It’s a bit like switching from Winbose to Linux: one knows the second is superior and better, but at the beginning it feels overwhelmingly complicated. One needs a bit of time and learning, and at some point after getting sufficient knowledge about it, it does not look so scary anymore.
That is a really good conclusion. For the meantime, I’m staying with btrfs, the raid options, recovery, modularity … are really impressive.
I’ve done the scrub today, once from live media, once from booted system on it’s own boot partition, didn’t accomplish much, but at least there wont be bitrot. I’ll see if manual checking is viable, if not, I’ll give btrfsmaintenance a try.. One warning, btrfs filesystem usage without elevation doesn’t show the Unallocated Volume, the possibly most important one.
I’ll try the long re-balancing tomorrow. Here are today’s numbers:
sudo btrfs filesystem usage /media/mint/9fa777d4-6ca8-4457-a1eb-eba91ac8eccd
Overall:
Device size: 944.77GiB
Device allocated: 837.07GiB
Device unallocated: 107.70GiB
Device missing: 0.00B
Used: 782.24GiB
Free (estimated): 158.71GiB (min: 104.86GiB)
Data ratio: 1.00
Metadata ratio: 2.00
Global reserve: 512.00MiB (used: 0.00B)
Data,single: Size:827.01GiB, Used:776.00GiB (93.83%)
/dev/mapper/luks-fcd41acc-db81-4f2d-9e84-159b7c178fdf 827.01GiB
Metadata,DUP: Size:5.00GiB, Used:3.12GiB (62.43%)
/dev/mapper/luks-fcd41acc-db81-4f2d-9e84-159b7c178fdf 10.00GiB
System,DUP: Size:32.00MiB, Used:128.00KiB (0.39%)
/dev/mapper/luks-fcd41acc-db81-4f2d-9e84-159b7c178fdf 64.00MiB
Unallocated:
/dev/mapper/luks-fcd41acc-db81-4f2d-9e84-159b7c178fdf 107.70GiB
$ sudo btrfs scrub start -Bd /media/mint/9fa777d4-6ca8-4457-a1eb-eba91ac8eccd
scrub device /dev/mapper/luks-fcd41acc-db81-4f2d-9e84-159b7c178fdf (id 1) done
Scrub started: Tue May 5 12:22:58 2026
Status: finished
Duration: 0:10:34
Total to scrub: 837.07GiB
Rate: 1.23GiB/s
Error summary: no errors found
$ sudo btrfs filesystem usage /media/mint/9fa777d4-6ca8-4457-a1eb-eba91ac8eccd
Overall:
Used: 782.24GiB
Data ratio: 1.00
Unallocated:
Overall:
Device slack: 0.00B
Used: 782.26GiB
Free (estimated): 158.69GiB (min: 104.84GiB)
Free (statfs, df): 158.69GiB
Data ratio: 1.00
Global reserve: 512.00MiB (used: 112.00KiB)
Multiple profiles: no
Data,single: Size:827.01GiB, Used:776.01GiB (93.83%)
Metadata,DUP: Size:5.00GiB, Used:3.12GiB (62.45%)
Unallocated:
Starting scrub on devid 1
Scrub device /dev/mapper/luks-fcd41acc-db81-4f2d-9e84-159b7c178fdf (id 1) done
Scrub started: Tue May 5 15:00:47 2026
Status: finished
Duration: 0:11:03
Total to scrub: 781.64GiB
Rate: 1.18GiB/s
Please enter the PIN:
Please touch the FIDO authenticator.
Overall:
Device allocated: 837.13GiB
Device unallocated: 107.63GiB
Device slack: 0.00B
Used: 781.59GiB
Free (estimated): 159.27GiB (min: 105.46GiB)
Free (statfs, df): 159.27GiB
Data ratio: 1.00
Data,single: Size:827.01GiB, Used:775.37GiB (93.76%)
Metadata,DUP: Size:5.00GiB, Used:3.11GiB (62.24%)
System,DUP: Size:64.00MiB, Used:128.00KiB (0.20%)
/dev/mapper/luks-fcd41acc-db81-4f2d-9e84-159b7c178fdf 128.00MiB
Unallocated:
/dev/mapper/luks-fcd41acc-db81-4f2d-9e84-159b7c178fdf 107.63GiB
So I’ve run the aggressive balance as well, suprisingly, it only took 12 minutes and got me 20 extra gigs of unallocated.
