If you aren’t getting error messages it’s unlikely you’re affected. Check here:
http://linrunner.de/en/tlp/docs/tlp-faq.html#warnings :
Which kind of warnings does “tlp-stat -w” check for?
Currently the command checks the kernel log for errors possibly caused by the settings for SATA ALPM.
What should I do if warnings are shown?
TLP’s default setting on battery
SATA_LINKPWR_ON_BAT=min_power
is optimimized for maximum power saving. Try to use less aggressive values:
SATA_LINKPWR_ON_BAT=medium_power
or
SATA_LINKPWR_ON_BAT=max_performance
or disable the setting completely – see SATA ALPM.
Don’t forget to reboot before checking again.
The same applies to SATA_LINKPWR_ON_AC if you changed the default setting.
