Can't see hdd disk which is connected via optibay
manjaro doesn’t see hdd disk at all (which is connected to dvd port via optibay)
CPU: dual core Intel Core i3-4005U (-MT MCP-) speed/min/max: 1398/800/1600 MHz
Kernel: 6.1.31-2-MANJARO x86_64 Up: 4m Mem: 1957.3/7866.3 MiB (24.9%)
Storage: 119.24 GiB (8.0% used) Procs: 183 Shell: Zsh inxi: 3.3.27
Welcome to Manjaro! :smiling_face_with_three_hearts:
  1. Please read the information behind this link. It will help you to post necessary information.
  1. Please press the three dots below your post and then press the :pencil2:
  • If you give us information about your system, we can see what we’re talking about and make better suggestions.
  • You can do this by using inxi in a terminal or in console.
  • Personally identifiable information such as serial numbers and MAC addresses are filtered out by this command
  • Presenting the information in this way allows everyone to be familiar with the format and quickly find the items they need without missing anything.
  1. Copy the output from inxi (including the command) and paste it into your post.
  • To make it more readable, add 3 backticks ``` on an extra line before and after the pasted text.
Have you already :mag: for your problem in the forum ? (Wisdom lies in reading :wink: )
If your computer system cannot see the disk in the bay - it is likely caused by insufficient connection - the optibay’s sata connector may not be seated completely.
As for Manjaro - it will see what the system provides - after all it is just a sata connection point.
