When I start btop
from Konsole in zsh or bash I get the error:
ERROR: Exception in runner thread -> Cpu:: -> graphs, clock, meter : unordered_map::at
bpytop runs fine.
When I start btop
bpytop runs fine.
Anything more in the log1?
Either way, try removing your config file2.
1 ~/.config/btop/btop.log
2 ~/.config/btop/btop.conf
2024/05/30 (15:45:07) | ===> btop++ v.1.3.2
2024/05/30 (15:45:07) | WARNING: NVML: Failed to get maximum GPU power draw, defaulting to 225W: Not Supported
2024/05/30 (15:45:07) | WARNING: NVML: Failed to get maximum GPU temperature, defaulting to 110°C: Not Supported
2024/05/30 (15:45:07) | WARNING: NVML: Failed to get GPU utilization: Not Supported
2024/05/30 (15:45:07) | WARNING: NVML: Failed to get PCIe TX throughput: Not Supported
2024/05/30 (15:45:07) | WARNING: NVML: Failed to get GPU clock speed: Not Supported
2024/05/30 (15:45:07) | WARNING: NVML: Failed to get PCIe RX throughput: Not Supported
2024/05/30 (15:45:07) | WARNING: NVML: Failed to get VRAM clock speed: Not Supported
2024/05/30 (15:45:07) | WARNING: NVML: Failed to get GPU power usage: Not Supported
2024/05/30 (15:45:09) | ERROR: Exception in runner thread -> Cpu:: -> graphs, clock, meter : unordered_map::at
(Also widget thot RAM shows no RAM )
Did not help me.
Try downgrading to 1.2.13-1, the GPU support doesn’t work very well:
sudo pacman -Syu --needed manjaro-downgrade
sudo manjaro-downgrade btop
Thank you. That version is running after removing the config file.²
You’re welcome. If you want GPU stats, I suggest installing nvtop
Thank you I forgot to reinstall that 1.
