55 ManjaroTower kernel: usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
Aug 06 23:46:03 ManjaroTower kernel: usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
Aug 06 23:46:12 ManjaroTower kernel: usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
Aug 06 23:46:17 ManjaroTower kernel: usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
Aug 06 23:46:21 ManjaroTower kernel: usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
Aug 06 23:46:25 ManjaroTower kernel: usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
Aug 06 23:46:29 ManjaroTower kernel: usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
Aug 06 23:46:33 ManjaroTower kernel: usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
Aug 06 23:46:38 ManjaroTower kernel: usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
Aug 06 23:46:42 ManjaroTower kernel: usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
Aug 06 23:46:48 ManjaroTower kernel: usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
Aug 06 23:46:52 ManjaroTower kernel: usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
Aug 06 23:46:57 ManjaroTower kernel: usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
Aug 06 23:47:02 ManjaroTower kernel: usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
Aug 06 23:47:08 ManjaroTower kernel: usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
Aug 06 23:47:11 ManjaroTower kwin_x11[604]: kwin_core: XCB error: 10 (BadAccess), sequence: 5149, resource id: 495, major code: 142 (Composite), minor code: 2 (RedirectSubwindows)
Aug 06 23:47:11 ManjaroTower plasmashell[649]: qt.qpa.xcb: QXcbConnection: XCB error: 4 (BadPixmap), sequence: 2738, resource id: 41943121, major code: 54 (FreePixmap), minor code: 0
Aug 06 23:47:11 ManjaroTower plasmashell[649]: qt.qpa.xcb: QXcbConnection: XCB error: 13 (BadGC), sequence: 2739, resource id: 41943122, major code: 60 (FreeGC), minor code: 0
Aug 06 23:47:11 ManjaroTower plasmashell[649]: qt.qpa.xcb: QXcbConnection: XCB error: 4 (BadPixmap), sequence: 2740, resource id: 41943123, major code: 54 (FreePixmap), minor code: 0
Aug 06 23:47:11 ManjaroTower plasmashell[649]: qt.qpa.xcb: QXcbConnection: XCB error: 13 (BadGC), sequence: 2741, resource id: 41943124, major code: 60 (FreeGC), minor code: 0
Aug 06 23:47:11 ManjaroTower plasmashell[649]: qt.qpa.xcb: QXcbConnection: XCB error: 4 (BadPixmap), sequence: 2742, resource id: 41943125, major code: 54 (FreePixmap), minor code: 0
Aug 06 23:47:11 ManjaroTower plasmashell[649]: qt.qpa.xcb: QXcbConnection: XCB error: 13 (BadGC), sequence: 2743, resource id: 41943126, major code: 60 (FreeGC), minor code: 0
Aug 06 23:47:11 ManjaroTower plasmashell[649]: qt.qpa.xcb: QXcbConnection: XCB error: 4 (BadPixmap), sequence: 2744, resource id: 41943127, major code: 54 (FreePixmap), minor code: 0
Aug 06 23:47:11 ManjaroTower plasmashell[649]: qt.qpa.xcb: QXcbConnection: XCB error: 13 (BadGC), sequence: 2745, resource id: 41943128, major code: 60 (FreeGC), minor code: 0
Aug 06 23:47:11 ManjaroTower plasmashell[649]: qt.qpa.xcb: QXcbConnection: XCB error: 4 (BadPixmap), sequence: 2746, resource id: 41943129, major code: 54 (FreePixmap), minor code: 0
Aug 06 23:47:11 ManjaroTower plasmashell[649]: qt.qpa.xcb: QXcbConnection: XCB error: 13 (BadGC), sequence: 2747, resource id: 41943130, major code: 60 (FreeGC), minor code: 0
Aug 06 23:47:11 ManjaroTower plasmashell[649]: qt.qpa.xcb: QXcbConnection: XCB error: 4 (BadPixmap), sequence: 2748, resource id: 41943131, major code: 54 (FreePixmap), minor code: 0
Aug 06 23:47:11 ManjaroTower plasmashell[649]: qt.qpa.xcb: QXcbConnection: XCB error: 13 (BadGC), sequence: 2749, resource id: 41943132, major code: 60 (FreeGC), minor code: 0
Aug 06 23:47:11 ManjaroTower plasmashell[649]: qt.qpa.xcb: QXcbConnection: XCB error: 4 (BadPixmap), sequence: 2750, resource id: 41943117, major code: 54 (FreePixmap), minor code: 0
Aug 06 23:47:11 ManjaroTower plasmashell[649]: qt.qpa.xcb: QXcbConnection: XCB error: 13 (BadGC), sequence: 2751, resource id: 41943118, major code: 60 (FreeGC), minor code: 0
Aug 06 23:47:11 ManjaroTower plasmashell[649]: qt.qpa.xcb: QXcbConnection: XCB error: 4 (BadPixmap), sequence: 2752, resource id: 41943119, major code: 54 (FreePixmap), minor code: 0