Overall:
Device allocated: 840.07GiB
Device unallocated: 104.70GiB
Device slack: 0.00B
Used: 789.22GiB
Free (estimated): 151.75GiB (min: 99.40GiB)
Free (statfs, df): 151.75GiB
Data ratio: 1.00
Data,single: Size:830.01GiB, Used:782.95GiB (94.33%)
/dev/mapper/luks-fcd41acc-db81-4f2d-9e84-159b7c178fdf 830.01GiB
Metadata,DUP: Size:5.00GiB, Used:3.14GiB (62.72%)
Unallocated:
/dev/mapper/luks-fcd41acc-db81-4f2d-9e84-159b7c178fdf 104.70GiB
sudo btrfs balance start -dusage=75 -musage=75 /
Done, had to relocate 32 out of 837 chunks
Overall:
Device allocated: 820.07GiB
Device unallocated: 124.70GiB
Device slack: 0.00B
Used: 789.37GiB
Free (estimated): 153.61GiB (min: 91.26GiB)
Free (statfs, df): 153.61GiB
Data ratio: 1.00
Data,single: Size:812.01GiB, Used:783.09GiB (96.44%)
/dev/mapper/luks-fcd41acc-db81-4f2d-9e84-159b7c178fdf 812.01GiB
Metadata,DUP: Size:4.00GiB, Used:3.14GiB (78.43%)
/dev/mapper/luks-fcd41acc-db81-4f2d-9e84-159b7c178fdf 8.00GiB
Unallocated:
/dev/mapper/luks-fcd41acc-db81-4f2d-9e84-159b7c178fdf 124.70GiB
I think that my balance with the filesystem stretched over the USB drive probably did most of the balancing, so that’s why this task was possibly lighter.
I’ll definitely be doing the scrubs monthly and probably weekly balances, just much less aggressive, I’m thinking having 25 or 50% empty chunks moved.
What I’ve realized, had the error happened during the system update, I’ll be in much worse state, ofc, I’d still be able to eventually use a snapshot, but it would have been much harder. I’ll definitely be checking the unallocated size and fragmentation before each larger update now
Once again, thank you for all the advice
Glad it all worked out. Even though you were literally converting raid types, and adding unreliable flash sticks into the mix! Btrfs just kept everything in chunks, and you just moved them around. Nothing damaged whatsoever.
This is one of the great things about btrfs. Add or remove devices, convert raid profiles, rebalance data, all on your live root filesystem. And you even went the “wrong” direction for a while, and all was still fine in the end.
Just wait until you find out all the things you can do with these snapshots. ![]()
Doing these device add/removes and balances most likely cleaned part of that up for us. Giving you some free space.
Yes. ![]()
Weekly sounds like a bit much, and aggressive balances are rarely needed. There’s a point where all you are doing is extra SSD wear and IO. Especially with high snapshot retention and turn over. Certain workloads can accelerate allocator fragmentation and metadata pressure.
You generally do not want heavily-used databases, VM images, containers, or virtual disks living on heavily snapshotted CoW storage.
This is where I put certain things on xfs (or ext4 is fine too). But I default to everything on btrfs.
Snapshot cleanup/deletion is usually what fragments chunk allocation the most. So that is a good time to check it.
Data,single: Size:827.01GiB, Used:776.00GiB (93.83%) /dev/mapper/luks-fcd41acc-db81-4f2d-9e84-159b7c178fdf 827.01G…
Data,single: Size:812.01GiB, Used:783.09GiB (96.44%) /dev/mapper/luks-fcd41acc-db81-4f2d-9e84-159b7c178fdf 812.01GiB
You can see that the balance reclaimed about 15 GiB of chunk allocation back into unallocated space, but overall the filesystem was already in fairly decent shape after the earlier recovery work.
Normally it is not worth running balances this aggressively unless there is a specific reason.
But now you know what to watch for, and honestly that is the important part.
And yes, 70-80% allocation/utilization is completely fine for Btrfs.
Still, it’s always good to experiment and learn. ![]()