Aug 06 23:47:11 ManjaroTower plasmashell[649]: qt.qpa.xcb: QXcbConnection: XCB error: 13 (BadGC), sequence: 2753, resource id: 41943120, major code: 60 (FreeGC), minor code: 0
Aug 06 23:47:13 ManjaroTower kernel: usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
Aug 06 23:47:18 ManjaroTower kernel: usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
Aug 06 23:47:22 ManjaroTower kernel: usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
Aug 06 23:47:26 ManjaroTower kernel: usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
Aug 06 23:47:32 ManjaroTower kernel: usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
Aug 06 23:47:37 ManjaroTower kernel: usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
Aug 06 23:47:41 ManjaroTower kernel: usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
Aug 06 23:47:47 ManjaroTower plasmashell[649]: QQmlEngine::setContextForObject(): Object already has a QQmlContext
Aug 06 23:47:47 ManjaroTower plasmashell[649]: kf.coreaddons: "Could not find plugin org.kde.plasma.folder"
Aug 06 23:47:47 ManjaroTower plasmashell[649]: Error loading KCM: "Could not find plugin org.kde.plasma.folder"
Aug 06 23:47:47 ManjaroTower plasmashell[649]: kf.coreaddons: "Could not find plugin org.kde.color"
Aug 06 23:47:47 ManjaroTower plasmashell[649]: Error loading KCM: "Could not find plugin org.kde.color"
Aug 06 23:47:47 ManjaroTower plasmashell[649]: kf.coreaddons: "Could not find plugin org.kde.haenau"
Aug 06 23:47:47 ManjaroTower plasmashell[649]: Error loading KCM: "Could not find plugin org.kde.haenau"
Aug 06 23:47:47 ManjaroTower plasmashell[649]: kf.coreaddons: "Could not find plugin org.kde.image"
Aug 06 23:47:47 ManjaroTower plasmashell[649]: Error loading KCM: "Could not find plugin org.kde.image"
Aug 06 23:47:47 ManjaroTower plasmashell[649]: file:///usr/lib/qt/qml/org/kde/kirigami.2/PlaceholderMessage.qml:235:5: QML Heading: Binding loop detected for property "verticalAlignment"
Aug 06 23:47:47 ManjaroTower plasmashell[649]: Qt Quick Layouts: Detected recursive rearrange. Aborting after two iterations.
Aug 06 23:47:47 ManjaroTower plasmashell[649]: file:///usr/lib/qt/qml/org/kde/kcm/SettingHighlighter.qml:0: ReferenceError: kcm is not defined
Aug 06 23:47:47 ManjaroTower plasmashell[649]: file:///usr/lib/qt/qml/org/kde/kcm/SettingHighlighter.qml:37: ReferenceError: kcm is not defined
Aug 06 23:47:47 ManjaroTower plasmashell[649]: file:///home/fabio/.local/share/plasma/plasmoids/com.github.rliwoch.plasmoid-wunderground-extended/contents/ui/HorizontalCompactLayout.qml:107:9: Unable to assign [undefined] to QString
Aug 06 23:47:47 ManjaroTower plasmashell[649]: qml: PlasmaExtras.ScrollArea is deprecated. Use PlasmaComponents3.ScrollView instead.
Aug 06 23:47:47 ManjaroTower plasmashell[649]: Both point size and pixel size set. Using pixel size.
Aug 06 23:47:47 ManjaroTower plasmashell[649]: Error: cannot change the containment to AppletsLayout
Aug 06 23:47:48 ManjaroTower plasmashell[649]: file:///usr/lib/qt/qml/org/kde/kcm/SettingHighlighter.qml:0: ReferenceError: kcm is not defined
Aug 06 23:47:50 ManjaroTower kernel: usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
Aug 06 23:47:55 ManjaroTower plasmashell[649]: file:///usr/share/plasma/wallpapers/org.kde.image/contents/ui/main.qml:16:1: QML StackView: Binding loop detected for property "configuredImage"
Aug 06 23:47:58 ManjaroTower kernel: usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
Aug 06 23:48:03 ManjaroTower kernel: usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
Aug 06 23:48:07 ManjaroTower kernel: usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
Aug 06 23:48:13 ManjaroTower kernel: usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
Aug 06 23:48:17 ManjaroTower kernel: usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
Aug 06 23:48:25 ManjaroTower kernel: usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
Aug 06 23:48:29 ManjaroTower kernel: usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
Aug 06 23:48:31 ManjaroTower plasmashell[649]: qml: PlasmaExtras.ScrollArea is deprecated. Use PlasmaComponents3.ScrollView instead.
Aug 06 23:48:31 ManjaroTower plasmashell[649]: libpng warning: iCCP: known incorrect sRGB profile
Aug 06 23:48:31 ManjaroTower plasmashell[649]: libpng warning: known incorrect sRGB profile
Aug 06 23:48:31 ManjaroTower plasmashell[649]: libpng warning: profile matches sRGB but writing iCCP instead
Aug 06 23:48:32 ManjaroTower kwin_x11[604]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 18921, resource id: 41943192, major code: 18 (ChangeProperty), minor code: 0
Aug 06 23:48:32 ManjaroTower systemsettings[1370]: QCommandLineParser: argument list cannot be empty, it should contain at least the executable name
Aug 06 23:48:32 ManjaroTower kwin_x11[604]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 19127, resource id: 41943193, major code: 18 (ChangeProperty), minor code: 0
Aug 06 23:48:36 ManjaroTower kernel: usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
Aug 06 23:48:41 ManjaroTower kernel: usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
Aug 06 23:48:48 ManjaroTower kernel: usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
Aug 06 23:48:52 ManjaroTower kernel: usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
Aug 06 23:48:57 ManjaroTower kwin_x11[604]: kwin_core: XCB error: 152 (BadDamage), sequence: 22027, resource id: 14681653, major code: 143 (DAMAGE), minor code: 2 (Destroy)
Aug 06 23:48:57 ManjaroTower kwin_x11[604]: kwin_core: XCB error: 3 (BadWindow), sequence: 22028, resource id: 14681631, major code: 129 (SHAPE), minor code: 6 (Input)
Aug 06 23:48:57 ManjaroTower kwin_x11[604]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 22029, resource id: 14681631, major code: 2 (ChangeWindowAttributes), minor code: 0
Aug 06 23:48:59 ManjaroTower kernel: usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
Aug 06 23:48:59 ManjaroTower kwin_x11[604]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 23017, resource id: 41943195, major code: 18 (ChangeProperty), minor code: 0
Aug 06 23:48:59 ManjaroTower plasmashell[649]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:370: Unable to assign [undefined] to QString
Aug 06 23:49:04 ManjaroTower kernel: usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
Aug 06 23:49:08 ManjaroTower kernel: usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
Aug 06 23:49:12 ManjaroTower kernel: usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
Aug 06 23:49:13 ManjaroTower kwin_x11[604]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 28426, resource id: 77594828, major code: 15 (QueryTree), minor code: 0
Aug 06 23:49:16 ManjaroTower kernel: usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
Aug 06 23:49:19 ManjaroTower kwin_x11[604]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 31924, resource id: 77594847, major code: 15 (QueryTree), minor code: 0
Aug 06 23:49:23 ManjaroTower kernel: usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
Aug 06 23:49:26 ManjaroTower kwin_x11[604]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 36310, resource id: 77594863, major code: 15 (QueryTree), minor code: 0
Aug 06 23:49:27 ManjaroTower kernel: usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
Aug 06 23:49:33 ManjaroTower kernel: usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
Aug 06 23:49:40 ManjaroTower kernel: usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
Aug 06 23:49:44 ManjaroTower kernel: usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
Aug 06 23:49:48 ManjaroTower plasmashell[649]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:370: Unable to assign [undefined] to QString
Aug 06 23:49:49 ManjaroTower xdg-desktop-portal-kde[790]: xdp-kde-settings: Namespace "org.gnome.desktop.wm.preferences" is not supported
Aug 06 23:49:55 ManjaroTower kernel: usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
Aug 06 23:52:43 ManjaroTower plasmashell[649]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x55be89e2f790) QQmlContext(0x55be8783edf0) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Aug 06 23:52:43 ManjaroTower plasmashell[649]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:219:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
Aug 06 23:52:43 ManjaroTower plasmashell[649]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:219:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
Aug 06 23:52:43 ManjaroTower plasmashell[649]: file:///usr/lib/qt/qml/org/kde/plasma/components.3/ScrollView.qml:45:27: QML ScrollBar: Binding loop detected for property "visible"
Aug 06 23:52:43 ManjaroTower plasmashell[649]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/SelectableLabel.qml:38:5: QML TextArea: Binding loop detected for property "implicitHeight"
Aug 06 23:52:43 ManjaroTower plasmashell[649]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x55be8b8911e0) QQmlContext(0x55be8783edf0) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Aug 06 23:52:43 ManjaroTower kwin_x11[604]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 41091, resource id: 41943203, major code: 15 (QueryTree), minor code: 0
Aug 06 23:52:46 ManjaroTower kernel: usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
Aug 06 23:52:50 ManjaroTower kernel: usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
Aug 06 23:52:51 ManjaroTower kwin_x11[604]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 45999, resource id: 41943205, major code: 15 (QueryTree), minor code: 0
Aug 06 23:52:58 ManjaroTower kernel: usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
Aug 06 23:53:02 ManjaroTower kernel: usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
Aug 06 23:53:08 ManjaroTower kernel: usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
Aug 06 23:53:15 ManjaroTower kernel: usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
Aug 06 23:53:19 ManjaroTower kernel: usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
Aug 06 23:53:23 ManjaroTower kwin_x11[604]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 52614, resource id: 41943216, major code: 18 (ChangeProperty), minor code: 0
Aug 06 23:53:23 ManjaroTower plasmashell[649]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:370: Unable to assign [undefined] to QString
Aug 06 23:53:27 ManjaroTower kernel: usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
